Hello Group,
I have this issue with my son's car , it started when he let the battery completely die several times. I have got the pin using a VAG-TACHO cable and am having trouble getting access to recode keys with my VAGCOM cable no matter what I try it won't let me access with code from vag-tacho any ideas, Thanks for your time I have only spent weeks on this issue so far,
Smiles
Smiles
Tuesday,13,October,2020,19:22:46:63831
VCDS Version: 20.4.2.0
Chassis Type: 1J - VW Golf/Bora IV (1998 > 2006)
76
Mileage: 212790km-132221miles
Address 01: Engine Labels: 06A-906-018-AEG.lbl
Part No: 06A 906 018 JJ
Component: 2.0l R4/2V MOTR AT V01
Coding: 00033
Shop #: WSC 26002
VCID: 73EBCD98414C7F1E1E-4B18
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - Intermittent
Readiness: 0110 1101
Address 02: Auto Trans Labels: 01M-927-733.lbl
Part No: 01M 927 733 HM
Component: AG4 Getriebe 01M 4604
Coding: 00011
VCID: 0205985C0EF6469605-0962
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 P
Component: ABS 20 IE CAN 0001
Coding: 03504
VCID: 3E7D2CAC3A8EE27621-4B32
00283 - ABS Wheel Speed Sensor; Front Left (G47)
35-10 - - - Intermittent
01130 - ABS Operation
Part No: 6Q0 909 605 A
Component: 11 AIRBAG VW5 0004
Coding: 12593
VCID: 356F33800FB8212EF0-4B18
00532 - Supply Voltage B+
Address 17: Instruments Labels: 1J0-920-xx0-17.lbl
Part No: 1J0 920 900 K
Component: A4-KOMBIINSTR. VDO V26
Coding: 07242
Shop #: WSC 00050
VCID: 2A5510FCD6067ED66D-515A
Subsystem 1 - Part No: IMMO
Component: IDENTNR: VWZ7Z0Y2254987
IMMO-IDENTNR: VWZ7Z0Y2254987
01176 - Key
07-00 - Signal too Low
01179 - Incorrect Key Programming
35-00 - -
Part No: 6N0 909 901
Coding: 00007
VCID: 70E1C294305A4406E3-5178
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AJ
Component: 60 Zentral-SG Komf. 0001
Coding: 04096
VCID: 060D844C22DE7AB629-4B18
Subsystem 1 - Part No: 1J1959801C
Component: 60 T�rsteuerger. FS0002r
Subsystem 2 - Part No: 1J1959802D
Component: 60 T�rsteuerger. BF0002r
Subsystem 3 - Part No: 1J4959811C
Component: 60 T�rsteuerger. HL0002r
Subsystem 4 - Part No: 1J4959812C
Component: 60 T�rsteuerger. HR0002r
15 Faults Found:
00949 - Central Locking Motor - tailgate (V53); LOCK
25-10 - Unknown Switch Condition - Intermittent
00953 - Interior Light Time limit
01141 - Luggage Compartment Unlocking Switch (E165)
35-00 - -
52-10 - Supply Voltage Too High - Intermittent
35-00 - -
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1J0 035 180 D
Component: RADIO 3CP 0002
Coding: 01401
VCID: 2041F2D4A03AB48633-4B18
End-------------------------(Elapsed Time: 05:00)--------------------------
