Hi
I have Golf MK7.5 R 2017. Retrofitted A5 - Frt Camera on windscreen. It is second hand camera which I calibrated to the car as well.
Traffic Sign Recognition works fine after calibration. Now I have one fault and LDW doesn't work.
Followed exactly the guide for retrofitting it on MK7, however Mk7 have coding on BCM, MK7.5 is all 000000 so cannot code in LDW on that.
I suspect something is coded to much in A5 or I have something missing on other modules but cannot figure out what is it.
Maybe someone have Golf MK7.5 R with A5 camera fitted so could share his coding and adaptations channels for 09 and A5 please?
Please see scan below (skip the part for TPMS)
Best Regards
Friday,16,October,2020,10:01:46:40917
VCDS Version: 20.4.2.0 HEX-NET CB: 0.4513.4
[URL="http://www.Ross-Tech.com"]www.Ross-Tech.com[/URL]
Dealer/Shop Name:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 22 29 39 42 44 4B 52 5F 65
A5 A9 D6 D7
Address 01: Engine (J623-DJHA) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 J HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0003
Revision: --H13---
Coding: 092500122466050B2004
ASAM Dataset: EV_ECM20TFS0208V0906259J 001005
ROD: EV_ECM20TFS0208V0906259J.rod
VCID: 47DEB902FE3221BE92-8012
Part No SW: 0GC 300 011 M HW: 0GC 927 711 G
Component: GSG DQ381 H06 0707
Revision: 00H06V07
ROD: EV_TCMDQ381061.rod
VCID: 2C14E6AE4794E2E69F-8078
Part No SW: 5Q0 614 517 CF HW: 5Q0 614 517 AD
Component: ESC H25 0513
Revision: 00000000 Serial number: 60877000001370
Coding: 01FA93A15426216F4777070040C66980C92A84E2E0029677384250084208430000000012121212B835351919323200
VCID: 77BE09C2CE52913E22-8022
Part No SW: 5G0 907 044 CF HW: 5G0 907 044 CF
Component: Climatronic H04 1801
Revision: 00001K08
Coding: 0012000420011001100500000010102A
VCID: 6D922BAABC0E2BEEC8-8038
Air quality sensor:
Part No SW: 5Q0 937 084 CF HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H34 0236
Serial number: 02001709003372
ROD: EV_BCMBOSCH_017.rod
VCID: 7EB01CE6E168A07661-802A
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 170313 042 0551
Serial number: 170324133416
Component: RLHS 042 0105
Serial number: S5Y17M04D04H03M46S43
Coding: 00A8DD
Serial number: 000000000ZY170592F3Z
Serial number: 00000000000069081031
Part No SW: 5QA 919 294 A HW: 5QA 919 294
Component: PDC 8 KanalH07 0038
Serial number: 000308418617091
Coding: 0471051011
ASAM Dataset: EV_EPHVA18AU3700000 009031
VCID: 4AD88036ED20DCD68D-801E
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 H HW: 3QF 907 572
Coding: 3305678159FFC728949C810580400600000000000000000000
VCID: 3C34D6EEB7F472660F-8068
Part No SW: 5Q0 959 655 AR HW: 5Q0 959 655 AR
Component: AirbagVW21 003 0318
Serial number: 003TDR2U1WGO
Coding: 98CCC000000000005C0000CF008800000065
VCID: 106C525ECBFCA60683-8044
Belt Pretensioner left:
Component: BeltPretRevFL H37 0350
Serial number: 34169677E30031751645
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H37 0350
Serial number: 34169676E31031740558
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 000 104 17
Serial number: 357000000008FA58B22X
Subsystem 4 - Part No SW: ----------- HW: 480 000 104 17
Serial number: 35800000000D4695B22P
Subsystem 5 - Part No SW: ----------- HW: 480 402 903 17
Serial number: 3510001B724CEFC172FQ
Subsystem 6 - Part No SW: ----------- HW: 480 402 903 17
Serial number: 3520001992527B25643X
Subsystem 7 - Part No SW: ----------- HW: 480 402 903 17
Serial number: 3550001A72527B2185A+
Part No SW: 5Q0 953 507 GH HW: 5Q0 953 549 E
Revision: -------- Serial number: 31031708490792
Coding: 0410
VCID: 024868169590C49605-8056
Part No SW: 5G1 920 791 HW: 5G1 920 791
Component: KOMBI 409 2180
