Touareg 7P Adaptive Air Suspension Reset
lee1234
C?ID=68622
Hi again.
2011 Touareg 7P UK Right Hand Drive.
Wife out in the Touareg 7P today when I get a call - 'I've got a warning light on. It says - Running gear - Workshop with a picture of a car with up and down arrows'. This is while she is towing a horse (only about 5 miles). She says nothing seems wrong so I say just take it nice and steady and I'll take a look when you get home.
When she gets home the car is pointing skyward sitting on the bump stops at the back. No issues with Module 34 since we got the car about 2 months ago.
First thing is a full scan which is included below. Here is snippet of the relevant section, module 34.
Address 34: Level Control (J197)       Labels:. 7P0-907-553.clb
   Part No SW: 7P0 907 553 K    HW: 7P0 907 553 K
   Component: PASM          H01 1110
   Revision: 00000000    Serial number: 00000110130690
   Coding: 14210000
   Shop #: WSC 00606 210 88440
   ASAM Dataset: EV_PASMConti 001004
   ROD: EV_PASMConti.rod
   VCID: 3F8D7966A6E2F67E2A-806A
0644 - Level control system
          C10D3 07 [008] - Mechanical Failure
                    Fault Frequency: 131
                    Reset counter: 1
                    Mileage: 690688 km
                    Date: 2037.02.05
                    Time: 06:41:06
                    Default: CA
                    Default: 8A
                    Default: 00
0610 - Sensor for Ride-Height
          C1048 07 [008] - Mechanical Failure
                    Reset counter: 1
                    Mileage: 692224 km
                    Date: 2037.02.30
                    Time: 18:53:06
                    Default: E9
                    Default: 83
                    Default: 00
0530 - Valve for Air-Spring Rear Left
          C103E 4B [008] - Over temperature
                    Reset counter: 1
                    Mileage: 692992 km
                    Date: 2037.02.30
                    Time: 31:21:06
                    Default: 43
                    Default: 83
                    Default: 00
0544 - Bleed Valve for Ride-Height
          C103B 4B [008] - Over temperature
                    Reset counter: 1
                    Mileage: 693248 km
                    Date: 2037.02.31
                    Time: 04:13:06
                    Default: 22
                    Default: 83
                    Default: 00
Cleared all codes, and drove back and forward a few times on the driveway, and then up and down the road, but no errors returned even though car remained way too low at the back.
Then I tried some of the Basic setting options, but nothing seemed to do anything. Nothing moved as far as I could tell. (That was probably not a good move, but hopefully a proper reset will sort whatever wrong things I did back to correct?)
Then I take a look under the back of the car and found a broken level sensor, so that is an easy fix. I have a replacement on its way.
But my question is what to do after I have fitted the replacement? I assume that I need to do some basic settings, but not sure what. I note that the module is UDS and I do not have HEX-V2 or HEX-NET. I do have HEX-USB+CAN.
Elsa just says - Reset adaptive suspension with the vehicle diagnosis system, testing and information system - VAS5051B.
I found the page below, but not sure if I can do these activities with my HEX-USB+CAN. Perhaps someone can confirm? Or point me to the right place of how to do setup after level sensor is replaced please with HEX-USB+CAN? Or do I need to quickly get my hands on a HEX-V2?
