Audi A6, AFL - DTC U1112
pipina89
Slovenia
C?ID=168592
Hi, I have problem with AFL lights not working correctly MIL in ON - won't turn when cornering. Usually when I see DTC " Function Restriction due to Implausible Message " I have a problem on other module or wiring on the CAN but here is only present in AFL module. Airbag pretension fault is old and car work OK with this code present for few years in attachment VCDS readout. I will be grateful for any help-hint. The car has only ECU tuning no other retrofits.
Regards
Thursday,15,October,2020,18:56:28:49571
VCDS Version: 20.4.0.1
VIN: WAUZZZ4G0EN015422   License Plate:
Mileage: 267106km-165971mi   Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 03 05 08 09 10 15 16 17 19 28 3B 42 44 46 52 53 55 56 5F
          62 6C 6D 72 85 8F 90
VIN: WAUZZZ4G0EN015422   Mileage: 267106km-165971miles
8F-Pretens. Frt Left -- Status: Malfunction 0010
Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 LA    HW: 03L 906 018 JL
   Component: R4 2,0L EDC   X25 2023
   Revision: 45X25---
   Coding: 12194012232401080000
   Shop #: WSC 01286 386 08256
   ASAM Dataset: EV_ECM20TDI01103L906018LA 003009
   ROD: EV_ECM20TDI01103L906018GT.rod
   VCID: 74E71E78DF7A8C2616-8020
   Part No SW: 4G0 907 379 L    HW: 4G0 907 379 L
   Component: ESP PREMIUM   H09 0450
   Coding: 06A09F016005F9809B00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004039
   VCID: 3A7BF040BD9E3A560C-806E
   Part No SW: 4H0 907 064 CN    HW: 4H0 907 064 CN
   Component: BCM2 2.0      H33 0433
   Coding: 03A93046000000000000
   VCID: 77FD2974C60CE73E33-8022
   Serial number: 2313000094137009
   Part No SW: 4G0 820 043 AE    HW: 4G0 820 043 AE
   Component: KLIMA 4 ZONEN H13 0087
   Serial number: 07061300041115
   Coding: 340200B8A5
   ASAM Dataset: EV_AirCondiComfoUDS 002040
   VCID: 62CB6820758E129674-8036
   Part No SW: 4H0 907 063 CF    HW: 4H0 907 063 F
   Revision: 20012002    Serial number: 00000001447213
   Coding: 0200201050B49F60C4810083000019080F9C87082E080201000008406100
   VCID: 6ED30C10B956A6F6E0-803A
   Component: WWS57X 130518  H36 0080
   Serial number:         130527033725
   Coding: 0045F7
   Serial number: 21390154
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 S    HW: 4G0 941 531 S
   Component: E1 - LDS  H07 0044
   Serial number: 03 06 2013  00000030
   Serial number: EA68CFA6000000000001
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 26
                    Mileage: 267106 km
                    Date: 2020.10.15
                    Time: 18:49:00
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61031315502030
   Coding: A8C208
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: 71E9176CA068B90EFD-8024
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG00DH80X
   Coding: 30323436313230303031554A304C34473053
   VCID: 3663E4708986DE36E8-8062
   Serial number: 3575HRB400250HLEKH47
   Serial number: 3585HRB401E50GS8HGHU
   Serial number: 3515JRB400Q50IBOO1IU
   Serial number: 3525JRB400650IC2R9B.
