BCM2 Coding
S4Allroad
Toronto, Canada
C?ID=415231
Hello everybody. I apologise for the noobish way of writing. I armed myself with HEX-NetPro and decided to do some coding to my swapped 2014 Allroad (everything from a 2014 S4).
I am trying to code BCM2 that now resides in the Allroad to close the assisted trunk lid. Opening the lid works no problem but when I code the assisted lid in 46-Central Conv. Byte 6 it returns "Coding rejected. Error 31".
From what I've read it's quite possible that the BCM2 from the S4 does not support assisted lid. Is there a way to find out what's in the module. And also is there a way to take the Allroad module and program it to work with the rest of the S4 modules?
Thank you
G
P.S. I did not post a complete scan because I am embarrassed of the way the car looks and is full with codes. It's literally in peaces. I just started it for a few seconds this weekend but the interior is everywhere.
South Molton, UK
Don't worry about the number of fault codes in the scan, we've almost certainly seen worse :facepalm:
We really do need to see the Auto-Scan to know what HW & SW is in the modules to be able to answer your questions.
S4Allroad
Toronto, Canada
C?ID=415231
Monday,12,October,2020,13:59:43:41760
VCDS Version: 20.4.2.0 (x64)  HEX-NET2 CB: 0.4527.4
Dealer/Shop Name: Best Buy Auto Inc
Workshop Code: 198 01983 001983
VIN: WAUFGCFL1EA065561   License Plate:
Chassis Type: FL-AU48 (8R0)
Scan: 01 02 03 05 08 09 14 15 16 17 19 22 36 42 44 46 52 53 56 5F
          62 6C 6D 72 A9
04-Steering Angle -- Status: Sporadic communication error 1000
05-Acc/Start Auth. -- Status: Malfunction 1010
08-Auto HVAC -- Status: Cannot be reached 1100
14-Susp. Elect. -- Status: Not registered 0011
17-Instruments -- Status: Malfunction 1010
22-AWD -- Status: Not registered 0011
36-Seat Mem. Drvr -- Status: Cannot be reached 1100
44-Steering Assist -- Status: Malfunction 1010
46-Central Conv. -- Status: Malfunction 1010
5F-Information Electr. -- Status: Cannot be reached 1100
6C-Back-up Cam. -- Status: Not registered 0011
A9-Struct. Borne Sound -- Status: Not registered 0001
Address 01: Engine (J623-CGXC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 8K5 907 551 F    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0002
   Revision: --H07---
   Coding: 0A250034052600060000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30TFS0218K5907551F 001002
   ROD: EV_ECM30TFS0218K5907551F.rod
   VCID: 3924467689D3A0C355D-806C
7888 - Implausible Data Received from Steering Angle Sensor Module (G85)
          U0428 00 [037] - -
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 12:32:12
                    Engine speed: 0.00 /min
                    Coolant temperature: 15 °C
                    Intake air temperature: 17 °C
                    Voltage terminal 30: 12.085 V
                    Engine speed: actual: 0 /min
                    MAF_ENVD: 0.00000 mg/stroke
                    Coolant temperature (unfiltered): 15.00 °C
                    Engine: operating status: ES
                    Battery voltage: 11.578125 V
                    Vehicle speed: actual: 0 km/h
6056 - No Communications with HVAC Control Module (J301)
          U0164 00 [037] - -
                    Mileage: 147744 km
                    Coolant temperature: 14 °C
                    Intake air temperature: 15 °C
                    Voltage terminal 30: 11.679 V
                    T_AST_ENVD: 0.00 s
                    Gear: 0
6068 - No Communication with Instrument Cluster
          U0155 00 [036] - -
                    Mileage: 147744 km
                    Voltage terminal 30: 11.780 V
                    T_AST_ENVD: 0.00 s
                    Gear: 0
                    Battery voltage: 11.679688 V
6082 - Steering Column Control Module
          U0212 00 [036] - No Communications
                    Mileage: 147744 km
                    T_AST_ENVD: 0.00 s
                    Gear: 0
                    Battery voltage: 11.070313 V
6078 - No Communications with Steering Angle Sender (G85)
          U0126 00 [036] - -
                    Mileage: 147744 km
                    T_AST_ENVD: 0.00 s
                    Gear: 0
                    Battery voltage: 11.171875 V
20248 - No Communications with HVAC Control Module (J301)
          U0164 00 [037] - -
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 00:00:15
                    Voltage terminal 30: 11.577 V
                    T_AST_ENVD: 0.00 s
                    Gear: 0
                    Battery voltage: 11.476563 V
Readiness: 1110 1101
   Part No SW: 8K5 927 156 D    HW: 0B5 927 156 K
   Component: 0B5 30TFSINAR H02 0002
   Revision: --H02---
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMDL501021 001015
   ROD: EV_TCMDL501021.rod
   VCID: 3A26597A8CD5ABDB5C7-806E
8007 - No Communications with Steering Angle Sender (G85)
          U0126 00 [038] - -
          [Lost Communication With Steering Wheel Angle Sensor Control Module]
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 00:00:11
                    Engine speed: 0 /min
                    Transmission input speed: 0 /min
                    Engine torque: -52 Nm
                    Transmission fluid temperature: 17 °C
                    Accelerator position: 0.0 %
                    Clutch status: Beide Kupplungen offen
                    Voltage terminal 30: 11.900 V
                    Voltage_5V_CAN_pressuresensors-Param to DOP: 4.916 V
20363 - No Communications with HVAC Control Module (J301)
          U0164 00 [039] - -
          [Lost Communication With Air Conditioning Control Module]
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 00:00:11
8015 - Steering Column Control Module
          U0212 00 [038] - No Communications
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 00:00:11
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
   Part No SW: 8K9 907 379 N    HW: 8K9 907 379 N
   Component: ESP8 quattro  H09 0020
   Coding: 0E150001
   Shop #: WSC 06335 000 00000
   VCID: 4DCC02A62DDB2C63E95-8018
8 Faults Found:
00493 - ESP-Sensor Unit (G419)
                    Fault Status: 01100101
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:09
