Having issues with my actuator. Had the DTC for it. Took everything apart, cleaned turbo, replaced the actuator, put everything back together and still have the same codes. Actually have more codes. Read somewhere that you should unplug the fuel pump relays and turn engine over to verify oil gets into the turbo. Did that so now I have fuel pump relay error codes, too. Tested old actuator and it didn't hold vacuum. Test new actuator and it does hold vacuum so I don't think I actually have an actuator problem anymore. Looking back at prior scan I did before replacing the actuator, I notice now that I had another code that I didn't notice at the time - P2563 Boost Control Position Sensor. Not sure how I missed that but here we are. Anyway, here are my questions followed by the scan.
N75 solenoid tests fine.
No voltage at 3 pin plug at turbo. Is one of the three wires there a signal wire so no voltage would show there?
Obviously, I have VCDS, Do I need to connect the plugs up and use it to check the voltage?
Could both the boost control sensor and the actuator BOTH have been bad going into this situation?
Thursday,15,October,2020,08:56:37:04001
VCDS Version: 20.4.2.0 (x64)
VIN: 3VWTL81KX9M348236 License Plate: 8:56AM 09 JETTA
Mileage: 204080km-126809mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 4F 52 56 62 65 72
VIN: 3VWTL81KX9M348236 Mileage: 204080km-126809miles
Address 01: Engine (CBE) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 J HW: 03L 906 022 J
Component: R4 2.0l TDI G001SG 9983
Revision: 12H01--- Serial number: VWX7Z0I424A0RN
Coding: 0050072
Shop #: WSC 20853 002 1048576
VCID: 356AD9E75C4ED72EF0-8060
10 Faults Found:
009571 - Turbocharger Boost Control Position Sensor Circuit
P2563 - 000 - Implausible Signal - Intermittent
Mileage: 204066 km
Time: 16:24:34
RPM: 828 /min
Voltage: 13.76 V
Temperature: 234.0°C
Lambda: -0.8 %
Bin. Bits: 00001110
Voltage: 2.432 V
000175 - Actuator Module for Turbocharger 1
P00AF - 000 - Stuck - Intermittent
Mileage: 204066 km
Time: 16:24:36
RPM: 828 /min
Load: 0.0 %
Load: 100.0 %
Lambda: 17.4 %
Pressure: 968.0 mbar
Temperature: 36.9°C
P00AF - 001 - Stuck - Intermittent
Fault Status: 00100001
Mileage: 204067 km
Time: 16:45:48
RPM: 874 /min
Speed: 21.0 km/h
Load: 0.0 %
Load: 9.8 %
Lambda: 16.6 %
Temperature: 43.2°C
P00AF - 002 - Stuck
Fault Status: 01100010
Mileage: 204082 km
Time: 17:48:18
RPM: 828 /min
Load: 34.9 %
Mass Air / Rev.: 0.0 mg/str
Mass Air / Rev.: 265.0 mg/str
001575 - Fuel Pump Relay Control Circuit
P0627 - 000 - Open Circuit - Intermittent
Mileage: 204082 km
Voltage: 11.78 V
Pressure: 0.0 bar
Inj. Quantity: 0.0 mg/str
Lambda: 27.6 %
Lambda: 10.3 %
009778 - Relay for Fuel Pump 2 (J49)
P2632 - 000 - Open Circuit - Intermittent
Mileage: 204082 km
Voltage: 11.78 V
Pressure: 0.0 bar
Lambda: 27.6 %
Lambda: 10.3 %
P2563 - 002 - Implausible Signal - Intermittent - MIL ON
Fault Status: 10100010
Mileage: 204083 km
Time: 19:17:14
RPM: 851 /min
Voltage: 13.00 V
Temperature: 90.0°C
Lambda: 12.6 %
Bin. Bits: 00000010
Voltage: 0.228 V
009572 - Turbocharger Boost Control Position Sensor Circuit
P2564 - 000 - Signal too Low - Intermittent
Mileage: 204083 km
Voltage: 11.78 V
Temperature: 42.0°C
Lambda: 12.6 %
Bin. Bits: 00000000
Voltage: 0.000 V
001136 - Exhaust Pressure Sensor 1
P0470 - 000 - Malfunction - Intermittent
Mileage: 204083 km
Temperature: 15.3°C
Temperature: 13.5°C
Temperature: 6.0°C
Pressure: 0 mbar
Pressure: -3 mbar
000069 - Boost Pressure Control Valve/Solenoid (Bank 1)
P0045 - 000 - Open Circuit - Intermittent
Mileage: 204083 km
Load: 0.0 %
Load: 9.8 %
Lambda: 0.0 %
Pressure: 955.9 mbar
Temperature: 18.0°C
Readiness: 1 4 0 0 0
