A7 C7.5 Compact RVC Retrofit
Phoenixx2
England
C?ID=124988
Good Evening all,
Apologies if this may have already been covered...
Recently fitted a RVC compact camera 4S0 980 556 A, to my Audi A7 3.0T with MIB2 MMI.
Install went well and camera is working as expected on the screen.
When I come to carry out calibration I cannot get access to the basic settings? Security access 22351 reports an "Controller refused to send seed! Error 7F:Service not supported in active session"
Is this something anyone has come across before? Am i possibly missing a step to carry out calibration?
Carried out auto scan below..
Added additional info from advanced ID on the 6C module to the bottom of the auto scan if it helps.
Sunday,11,October,2020,19:31:51:05864
VCDS Version: 20.4.2.0 (x64)  HEX-NET2 CB: 0.4527.4
VIN: WAUZZZ4G4GN116630   License Plate: RY65
Mileage: 70705km-43934mi   Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 28 30 36 3B 42 44 46 52 53 55
          5F 62 6C 6D 72 82 85
VIN: WAUZZZ4G4GN116630   Mileage: 70705km-43934miles
Address 01: Engine (J623-CREC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G2 907 551 B    HW: 4H2 907 551 A
   Component: 3.0l V6 TFSI  H10 0001
   Revision: --H10---
   Coding: 1A2500340527010B3800
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TFS0214G2907551B 002001
   ROD: EV_ECM30TFS0214G2907551B_002.rod
   VCID: 2A0669F89C7E47DB2C7-807E
Readiness: 1010 0001
   Part No SW: 4G0 927 166 D    HW: 0B5 927 156 K
   Component: 0B5 30TFSIRdW H03 0009
   Revision: --H03---
   Coding: 100001
   ASAM Dataset: EV_TCMDL501021 001021
   ROD: EV_TCMDL501021.rod
   VCID: 2E0E65E8A0962BFBF0F-807A
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 44A69E43226579C29B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41D42E540108A4831DD-8014
   Part No SW: 4H0 907 064 GP    HW: 4H0 907 064 GP
   Component: BCM2 2.0      H37 0572
   Coding: 05BA6F4E000000000000
   VCID: 7DAC92A43DF00063395-8028
   Serial number: 2315000204963002
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 13111500041083
   Coding: 66A311783D0000
   VCID: 6398C4DCBBD4D6932F1-8036
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0311
   Revision: 15020001    Serial number: 00001213146801
   Coding: 0105C01550349FE041014087800018000F9DC30A2F080201800008946100130200400034030000
   VCID: 71B4BE9471A87403ADD-8024
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 150924  H38 0080
   Serial number:         151002074517
   Coding: 0045F7
   Serial number: 60939576
   Coding: 02006E
   Subsystem 3 - Part No SW: 4G0 941 531 BG    HW: 4G0 941 531 BG
   Component: E1 - LDS  H07 0044
   Serial number: 10 11 2015  00000275
   Component: EVLS-SG  H08 0300
   Serial number: WA121750000015675279
   Coding: 020300
   Serial number: 2F998AD7000000000001
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1007C3PX
   Coding: 30333046313130313235554A305234473853
   VCID: 3B285CBC63E4CE53471-806E
   Serial number: 3575HRB400Q551R0H9QN
   Serial number: 3585HRB400I551R08HG5
   Serial number: 3515JRB40513L83688KT
   Serial number: 3525JRB405V3JRS03OST
   Serial number: 3554VRB400U554Q2LI7-
   Serial number: 3564VRB400U554Q2H8T2
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90372OK7000K2
   Coding: 000434
   VCID: 382243B05252E54BAA3-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Serial number: 24 10 2015  D0065939
   Part No SW: 4G8 920 986 K    HW: 4G8 920 986 K
   Component: TBenGb        H11 0104
   Revision: 07001088    Serial number: 658250915596036
   Coding: 33A600020B432600010100
   ASAM Dataset: EV_RBD4K 004055
   ROD: EV_RBD4K_AU57.rod
   VCID: 40D22B500A02AD8B123-8014
   Part No SW: 4G8 907 468 F    HW: 4G8 907 468
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000002055273
   Coding: C0CD073018
   ASAM Dataset: EV_GatewPkoUDS 001028
   Serial number: 9732888303
   Voltage stabilizer:
   Serial number: 150905000000000000F1
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0112
   Serial number: 12111500041074
   Coding: 22
   VCID: 3D2C52A47DF0C063795-8068
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000082277
   Coding: 01010101000000000001000102
   VCID: 649AC7C0BE5AD1ABD6B-8030
   Revision: AA000000    Serial number: 00000171842404
   Coding: 00781B0000006001000001010101102030303232203232
   VCID: 77A0808C1FCC2A33639-8022
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA820AJRCT
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 363E4D8858C6133BB8F-8062
   Component: TSG FA        H03 0511
   Coding: 011C56034E21620002080402