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x0002
                    Hex Value: 0xC88B
                    Hex Value: 0x0000
                    Fault Frequency: 17
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:09
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x0023
                    Hex Value: 0x2A8B
                    Hex Value: 0x0000
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:09
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x0015
                    Hex Value: 0x098B
                    Hex Value: 0x0000
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:09
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x000A
                    Hex Value: 0xE38B
                    Hex Value: 0x0000
01794 - Control Module - Incorrect Chassis (VIN) Number
            000 - - - MIL ON
                    Fault Status: 11100000
                    Fault Frequency: 22
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:13
                    Hex Value: 0x0000
                    Hex Value: 0x0282
                    Hex Value: 0x0039
                    Hex Value: 0x138B
                    Hex Value: 0x0000
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:49:54
                    Hex Value: 0x0040
                    Hex Value: 0x0782
                    Hex Value: 0x0010
                    Hex Value: 0x108C
                    Hex Value: 0x0000
                    Fault Frequency: 17
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:09
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x0023
                    Hex Value: 0x2A8B
                    Hex Value: 0x0000
                    Fault Frequency: 17
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:09
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x0023
                    Hex Value: 0x2A8B
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 HM    HW: 8K0 907 064 GM
   Component: BCM2 2.0      H13 0641
   Coding: 0D824040000000000000
   VCID: 0256E19AA405231B447-8056
   Subsystem 1 - Part No SW: 8K0 959 754 BB    HW: 8K0 959 754 BB
   Serial number: 0813000137130018
   Serial number: 0213000329563016
00183 - Interior Access/Start Authorization Antenna 1 (R138)
                    Fault Status: 00101011
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:39:55
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:49:54
                    Fault Frequency: 9
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 14:19:43
02811 - Control Module for Electronic Steering Column Lock (J764)
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 14:19:43
00166 - Access/Start Authorization Switch (E415)
                    Reset counter: 178
03026 - Enabling Terminal 15:
                    Fault Status: 00101001
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 14:55:32
Address 08: Auto HVAC
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00000681395602
   Coding: 26000096863CAFE0290048C300003D0D0F9CD708A2090221000008004400070200040030000000
   VCID: 7AA6997ACCD56BDB1C7-802E
   Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: MITSUBA310114  H18 0461
   Serial number: 1401280710666
   Coding: 004577
   Subsystem 2 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 3 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 8E69C017000000000001
20 Faults Found:
                    Fault Frequency: 37
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:11
02234 - Right Headlight Power Output Stage (J668)
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:11
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:11
01229 - A/C Humidity Sensor (G260)
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:11
02258 - Door Opener Transmitter
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:11
01543 - Parking Aid Warning Chime (H15)
                    Fault Status: 01101001
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:12
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                    Fault Status: 01101100
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:13
00910 - Indicator Lamp for Emergency Flashers (K6)
                    Fault Status: 00101100
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:13
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:16
02659 - Power Output Stage for Right Headlight (J668); Incorrectly Coded
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 19:10:57
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 19:12:50
03189 - Bulb for Side Marker Light; Front Right
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 14:09:36
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 14:09:39
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 14:19:44
                    Reset counter: 178
                    Mileage: 147744 km
                    Reset counter: 138
                    Mileage: 1048574 km
01800 - Light Switch (E1)
                    Reset counter: 138
                    Mileage: 1048574 km
03280 - Switch Position of Light-Switch Knob
                    Fault Status: 01101000
                    Reset counter: 138
                    Mileage: 1048574 km
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 00:00:17
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 00:00:19
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 8R0 907 364 C    HW: 8K0 907 364
   Component: DAEMPFUNGS-SG H09 0054
   Revision: 00000000    Serial number: 26091301570002
   Coding: 010181
   VCID: 3A26597A8C55ABDB5C7-806E
01769 - Sensor for Vehicle Leveling; Front Right (G289)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Frequency: 17
                    Reset counter: 229
                    Mileage: 146540 km
                    Date: 2020.05.21
                    Time: 15:34:13
03262 - Comfort Restriction
                    Fault Frequency: 58
                    Reset counter: 138
                    Mileage: 146540 km
                    Date: 2020.05.21
                    Time: 15:34:13
                    Error Code: 2
                    Bin. Bits: 00000000
00140 - Front Right Body Acceleration Sensor (G342)
