New User with MK7.5 Digital Cluster Swap Issues
burntherabbit
Elkton, MD, USA
H11-2H
2019 GTI Rabbit Edition
I did the digital cluster/cockpit retrofit, on a vehicle that also needed an MIB2 retrofit.
The radio works, cluster works, however I keep getting a code for U015500 (throwing a CEL).
My current gateway hardware: 3Q0907530AA / 3Q0907530C
Gateway software: version 5366
@burntherabbit :Hi.
hmm....... in the vast wide world of possible reasons for the error - alas, the information provided in your post only restricts the probable causes slightly!
Much better way to hone-in on an answer is if you post-up a copy of FULL (meaning unedited) auto-scan for the car using the latest VCDS software -please
see here
burntherabbit
Elkton, MD, USA
H11-2H
Sorry for the super late response- been working some OT & haven't had a chance to get into it.
VIN: 3VW5T7AU1KM010914   License Plate:
Mileage: 44475km-27635mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 05 08 09 13 15 17 19 29 2B 32 39 3C 42 44 4B 52 5F A9
          D6 D7
VIN: 3VW5T7AU1KM010914   Mileage: 44475km-27635miles
29-Left Light -- Status: Malfunction 0010
A9-Struct. Borne Sound -- Status: Malfunction 0010
Address 01: Engine (J623-DKFA)       Labels: None
   Part No SW: 5G0 906 259 Q    HW: 06K 907 425 J
   Component: R4 2.0l TFSI  H13 0005
   Revision: --H13---
   Coding: 091900122424002F1000
   Shop #: WSC 47809 004 1048576
   ASAM Dataset: EV_ECM20TFS0205G0906259Q 001006
   ROD: EV_ECM20TFS0205G0906259Q.rod
   VCID: 3C21373926E3EC7B4EB-8068
17178 - Implausible Data Received from ESP Control Module
          U0416 00 [032] - -
19868 - No Communication with Instrument Cluster
          U0155 00 [175] - -
                    Fault Frequency: 42
                    Mileage: 42220 km
                    Date: 2020.08.19
                    Time: 00:00:42
                    Engine speed: 0.00 /min
                    Coolant temperature: 73 ∞C
                    Intake air temperature: 54 ∞C
                    Voltage terminal 30: 12.363 V
                    Engine: operating status: ES
                    ECU_STATE: ENG_STOP
                    Engine oil temperature: 99.0 ∞C
                    Time since engine start: 0.0 s
                    T_ES: 0 min
                    Cruise control switch actuation-Main switch: not activated
                    Cruise control switch actuation-Setting: not activated
                    Cruise control switch actuation-Activation: not activated
                    Cruise control switch actuation-Accelerate: not activated
                    Cruise control switch actuation-Decelerate: not activated
                    Cruise control switch actuation-Cancel: not activated
                    Cruise control switch actuation-Main switch hardware: not activated
                    Cruise control switch actuation-Limit button: not activated
                    Cruise control switch actuation-Main switch CAN: not activated
                    Cruise control switch actuation-Large increment: not activated
                    T_AST_SAE: 0 s
   Part No SW: 5Q0 614 517 DR    HW: 5Q0 614 517 BM
   Component: ESC           H45 0108
   Revision: 00000000    Serial number: 53278000000138
   Coding: 01FA6BA15021096C4080020160C76880D60A90024006163610435051D0894B0B0000000012121212B835351919323200
   Shop #: WSC 01383 790 50316
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 04518FD91E9354BB76B-8050
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0501819761
   Coding: 132C0C0623
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 43D34CC55B1D93830F1-8016
   Part No SW: 5GM 907 426 G    HW: 5GM 907 426 G
   Component: AC Manuell    H03 2001
   Revision: 00001K05
   Coding: 00020004200110000000000000000006
   VCID: 4CC167F976435CFBFEB-8018
   Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
   Part No SW: 5Q0 937 087 BA    HW: 5Q0 937 087 BA
   Component: BCM PQ37BOSCH 036 0265
   Revision: --------    Serial number: C86413121803S2
   Shop #: WSC 00066 790 00075
   ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
   ROD: EV_BCMBOSCH_019.rod
   VCID: 7BA3F425636D2B43071-802E
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    181026  043 0551
   Serial number: 97022066181106134310
   Subsystem 2 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  050 0105
   Serial number: S5Y18M11D27H06M28S52
   Coding: 00A8DD
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 521 M    HW: 5Q1 953 569
   Component: Lenks.Modul  H03 0170
   Serial number: 0300050120190C202356
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Coding: 2D00008101FFC728949C810500401600000000000000000004
   Shop #: WSC 00066 790 00392
   VCID: 44D14FD95E1394BB36B-8010
   Serial number: 003GCR0ANVF8
   VCID: 47CB58D56F25BFA3D39-8012
   Occupant Detection:
   Serial number: IBH00000000000AUZ11.