Coding: 27AD30886E84060001886B071400000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009052
VCID: 699A5FBA88E637CEA4-803C
Part No SW: 3Q0 907 530 C HW: 3Q0 907 530 C
Component: GW MQB High 515 5286
Serial number: 26031710521785
Coding: 030100047F085900FB00827E1C0F00010001050000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 2F2EF1A2768299FEBA-807A
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29170000733470097125
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 6690713504
Serial number: HA1-00022.02.17
Coding: 0001
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 D HW: 8V0 907 399 D
Component: LCM_MLBevoH08 0014
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Component: TSG FS 020 0041
Serial number: 170217EBF34514
Coding: 003F0220D001048000001000
VCID: 43C6AD12CA0A0D9E4E-8016
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000014041349
Coding: 0D0000
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 9107
ROD: EV_SteerAssisMQB_013.rod
VCID: 3A38D0F6BDC04C561D-806E
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 001 0285
Serial number: 01041710800561
Coding: 000000050100165601100F01020000000000000000000000000000000000
VCID: 72A838D6A530F41615-8026
Component: TSG BFS 020 0041
Serial number: 150317ECF40384
Coding: 003F0020DE01048000801000
VCID: 42C8A816D510049645-8016
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000014010420
Coding: 150000
Part No SW: 3Q0 035 874 B HW: 3Q0 035 874 B
Component: MU-S-ND-ER 840 0753
Coding: 02731001FF00000051110101008808001F0507E601200000CF
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 312AF7DA60B68F0EAC-8064
Subsystem 1 - Part No SW: 5G6 919 605 D HW: 5G6 919 605 D
Component: ABT_Std-2_Nav H41 8077
Serial number: VWZ6ZHT0930365
Subsystem 2 - Part No SW: 3G0 919 866 AQ HW: -----------
Component: ECE1 2017 --- 0730
Address 65: Tire Pressure (J502) Labels: None
Part No SW: 4M0 907 273 HW: 4M0 907 273
Component: RDKHUFAU736 H03 0008
Serial number: 00000000000684
ASAM Dataset: EV_RDKHUFAU736 002006
ROD: EV_RDKHUFAU736.rod
8390147 - Tire Pressure Monitoring
C10DC 54 [009] - Missing Calibration / Basic Setting
Reset counter: 203
Mileage: 61506 km
Date: 2020.10.15
Time: 16:14:36
Expanded ambient data 1-Left front tire pressure sensor: identification: 544657418
Expanded ambient data 1-Right front tire pressure sensor: identification: 544704311
Expanded ambient data 1-Left rear tire pressure sensor: identification: 544698516
Expanded ambient data 1-Right rear tire pressure sensor: identification: 544698599
Part No SW: 3Q0 980 654 L HW: 3Q0 980 654 A
Component: MQB_B_MFK H12 0610
Serial number: 05081912P24826
Coding: 0003070000000401000213448156A90094000E12002000
ROD: EV_MFKBoschMQBB_002.rod
VCID: 40CCA21EDB1C168653-8014
1122597 - Local Data Bus
U1169 00 [009] - Missing Message
[Timeout_RDR1_Header]
Reset counter: 206
Mileage: 61557 km
Date: 2020.10.16
Time: 09:21:21
Control Module temperature: 36 °C
Outside air temperature: 7.5 °C
Vehicle speed: 0.00 km/h
System run time: 64050.5 s
Voltage terminal 15: 13.8 V
mid: 01 43
Status of camera: operational
Engine_Running_Info: 0
Software_Info_4: 0
Software_Info_3: 1
Software_Info_2: 6
Software_Info_1: 0
Part No SW: 5G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 170227201360
Part No SW: 7P5 941 572 A HW: 7P5 941 572 A
Component: LED1L H06 0002
ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: EV_LEDMinMaxL_KEBODAVW481.rod
VCID: 393ACFFAB8C6474E14-806C
Component: LED1R H06 0002
ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
ROD: EV_LEDMinMaxRKEBODVW481.rod
End----------(Elapsed Time: 01:52, VBatt start/end: 14.0V/13.7V)-----------
Best Regards