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.06.24
                    Time: 15:49:53
03263 - Functional Restriction
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.06.24
                    Time: 15:49:53
                    Error Code: 7
                    Bin. Bits: 00000000
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:08:37
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 00000000 00000001
                    Fault Status: 00101101
                    Fault Frequency: 14
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:21:30
   Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
   Component: AirbagVW-AU10 H47 0610
   Serial number: 003KJDB0KRJ3
   Coding: 30454435473030303030554A304C384B3053
   Shop #: WSC 39886 001 1048576
   VCID: 4AC609BADC353B5BCC7-801E
   Serial number: 6334MSME434E1809G
   Serial number: 6344MSME434E15027
   Serial number: 6352QSME12414F48G
   Serial number: 6362QSME144210482
   Serial number: 63732SME67401158V
   Serial number: 63832SME63403E7A4
25 Faults Found:
          B1006 1B [137] - Resistance Too High
                    Mileage: 147744 km
                    Date: 2020.06.08
                    Time: 05:19:04
9442587 - Igniter for battery interrupt
          B1015 1B [136] - Resistance Too High
                    Mileage: 147744 km
                    Date: 2020.06.08
                    Time: 05:19:04
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 1B [137] - Resistance Too High
                    Mileage: 147744 km
                    Date: 2020.08.14
                    Time: 00:01:13
          B1000 1B [137] - Resistance Too High
                    Mileage: 147744 km
                    Date: 2020.06.08
                    Time: 05:19:04
9437467 - Igniter 2 for Driver's Airbag
          B1001 1B [137] - Resistance Too High
                    Mileage: 147744 km
                    Date: 2020.06.08
                    Time: 05:19:04
9437723 - Igniter for Passenger's Airbag
          B1002 1B [137] - Resistance Too High
                    Mileage: 147744 km
                    Date: 2020.06.08
                    Time: 05:19:04
9437979 - Igniter 2  for Passenger's Airbag
          B1003 1B [137] - Resistance Too High
                    Mileage: 147744 km
                    Date: 2020.06.08
                    Time: 05:19:04
9442075 - Driver's Belt Force Limiter Igniter
          B1013 1B [137] - Resistance Too High
                    Mileage: 147744 km
                    Date: 2020.06.08
                    Time: 05:19:04
9442331 - Passenger's Belt Force Limiter Igniter
          B1014 1B [137] - Resistance Too High
                    Mileage: 147744 km
                    Date: 2020.08.14
                    Time: 00:01:13
9440027 - Driver's side; side-airbag igniter
          B100B 1B [137] - Resistance Too High
                    Mileage: 147744 km
                    Date: 2020.08.14
                    Time: 00:01:13
9439771 - Front Passenger's Side Airbag Igniter
          B100A 1B [137] - Resistance Too High
                    Mileage: 147744 km
                    Date: 2020.08.14
                    Time: 00:01:13
9438491 - Igniter for Driver head airbag
          B1005 1B [137] - Resistance Too High
                    Mileage: 147744 km
                    Date: 2020.06.08
                    Time: 05:19:04
9438235 - Igniter for Front passenger's Head Curtain Airbag
          B1004 1B [137] - Resistance Too High
                    Mileage: 147744 km
                    Date: 2020.06.08
                    Time: 05:19:04
9439515 - Seat Belt Tensioner Igniter; rear; driver's side
          B1009 1B [137] - Resistance Too High
                    Mileage: 147744 km
                    Date: 2020.06.08
                    Time: 05:19:04
9439259 - Igniter for Seat Belt Tensioner; Rear Passenger's Side
          B1008 1B [137] - Resistance Too High
                    Mileage: 147744 km
                    Date: 2020.06.08
                    Time: 05:19:04
9441819 - Safety belt tensioner igniter; rear; center
          B1012 1B [137] - Resistance Too High
                    Mileage: 147744 km
                    Date: 2020.06.08
                    Time: 05:19:04
9444097 - Front Passenger's Front Airbag Crash Sensor
          B101B 01 [136] - Electrical Failure
                    Mileage: 147744 km
                    Date: 2020.06.24
                    Time: 15:50:13
9444115 - Front Passenger's Front Airbag Crash Sensor
          B101B 15 [136] - Open or Short to Plus
                    Mileage: 147744 km
                    Date: 2020.06.24
                    Time: 17:10:52
9444137 - Front Passenger's Front Airbag Crash Sensor
          B101B 29 [136] - Signal Implausible
                    Mileage: 147744 km
                    Date: 2020.06.24
                    Time: 15:49:49
13697280 - Component Protection
          U1101 00 [137] - Active
                    Fault Frequency: 32
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 17:55:59
9444373 - Safety belt switch - driver side
          B101C 15 [137] - Open or Short to Plus
                    Mileage: 147744 km
                    Date: 2020.08.14
                    Time: 00:01:12
9444629 - Safety belt switch - passenger side
          B101D 15 [137] - Open or Short to Plus
                    Mileage: 147744 km
                    Date: 2020.08.14
                    Time: 00:01:12
9444885 - Driver's seat position sensor
          B101E 15 [137] - Open or Short to Plus
                    Mileage: 147744 km
                    Date: 2020.08.14
                    Time: 00:01:12
9445141 - Passenger's seat position sensor
          B101F 15 [137] - Open or Short to Plus
                    Mileage: 147744 km
                    Date: 2020.08.14
                    Time: 00:01:12
9447424 - Front crash data stored
          B1028 00 [137] - -
                    Mileage: 147744 km
                    Date: 2020.06.08
                    Time: 05:18:59
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862NBH0015W
   Coding: 000017
   VCID: 48C233B2C2B9C94BDA3-801C
                    Fault Frequency: 34
