RNS-MFD1 reverse camera
s0n0r
Romania
C?ID=359031
Hello everybody
I got a RNS MFD1 and I want to add a backup camera. Done all the connections, it even automatically switches to video when in reverse but...no video, just black screen.
I googled for info and ran over a video tutorial...saying that the head unit should be adapted on group 56 Radio, channel... from 0 to 1.
I'm no longer able to find that video again, as well as adaptation channels info for RNS MFD1.
The camera I'm using is 5N0827566D and the unit 3B0035191G
Any info is apreciated.
Thank you
South Molton, UK
We will definitely need to see a full unedited VCDS Auto-Scan of the vehicle you are fitting the camera to in order to suggest what coding and/or adaptation changes will be needed.
s0n0r
Romania
C?ID=359031
ok. As soon as my friends car will be available I will save and post a full auto-scan.
johnandbek
C?ID=402988
My son's car (MK6 TDI) is having the same issue with a retrofitted back-up camera (in the badge). When we contacted the point of sale, they said that if the screen changes on the RNS when shifting into reverse, and changes back to a traditional display when out of reverse, your coding is correct and that it is a power issue to the camera (either 12v or the reverse light trigger). We haven't solved our problem either BTW.
s0n0r
Romania
C?ID=359031
I just managed to do a full scan as the car came back from bodywork repairs.
s0n0r
Romania
C?ID=359031
Thursday,22,October,2020,20:31:14:04407
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
VCDS Version: 20.4.2.0  HEX-NET CB: 0.4513.4
Mileage: 238040km-147911mi   Repair Order:
Chassis Type: 1J - VW Golf/Bora IV (1998 > 2006)
          76
   Mileage: 238040km-147911miles
   Part No: 06A 906 032 BN
   Component: 2.0l R4/2V      G   3487
   Coding: 00031
   Shop #: WSC 31414
   VCID: 6B96C5AE1B94C7DED6-5160
Readiness: 0000 1000
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-A.lbl
   Part No: 1C0 907 379 F
   Component: ESP ALLRAD MK60     0103
   Coding: 0022534
   Shop #: WSC 31414 000 00000
   VCID: 2D120BB6B50009EE88-5184
   Part No: 3B1 907 044 C
   Component: CLIMATRONIC     C 1.0.0
   Coding: 01000
   Shop #: WSC 31414
   VCID: 210AE786A9D8DD8E3C-51A8
   Part No: 6Q0 909 605 A
   Component: 27 AIRBAG VW5  01   0006
   Coding: 12855
   Shop #: WSC 31414
   VCID: 352223D60D50412EF0-4B3C
   Part No: 1J0 907 487 B
   Component: Lenkradelektronik   0001
   Coding: 00008
   Shop #: WSC 31414
   VCID: 302C12C2F2326406A3-51F2
   Part No: 1J5 920 845 AX
   Component: A4-KOMBIINSTR. VDO V11
   Coding: 21112
   Shop #: WSC 10179
   VCID: 054293161D3011AE20-5160
   Subsystem 1 - Part No: IMMO
   Component: IDENTNR: VWZ7Z0F4288031
   IMMO-IDENTNR: VWZ7Z0F4288031
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 10179
   VCID: 70ACD2C232B22406E3-5160
Address 22: AWD        Labels: 02D-900-554.lbl
   Part No: 02D 900 554 D
   Component: HALDEX LSC  ECC     0011
   VCID: 210AE786A9D8DD8E3C-4B1E
Address 37: Navigation        Labels: 3B0-919-887.lbl
   Part No: 3B0 919 887 H
   Component: Navigation     BNO 0102
   Coding: 00001
   Shop #: WSC 00028
   VCID: 373E29DE175CB33EE2-4B00
   Part No: 1J0 959 799 AH
   Component: 2K Zentral-SG Komf. 0001
   Coding: 04097
   Shop #: WSC 31414
   VCID: 04448E12160A28A637-4B1E
   Subsystem 1 - Part No: 1J1959801C
   Component: 2K Tőrsteuerger. FS0002r
   Subsystem 2 - Part No: 1J1959802D
   Component: 2K Tőrsteuerger. BF0002r
   Subsystem 3 - Part No: 1J4959811C
   Component: 2K Tőrsteuerger. HL0002r
   Subsystem 4 - Part No: 1J4959812C
   Component: 2K Tőrsteuerger. HR0002r
Address 56: Radio        Labels: 3B0-035-186.lbl
   Part No: 3B0 035 186 D
   Component: Radio          BNO 0102
   Coding: 02407
   Shop #: WSC 00028
   VCID: 200CE282A2D2D48633-4B00
00853 - Loudspeaker(s); Rear
            36-00 - Open Circuit
End----------(Elapsed Time: 04:14, VBatt start/end: 13.6V/13.6V)-----------
Adaptation Channel 001:
Stored value 1928
Adaptation Channel 002:
Stored value 45
Adaptation Channel 003:
Stored value 0
Adaptation Channel 008:
Stored value 0
s0n0r
Romania
C?ID=359031
Did you recode the RNS (510 I presume) after camera instalation? You need to "tell" the unit it's got a backup camera connected.
s0n0r
Romania
C?ID=359031
Full VCDS Auto-Scan posted.
siLc
Tallinn, Estonia
C?ID=330192
How did you convert the 5N0827566 camera's RGB signal to be suitable for the antique RNS-MFD/RNS-D?
s0n0r
Romania
C?ID=359031
I didn't have to. Actually I was afraid it would be the RGB version, as the ones I already installed (retrofited) on my Golf mk5 and VW T5 Multivan but I had a surprise when got it, the video cable Fakra connector had only two wires instead of four, that indicates it should be a composite video signal. Therefore I'm lost because I don't know what's the reason for black screen only, is it the MFD that needs adaptation, is it the camera or both? :) The problem is that the designated car for this retrofit is not mine, so for every "step" I have to coordinate an availability day...
s0n0r
Romania
C?ID=359031
OK. Since no suggestions so far, It seems that I have to figure it out all by myself.
Thank you anyway.
