MK5 GTI Signals and Cruise not working
   #21
MartinsX
Riga, Latvia
C?ID=268515
1K0-953-549-BG     Type 2     SW 0101     Highline     Yes     1.3     -
1K0-953-549-BK     Type 2     SW 0100/0101     Highline     Yes     1.3     -
Those are Yours. Highline - with all possible options.
Just to make turn signals work for passing inspection any other 1K0953549 with Type2 slip ring and integrated SAS may fit (You will have no MFSW working with Midline and Lowline modules and no CCS with Lowline modules)
Do I need to put this question up in the retrofit section?
No, multiple threads with the same car and problem are not accepted by administrators. Just wait for some gurus chime in.
I know that having a highline J527 is requirement for retrofitting MFSW, so I guess forum members who are doing retrofits for hobby or for business may have extra knowledge in this case. I'm not one of them.
   #23
KenMacG
Oakfield, NS, CA
C?ID=384933
Interesting, will a BF work? Does the LIN only matter for communication with the steering wheel? Thanks!!!
1K0-953-549-BFType 2SW 0101MidlineYes--
1K0-953-549-BGType 2SW 0101HighlineYes1.3-
   #24
KenMacG
Oakfield, NS, CA
C?ID=384933
I went back to the scrap yard today. The car that version BF was in got crushed... should have grabbed it on Friday I guess, lol. I grabbed an AP version today and threw it into the car.
1K0-953-549-APType 2SW 0070MidlineYes--
My old one is a BG
I have more new codes to do with the new module, but the signals work! Yeah.
Here's the new codes; how do I get my air bag, power steering and ABS working again? Thanks all!
Wednesday,21,October,2020,12:43:35:43089
VIN: WVWFV71K58W214236   License Plate:
Mileage: 187870km-116737mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 55 56
VIN: WVWFV71K58W214236   Mileage: 187870km-116737miles
1C-Position Sensing -- Status: Malfunction 0010
   Part No SW: 1K0 907 115 S    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWX7Z0GD3NC9GI
   Coding: 0403010A1C070160
   Shop #: WSC 01279 785 00200
   VCID: 36352191A44DF8ABB8F-8062
001110 - EVAP System
               P0456 - 001 - Very Small Leak Detected - Intermittent
                    Fault Status: 00110001
                    Mileage: 185659 km
                    Time: 02:08:57
                    RPM: 1473 /min
                    Load: 25.5 %
                    Speed: 59.0 km/h
                    Temperature: 73.0°C
                    Temperature: 22.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.589 V
008577 - Performance Malfunction in Cooling System
               P2181 - 008 -  - Intermittent
                    Fault Status: 00111000
                    Mileage: 185758 km
                    Time: 03:50:27
                    RPM: 3232 /min
                    Load: 59.6 %
                    Speed: 110.0 km/h
                    Temperature: 75.0°C
                    Temperature: 28.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 12.446 V
               P0299 - 002 - Control Range Not Reached - Intermittent
                    Fault Status: 00110010
                    Mileage: 187045 km
                    Time: 23:44:43
                    RPM: 2760 /min
                    Load: 58.8 %
                    Speed: 94.0 km/h
                    Temperature: 74.0°C
                    Temperature: 30.0°C
                    Voltage: 13.335 V
008583 - Bank 1; System too Lean at Idle
               P2187 - 004 -  - Intermittent
                    Fault Status: 00110100
                    Mileage: 187315 km
                    Time: 00:08:10
                    RPM: 852 /min
                    Load: 14.9 %
                    Temperature: 63.0°C
                    Temperature: 24.0°C
                    Voltage: 12.954 V
Readiness: 0110 0101
   Part No SW: 02E 300 050 J    HW: 02E 927 770 AD
   Component: GSG DSG         082 1409
   Revision: 05108020    Serial number: 00001007111167
   Shop #: WSC 04940 001 00001
   VCID: 196FCA2D359337D3B5D-804C
   Revision: 00H11001
   Coding: 0021122
   VCID: 73B3D885F7BFAD835F1-8026
   Part No SW: 1K0 907 044 DE    HW: 1K0 907 044 DE
   Component: ClimatronicPQ35 130 1213
   Revision: 00130023    Serial number: 00000000000000
   VCID: 6D87CEFD919B7B73895-8038
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
   Revision: 00H54000    Serial number: 00000007909076
   Coding: 178D8F214004150047140000001400000028770B5C000100000000000000
   Shop #: WSC 95855 999 79324
   VCID: 71BFD28D8DA39F93ADD-8024
   Component: Wischer 151207 021  0501
   Coding: 00038805
   Shop #: WSC 95855
                    Reset counter: 28
