Hello, another newbie here.
So, i have ATD pd engine, ecu and cluster from 2003 Golf installed to Golf mk2.
I bought VCDS recently and tried to check things are ok.
I cannot acces to 03-ABS Brakes "No response from controller".
I have CAN connected to ecu, cluster, obd port and abs module.
VCDS does not find CAN either.
I can acces for example to 01-engine and 17-Instruments.
Car has now mark20 ABS from some random golf, bought used, so that can fail too, but i doubt, because this project is made by me, so all fails are possible.
Does that abs communicate by k-line or does it really need that CAN?
Fuses and wires are checked several times.
76
VIN: WVWZZZ1JZ4W049107 Mileage: 489440km-304123miles
Address 01: Engine Labels: 038-906-019-AXR.lbl
Part No: 038 906 019 KH
Component: 1,9l R4 EDC G000SG 4901
Coding: 00002
Shop #: WSC 01266
VCID: 678BBF338672F303F39-4B3C
19463 - Camshaft Position Sensor (G40)
P3007 - 35-00 - No Signal
16725 - Camshaft Position Sensor (G40)
P0341 - 00-00 - Implausible Signal
17571 - Fuel Temp Sensor (G81)
P1163 - 35-10 - Open or Short to Plus - Intermittent
Readiness: 1 1 1 1 1
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 826 C
Component: KOMBI+WEGFAHRSP VDO V20
Coding: 00132
VCID: 290FF90B50E6057325D-5160
WVWZZZ1JZ4W049107 VWZ7Z0C7999914
7 Faults Found:
30-00 - Open or Short to Plus
01128 - Immobilizer Pickup Coil (D2)
35-00 - -
01176 - Key
07-00 - Signal too Low
01177 - Engine Control Unit
64-10 - Not Currently Testable - Intermittent
49-00 - No Communications
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 01266
VCID: 70B9D46FB3BC34BBA23-5160
End----(Elapsed Time: 05:26, VBatt start/end: 12.4V/12.3V. VIgn 0.0V)------