   Coding: 30305A
   Subsystem 2 - Part No SW: -----------    HW: 480 003 110 18
   Serial number: 35700000000DE719553T
   Subsystem 3 - Part No SW: -----------    HW: 480 003 110 18
   Serial number: 3580000000017289253A
   Subsystem 4 - Part No SW: -----------    HW: 480 400 208 18
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001B729F261285E6
   Subsystem 5 - Part No SW: -----------    HW: 480 400 109 18
   Component: SideSensor_Pr  004 6149
   Serial number: 35200010A2B7DBA4E52E
   Subsystem 6 - Part No SW: -----------    HW: 480 400 312 18
   Component: FrontSensor_D  003 6149
   Serial number: 3550001AD2DA6D71452E
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 312 18
   Component: FrontSensor_P  003 6149
   Serial number: 3560001AD2DA6D72227G
   Part No SW: 5G1 920 791 A    HW: 5G1 920 791 A
   Component: KOMBI         409 3197
   Coding: 0BBD21122980CF0502886B295000000000000000
   Shop #: WSC 03600 003 1048576
   VCID: 2A0D0161DC7762CB2C7-807E
          U1110 00 [008] - -
          [BAP_TEL_0x28 keine Kommunikation]
                    Fault Frequency: 58
                    Reset counter: 175
                    Mileage: 42220 km
                    Date: 2020.08.19
                    Time: 00:25:48
16776996 - Databus
          [FCW_01 keine Kommunikation]
                    Reset counter: 88
                    Mileage: 42221 km
                    Date: 2020.08.19
                    Time: 16:32:34
   Serial number: 30111800841065
   Coding: 0101000830085900FB00002B080F00000001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E85CD71201F4EEBB0F-803A
   Component: 0-00-0d-00-04
   Subsystem 2 - Part No SW: 5G0 959 442 AD    HW: 5G0 959 442 AD  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0052
   Serial number: 29180002520280018435
   Coding: 28FFFF
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
0033 - Supply voltage
          [Supply voltage - lower limit exceeded]
                    Reset counter: 139
                    Mileage: 43170 km
                    Date: 2020.08.25
                    Time: 20:01:32
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H07 0021
   Serial number: 18000352616009
   Shop #: WSC 00066 790 00082
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 313F160DF1A11113EDD-8064
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 P    HW: 0CQ 907 554 P
   Component: Quersperre    H52 8043
   Serial number: HA1-00014.08.18
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   VCID: 52FD798194670A0BB47-8006
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Serial number: 0500737361
   Coding: 01011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D273A3D3DF9E573795-8068
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0081
   Serial number: 0502453677
   Coding: 010111
   Part No SW: 5Q4 959 593 M    HW: 5Q4 959 593 F
   Component: TSG FS        006 0247
   Serial number: 42038833802235
   Coding: 003E13200000040000000000
   VCID: 4FFB70F5875567E39B9-801A
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000001448439
   Coding: 011000
          B1487 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 138
                    Mileage: 42220 km
                    Date: 2020.08.19
                    Time: 00:00:05
1114115 - Window Regulator; Rear Driver Side
          B131F 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 141
                    Mileage: 42419 km
                    Date: 2020.08.19
                    Time: 22:16:07
Address 44: Steering Assist
   Component: FCM MQB Low   002 0345
   Serial number: 07111800841006
   Coding: 000000050900210A01110F00030000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 3537221D05C93D33B15-8060
   Part No SW: 5Q4 959 592 M    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0247
   Serial number: 46038833404326
   VCID: 4EC56DF1805F6EEB90F-801A
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000001434331
   Coding: 091000
                    Reset counter: 138
                    Mileage: 42220 km
                    Date: 2020.08.19
                    Time: 00:00:05
   Part No SW: 3Q0 035 876 A    HW: 3Q0 035 876 A
   Component: MU-S-NS-US    840 0755
   Coding: 02731002FF00000051220001001808009F0503D401200105C6
   Shop #: WSC 00046 000 00000
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 323D1901F4A72A0B947-8066
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  H51 8130
   Serial number: VWZ6ZJV0686640
   Subsystem 2 - Part No SW: 3G0 919 866 BB    HW: -----------
   Component: NAR 2017  --- 0525
0513 - Rear Right Treble Speaker
          B1068 13 [009] - Open Circuit
          [Hochtonlautsprecher Kanal 1: Unterbrechung (AC-Diagnose)]
                    Reset counter: 88
                    Mileage: 42221 km
                    Date: 2020.08.19
                    Time: 16:32:37
                    Voltage terminal 30: 13.0 V
0528 - Rear Left Treble Speaker
          B1066 13 [009] - Open Circuit
          [Hochtonlautsprecher Kanal 4: Unterbrechung (AC-Diagnose)]
                    Reset counter: 88
                    Mileage: 42221 km
                    Date: 2020.08.19
                    Time: 16:32:37
0009 - Antenna for Satellite Radio
          B10F4 13 [009] - Open Circuit
                    Reset counter: 88
                    Mileage: 42221 km
                    Date: 2020.08.19
                    Time: 16:32:34
                    Voltage terminal 30: 13.2 V
                    SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
                    SDARS_tuner_status_2-Audio Signal: Not available
                    SDARS_tuner_status_2-Antenna current: 24 mA
                    SDARS_tuner_status_2-Reception quality: No_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 07
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 07
   Part No SW: 5G0 907 159 G    HW: 4H0 907 159 A
   Serial number: 181012203252
0006 - Actuator for Structural Accoustics
          P193A 00 [009] - Open Circuit
                    Fault Frequency: 13
                    Reset counter: 136
                    Mileage: 42221 km
                    Date: 2020.08.19
                    Time: 16:32:34
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 392F2E2D29D1D95355D-806C
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxRKEBODVW481.rod
End----------(Elapsed Time: 01:46, VBatt start/end: 12.3V/12.5V)-----------