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:13
                    (no units): 29.0
                    Text: 1D83FFFFFFFFFFFFFF
                    Ign. Timing: 32482.5 °ATDC
                    Raw, Index/Key Err.: 255 255 255
01426 - Controls in Steering Wheel (E221)
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:13
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 14:19:44
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 02:15:29
Address 17: Instruments
   Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0060
   Revision: 1Y080030    Serial number: 3041Y14205017F
   Coding: 80C303FF00
   VCID: 4AC609BADCB53B5BCC7-801E
   Serial number: 8277501403
16 Faults Found:
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:17
                    Bin. Bits:    10111
                    Voltage: 11.20 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
01964 - Control Module for Seat & Steering Column Memory (J136)
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:17
                    Bin. Bits:    10111
                    Voltage: 11.20 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
02252 - Generator
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:38:16
                    Bin. Bits:    10111
                    Voltage: 11.20 V
                    Count: 6
                    Bin. Bits:    10000
01304 - Radio
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:38:16
                    Bin. Bits:    10111
                    Voltage: 11.20 V
                    Count: 6
                    Bin. Bits:    10000
03158 - Control Module for Information Electronics 1 (J794)
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:38:16
                    Bin. Bits:    10111
                    Voltage: 11.20 V
                    Count: 6
                    Bin. Bits:    10000
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:38:16
                    Bin. Bits:    10111
                    Voltage: 11.20 V
                    Count: 6
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:49:57
                    Bin. Bits:    10011
                    Voltage: 11.30 V
                    Count: 6
                    Text: FFB1742C00028100
                    Text: 0000000000000000
                    Raw, Form. N/A: 000 000 000
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 19:00:05
                    Bin. Bits:    10011
                    Voltage: 11.20 V
                    Count: 6
                    Text: 0200000000000000
                    Fault Frequency: 15
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 13:24:44
                    Bin. Bits:    10111
                    Voltage: 11.40 V
                    Count: 6
00456 - Control Module for Access and Start Control (J518)
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 14:19:45
                    Bin. Bits:    10000
                    Voltage: 12.10 V
                    Count: 11
                    Bin. Bits:    10000
                    Time: 25.40 s
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 14:19:45
                    Bin. Bits:    10000
                    Voltage: 12.10 V
                    Count: 11
                    Bin. Bits:    10000
                    Time: 25.40 s
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 15:01:57
                    Bin. Bits:    10000
                    Voltage: 11.30 V
                    Count: 10
                    Bin. Bits:    10000
                    Time: 25.40 s
                    Reset counter: 138
                    Bin. Bits:    00000
                    Voltage: 11.40 V
                    Count: 7
                    Bin. Bits:    10000
                    Time: 0.90 s
                    Reset counter: 178
                    Bin. Bits:    10000
                    Voltage: 11.40 V
                    Count: 7
                    Bin. Bits:    10000
                    Time: 4.90 s
                    Reset counter: 178
                    Bin. Bits:    10000
                    Voltage: 11.80 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 0.40 s
00384 - Optical Databus
                    Reset counter: 138
                    Bin. Bits:    10000
                    Voltage: 12.00 V
                    Count: 9
                    Bin. Bits:    00000
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H14 0100
   Serial number: 002609130001493
   VCID: 2F30782E47977E73FB9-807A
0059 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [137] - -
          [ESP - Steuergerät nicht verfügbar DRC_CAN_ESP_01_SYS_ST]
                    Fault Frequency: 38
                    Reset counter: 229
                    Mileage: 147744 km
                    Date: 2020.06.08
                    Time: 05:19:00
0303 - No Communication with ABS Brake Control Module
          U0121 00 [137] - -
          [ESP - Steuergerät keine Kommunikation DTC_CAN_ESP_09_NO_COM]
                    Reset counter: 229
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 17:55:52
0243 - Steering Column Control Module
          U0212 00 [008] - No Communications
          [Lenkradwinkelsensor keine Kommunikation DTC_CAN_LWI_NO_COM]
                    Reset counter: 14
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 17:57:42
0267 - Steering angle sensor
          B1168 4A [137] - Incorrect component(s) installed
                    Fault Frequency: 22
                    Reset counter: 229
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:21:22
0252 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [12V Unterspannung CAN Spannungsdiagnosegrenze DTC_CAN_LOW_VOLTAGE]
                    Reset counter: 14
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 19:00:17
Address 36: Seat Mem. Drvr
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0305
   Coding: 011C13204E00410001
   VCID: 56FEEDCA180D6FBB58F-8002
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.08.14
                    Time: 00:01:11
   Part No SW: 8K0 909 144 G    HW: 8K0 909 144 B
   Component: RCEPS         H40 0508
   Revision: 00001000    Serial number: 0006289154
   Coding: 100000000001
