- Oct 12, 2020
- 14
- 5
- Oakfield, NS, CA
- C?ID=384933
Hi all,
This is my first post; hopefully I can follow the JPPSG appropriately.
2008 GTI DSG, totally stock
Signals and Cruise Control are not working. I replaced the signal stalk lever with a brand new OEM one and nothing changed. When I look at the steering wheel control module for cruise it shows the that buttons on the stalk still work. I think it was 0x-16-04-00?
Checked the fuses under the dash.
Here are my codes:
Side note, this is my winter beater car that I've had for two years and I've never really cared what VCDS was telling me; there are lots of codes. I know the AC doesn't work and my wastegate actuator rod is broken; both on the to do list, lol. Normally I just clear the EVAP codes whenever they pop up with a little shitty bluetooth scan tool. I'm not concerned with most of the codes right now as I need to get my signals working to pass safety inspection in Nova Scotia Canada.
Thanks in advance for your help solving what part to change or what to track down regarding my signals and cruise control.
Here are my codes:
Monday,12,October,2020,12:23:45:43089
VCDS Version: 20.4.2.0 (x64) HEX-V2 CB: 0.4513.4
VIN: WVWFV71K58W214236 License Plate:
Mileage: 187870km-116737mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 55 56
VIN: WVWFV71K58W214236 Mileage: 187870km-116737miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 S HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWX7Z0GD3NC9GI
Coding: 0403010A1C070160
Shop #: WSC 01279 785 00200
VCID: 36352191A44DF8ABB8F-8062
001110 - EVAP System
P0456 - 001 - Very Small Leak Detected - Intermittent
Fault Status: 00110001
Mileage: 185659 km
Time: 02:08:57
RPM: 1473 /min
Load: 25.5 %
Speed: 59.0 km/h
Temperature: 73.0°C
Temperature: 22.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.589 V
008577 - Performance Malfunction in Cooling System
P2181 - 008 - - Intermittent
Fault Status: 00111000
Mileage: 185758 km
Time: 03:50:27
RPM: 3232 /min
Load: 59.6 %
Speed: 110.0 km/h
Temperature: 75.0°C
Temperature: 28.0°C
Absolute Pres.: 990.0 mbar
Voltage: 12.446 V
000665 - Boost Pressure Regulation
P0299 - 002 - Control Range Not Reached - Intermittent
Fault Status: 00110010
Mileage: 187045 km
Time: 23:44:43
RPM: 2760 /min
Load: 58.8 %
Speed: 94.0 km/h
Temperature: 74.0°C
Temperature: 30.0°C
Voltage: 13.335 V
008583 - Bank 1; System too Lean at Idle
P2187 - 004 - - Intermittent
Fault Status: 00110100
Mileage: 187315 km
Time: 00:08:10
RPM: 852 /min
Load: 14.9 %
Temperature: 63.0°C
Temperature: 24.0°C
Voltage: 12.954 V
005699 - Please check DTC Memory of Electric Load Controller
P1643 - 001 -
Fault Status: 01100001
Load: 0.0 %
Temperature: 69.0°C
Temperature: 28.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 11.684 V
Readiness: 0110 0101
Part No SW: 02E 300 050 J HW: 02E 927 770 AD
Component: GSG DSG 082 1409
Revision: 05108020 Serial number: 00001007111167
Shop #: WSC 04940 001 00001
VCID: 196FCA2D359337D3B5D-804C
Revision: 00H11001
Coding: 0021122
VCID: 73B3D885F7BFAD835F1-8026
Part No SW: 1K0 907 044 DE HW: 1K0 907 044 DE
Component: ClimatronicPQ35 130 1213
Revision: 00130023 Serial number: 00000000000000
VCID: 6D87CEFD919B7B73895-8038
00716 - Air recirculation Flap Positioning Motor (V113)
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Revision: 00H54000 Serial number: 00000007909076
Coding: 178D8F214004150047140000001400000028770B5C000100000000000000
Shop #: WSC 95855 999 79324
VCID: 71BFD28D8DA39F93ADD-8024
Component: Wischer 151207 021 0501
Coding: 00038805
Shop #: WSC 95855
Reset counter: 28
Date: 2005.09.13
Time: 31:63:63
Voltage: 11.95 V
Component: 6L AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D0A75GS
Coding: 0013900
Shop #: WSC 01269 785 00200
VCID: 6C81C3F9AA81727B9EB-8038
Subsystem 1 - Serial number: 6332MSME2C4342659
Subsystem 2 - Serial number: 6342MSME37714844A
Subsystem 3 - Serial number: 6352QSME4B163671G
Subsystem 4 - Serial number: 6362QSME4947260FP
Subsystem 5 - Serial number: 63727SME125B2425Z
Subsystem 6 - Serial number: 63827SME126B57643
Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
Component: J0527 051 0100
Coding: 0012122
VCID: 78A9EFA9EED9CEDB6A3-802C
Component: E0221 002 0010
00886 - Turn Signal Switch (E2)
014 - Defective
00895 - Cruise Control Switch (E45)
Part No SW: 1K6 920 874 A HW: 1K6 920 874 A
Component: KOMBIINSTRUMENT VDD 1216
Revision: V0002000 Serial number: VWX7Z0GD3NC9GI
Coding: 0007303
Shop #: WSC 01287 785 00200
VCID: 313F128D4D23DF93EDD-8064
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 121207F2000159
Coding: ED811F060012020000
VCID: 303917894629D69BE23-8064
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1225223T2BWB03
VCID: 7DA7FEBDC1FBEBF3395-8028
Component: IMMO VDD 1216
Component: Tuer-SG 006 1207
Coding: 0001077
VCID: 38292FA9AE590EDBAA3-806C
008 - Implausible Signal
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.074 H08 1901
Shop #: WSC 00000 028 00001
VCID: 3537269DB94BF3B3B15-8060
Part No SW: 1K0 959 433 CA HW: 1K0 959 433 CA
Component: KSG PQ35 G2 020 0204
Coding: 939006885103281B0904058FB0080A0488BC00
Coding: 0001076
VCID: 392F2AAD955317D355D-806C
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74B1DB99F2B1AABB46B-8020
Part No SW: 1K0 035 180 M HW: 1K0 035 180 M
Component: Radio PM6 019 0035
Revision: 00019000 Serial number: VWZ5Z7G2198199
Coding: 0040401
VCID: 2A0D05E160F5AC4B2C7-807E
End----------(Elapsed Time: 01:06, VBatt start/end: 12.9V/12.9V)-----------
