MK5 GTI Signals and Cruise not working
KenMacG
Oakfield, NS, CA
C?ID=384933
Hi all,
This is my first post; hopefully I can follow the JPPSG appropriately.
2008 GTI DSG, totally stock
Signals and Cruise Control are not working. I replaced the signal stalk lever with a brand new OEM one and nothing changed. When I look at the steering wheel control module for cruise it shows the that buttons on the stalk still work. I think it was 0x-16-04-00?
Checked the fuses under the dash.
Here are my codes:
Side note, this is my winter beater car that I've had for two years and I've never really cared what VCDS was telling me; there are lots of codes. I know the AC doesn't work and my wastegate actuator rod is broken; both on the to do list, lol. Normally I just clear the EVAP codes whenever they pop up with a little shitty bluetooth scan tool. I'm not concerned with most of the codes right now as I need to get my signals working to pass safety inspection in Nova Scotia Canada.
Monday,12,October,2020,12:23:45:43089
VIN: WVWFV71K58W214236   License Plate:
Mileage: 187870km-116737mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 55 56
VIN: WVWFV71K58W214236   Mileage: 187870km-116737miles
   Part No SW: 1K0 907 115 S    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWX7Z0GD3NC9GI
   Coding: 0403010A1C070160
   Shop #: WSC 01279 785 00200
   VCID: 36352191A44DF8ABB8F-8062
001110 - EVAP System
               P0456 - 001 - Very Small Leak Detected - Intermittent
                    Fault Status: 00110001
                    Mileage: 185659 km
                    Time: 02:08:57
                    RPM: 1473 /min
                    Load: 25.5 %
                    Speed: 59.0 km/h
                    Temperature: 73.0°C
                    Temperature: 22.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.589 V
008577 - Performance Malfunction in Cooling System
               P2181 - 008 -  - Intermittent
                    Fault Status: 00111000
                    Mileage: 185758 km
                    Time: 03:50:27
                    RPM: 3232 /min
                    Load: 59.6 %
                    Speed: 110.0 km/h
                    Temperature: 75.0°C
                    Temperature: 28.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 12.446 V
               P0299 - 002 - Control Range Not Reached - Intermittent
                    Fault Status: 00110010
                    Mileage: 187045 km
                    Time: 23:44:43
                    RPM: 2760 /min
                    Load: 58.8 %
                    Speed: 94.0 km/h
                    Temperature: 74.0°C
                    Temperature: 30.0°C
                    Voltage: 13.335 V
008583 - Bank 1; System too Lean at Idle
               P2187 - 004 -  - Intermittent
                    Fault Status: 00110100
                    Mileage: 187315 km
                    Time: 00:08:10
                    RPM: 852 /min
                    Load: 14.9 %
                    Temperature: 63.0°C
                    Temperature: 24.0°C
                    Voltage: 12.954 V
005699 - Please check DTC Memory of Electric Load Controller
               P1643 - 001 -
                    Fault Status: 01100001
                    Temperature: 69.0°C
                    Temperature: 28.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 11.684 V
Readiness: 0110 0101
   Part No SW: 02E 300 050 J    HW: 02E 927 770 AD
   Component: GSG DSG         082 1409
   Revision: 05108020    Serial number: 00001007111167
   Shop #: WSC 04940 001 00001
   VCID: 196FCA2D359337D3B5D-804C
   Revision: 00H11001
   Coding: 0021122
   VCID: 73B3D885F7BFAD835F1-8026
   Part No SW: 1K0 907 044 DE    HW: 1K0 907 044 DE
   Component: ClimatronicPQ35 130 1213
   Revision: 00130023    Serial number: 00000000000000
   VCID: 6D87CEFD919B7B73895-8038
00716 - Air recirculation Flap Positioning Motor (V113)