   Shop #: WSC 06334 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008015
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 353C4A46A5CB44A3B15-8060
3158276 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Botschaftsausfall des Lenkwinkelsensors]
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 00:00:14
                    Write only channel
4205828 - Steering angle sensor
          B1168 54 [137] - Missing Calibration / Basic Setting
                    Fault Frequency: 16
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 19:00:19
                    Write only channel
5258753 - Steering End Stops Not Learned
          C10AC F0 [137] - Unknown Error Elaboration
          [Lenkungsendanschläge nicht angelernt]
                    Fault Frequency: 67
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.08.14
                    Time: 00:00:16
                    Write only channel
   Revision: 00002001    Serial number: 0317546532
   Coding: 0106023A00FA509580B0023200000000
   Shop #: WSC 06324 123 12345
   Subsystem 2 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS150  H08 0043
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J394 PS240  H08 0043
12 Faults Found:
02906 - Control Module for Sliding Roof; Rear (J392)
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 01:19:55
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 19:13:57
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 02:15:32
03233 - Controls for Garage Door Opener (E284)
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 00:00:14
03128 - Switch 1 for Sunroof
                    Fault Frequency: 24
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 15:01:57
01514 - Regulator for Roof
                    Fault Frequency: 18
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 15:01:57
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 15:01:57
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 00:10:22
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 14:19:43
01512 - Control Module for Sliding Roof
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 14:19:43
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 14:19:43
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 01:09:17
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0305
   VCID: 55FCEAC6050B64A3515-8000
                    Reset counter: 138
                    Mileage: 1048574 km
   Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
   Component: EPB-4         H01 0004
   Revision: --------    Serial number: 30000000113876
   ROD: EV_ParkiBrake_AU48.rod
131840 - Switch for Electric Parking Brake
          C100C 13 [137] - Open Circuit
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 14:50:44
                    Voltage terminal 30: 11.3 V
                    Internal Fault ID: 34
                    Network management state: Ready for busstat
                    Function light in parking brake button: OFF
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: On
                    Terminal 15 status: OFF
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: No enabling
                    Status of parking brake button: Open circuit
                    Status ParkingBrake left: Open
                    Status ParkingBrake right: Open
197120 - Indicator Lamp in Controls
          C1014 14 [009] - Short to Plus
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 14:52:36
                    Internal Fault ID: 57
                    Function light in parking brake button: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
463360 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FC_SIGNAL_AB_GURTSCHLOSS_FA_ERROR_VALUE]
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:20
                    Voltage terminal 30: 11.2 V
                    Internal Fault ID: 103
                    Yellow warning lamp: OFF
                    Terminal 15 status: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    Internal Parking Brake state: static
463616 - Function Restriction due to Faults in Other Modules
          U1113 00 [137] - -
          [FC_SIGNAL_ESP_QBIT_LAENGSBESCHLEUNIGUNG_QBIT]
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:20
                    Internal Fault ID: 185
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
Address 56: Radio
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H07 0305
   Coding: 010C13204000210001
   VCID: 59E4E6F6691340C375D-800C
   Revision: --H08---    Serial number: 525PA8-J38901G
   Coding: 1000007
   VCID: 38224372BE59B9CBAA3-806C
03006 - Back-up Camera System not calibrated
                    Reset counter: 138
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 00:00:12
                        Reverse OFF
                    Count: 3
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 00:00:16
                        Reverse OFF
                    Count: 3
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8K9 827 851 C    HW: 8K9 827 851 C
   Component: J605  Master  H53 0330
   Revision: --------    Serial number: 8K9827851C
   VCID: 3E2E556A907D87FB60F-806A
   Subsystem 1 - Part No SW: 8K9 827 852 C    HW: 8K9 827 852 C
   Component: J756  Slave  H53 0330
   Serial number: 8K9827852C
   Component: TSG HR        H07 0305
Address A9: Struct. Borne Sound        Labels: 4H0-907-159.clb
   Part No SW: 8K0 907 159     HW: 4H0 907 159 A
   ASAM Dataset: EV_SoundActuaGen2AU64X 002005
   ROD: EV_SoundActuaGen2AU64X_002.rod
   VCID: 72B6B15A9425139B547-8026
End----(Elapsed Time: 02:55, VBatt start/end: 11.6V/11.6V. VIgn 11.7V)-----
S4Allroad
Toronto, Canada
C?ID=415231
Tuesday,13,October,2020,20:47:14:41760
Mileage: 147740km-91801mi   Repair Order:
          62 6C 6D 72 A9
VIN: WAUFGCFL1EA065561   Mileage: 147740km-91801miles
   Revision: --H07---
   Coding: 12250034052600060000
   Shop #: WSC 01983 198 01983
          U0428 00 [032] - -
                    Fault Frequency: 12
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 12:32:12
                    Battery voltage: 11.375000 V
          U0164 00 [036] - -
                    Fault Frequency: 11
                    Mileage: 147744 km