                    Mileage: 187875 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.00 V
   Component: 6L AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D0A75GS
   Coding: 0013900
   Shop #: WSC 01269 785 00200
   VCID: 6C81C3F9AA81727B9EB-8038
   Subsystem 1 - Serial number: 6332MSME2C4342659
   Subsystem 2 - Serial number: 6342MSME37714844A
   Subsystem 3 - Serial number: 6352QSME4B163671G
   Subsystem 4 - Serial number: 6362QSME4947260FP
   Subsystem 5 - Serial number: 63727SME125B2425Z
   Subsystem 6 - Serial number: 63827SME126B57643
            001 - Upper Limit Exceeded - Intermittent - MIL ON
   Part No SW: 1K0 953 549 AP    HW: 1K0 953 549 AP
   Component: Lenksäulenmodul 036 0070
   Coding: 0010021
   Shop #: WSC 00066 000 00000
   VCID: 00598749B609861B523-8054
   Part No SW: 1K6 920 874 A    HW: 1K6 920 874 A
   Component: KOMBIINSTRUMENT VDD 1216
   Revision: V0002000    Serial number: VWX7Z0GD3NC9GI
   Coding: 0007303
   Shop #: WSC 01287 785 00200
   VCID: 313F128D4D23DF93EDD-8064
   Revision:   H07 01    Serial number: 121207F2000159
   Coding: ED811F060012020000
   VCID: 303917894629D69BE23-8064
                    Reset counter: 27
                    Mileage: 187875 km
                    Time: 00:00:01
   Part No SW: 1K6 919 879     HW: 1K6 919 879
   Component: Kompass         001 0003
   Revision: 00001000    Serial number: 1225223T2BWB03
   VCID: 7DA7FEBDC1FBEBF3395-8028
                    Reset counter: 28
                    Mileage: 187875 km
   Component: IMMO            VDD 1216
   Component: Tuer-SG         006 1207
   Coding: 0001077
   VCID: 38292FA9AE590EDBAA3-806C
00105 - Signal Central Locking SAVE/LOCK Drivers Side
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.074 H08 1901
   Shop #: WSC 00000 028 00001
   VCID: 3537269DB94BF3B3B15-8060
02546 - Steering Limit Stop
                    Mileage: 187870 km
                    Temperature: 9.0°C
                    Voltage: 11.30 V
                    Voltage: 11.10 V
   Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
   Coding: 939006885103281B0904058FB0080A0488BC00
                    Reset counter: 28
                    Mileage: 187875 km
                    Time: 00:00:01
   Coding: 0001076
   VCID: 392F2AAD955317D355D-806C
   Part No: 1T0 907 357
   Coding: 0000003
   VCID: 74B1DB99F2B1AABB46B-8020
   Part No SW: 1K0 035 180 M    HW: 1K0 035 180 M
   Component: Radio PM6       019 0035
   Revision: 00019000    Serial number: VWZ5Z7G2198199
   Coding: 0040401
   VCID: 2A0D05E160F5AC4B2C7-807E
                    Fault Status: 00101011
                    Reset counter: 27
                    Mileage: 187875 km
                    Time: 00:28:36
End----------(Elapsed Time: 01:08, VBatt start/end: 13.0V/13.1V)-----------
   #25
KenMacG
Oakfield, NS, CA
C?ID=384933
I did some searching.
Do I do simply do this?
Replacement
  • Run and save a complete Auto-Scan and save it prior to module removal. See the Online Manual Auto-Scan.
  • Code the new module with the Coding from the original module found in the Auto-Scan.
  • Clear fault codes in the Steering Wheel module and verify all functions are working as per design.
  • Run and save another Auto-Scan and save it. The 03-ABS Brakes and 44-Steering Assist modules may have G85 and/or Steering Limit Stop fault codes that need to be corrected. See Vehicle specific Diagnostic Procedures for Details.
From here:
My steering module coding is 00121122, new one is 0010021; which translates to buttons on the steering wheel, paddles on the wheel and rear wiper for things that are different. This steering module does not support the buttons or the paddles (from what I understand) so do I leave those two fields 0xxx??xx as zeros since they won't work? Then just change the last digit that enables the rear wiper?
I'm finding lots of handy stuff on Ross-Tech; just wanna make sure I'm doing it correctly:)
   #26
MartinsX
Riga, Latvia
C?ID=268515
You understood everything correctly ;)
End stops and SAS in most cases may adapt automatically - You just need to start engine and turn wheel from end to end with holding it at both ends for some 5-10 sec plus drive a bit straight and a bit curvy. If yellow steering lamp does not go off, try calibration with VCDS according procedure.
   #27
KenMacG
Oakfield, NS, CA
C?ID=384933
Huge thanks to everyone, especially MartinsX (I owe you some beers).
Everything is working as expected. No lights on the dash, all functions on the stalks work (cruise, signals, rear wiper, wipers, high beams and high beam flashers). I'm good to go:)
Thanks again everyone!
