Q7 suspension adaptation failing
e11is
C?ID=406785
hi I am wondering if anyone could offer me some advice, pretty much a new user when it comes using VCDS!
I'm trying to carry a new air suspension adaptation in module (34) 2008 Q7 4.2tdi after noticing the front was far to high after getting new tyres fitted! when entering new values for the front it keeps saying invalid, as suggested in the guide I've tried jacking/rocking the vehicle which works on the front nearside value but when it comes to the offside it wont accept the value or anything a few millimetres either side I believe the max is 535 i am currently measuring 525.
now I've tried and it wont accept the values the system is now logging code 01437 - control position not learned! (orange suspension light now stays on didn't before I tried)
what I've tried so far
followed the guide correctly, level ground correct access code (31564), doors shut in park etc
checked the sensors and linkages which appear to be working and recording live data (as you can see from the pictures i am not sure if the deviation on the front right is causing me further problems or failure.
inspected the pivot links on the front level sensors which were very stiff and corroded so replaced them which has made no difference, with the arms off I swept the sensor while referencing live data which recorded the movement so assume the senor is good!
compressor fuse good
compressor relay good
no leaks
any advice would be appreciated, pulling my hair out with this one:banghead:!!!
unsure on how to add pictures, ill also add the autoscan if that helps!
South Molton, UK
Please post a full unedited VCDS Auto-Scan which will show not only the fault codes but also how your Q7 is equipped.
e11is
C?ID=406785
Monday,13,July,2020,15:56:03:05482
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WAUZZZ4L58D058502   License Plate: BRI Q7
Mileage: 102500km-63690mi   Repair Order:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 11 31 15 16 17 18 19 1E 28 34 37 3C
          42 46 47 4F 52 55 56 61 62 67 6C 6D 6F 72 76 77
VIN: WAUZZZ4L58D058502   Mileage: 102500km-63690miles
   Part No SW: 4L0 910 409 D    HW: 4E1 907 409 B
   Component: 4.2L V8TDI  G000AGMª0010
   Revision: --H05---    Serial number:
   Coding: 0011779
   Shop #: WSC 31414 790 00001
   VCID: 2B02FE5F7F0466F3D69-807E
Address 02: Auto Trans        Labels: 09D-927-750.clb
   Part No SW: 09D 927 750 JJ    HW: 09D 927 750 JJ
   Component: AL 750 6A           1167
   Revision: 00H78000    Serial number:
   Coding: 0000504
   VCID: 7F5AFA0FDBFC2A532A1-802A
   Part No SW: 4L0 910 517 B    HW: 4L0 614 517 D
   Component: ESP ALLRAD MK25E1   0010
   Revision: 00H30001
   Coding: 0103601
   VCID: 290E045775F874E3245-807C
                    Fault Frequency: 70
                    Reset counter: 188
                    Mileage: 90880 km
                    Date: 2019.06.25
                    Time: 12:29:35
                    Count: 8261
                    Count: 128
                    Count: 41472
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0230
   Revision: 09010701    Serial number: 10601501014920
   Coding: 0000147
   Shop #: WSC 00759 210 86480
   VCID: 6392567F5754EEB32E9-8036
   Subsystem 1 - Part No: 4F0 910 131 E
   Component: FBSAUDIC6 EZS   H46 0080
   Subsystem 2 - Part No: 4F0 910 220 D
   Component: FBSAUDIC6 IDG   H01 0040
                    Reset counter: 167
                    Mileage: 101441 km
                    Date: 2020.06.19
                    Time: 07:44:50