https://forums.ross-tech.com/index.php?threads/12737/
Thanks very much
Saturday,10,October,2020,13:19:54:40778
VCDS Version: 20.4.2.0 (x64)
VIN: WVGZZZ7PZBD04xxxx   License Plate:
Mileage: 121500km-75496mi   Repair Order:
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 32 34 42 46 52 53 56 5F
          62 65 69 72
VIN: WVGZZZ7PZBD04xxxx   Mileage: 121500km-75496miles
32-Differential Locks -- Status: Malfunction 0010
Address 01: Engine (J623-CASA)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P0 907 401     HW: 7P0 907 401
   Component: 3.0TDI EDC17  H17 0009
   Revision: 51H17---
   Coding: 296A4012233E01020000
   Shop #: WSC 59816 001 1048576
   ASAM Dataset: EV_ECM30TDI0117P0907401 002011
   ROD: EV_ECM30TDI0117P0907401.rod
   VCID: 6CD7FE2A8714BDE6DF-8038
18660 - Start interruption due to insufficient engine speed
          P151D 00 [032] - -
                    Mileage: 121192 km
                    Date: 2020.10.02
                    Time: 21:00:35
                    Engine speed: 803.00 /min
                    Normed load value: 19.2 %
                    Coolant temperature: 65 ∞C
                    Intake air temperature: 34 ∞C
                    Voltage terminal 30: 11.560 V
                    Unlearning counter according OBD: 26
5618 - Engine Off Timer Performance
          P150A 00 [096] - -
                    Mileage: 121452 km
                    Engine speed: 251.50 /min
                    Normed load value: 94.1 %
                    Intake air temperature: 18 ∞C
                    Voltage terminal 30: 10.460 V
                    Shut-off timer: last engine shut-off time: 18 s
                    Shut-off timer: last ECM after-run time: 17 s
                    Time since ignition off: 18 s
                    Shut-off timer: instrum panel counter: open circuit in term 30-Bits 0-7: 0
                    Terminal 15 status-Bits 0-7: 1
   Part No SW: 0C8 927 750 H    HW: 0C8 927 750 H
   Component: AL1000 AISIN  001 1885
   Coding: 001568
   Shop #: WSC 80093 222 69422
   ASAM Dataset: EV_TCMAL991031 001001
   ROD: EV_TCMAL991031_001_VW52.rod
   VCID: 31692F5E60B6100EAC-8064
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 K    HW: 7P0 907 379 A
   Component: MK25A         H36 0418
   Revision: --------    Serial number: 408810010EC010
   Coding: 4B6B13C30B282555D2F9C897D0D5A4507700
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_MK25AXT 007001
   ROD: EV_ESPMK25A00700.rod
   VCID: 45816B8EC43EACAE60-8010
   Part No SW: 4H0 907 064 AL    HW: 4H0 907 064 AL
   Component: BCM2 2.0      H24 0217
   Coding: 01B60000000000000000
   VCID: 73E5E556D22A621E1E-8026
   Subsystem 1 - Part No SW: 7P6 959 754 AA    HW: 7P6 959 754 AA
   Component: FBSTOUAREGIDG  H05 0051
   Serial number: 0511000006863003
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Component: J764 ELV MLB  H38 0044
   Serial number: 2311000064792009
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 AG    HW: 7P6 907 040 AG
   Component: Klima 2 Zonen H18 0613
   Coding: B626000890
   VCID: 79F9D77EF846184E54-802C
0243 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 129
                    Mileage: 121469 km
                    Date: 2020.10.10
                    Time: 07:29:45
   Part No SW: 4H0 907 063 L    HW: 4H0 907 063 D
   Component: BCM1 2.0      H12 0092
   Revision: 15012002    Serial number: 00000000983783
   Coding: 6900001181345D010005000300005F5F431D670807000241000000000000
   VCID: 31692F5E68B6100EAC-8064
   Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
   Component: WWS    110322  31  0020
   Serial number: 90243401110330185104
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 D    HW: 7P0 955 559 D  Labels: 8K0-955-559.CLB
   Component: RLFS  H09 0011
   Serial number: 10146184
   Coding: 035223
   Subsystem 3 - Part No SW: 7P6 941 431 B    HW: 7P6 941 431 B
   Component: E1 - LDS  H04 0031
   Serial number: 00000000001003110167
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475     HW: 7P6 919 475
   Component: PARKHILFE 8K  H03 0016
   Revision: --------    Serial number: 55901105901039
   Coding: 328501
   ASAM Dataset: EV_VW526ParkiAssis2 001008
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 55A1BBCE349E1C2E10-8000
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 B    HW: 7P0 959 655 B
   Component: VW10Airbag00K H05 0023
   Revision: --------    Serial number: 003JX0023TJM
   Coding: 00000000000000000000000000000000304B
   ROD: EV_AirbaVW10BPAVW526_001.rod
   VCID: 408F7A9ADB1C898653-8014
   Serial number: 3575LRB405D0CE32297L
   Serial number: 3585LRB405V0DGESAOMW
   Serial number: 3515RRB405D0H4DU4P7T
   Serial number: 3525RRB40650H1GGMP9T