   Serial number: 3554VRB406521D0K313F
   Serial number: 3564VRB401E50ILUF0CZ
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20130611000095
   Coding: 000015
   VCID: 306FD26863E2F006B2-8064
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Part No SW: 4G8 920 932 S    HW: 4G8 920 932 S
   Component: TDieRdw       H80 0618
   Revision: 30460230    Serial number: 658050613596037
   Coding: 13A410000B410008000000
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: 3F8D8154A6BC1F7E3B-806A
   Part No SW: 4G0 907 468 AC    HW: 4G0 907 468 AC
   Component: J533--Gateway H12 0037
   Revision: --------    Serial number: 00000000972658
   Coding: 00CD074400
   ASAM Dataset: EV_GatewPkoUDS 001018
   Serial number: 5330390703
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 1303260000000000054A
   Part No SW: 4G0 919 158 K    HW: 4G0 919 158 K
   Component: KLIMA FOND    H07 0087
   Serial number: 07061300041878
   Coding: 20
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002019
   VCID: 377DE9748E8C273EF3-8062
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H02 0056
   Revision: --------    Serial number: EJ1BPA8203UGDN
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   Component: TSG FA        H03 0507
   Coding: 011C16004C00628002080002
   VCID: 479D99B4F66C57BE83-8012
   Component: RCEPS         H36 0010
   Revision: 00001000    Serial number: 0007563757
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 326BD86065EEC216C4-8066
   Revision: 00002001    Serial number: 0309134464
   Coding: 0100062820B930408320090408010F470000000000000000000000000000
   Component: TSG BF        H03 0507
   Coding: 011C16004E00628002080002
   VCID: 468394B0F1664EB678-8012
   Part No SW: 4H0 907 801 G    HW: 4H0 907 801 A
   Component: EPB-4         H03 0014
   Revision: --------    Serial number: 00000000713089
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2C57C61847CA94E68E-8078
Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
   Part No SW: 4H4 907 357 C    HW: 4H4 907 357 A
   Component: ....AFS13.... H01 0020
   Serial number: 130608-0004-007
   Coding: 11229633F91AEB00
   Shop #: WSC 22138 142 13177
   ASAM Dataset: EV_AdvanFrontSyste 005001
   ROD: EV_AdvanFrontSyste_AU21.rod
H02 0010
   Coding: 1D0000
H02 0010
   Coding: 1D0000
0061 - Function Restriction due to Implausible Message(s)
          U1112 00 [137] - -
                    Reset counter: 26
                    Mileage: 267106 km
                    Date: 2020.10.15
                    Time: 18:49:40
   Part No SW: 4G0 035 056 J    HW: 4G0 035 056
   Component: Radio U STD   H60 0133
   Revision: AB001007    Serial number: 230FX0D7661391
   Coding: 010003020100000001
   VCID: 285F3A085B32B8C66A-807C
   Part No SW: 4G0 035 666 K    HW: 4G0 035 666 H
   Component: H-BN-EU       H51 0732
   Revision: --------    Serial number: 189F10D7544812
   Coding: 050100010003A1EF05908B3E00000003E00101020000000000
   Subsystem 1 - Part No: 8R0 060 884 BC
   Component: EUR 2013/2014  1603
   Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
   Component: DU8 C7 SV  H43 0021
   Serial number: AUZ8ZDDD001M2MW
   Subsystem 3 - Part No SW: 4G1 919 710 C    HW: 4G1 919 710 C
   Component: E380 BDT C7  H11 0204
   Serial number: 90349MF6000DT
   Component: CD-Database  5298
   Component: TSG HL        H03 0507
   Coding: 010814004000628002080002
   VCID: 49999F8CE078A1CE95-801C
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 B    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H07---    Serial number: 525 PA8J35G7LI
   Coding: 1080005
   VCID: 264334309126AEB658-8072
   Part No SW: 4G9 959 107 B    HW: 4G9 959 107 A
   Component: HDSG-Modul    H03 0143
   Revision: 14003001    Serial number: 152300546
   Coding: 097205C010
   ROD: EV_HDSGAu571.rod
   VCID: 3561E37C9480D52EE1-8060
   Component: TSG HR        H03 0507
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H26 0038
   Coding: 64040000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 264334305926AEB658-8072
   Coding: 00060000031F030000030801424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW51.rod
   VCID: 3169D76C60E8F90EBD-8064
12586240 - Internal Control Module Memory Check Sum Error
          B2000 09 [137] - Component Failure
                    Mileage: 152506 km
                    Date: 2015.10.13
                    Time: 14:45:02
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R_VW51.rod
End-------------------------(Elapsed Time: 05:16)--------------------------
I believe the fault in the headlight range module is indicating it's unhappy about something with the On-Board Camera, but it's not immediately obvious what that might be, since there are no faults in that module. :confused:
pipina89
Slovenia
C?ID=168592
Hi, from what did you see that onboard camera can be a problem? Front glass was not changed also the camera is original. I know there was few technical actions on onboard camera on A6, but facelift models. I will try to unplug it and see DTCs, or you thing realignment will do the job?
Regards