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
   Revision: 00H54000    Serial number: 00000007909076
   Coding: 178D8F214004150047140000001400000028770B5C000100000000000000
   Shop #: WSC 95855 999 79324
   VCID: 71BFD28D8DA39F93ADD-8024
   Component: Wischer 151207 021  0501
   Coding: 00038805
   Shop #: WSC 95855
                    Reset counter: 28
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.95 V
   Component: 6L AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D0A75GS
   Coding: 0013900
   Shop #: WSC 01269 785 00200
   VCID: 6C81C3F9AA81727B9EB-8038
   Subsystem 1 - Serial number: 6332MSME2C4342659
   Subsystem 2 - Serial number: 6342MSME37714844A
   Subsystem 3 - Serial number: 6352QSME4B163671G
   Subsystem 4 - Serial number: 6362QSME4947260FP
   Subsystem 5 - Serial number: 63727SME125B2425Z
   Subsystem 6 - Serial number: 63827SME126B57643
   Part No SW: 1K0 953 549 BG    HW: 1K0 953 549 BG
   Component: J0527           051 0100
   Coding: 0012122
   VCID: 78A9EFA9EED9CEDB6A3-802C
00886 - Turn Signal Switch (E2)
            014 - Defective
00895 - Cruise Control Switch (E45)
   Part No SW: 1K6 920 874 A    HW: 1K6 920 874 A
   Component: KOMBIINSTRUMENT VDD 1216
   Revision: V0002000    Serial number: VWX7Z0GD3NC9GI
   Coding: 0007303
   Shop #: WSC 01287 785 00200
   VCID: 313F128D4D23DF93EDD-8064
   Revision:   H07 01    Serial number: 121207F2000159
   Coding: ED811F060012020000
   VCID: 303917894629D69BE23-8064
   Part No SW: 1K6 919 879     HW: 1K6 919 879
   Component: Kompass         001 0003
   Revision: 00001000    Serial number: 1225223T2BWB03
   VCID: 7DA7FEBDC1FBEBF3395-8028
   Component: IMMO            VDD 1216
   Component: Tuer-SG         006 1207
   Coding: 0001077
   VCID: 38292FA9AE590EDBAA3-806C
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.074 H08 1901
   Shop #: WSC 00000 028 00001
   VCID: 3537269DB94BF3B3B15-8060
   Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
   Coding: 939006885103281B0904058FB0080A0488BC00
   Coding: 0001076
   VCID: 392F2AAD955317D355D-806C
   Part No: 1T0 907 357
   Coding: 0000003
   VCID: 74B1DB99F2B1AABB46B-8020
   Part No SW: 1K0 035 180 M    HW: 1K0 035 180 M
   Component: Radio PM6       019 0035
   Revision: 00019000    Serial number: VWZ5Z7G2198199
   Coding: 0040401
   VCID: 2A0D05E160F5AC4B2C7-807E
End----------(Elapsed Time: 01:06, VBatt start/end: 12.9V/12.9V)-----------
Thanks in advance for your help solving what part to change or what to track down regarding my signals and cruise control.
Bruce
Near Philadelphia, PA, USA
Hi and thanks for a great first post.
If you look at the report, there are three things that I think are related to your turn signals and the cruise control. As I don't know this car, I am assuming the turn signals and the cruise control are on two different stalks.
What I see is that something is not right with the wiring in the steering column. The steering angle sensor and both stalks are not working. That would lead me to want to investigate what is going on with that steering column. Did you try replacing or modifying the steering wheel? Was the car in some minor crash that affected the steering column?
Look to that area... look at wiring... go to erWin and download the wiring diagrams. i think this is going to be an old fashion chase the wires kind of repair. I doubt all three of those components failed.
Maybe others here will have more ideas.
KenMacG
Oakfield, NS, CA
C?ID=384933
Thanks Bruce. I'll have to download the wiring diagram.
The signal and cruise are on the same stalk, along with the high beams (high beams still work). The code for steering angle sensor seems to happen whenever the battery is disconnected on my MK6 GTI and goes away after I drive 100 yards; I was thinking that was the same thing on this car.
Possibly worth noting; the 4 way flashers work.