                    Coolant temperature: 18 °C
                    Intake air temperature: 19 °C
                    Voltage terminal 30: 12.695 V
                    T_AST_ENVD: 0.00 s
                    Gear: 0
                    Battery voltage: 12.695313 V
          U0155 00 [032] - -
                    Mileage: 147744 km
                    T_AST_ENVD: 0.00 s
                    Gear: 0
          U0212 00 [032] - No Communications
                    Mileage: 147744 km
                    T_AST_ENVD: 0.00 s
                    Gear: 0
          U0126 00 [032] - -
                    Mileage: 147744 km
                    T_AST_ENVD: 0.00 s
                    Gear: 0
          U0164 00 [036] - -
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 00:00:15
                    Voltage terminal 30: 12.593 V
                    T_AST_ENVD: 0.00 s
                    Gear: 0
                    Battery voltage: 12.593750 V
   Revision: --H02---
          U0126 00 [036] - -
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 00:00:11
          U0164 00 [038] - -
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 00:00:11
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 00:00:11
   Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
   Coding: 29150A01
   VCID: 0944F6B69933704305D-805C
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 04:50:42
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x001A
                    Hex Value: 0x098D
                    Hex Value: 0x0000
01324 - Control Module for All Wheel Drive (J492)
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 04:50:42
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x000E
                    Hex Value: 0x508D
                    Hex Value: 0x0000
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:39:55
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:49:54
                    Fault Frequency: 16
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 14:19:43
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 14:19:43
                    Reset counter: 178
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 14:55:32
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01140220142852
   Coding: 6480208000
   VCID: 392446768953A0C355D-806C
10 Faults Found:
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.13
                    Time: 20:26:11
00359 - Left Front Upper Body Outlet Temperature Sensor (G385)
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.13
                    Time: 15:45:24
                    Temperature: 17.0°C
                    Voltage: 12.20 V
00360 - Front Right Upper Body Outlet Temperature Sensor (G386)
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.13
                    Time: 15:45:24
                    Temperature: 17.0°C
                    Voltage: 12.20 V
00797 - Sunlight Photo Sensor (G107)
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.13
                    Time: 15:45:24
                    Temperature: 17.0°C
                    Temperature: 17.0°C
                    Output: 300 W
                    Output: 300 W
03037 - Rear Temperature Selection Potentiometer (G538)
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.13
                    Time: 15:45:24
                    Voltage: 12.20 V
                    Voltage: 4.90 V
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.13
                    Time: 15:45:26
                    Temperature: 17.0°C
                    Temperature: 19.0°C
                    Absolute Pres.: 1.0 bar
                    Current: 0.000 A
                    Temperature: 16.0°C
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.13
                    Time: 15:45:34
01230 - Left Footwell Vent Temperature Sensor (G261)
                    Fault Status: 00101010
                    Reset counter: 178
                    Temperature: 18.0°C
                    Voltage: 12.00 V
01231 - Right Footwell Vent Temperature Sensor (G262)
                    Reset counter: 178
                    Temperature: 18.0°C
                    Voltage: 12.00 V
00818 - Sensor for Evaporator Outlet Temperature (G263)
                    Reset counter: 178
                    Temperature: 18.0°C
                    Absolute Pres.: 2.6 bar
                    Voltage: 12.00 V
                    Current: 0.000 A
   Subsystem 1 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
   Serial number: 22267101
   Coding: 02005D
   Subsystem 2 - Part No SW: 8K0 941 531 AS    HW: 8K0 941 531 AS
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001402145306
   Subsystem 3 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
20 Faults Found:
                    Fault Frequency: 63
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:11
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:11
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:11
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:11
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:11
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:12
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:13
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:13
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:16
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 19:10:57
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 19:12:50
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 14:09:36
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 14:09:39
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 14:19:44
                    Reset counter: 178
                    Mileage: 147744 km
                    Reset counter: 178
                    Mileage: 1048574 km
                    Reset counter: 178
                    Mileage: 1048574 km
                    Reset counter: 178
                    Mileage: 1048574 km
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.13
                    Time: 18:05:23
00908 - Control Module for Wiper Motor
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.13
                    Time: 18:05:19
   Coding: 010181
                    Fault Frequency: 17