Address 07: Control Head        Labels: 4L0-910-7xx-07-H.clb
   Part No SW: 4L0 910 732 G    HW: 4E0 035 729 A
   Component: Interfacebox    H43 5140
   Revision: 00000000    Serial number: 387CU087570244
   Coding: 0002002
   VCID: 2D06F047411068C3C8D-8078
   Subsystem 1 - Part No: 4L0 910 609
   Component: E0380 BedienteilH01 0060
   Subsystem 2 - Serial number: 00000001018404
   Subsystem 3 - Serial number: 0106.03.080000000100011472ÿ
   Subsystem 4 - Serial number: 011472ÿ
   Part No SW: 4L0 910 043 B    HW: 4L0 820 043 L
   Component: KLIMABETAETIGUNGH07 0030
   Revision: 00---013    Serial number: 00000000159705
   Coding: 0132120
   VCID: 2312167F17D4AEB36E9-8076
                    Fault Frequency: 95
                    Reset counter: 186
                    Mileage: 92859 km
                    Date: 2019.08.10
                    Time: 13:17:13
                    Temperature: 62.0°C
                    Temperature: 23.0°C
                    Temperature: -55.0°C
                    RPM: 680 /min
                    Absolute Pres.: 1.0 bar
                    Current: 0.000 A
                    Temperature: 26.0°C
00003 - Control Module
                    Fault Status: 00100011
                    Mileage: 100259 km
                    Date: 2020.05.13
                    Time: 16:55:58
                    Temperature: 23.0°C
   Part No SW: 4F0 910 279 K    HW: 4F0 907 279
   Component: ILM Fahrer      H18 0250
   Coding: 0013121
   VCID: 313EEC375D280C23EC5-8064
   Subsystem 1 - Part No: 4L2 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H11 0100
   Coding: 00064792
   Shop #: WSC 31414
   Subsystem 2 - Part No: 4E0 910 557 B  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0100
   Coding: 00150059
   Shop #: WSC 31414
   Part No SW: 4L0 910 110 B    HW: 4L0 035 110
   Component: MP3-Changer     H45 0390
   Revision: 00045002    Serial number: AUZ5ZBH8341582
   VCID: 1E64278B3CB6835B417-804A
Address 11: Engine II        Labels: Redir Fail!
   Component: 4.2L V8TDI  G000AGSª0010
   Coding: 0011779
   Shop #: WSC 00046 000 00000
   Part No SW: 4L0 910 655 D    HW: 4L0 959 655 C
   Component: 71 AIRBAG AUDI8RH42 0230
   Revision: 03H42000    Serial number: 00399D04937E
   Coding: 0014129
   VCID: 2E04F74B4C1613DBF17-807A
   Subsystem 1 - Serial number: 6332QSME580434177
   Subsystem 2 - Serial number: 6342QSME59667A4BY
   Subsystem 3 - Serial number: 6352QSME5A09364DR
   Subsystem 4 - Serial number: 6362QSME4F4E3B03W
   Subsystem 5 - Serial number: 63734SME526E572FE
   Subsystem 6 - Serial number: 63834SME526E1603$
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
   Component: J0527               0410
   Revision: 00H03000    Serial number: 90026080640174
   Coding: 0102142
   VCID: 270A026F63EC4293321-8072
   Component: E0221           H02 0030
Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 C    HW: 4L0 920 981 B
   Component: KOMBIINSTR. M73 H23 0240
   Revision: 00000000    Serial number: 74132GJ38
   Coding: 3681458
   Shop #: WSC 80093 222 69422
Address 18: Aux. Heat        Labels: 4L0-910-105.lbl
   Part No SW: 4L0 910 105     HW: 4L0 815 071 E
   Component: Heizgeraet      H08 0090
   Revision: 0000000D    Serial number: 00000009014264
   Coding: 0000001
   VCID: 609859734642F5AB33B-8034
Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
   Part No SW: 4L0 910 468 A    HW: 4L0 907 468 C
   Component: J533__Gateway   H06 0060
   Revision: 00H06000    Serial number: 1000D07A138075
   Coding: F57BFEFF74720200