I found this scan from August when the signals first stopped working. There are a few notes I added in for possible solutions; disregard or tell me I'm wrong, lol. What I'm really after is figuring out these signals. Thanks again all:)
Saturday,29,August,2020,18:40:50:43089
Mileage: 187640km-116594mi   Repair Order:
VIN: WVWFV71K58W214236   Mileage: 187640km-116594miles
               P0456 - 001 - Very Small Leak Detected - Intermittent - MIL ON
                    Fault Status: 10100001
                    Mileage: 185659 km
                    Time: 02:08:57
                    RPM: 2730 /min
                    Load: 21.2 %
                    Speed: 110.0 km/h
                    Temperature: 74.0°C
                    Temperature: 21.0°C
                    Voltage: 13.462 V
http://wiki.ross-tech.com/wiki/index.php/16840/P0456/001110
Check fuel cap and evap system N80 valve
                    Mileage: 185758 km
                    Time: 03:50:27
                    RPM: 1795 /min
                    Load: 43.1 %
                    Speed: 47.0 km/h
                    Temperature: 74.0°C
                    Temperature: 33.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.462 V
http://wiki.ross-tech.com/wiki/index.php/18613/P2181/008577
Failed at 74C...  probably thermostat sticking open?
001090 - EVAP Emission Control Sys
               P0442 - 001 - Small Leak - Intermittent
                    Fault Status: 00100001
                    Mileage: 186049 km
                    Time: 21:06:01
                    RPM: 2036 /min
                    Load: 25.1 %
                    Speed: 82.0 km/h
                    Temperature: 65.0°C
                    Temperature: 20.0°C
                    Voltage: 13.081 V
               P0299 - 002 - Control Range Not Reached - MIL ON
                    Fault Status: 11100010
                    Mileage: 187045 km
                    Time: 23:44:43
                    RPM: 2760 /min
                    Load: 58.8 %
                    Speed: 94.0 km/h
                    Temperature: 74.0°C
                    Temperature: 30.0°C
                    Voltage: 13.335 V
http://wiki.ross-tech.com/wiki/index.php/16683/P0299/000665
                    Mileage: 187315 km
                    Time: 00:08:10
                    RPM: 852 /min
                    Load: 14.9 %
                    Temperature: 63.0°C
                    Temperature: 24.0°C
                    Voltage: 12.954 V
               P1643 - 001 -
                    Fault Frequency: 19
                    Mileage: 187416 km
                    Temperature: 14.0°C
                    Temperature: 16.0°C
                    Voltage: 11.811 V
http://wiki.ross-tech.com/wiki/index.php/18051/P1643/005699
Will be fixed when cruise is fixed
   Revision: 00H11001
   Coding: 0021122
   Coding: 00038805
   Shop #: WSC 95855
   Coding: 0013900
   Coding: 0012122
            014 - Defective
02413 - Switch for Selector Lever Position P Lock (F319)
00194 - Ignition Key Removal Lock
http://wiki.ross-tech.com/wiki/index.php/00895
https://www.autotitre.com/forum/Seat/Altea/FORUM-Seat-Altea-Seat-Altea-Xl-Seat-Toledo.-25020p1125.htm
http://wiki.ross-tech.com/wiki/index.php/02413
http://wiki.ross-tech.com/wiki/index.php/00194
   Coding: 0007303
   Coding: 0001077
   Coding: 0001076
   Coding: 0000003
   Coding: 0040401
End----------(Elapsed Time: 01:04, VBatt start/end: 13.1V/12.8V)-----------
MartinsX
Riga, Latvia
C?ID=268515
Those:
   Coding: 0012122
            014 - Defective
are for 95% because of faulty turn/cruise stalk. Very common for MK5.
Stay away from cheap aftermarket replacement - they may be already faulty while in package... Better used OE part.
This should solve turn signal problem.
But, cruise control may still not work, if some of fault codes in ECU are active in current driving cycle...
KenMacG
Oakfield, NS, CA
C?ID=384933
Hi MartinsX, I heard it was a common thing and I already replaced the stalk with a brand new OEM unit... nothing changed unfortunately. What's the other 5% chance, lol. Starting to think it may be the J527 - Steering Column Electronic Systems Control Module; but I honestly don't know.