   VCID: 47C0304C2FAC9AB3D39-8012
   Component: RCevo         H53 0202
   Revision: 00000002    Serial number: 0000353552
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A2659B86CDEF75B5C7-806E
   Revision: 00002001    Serial number: 0385834689
   Coding: 013B0E22A0B9B805C3300A0400030D470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177 A
   Component: Sensor, DWA  005 0002
   Subsystem 3 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS40.402  H03 0004
   Serial number: 0000FST000NHLG500000
   Coding: 901E02
   Subsystem 4 - Part No SW: 4G8 959 252 A    HW: 4G8 959 252
   Component: HSP-SG  H11 0031
   Serial number: WA122232000016854829
   Subsystem 5 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93658547
   Component: TSG BF        H03 0511
   VCID: 46DE3D4828A683BB28F-8012
   Part No SW: 4H0 907 801 L    HW: 4H0 907 801 A
   Component: EPB-4         H05 0017
   Revision: --------    Serial number: 00000002163345
   ASAM Dataset: EV_ParkiBrake 001029
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 31347E94B1A83403EDD-8064
   Coding: 05FE02202A130200
   VCID: 343A77804EBA012B86B-8060
   Subsystem 1 - Part No SW: 7PP 941 472 K    HW: 7PP 941 472 K  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 7570
   Coding: E02100
   Subsystem 2 - Part No SW: 7PP 941 472 K    HW: 7PP 941 472 K  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 7570
   Coding: E02100
   Matrix Headlamp Powermodule 1 Left:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0031
   Coding: E02100
   Matrix Headlamp Powermodule 1 Right:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0031
   Coding: E02100
Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 018     HW: 4G1 035 021 D
   Component: MU-H-LND-EU   051 0389
   Serial number: A733K0FB002289
   Coding: 017503010000000013111102000A00132F000CE7F1700100DF
   VCID: 5DECF2249DB0E063195-8008
   Subsystem 1 - Part No SW: V03 959 802 DD    HW: -----------
   Component: ECE 2018/2019  --- 0169
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9FY803E73
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G2 919 610 F    HW: 4G2 919 610 F
   Serial number: 90349OKG0000W
   Compact Disc Database:
   Component: Gracenote2  --- 1012
   Component: TSG HL        H03 0511
   Coding: 010814024021620002080002
   VCID: 49C4367439B86CC3C5D-801C
Address 6C: Back-up Cam. (J772)       Labels:| 4S0-980-556.clb
   Part No SW: 4S0 980 556 A    HW: 4M0 980 556 A
   Component: RVC Compact   H15 0201
   Coding: 0237060102002001000040
   ASAM Dataset: EV_CamSysRVRVCPANAAU57X 002003
   ROD: EV_CamSysRVRVCPANAAU57X_002.rod
   VCID: 392446B469D8FC4355D-806C
10489856 - No Basic Setting
          B2010 00 [009] - -
                    Reset counter: 219
                    Mileage: 70705 km
                    Date: 2020.10.11
                    Time: 19:25:06
                    passive
   Part No SW: 4G8 959 107 S    HW: 4G8 959 107 H
   Component: HDSG-Modul    H14 0049
   Revision: 11014001    Serial number: 308500974
   Coding: 0A3305C022
   ASAM Dataset: EV_HDSGAu573 001022
   ROD: EV_HDSGAu571.rod
   VCID: 45DC3A44152088A3215-8010
   Component: TSG HR        H03 0511
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 4G8 919 604 N    HW: 4G8 919 604 N
   Component: HeadUpDisplay H07 0306
   Coding: A20000
   ASAM Dataset: EV_HUDContiC7 001027
   ROD: EV_HUDContiC7.rod
   VCID: 3E2E55A870F6DB7B60F-806A
   Component: DPC-SG        H27 0081
   Coding: 60140000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C0A6FE0968A59EBDEB-8078
End----------(Elapsed Time: 02:14, VBatt start/end: 14.3V/14.4V)-----------
Control Module Part Number: 4S0 980 556 A
  Component and/or Version: RVC Compact   H15 0201
           Software Coding: 0237060102002001000040
            Work Shop Code: WSC 00000
Advanced Identification/FAZIT
     Identification: PS9-001
     Date: 18.07.18
     Manufacturer number: 0604
     Test stand number: 0747
Flash Status
     Programming Attempts(application): 1/0/0
     Programming Attempts(data): 3
     Successful Attempts(data): 3
     Flash Date: 12.09.20
     Flash Tool Code(data): 12345 123 12345
Misc.
     Hardware number: 4M0 980 556 A
     Workshop System Name: J772
     Equipment/PR Code: 00000000000000000000000A
     Dataset Number: 4GD909460E
     Dataset Version: 0005
     ASAM Dataset Revision: 002003
VCDS Info:
       Labels: 4S0-980-556.clb
Any help & direction apricated.
ghost
C?ID=139898
I never managed to get VCDS on calibration of RVC. Always had to use ODIS for that and works fine