Address 1E: Media Player 2 (R199)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785 D    HW: 4E0 035 785
   Component: SG ext.Player H15 0830
   Revision: 00000000
   VCID: 290E045779F874E3245-807C
   Part No SW: 4L0 910 158     HW: 4L0 919 158 C
   Component: KLIMABETAETIGUNGH05 0060
   Revision: 00---009    Serial number: 00000000157841
   Coding: 0000006
   VCID: 68884153AE728DEBFBB-803C
                    Mileage: 87316 km
                    Date: 2019.03.07
                    Time: 19:08:47
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 23
                    Mileage: 90518 km
                    Date: 2019.06.13
                    Time: 12:04:48
Address 34: Level Control        Labels: 4L0-910-553.lbl
   Part No SW: 4L0 910 553 C    HW: 4L0 907 553
   Component: LUFTFDR.-CDC    H03 7660
   Revision: --H03001    Serial number: 15.1528-0096.2
   Coding: 0015510
   VCID: 2A0CFB5B70FE7FFB2DF-807E
01577 - Turn-Off due to Over-Temp
                    Fault Status: 00100001
                    Fault Frequency: 111
                    Reset counter: 193
                    Mileage: 89552 km
                    Date: 2019.05.17
                    Time: 10:35:58
                    Error Code: 68
01583 - Leak in System Detected
                    Fault Frequency: 79
                    Reset counter: 194
                    Mileage: 98068 km
                    Date: 2020.01.17
                    Time: 12:13:56
                    Error Code: 70
   Part No SW: 4E0 910 888 E    HW: 4E0 919 887 M
   Component: MNS ECE         H51 1050
   Revision: 00000000    Serial number: 399CV087604163
   Shop #: WSC 00185 210 88124
   VCID: 3038E9335622052BE3B-8064
   Part No SW: 4L0 910 566 B    HW: 4L0 907 566 A
   Component: J0769_SWA_MasterH10 0130
   Revision: 00H10000    Serial number: 6PZ 009 014-00
   Coding: 0001101
   Subsystem 1 - Part No: 4L0 910 568 B
   Component: J0770_SWA_Slave_H08 0130
   Subsystem 2 - Serial number: 6PZ 009 014-20
   Subsystem 3 - Serial number: 3F13.02.0800H0800000010084ÿ
   Subsystem 4 - Serial number: 010084ÿ
Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
   Component: TSG FA          H12 0150
   Revision: 00000000    Serial number: @†T
   Coding: 0002651
   VCID: 2F3AEA4F4B1C1AD3FA1-807A
   Part No SW: 4L0 910 289 F    HW: 4L0 907 289 C
   Component: Komfortgeraet   H08 0060
   Revision: 0060 ---    Serial number: 01102302440000
   Coding: 7348475
   VCID: 3332E63FA7343E339E9-8066
   Subsystem 2 - Part No: 4F0 910 177
   Component: Innenraumueberw.H01 0020
Address 47: Sound System        Labels: 4L0-910-223-BO.lbl
   Part No SW: 4L0 910 223 G    HW: 4L0 035 223 D
   Component: DSP-High AU716  H03 0150
   Revision: PROD_01     Serial number: 00000000059340
   Coding: 0000023
   VCID: 280801536EF24DEB3BB-807C
   Part No SW: 4F0 910 280     HW: 4F0 907 280 E
   Component: ILM Beifahrer   H12 0100
   Revision:             Serial number: 00000000079229
   Coding: 0011101
   VCID: 5EE4678B7C36C35B017-800A
Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
   Component: TSG BF          H12 0150
   Revision: 00000000    Serial number: XU
   Coding: 0002651
   Part No SW: 4L0 910 357     HW: 4L0 907 357
   Component: AFS 1           H01 0040
   Coding: 0000022
   VCID: 698E4457B578B4E3E45-803C
   Part No SW: 4E0 910 541 Q    HW: 4E0 035 541 S
   Component: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Serial number: 388C4087678449
   Coding: 0000001
00856 - Radio Antenna
                    Fault Status: 00100111
                    Reset counter: 160
                    Mileage: 101108 km