MartinsX
Riga, Latvia
C?ID=268515
Ok, next questions:
Is the replacement part correct part number? The same as old part or direct replacement according ETKA or PL24 or dealers parts department?
Is it correctly installed? Maybe one contact pin is bent or broken during replacement? Removal/installation of J527 unit and connectors to it is a bit tricky for first time :D
What does MVB 001/1 in 0x16 show when moving stalk in left/right/middle positions (turn signal commands)?
What does MVB 004/1 and 004/2 in 0x16 show when pressing/releasing/moving through positions CCS buttons?
KenMacG
Oakfield, NS, CA
C?ID=384933
Thanks again MartinsX
Replacement part is the exact same number; I got it from the dealer. I just took the whole thing apart and double checked.
Also looks like the pins on J527 are all good.
0x16-001/1 = Not Oper. (when activated)
0x16-001/2 = Activated (when activated)
0x16-001/3 = Activated (when activated)
0x16-001/4 = Stage Int. (when set to intermittent)
0x16-004/1 = ON (when on)
0x16-004/2 = Delay/Stored Off/accel (down/normal/up positions of ccs buttons)
Drove the car up and down the driveway and all the lights on the dash went off. Here's the latest scan
Wednesday,14,October,2020,20:33:40:43089
                    Mileage: 185659 km
                    Time: 02:08:57
                    RPM: 1473 /min
                    Load: 25.5 %
                    Speed: 59.0 km/h
                    Temperature: 73.0°C
                    Temperature: 22.0°C
                    Voltage: 13.589 V
                    Mileage: 185758 km
                    Time: 03:50:27
                    RPM: 3232 /min
                    Load: 59.6 %
                    Speed: 110.0 km/h
                    Temperature: 75.0°C
                    Temperature: 28.0°C
                    Voltage: 12.446 V
                    Mileage: 187045 km
                    Time: 23:44:43
                    RPM: 2760 /min
                    Load: 58.8 %
                    Speed: 94.0 km/h
                    Temperature: 74.0°C
                    Temperature: 30.0°C
                    Voltage: 13.335 V
                    Mileage: 187315 km
                    Time: 00:08:10
                    RPM: 852 /min
                    Load: 14.9 %
                    Temperature: 63.0°C
                    Temperature: 24.0°C
                    Voltage: 12.954 V
               P1643 - 001 -
                    Temperature: 13.0°C
                    Temperature: 15.0°C
                    Voltage: 11.303 V
   Revision: 00H11001
   Coding: 0021122
   Coding: 00038805
   Shop #: WSC 95855
   Coding: 0013900
   Coding: 0012122
            014 - Defective
   Coding: 0007303
   Coding: 0001077
   Coding: 0001076
   Coding: 0000003
   Coding: 0040401
                    Fault Status: 00101011
                    Reset counter: 27
                    Mileage: 187875 km
                    Time: 00:28:36
End----------(Elapsed Time: 01:05, VBatt start/end: 12.9V/12.6V)-----------
MartinsX
Riga, Latvia
C?ID=268515
Coding of J527 looks correct:
0?xxxxx: Vehicle Type
0 = Normal
0x?xxxx: Transmission
1 = Automatic Transmission
0xx?xxx: Steering Wheel
2 = 3/4-Spoke Steering Wheel with Multifunction without Cruise & Voice Control
0xxxx?x: Board Computer / Cruise Control System (CCS)
2 = w/o Board Computer and with Cruise Control System (CCS)
0xxxxx?: Rear Wiper
2 = Rear Wiper installed
This shows J527 does not "see" turn signal switch positions.
Stalk is not switching contacts inside it (faulty stalk) or J527 internal circuit is faulty.
I don't have WD handy now, You could check Yourself what pins are involved and measure with DVOM does resistance changes in different stalk positions. Note - stalk has internal resistors in series for different positions, not only ON/OFF contacts and positions are recognized by resistance measurements.
P.S. If You have some experience with PCB repair/soldering, You may want to open J527 and check if pins or traces from pins does not have "cold soldering", micro-cracks or some other damage.
