Case Study: B201A - Check Software Version Management
wkeating
South Africa
C?ID=307967
I have followed procedure as discussed under 'how to thread: Case Study: B201A - Check Software Version Management, but when i insert info I as in my case A9 AD then I get the result 5FFCB anyone knows if there is a different step somewhere
South Molton, UK
That doesn't sound right as the operation XORs two 4 digit hex numbers which can only return a 4 digit hex result?
  • Agree
wkeating
South Africa
C?ID=307967
ok i did not change to hexadecimal 10 lets try that
@wkeating : Hi. What flavor car is this and what was the value of IDE02502-Confirmation of installation change in your hex5F module?
Usually it will be a hexadecimal number with up to 4 x digits (but it can be less than 4 x digits if the leading number is zero - some diagnostic cables don't report leading zeros) as @PetrolDave says, or it will be up to 5 x digit decimal number (i.e. sans alpha characters)!
PS: I hope that your hex5F module doesn't have a CP error that has been induced by a hack -might not be prudent to remove SVM error if this is the case!
wkeating
South Africa
C?ID=307967
Hi it is VW Polo 1.0 TSI and the correct result was 60 7f after chancing second input to: decimal (base 10)