                    Date: 2020.06.07
                    Time: 16:57:22
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4L0 910 181 A    HW: 4L0 915 181
   Component: J0644 BEM       H12 0690
   Revision: --------    Serial number: 00000000011610
   VCID: 2516086719E0508300D-8070
   Subsystem 1 - Part No: 4F0 915 105 D
   Component: von VA0  2803120276
   Coding: 344630393135313035442056413032383033313230323736
                    Fault Frequency: 25
                    Mileage: 85963 km
                    Date: 2018.12.24
                    Time: 15:23:58
Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
   Component: TSG HL          H21 0150
   Coding: 0002058
   Part No SW: 4E0 910 754 S    HW: 4E0 035 753 A
   Component: SDS 3502 UK     H46 0630
   Revision: 00000000    Serial number: 00000803040012
   Shop #: WSC 12336 024 394758
   VCID: 3634DF2BB4462B1BB97-8062
   Part No SW: 4L0 910 441 A    HW: 4L0 907 441 A
   Component: J772__Rearview      0050
   Revision: --H12---    Serial number: 525PA8-J82420Q
   Coding: 1021001
   VCID: 2410156312DAA98B173-8070
Address 6D: Trunk Elect.        Labels: None
   Part No SW: 4L0 910 945     HW: 4L0 827 851 C
   Component: ValeoHeckdeckel H25 0290
   Revision: --H25001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6C803D43BA8AA1CB9F3-8038
   Subsystem 3 - Serial number: RD11.03.08--H25001001A0179ÿ
   Subsystem 4 - Serial number: 1A0179ÿ
   Part No SW: 4L0 910 290     HW: 4L0 907 290
   Component: ILM HINTEN 2    H05 0060
   Revision: AAH05061    Serial number: 003527651-----
   Coding: 0000001
   VCID: 6596486759609083C0D-8030
Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
   Component: TSG HR          H21 0150
   Coding: 0002058
   Part No SW: 4F0 910 283 K    HW: 4F0 919 283 K
   Component: Parkhilfe 8-Kan H12 0100
   Revision: 00H12000    Serial number: 69840806601310
   Coding: 0221146
   VCID: 2C00FD437A0A61CBDF3-8078
   Part No SW: 4E0 910 336 K    HW: 4E0 862 335
   Component: Handyvorb2      H18 0950
   Revision: 00000000    Serial number: 00000005115740
   Coding: 0010900
End----(Elapsed Time: 02:24, VBatt start/end: 11.2V/11.7V. VIgn 11.6V)-----
Address 03: DTCs cleared
Address 05: DTCs cleared
e11is
C?ID=406785
the above is the most recent full scan i have, apologies its old but it details equipment, the current saved log is the latest from the module only, i believe the sensor issue is from when it was disconnected
Monday,05,October,2020,18:41:24:05482
VIN:    License Plate: AIR 3
Control Module Part Number: 4L0 910 553 C    HW: 4L0 907 553
  Component and/or Version: LUFTFDR.-CDC    H03 7660
           Software Coding: 0015510
            Work Shop Code: WSC 31414 790 00001
                      VCID: 2A0CFB5B70FE7FFB2C7-807E
01769 - Sensor for Vehicle Leveling; Front Right (G289)
                    Fault Status: 00101100
                    Reset counter: 38
                    Mileage: 105308 km
                    Date: 2020.10.05
                    Time: 18:31:47
                    Error Code: 26
01437 - Control Position not Learned
                    Fault Status: 11100101
                    Reset counter: 254
                    Mileage: 105308 km
                    Date: 2020.10.05
                    Time: 18:19:29
                    Error Code: 6
e11is
C?ID=406785
I have screen shots of the live data and current deviation but for some reason cant upload them I don't think I can because I don't have a URL link,
if it helps i could grab a current autoscan no problem!