                    Reset counter: 229
                    Mileage: 146540 km
                    Date: 2020.05.21
                    Time: 15:34:13
                    Fault Frequency: 74
                    Reset counter: 138
                    Mileage: 146540 km
                    Date: 2020.05.21
                    Time: 15:34:13
                    Error Code: 2
                    Bin. Bits: 00000000
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.06.24
                    Time: 15:49:53
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.06.24
                    Time: 15:49:53
                    Error Code: 7
                    Bin. Bits: 00000000
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:08:37
                    Fault Frequency: 16
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:21:30
25 Faults Found:
                    Mileage: 147744 km
                    Date: 2020.06.08
                    Time: 05:19:04
                    Mileage: 147744 km
                    Date: 2020.06.08
                    Time: 05:19:04
                    Mileage: 147744 km
                    Date: 2020.08.14
                    Time: 00:01:13
                    Mileage: 147744 km
                    Date: 2020.06.08
                    Time: 05:19:04
                    Mileage: 147744 km
                    Date: 2020.06.08
                    Time: 05:19:04
                    Mileage: 147744 km
                    Date: 2020.06.08
                    Time: 05:19:04
                    Mileage: 147744 km
                    Date: 2020.06.08
                    Time: 05:19:04
                    Mileage: 147744 km
                    Date: 2020.06.08
                    Time: 05:19:04
                    Mileage: 147744 km
                    Date: 2020.08.14
                    Time: 00:01:13
                    Mileage: 147744 km
                    Date: 2020.08.14
                    Time: 00:01:13
                    Mileage: 147744 km
                    Date: 2020.08.14
                    Time: 00:01:13
          B1005 1B [136] - Resistance Too High
                    Mileage: 147744 km
                    Date: 2020.06.08
                    Time: 05:19:04
          B1004 1B [136] - Resistance Too High
                    Mileage: 147744 km
                    Date: 2020.06.08
                    Time: 05:19:04
          B1009 1B [136] - Resistance Too High
                    Mileage: 147744 km
                    Date: 2020.06.08
                    Time: 05:19:04
          B1008 1B [136] - Resistance Too High
                    Mileage: 147744 km
                    Date: 2020.06.08
                    Time: 05:19:04
                    Mileage: 147744 km
                    Date: 2020.06.08
                    Time: 05:19:04
                    Mileage: 147744 km
                    Date: 2020.06.24
                    Time: 15:50:13
                    Mileage: 147744 km
                    Date: 2020.06.24
                    Time: 17:10:52
                    Mileage: 147744 km
                    Date: 2020.06.24
                    Time: 15:49:49
                    Fault Frequency: 47
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 17:55:59
                    Mileage: 147744 km
                    Date: 2020.08.14
                    Time: 00:01:12
                    Mileage: 147744 km
                    Date: 2020.08.14
                    Time: 00:01:12
                    Mileage: 147744 km
                    Date: 2020.08.14
                    Time: 00:01:12
                    Mileage: 147744 km
                    Date: 2020.08.14
                    Time: 00:01:12
          B1028 00 [137] - -
                    Mileage: 147744 km
                    Date: 2020.06.08
                    Time: 05:18:59
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372MIP001SK
   Coding: 000037
   VCID: 44DA2782FE91ED2B36B-8010
                    Reset counter: 0
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.12
                    Time: 17:19:01
                    Fault Status: 00100101
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.12
                    Time: 17:39:10
                    (no units): 62.0
                    Text: 3E89FFFFFFFFFFFFFF
                    Inj. On Time: 650.25 ms
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.13
                    Time: 13:00:40
   Part No SW: 8K0 920 931 Q    HW: 8K0 920 931 Q
   Component: KOMBIINSTR.   H35 0564
   Revision: 00000000    Serial number: ZAD5H01AE
   Coding: 8BA711009A010008020000
   VCID: 3C2A5F62866195EB4EB-8068
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:15
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:15
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:16
   Coding: 80C303FF00
16 Faults Found:
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:17
                    Bin. Bits:    10111
                    Voltage: 11.20 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:17
                    Bin. Bits:    10111
                    Voltage: 11.20 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
02252 - Generator
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:38:16
                    Bin. Bits:    10111
                    Voltage: 11.20 V
                    Count: 6
                    Bin. Bits:    10000
01304 - Radio
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:38:16
                    Bin. Bits:    10111
                    Voltage: 11.20 V
                    Count: 6
                    Bin. Bits:    10000
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:38:16
                    Bin. Bits:    10111
                    Voltage: 11.20 V
                    Count: 6
                    Bin. Bits:    10000
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:38:16
                    Bin. Bits:    10111
                    Voltage: 11.20 V
                    Count: 6
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:49:57
                    Bin. Bits:    10011
                    Voltage: 11.30 V
                    Count: 6
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 19:00:05
