Golf 2 Abs
Myllis
Finland
C?ID=417674
Hello, another newbie here.
So, i have ATD pd engine, ecu and cluster from 2003 Golf installed to Golf mk2.
I bought VCDS recently and tried to check things are ok.
I cannot acces to 03-ABS Brakes "No response from controller".
I have CAN connected to ecu, cluster, obd port and abs module.
VCDS does not find CAN either.
I can acces for example to 01-engine and 17-Instruments.
Car has now mark20 ABS from some random golf, bought used, so that can fail too, but i doubt, because this project is made by me, so all fails are possible.
Does that abs communicate by k-line or does it really need that CAN?
Fuses and wires are checked several times.
          76
VIN: WVWZZZ1JZ4W049107   Mileage: 489440km-304123miles
Address 01: Engine        Labels: 038-906-019-AXR.lbl
   Part No: 038 906 019 KH
   Component: 1,9l R4 EDC G000SG  4901
   Coding: 00002
   Shop #: WSC 01266
   VCID: 678BBF338672F303F39-4B3C
19463 - Camshaft Position Sensor (G40)
            P3007 - 35-00 - No Signal
16725 - Camshaft Position Sensor (G40)
            P0341 - 00-00 - Implausible Signal
17571 - Fuel Temp Sensor (G81)
            P1163 - 35-10 - Open or Short to Plus - Intermittent
Readiness: 1 1 1 1 1
   Part No: 1J0 920 826 C
   Component: KOMBI+WEGFAHRSP VDO V20
   Coding: 00132
   VCID: 290FF90B50E6057325D-5160
   WVWZZZ1JZ4W049107     VWZ7Z0C7999914
7 Faults Found:
            30-00 - Open or Short to Plus
01128 - Immobilizer Pickup Coil (D2)
            35-00 - -
01176 - Key
            07-00 - Signal too Low
01177 - Engine Control Unit
            64-10 - Not Currently Testable - Intermittent
            49-00 - No Communications
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 01266
   VCID: 70B9D46FB3BC34BBA23-5160
End----(Elapsed Time: 05:26, VBatt start/end: 12.4V/12.3V. VIgn 0.0V)------
Viking
C?ID=151455
Try again, but post the complete (unedited or cut) Autoscan please.
Myllis
Finland
C?ID=417674
This is what it gives
Sunday,11,October,2020,21:16:00:62067
VIN: WVWZZZ1JZ4W049107   License Plate:
Mileage: 489440km-304123mi   Repair Order:
          76
   Coding: 00002
   Shop #: WSC 01266
   Coding: 00132
7 Faults Found:
            35-00 - -
01176 - Key
   Coding: 00006
   Shop #: WSC 01266
End----(Elapsed Time: 05:24, VBatt start/end: 13.4V/13.4V. VIgn 0.0V)------
An MK60 can go either way. If it is from an Mk.4 car, it will do diagnostic communications via K-Line. If it is from an Mk.5 car, then it will want to do diagnostic communications via CAN.
Myllis
Finland
C?ID=417674
That i know it is from mk4. So it should communicate via K-Line, but i do not understand why not.
Sorry, you said MK20. For some reason I had it in my mind that this was an MK60. MK20 is (to the best of my knowledge) always K-Line.
Double-check power, ground, and K-line connections to it.