KenMacG
Oakfield, NS, CA
C?ID=384933
Awesome. I'm getting really good at taking the air bag out, lol. I'm taking the parts to work and I'll check them out. Thanks so much MartinsX
KenMacG
Oakfield, NS, CA
C?ID=384933
Okay, the investigation continues. The resistance changes when moving the signal stalk (2 kOhm, 0 kOhm, 0.8 kOhm) when cycling the signal.
The circuit board looks like the ground pin for the signal is a bit black, but it has continuity to the main ground out of J527.
What's next? Thanks All!
MartinsX
Riga, Latvia
C?ID=268515
If cleaning of "suspicious" ground pin does not help, I think next step is to replace J527...
KenMacG
Oakfield, NS, CA
C?ID=384933
I cleaned off the suspicious ground pin and dabbed a bit of solder on it along with the other pin for the cruise control.
Good news, for about 5 minutes it worked as long as the cruise control switch was off. Then it started indicated right signal at rest position... guess my J527 is now officially toast, lol. Good news is it's definitely the J527 causing my issues.
So these j527 are expensive brand new; I was thinking about grabbing one at the local scrap yard and taking my chances. This is my cheapo car so I'm really not looking to throw lots of money at it. Now to google which one I need, lol. Thanks for all your help!
MartinsX
Riga, Latvia
C?ID=268515
Better call dealer or ask someone with PL24 account to check by VIN. Those modules had a lot of p/n changes/suppersessions. And several versions exist, according additional equipment (MFSW etc.). Not all modules can be fitted to Your exact car with full functionality.
Good news are that those were used in all MK5 based cars - Golf5, Jetta, Touran etc. ;)
KenMacG
Oakfield, NS, CA
C?ID=384933
Right on. Do you mean call my buddies at the dealer to check vins on the scrapyard cars to make sure they have compatible modules?
I was thinking I would just find the MK5 that has DSG and paddles and start with that one. The part number is right on the bottom of the module so once the lower trim is off you can see it.
Is there something I'm missing other than my way is super manually intensive?
I really appreciate all the assistance by the way; this is awesome!
MartinsX
Riga, Latvia
C?ID=268515
Module with different partnumber may fully fit to Your car, if it is one of suppersession chain.
BTW does the p/n printed on Your module match the one in autoscan?
KenMacG
Oakfield, NS, CA
C?ID=384933
Lots of options at the scrapyard. Yes those numbers match my actual module.
I’ve found 4 that are the same number, but different letters at the end.
CP
CD
AP
BF
think any of those will work?
The dealer says only BG or BK will work...
MartinsX
Riga, Latvia
C?ID=268515
Dealer may be true...
I can confirm or disagree it later tonight.
Or someone else may chime in with his knowledge ;)
MartinsX
Riga, Latvia
C?ID=268515
I can confirm that. BG is Your current module, it is superseded by BK
Older MY versions with all the same functions are G and AK, those are superseded by BK, too.
Are they fully compatible with exactly Your car and will all other modules in car co-operate without bugs or glitches with those older version J527 - no one knows... If You can get one cheap, You can try.
Is the HW of G or AK compatible with BG or BK SW and can they be reflashed - I don't now, maybe some of forum's retrofits section guru's can comment such idea.
KenMacG
Oakfield, NS, CA
C?ID=384933
This rabbit hole is getting deep. I'm learning so much and having fun. I only searched golfs and Jettas yesterday. I'll probably go back and look at the Tiguans, sportwagons and any EOS they may have.
On that big chart of modules what is exactly interchangeable? I assume if it's LIN 1.3 it has to be a module that is LIN 1.3? If SW doesn't match, maybe I can update that? I would consider not being able to use the steering wheel functions to pass inspection; hell, I'd even consider putting in a different steering wheel if it got me up and running again. They only want 25 Canadian dollars for the used modules so I can definitely get one to try and then throw it out if I can't make it work. I'd really like to just find a BG or BK.
Do I need to put this question up in the retrofit section?
Honestly I was afraid to post on here as I figured it would be way over my head; but all of you have made it easy and understandable. Thanks all!
