04 passat tdi converted to manual 6 speed
krazyk
Canada
C?ID=363048
What is the procedure for deleting the auto trans (02) from the gateway list for this car (kline)? I have changed the engine coding from 0150034 to 0150032 but i can't seem to do nothing with gateway. I imagine a login password is required, anyone have it?
dieseldub
Bay Area, CA
C?ID=28764
Any Mk4 or B5 from about 2002 on up with the later revision CAN Gateway, you just simply resend the same 0006 coding it already has. When you do that, the Gateway automatically rebuilds the install list of what modules it's looking for based on what is currently detected on the 2 data buses this generation of car has.
So, when you resend that 0006 coding, be sure the transmission computer is unplugged when you do so, that way it rebuilds the install list without the transmission computer.
There's also coding changes required with the ABS module as well. Typically, the ECU itself also needs to be reflashed to properly function with a manual swap on the BHW. The BEW and ALH not so much, but for some reason, the BHW does need it.
krazyk
Canada
C?ID=363048
I have tried that procedure but the 02 remains on the list tcu has been unplugged. So a login is not required for the gateway? I can't even change that 0006 number to something else.
krazyk
Canada
C?ID=363048
sorry got busy with other work for a while, back to the project now
Tuesday,20,October,2020,08:51:01:20591
VCDS Version: 20.4.2.0 (x64)  HEX-NET CB: 0.4513.4
VIN: WVWME63B54E307479   License Plate:
Mileage: 328950km-204400mi   Repair Order:
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
VIN: WVWME63B54E307479   Mileage: 328950km-204400miles
   Part No SW: 038 997 016 K    HW: 028 101 143 3
   Component: R4 2,0L EDC G000SG  0811
   Revision: 12345678    Serial number: VWZ7Z0D9407690
   Coding: 0150032
   Shop #: WSC 00001 128 106502
   VCID: A6007E2F10B7E2B6C9-5184
18263 - Powertrain Data Bus
            P1855 - 000 - Software Version Monitoring
                    RPM: 798 /min
                    Torque: 28.0 Nm
                    Voltage: 14.29 V
                    Temperature: 18.0°C
                    Temperature: 84.6°C
                    Temperature: 60.3°C
16502 - Engine Coolant Temp. Sensor (G62)
            P0118 - 000 - Signal too High
                    RPM: 2268 /min
                    Torque: 408.0 Nm
                    Speed: 77.0 km/h
                    Load: 100.0 %
                    Voltage: 14.36 V
                    Bin. Bits: 00101100
                    Temperature: 44.1°C
                    Temperature: 46.8°C
Address 03: ABS Brakes        Labels: 4B0-614-517.lbl
   Part No: 4B0 614 517 G
   Component: ABS/ESP front       3428
   Coding: 04255
   Shop #: WSC 05311
   VCID: A50279233DB1E9AEC0-51CE
01486 - System Function Test Activated
            35-00 - -
   Part No: 1C0 909 605 C
   Component: 09 AIRBAG VW61 04   0003
   Coding: 12345
   Shop #: WSC 05311
   VCID: A4046427368B10A6D7-513C
            06-10 - Signal too High - Intermittent
Address 17: Instruments        Labels: 3B0-920-xx5-17.lbl
   Part No: 3B0 920 929 C
   Component: KOMBI+WEGFAHRSP VDO V04
   Coding: 15235
   VCID: A71E732B47BDFBBEF2-513C
   WVWME63B54E307479     VWZ7Z0D9407690
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 05311
   VCID: F0AC5877B2F3FC0663-513C
   Part No: 1C0 959 799 C
   Component: 08 Komfortgerát HLO 0003
   Coding: 00259
   Shop #: WSC 05311
   VCID: B73EA36B971D6B3E62-4B1E
   Subsystem 1 - Part No: 1C1959801
   Component: 08 Tõrsteuer.FS KLO 0202
   Subsystem 2 - Part No: 1C1959802
   Component: 08 Tõrsteuer.BF KLO 0202
   Subsystem 3 - Part No: 1C0959811
   Component: 08 Tõrsteuer.HL KLO 0202
   Subsystem 4 - Part No: 1C0959812
   Component: 08 Tõrsteuer.HR KLO 0202
Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
   Part No: 3B7 035 180 G
   Component:    Radio PM6        0016
   Coding: 00031
   Shop #: WSC 05311
End----------(Elapsed Time: 04:39, VBatt start/end: 11.9V/12.0V)-----------
I'm with @dieseldub. You shouldn't need to change it to something else. Re-code the Gateway with 00006. Exit the Gateway gracefully. Cycle the ignition off for 30 seconds, and turn it back on (but do not start the engine) and leave it like that for a minute.
But I think you've already accomplished this, since absolutely nothing is complaining about missing messages from the TCU.
krazyk
Canada
C?ID=363048
It appears to work but yet it remains on the install list i guess. Also got all other things to shut up, removed a few codes fixed abs sensor and turned off the seatbelt warning and went for single click all locks while at it.