                    Bin. Bits:    10011
                    Voltage: 11.20 V
                    Count: 6
                    Fault Frequency: 30
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 13:24:44
                    Bin. Bits:    10111
                    Voltage: 11.40 V
                    Count: 6
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 14:19:45
                    Bin. Bits:    10000
                    Voltage: 12.10 V
                    Count: 11
                    Bin. Bits:    10000
                    Time: 25.40 s
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 14:19:45
                    Bin. Bits:    10000
                    Voltage: 12.10 V
                    Count: 11
                    Bin. Bits:    10000
                    Time: 25.40 s
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 15:01:57
                    Bin. Bits:    10000
                    Voltage: 11.30 V
                    Count: 10
                    Bin. Bits:    10000
                    Time: 25.40 s
                    Reset counter: 178
                    Bin. Bits:    00000
                    Voltage: 11.40 V
                    Count: 7
                    Bin. Bits:    10000
                    Time: 0.90 s
                    Reset counter: 178
                    Bin. Bits:    10000
                    Voltage: 11.40 V
                    Count: 7
                    Bin. Bits:    10000
                    Time: 4.90 s
                    Reset counter: 178
                    Bin. Bits:    10000
                    Voltage: 11.80 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 0.40 s
                    Reset counter: 178
                    Bin. Bits:    10000
                    Voltage: 12.00 V
                    Count: 9
                    Bin. Bits:    00000
          U1017 00 [008] - -
                    Fault Frequency: 46
                    Reset counter: 14
                    Mileage: 147744 km
                    Date: 2020.06.08
                    Time: 05:19:00
          U0121 00 [008] - -
                    Reset counter: 14
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 17:55:52
                    Reset counter: 14
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 17:57:42
          B1168 4A [008] - Incorrect component(s) installed
                    Fault Frequency: 28
                    Reset counter: 14
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:21:22
          U1400 00 [008] - -
                    Reset counter: 14
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 19:00:17
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.08.14
                    Time: 00:01:11
          U1111 00 [008] - -
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 00:00:14
                    Write only channel
          B1168 54 [008] - Missing Calibration / Basic Setting
                    Fault Frequency: 19
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 19:00:19
                    Write only channel
                    Fault Frequency: 123
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.08.14
                    Time: 00:00:16
                    Write only channel
   Component: GTO BF  H01 0080
   Serial number: 00000000000000741269
   Subsystem 4 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
12 Faults Found:
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 01:19:55
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 19:13:57
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.13
                    Time: 20:33:56
00830 - Convertible Top Control Module (J256)
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.13
                    Time: 19:09:01
02907 - Control Module for Roof Shade (J394)
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.13
                    Time: 20:34:46
                    Fault Frequency: 24
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 15:01:57
03219 - Access and Start Authorization
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.12
                    Time: 17:38:00
00926 - Terminal 30
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.12
                    Time: 17:38:00
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 14:19:43
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 14:19:43
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 14:19:43
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 01:09:17
                    Reset counter: 178
                    Mileage: 1048574 km
          C100C 13 [008] - Open Circuit
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 14:50:44
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
          C1014 14 [008] - Short to Plus
                    Fault Frequency: 9
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 14:52:36
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
          U1113 00 [009] - -
                    Reset counter: 138
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:20
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
          U1113 00 [008] - -
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.10
                    Time: 18:37:20
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
Address 56: Radio
   Coding: 1000007
                    Reset counter: 138
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 00:00:12
                        Reverse OFF
                    Count: 3
                    Reset counter: 178
                    Mileage: 147744 km
                    Date: 2020.10.11
                    Time: 00:00:16
                        Reverse OFF
                    Count: 3
   Component: SAS-GEN 2     H06 0005
   Serial number: 130927200976
End----------(Elapsed Time: 01:59, VBatt start/end: 13.0V/13.0V)-----------
This one is the most recent. I am now confident that all the wiring is correct and finished all the wire management - rewrapping and guiding wires through the right paths.
Any help on that module would be greatly appreciated. I would really love to have at least basic idea about these modules and coding processes.
Thank you
G