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 CD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0120
Revision: 00H35001
Coding: 113B600D49260002880D06E7921F00423000
Shop #: WSC 56089 001 1048576
VCID: 76E81EEBC1C89C3639-8022
Part No SW: 1K0 820 047 JJ HW: 1K0 820 047 JJ
Component: Climatic PQ35 143 1313
Revision: 00143033 Serial number: 00000000000000
VCID: 75EA19E71CCE972E30-8020
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Revision: 00H54000 Serial number: 00000009459947
Coding: 14898F2340041500070000001C000000000873075C000120000000000000
VCID: 3260E2FBAD20C016D5-8066
Component: Wischer 110509 021 0501
Coding: 00038805
Revision: 00000000 Serial number: AUZ4Z7J0540598
Coding: 0000100
Shop #: WSC 00066 000 00000
VCID: 336EE7FF523AC91EDE-8066
02617 - Satellite Antenna (R170)
Fault Status: 01101011
Reset counter: 50
Mileage: 204083 km
Time: 08:52:23
Part No SW: 1K0 909 605 AD HW: 1K0 909 605 AD
Component: 02 AIRBAG VW8R 036 8900
Revision: 06036000 Serial number: 003EVM004ALJ
Coding: 0012338
VCID: 6ED8368B7998A4F6F1-803A
Subsystem 1 - Part No: 1K0 959 339 H
Component: BF-Gewichtsens. 007 0006
Subsystem 2 - Serial number: 6332MSME41060F4BC
Subsystem 3 - Serial number: 6342MSME461473300
Subsystem 4 - Serial number: 6351HSME1C4E32014
Subsystem 5 - Serial number: 6361HSME1C4E6A2CT
Subsystem 6 - Serial number: 63727SME1B5F662FL
Subsystem 7 - Serial number: 63827SME1C135113V
Part No SW: 1K0 953 549 CQ HW: 1K0 953 549 CQ
Component: J0527 053 0111
Coding: 0000034
VCID: 030E773F421AB99E0E-8056
Part No SW: 1K0 920 974 N HW: 1K0 920 974 N
Component: KOMBIINSTRUMENT 3HL 2418
Revision: V0005000 Serial number: VWX7Z0I424A0RN
Coding: 0007203
Shop #: WSC 06438 444 84346
VCID: 3972D5D77056334E14-806C
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 T HW: 1K0 907 951
Component: J533 Gateway H06 0071
Revision: H06 01 Serial number: 170309F2002285
Coding: E9807F07001303002002
VCID: 3874D0D34B5C2A46EB-806C
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1225223T5CA603
VCID: 7DFA01C724FECF6E78-8028
Component: IMMO 3HL 2418
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1519
Revision: 72009005 Serial number: 00000883598306
Coding: 0001205
VCID: 6FE62B8F7E92ADFEFA-803A
Fault Status: 01100101
Reset counter: 50
Mileage: 204083 km
Part No: 1K0 909 144 E
Component: EPS_ZFLS Kl. 70 2501
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2C5CFC838F0496E69F-8078
000 - - - MIL ON
Fault Status: 11100000
Mileage: 204083 km
Time: 08:52:12
Battery Volts: 11.7 V
DD
Temperature: 23.0°C
Count: 2
Steering Angle: 0.00°
Count: 1
SteerAng n.Init
Part No SW: 1K0 959 433 DA HW: 1K0 959 433 DA
Component: KSG PQ35 RDK 052 0225
Coding: 139007885283283F0904058FB0880F0488DC00
Shop #: WSC 00066 123 12345
VCID: 72E022FB6DA0801615-8026
Address 4F: Centr. Electr. II (J533) Labels:. 1K0-907-532.clb
Part No SW: 1K0 907 532 HW: 1K0 907 951
Coding: 050B0500
VCID: 66C84EAB91686CB689-8032
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE19SKB12 H01 0220
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE19SKB12 H01 0220
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 08121621485704
Coding: 0001204
VCID: 70E428F363ACB206E3-8024
Reset counter: 50
Mileage: 204083 km
Component: Radio DE2 016 0020
Revision: 00016000 Serial number: VWZ4Z7J2281869
Coding: 0040402
VCID: 2952059780F683CE64-807C
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000003900449
Coding: 0001168
VCID: 76E81EEB01C89C3639-8022
Reset counter: 50
Mileage: 204083 km
Component: RDK 0453
Coding: 0100101
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000003905867
Coding: 0001168
VCID: 77F613EF06C2E53E22-8022
End-------------------------(Elapsed Time: 02:15)--------------------------