e11is
C?ID=406785
todays autoscan
Saturday,17,October,2020,09:55:01:05482
VIN: WAUZZZ4L58D058502   License Plate: Q7
Mileage: 105310km-65436mi   Repair Order:
VIN: WAUZZZ4L58D058502   Mileage: 105310km-65436miles
   Coding: 0011779
   VCID: 2B02FE5F7F0466F3D71-807E
   Coding: 0000504
   VCID: 7F5AFA0FDBFC2A532B9-802A
   Revision: 00H30001
   Coding: 0103601
   VCID: 290E045775F874E325D-807C
                    Reset counter: 1
                    Mileage: 105315 km
                    Date: 2020.10.17
                    Time: 09:40:25
                    Count: 64
                    Count: 8385
                    Count: 128
                    Count: 44800
   Coding: 0000147
   VCID: 6392567F5754EEB32F1-8036
   Coding: 0002002
   VCID: 2D06F047411068C3C95-8078
   Coding: 0132120
   VCID: 2312167F17D4AEB36F1-8076
                    Reset counter: 41
                    Mileage: 105315 km
                    Date: 2020.10.15
                    Time: 18:06:41
                    Temperature: 88.0°C
                    Temperature: 21.0°C
                    RPM: 680 /min
                    Current: 0.000 A
                    Temperature: 16.0°C
   Coding: 0013121
   VCID: 313EEC375D280C23EDD-8064
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   VCID: 1E64278B3CB6835B40F-804A
   Coding: 0011779
   Coding: 0014129
   VCID: 2E04F74B4C1613DBF0F-807A
   Coding: 0102142
   VCID: 270A026F63EC4293339-8072
   Coding: 3681458
   Coding: 0000001
   VCID: 609859734642F5AB323-8034
   Revision: 00000000
   VCID: 290E045779F874E325D-807C
   Coding: 0000006
   VCID: 68884153AE728DEBFA3-803C
                    Reset counter: 1
                    Mileage: 105315 km
                    Date: 2020.10.15
                    Time: 18:06:46
02598 - Rear Right Upper Body Vent Motor (V316)
                    Fault Frequency: 12
                    Reset counter: 41
                    Mileage: 105315 km
                    Date: 2020.10.15
                    Time: 18:25:11
                    Voltage: 13.60 V
                    Temperature: -100.0°C
                    (no units): 115.0
                    (no units): 107.0
   Coding: 0015510
                    Reset counter: 1
                    Mileage: 105315 km
                    Date: 2020.10.15
                    Time: 19:56:11
                    Error Code: 6
   VCID: 3038E9335622052BE23-8064
   Coding: 0001101
   Coding: 0002651
   VCID: 2F3AEA4F4B1C1AD3FB9-807A
   Coding: 7348475
   VCID: 3332E63FA7343E339F1-8066
   Coding: 0000023
   VCID: 280801536EF24DEB3A3-807C
   Coding: 0011101
   VCID: 5EE4678B7C36C35B00F-800A
   Coding: 0002651
   Coding: 0000022
   VCID: 698E4457B578B4E3E5D-803C
   Coding: 0000001
   VCID: 2516086719E05083015-8070
   Coding: 0002058
   VCID: 3634DF2BB4462B1BB8F-8062
   Coding: 1021001
   VCID: 2410156312DAA98B16B-8070
   VCID: 6C803D43BA8AA1CB9EB-8038
   Coding: 0000001
   VCID: 6596486759609083C15-8030
   Coding: 0002058
   Coding: 0221146
   VCID: 2C00FD437A0A61CBDEB-8078
   Coding: 0010900
End----(Elapsed Time: 02:23, VBatt start/end: 11.0V/11.6V. VIgn 11.5V)-----
module info
Saturday,17,October,2020,09:55:39:05482
VIN: WAUZZZ4L58D058502   License Plate: Q71
                    Reset counter: 1
                    Mileage: 105315 km
                    Date: 2020.10.15
                    Time: 19:56:11
                    Error Code: 6
height and deviation PID's
Saturday,17,October,2020,09:56:41:05482
VIN: License Plate: Q7 PDIS
Address 34: Level Control (4L0 910 553 C)
09:56:25
Reg. Position deviation front left
not deviation front right
Learned deviation rear left
deviation rear right
130.0 vehicle height front left
99.0 vehicle height front right
102.0 vehicle height rear left
96.0 Vehicle height rear right
height and devaition PID's
FandaTDI
Czech Republic
C?ID=204559
I would check both front sensors/subframe/bushing/joints (biggest deviation and fault...) and also let it stay in highest position for let say one day (due to leak fault).
FandaTDI
Czech Republic
C?ID=204559
...and also prevent undervoltage like in the autoscans espec.while doing advanced functions!
e11is
C?ID=406785
thanks for the suggestion, I drove the car yesterday and tried to settle the suspension, i cant select any other setting then automatic currently because of the adaptation issue, everything so far is pointing towards a sensor issue at he minute I am going to test it today and go from there!
e11is
C?ID=406785
finally managed to get it to accept the four new values, only issues is now repeatedly ch5 shows error, but gives no information as to why!
i am going to slightly move the car and try again, i am getting closer....... i think, I've also managed to bring the deviation down.