   Serial number: 3555NRB405T0G2HUC0BX
   Serial number: 3565NRB405T0G2HU59B-
   Part No SW: 4H0 953 568 A    HW: 7P6 953 507
   Component: Lenks.Modul   H08 0007
   Revision: --------    Serial number: 90815KCL00014
   Coding: 000015
   Subsystem 1 - Part No SW: 7P6 959 542     HW: 7P6 959 542
   Component: E221__MFL-TAS  H03 0027
   Serial number: 0001087
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 981     HW: 7P6 920 981
   Component: Kombi         H13 0239
   Revision: 11240062    Serial number: 658220211593040
   Coding: 33273300B3002600010004
   ASAM Dataset: EV_KombiUDSRBVW526 001013
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 7AFBC872FD4013565D-802E
   Part No SW: 7P6 907 530 C    HW: 7P6 907 530 A
   Component: GW-CAN-L-MOST H08 5202
   Revision: --------    Serial number: 00000000118263
   Coding: 000D077500
   ASAM Dataset: EV_GatewVW526UDS 001006
   ROD: EV_GatewUDS_VW52.rod
   VCID: 387F127A83CCC146EB-806C
   Subsystem 1 - Part No SW: 7P0 915 181 A    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0140
   Serial number: 00000000005653000589
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 7PP 959 663 E    HW: 7PP 959 663 E
   Serial number: 11069001648011200181
   Part No SW: 0BV 927 755 A    HW: 0BV 927 755 A
   Component: TRANSFERCASE        0217
   VCID: 4C975EAA2F545DE6BF-8018
Address 32: Differential Locks        Labels: None
   Part No SW: 0BN 927 771     HW: 0BN 927 771
   Component: Quersperre          5220
   Revision: H04         Serial number: 411607253104
   VCID: 0109BF9E5896408E1C-8054
16353 - Control Module - Internal Malfunction
02412 - Differential Lock Rear
02062 - Differential Lock
   Coding: 14210000
                    Reset counter: 1
                    Mileage: 690688 km
                    Date: 2037.02.05
                    Time: 06:41:06
                    Default: CA
                    Default: 8A
                    Default: 00
                    Reset counter: 1
                    Mileage: 692224 km
                    Date: 2037.02.30
                    Time: 18:53:06
                    Default: E9
                    Default: 83
                    Default: 00
                    Reset counter: 1
                    Mileage: 692992 km
                    Date: 2037.02.30
                    Time: 31:21:06
                    Default: 43
                    Default: 83
                    Default: 00
                    Reset counter: 1
                    Mileage: 693248 km
                    Date: 2037.02.31
                    Time: 04:13:06
                    Default: 22
                    Default: 83
                    Default: 00
   Part No SW: 4H0 959 793 F    HW: 4H0 959 793 F
   Component: TSG FA        H07 0162
   Revision: --------    Serial number: 0000114291138
   Coding: 011D0620D001451005080002
   VCID: 3C770E6ABFF4ED660F-8068
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Component: BCM2 2.0      H24 BCM2 2.0      H24 02170217
   Revision: 00002001    Serial number: 0145501779
   Coding: 019B162228B9009483200624200000000000000000000000000000000000
   Subsystem 1 - Part No: 7P6 951 171
   Component: DWA-Sensor
   Component: LIN BACKUP HO
   Subsystem 3 - Part No: 7P0 959 591
   Component: J245 PS30.050
   Coding: 191100
   Subsystem 4 - Part No: 7P0 959 591 A
   Component: J394 PS30.050
   Coding: 191100
No Faults Found
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0162
   Revision: --------    Serial number: 0000114272719
   Coding: 011D0620D001451005080000
   VCID: 3B750D76BAFAEA5E06-806E
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 D    HW: 7P0 907 801 D
   Component: EPB           H51 1000
   Revision: 00000000    Serial number: A11308001C7
   Coding: 01040000
   ROD: EV_ParkbA7.rod
   VCID: 3467264A9FA42526C7-8060
   Slave 3:
   Part No SW: 4G0 035 061 S    HW: 4G0 035 061
   Component: Radio U DAB   H52 0154
   Revision: AB001007    Serial number: 109CU0B7514067
   Coding: 010105020100000001
   VCID: 2D51332E748E74EE88-8078
   Part No SW: 7P6 035 670 N    HW: 7P6 035 670 B
   Component: H-BNT-EU      H44 1047
   Revision: --------    Serial number: 478C00B7539551
   Coding: 010101050040E1ED01002B0E00000003F00401000000000000
   VCID: 408F7A9AD31C898653-8014
   Subsystem 1 - Part No: 8R0 060 884 N
   Component: EUR 2011  1205
   Subsystem 2 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: DU8 SV Touch  H24 0045
   Serial number: VWZ8Z9L2800WNN
   Subsystem 3 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: CD-Database  1886
03175 - Invalid Data Set
                    Reset counter: 72
                    Mileage: 121085 km
                    Date: 2020.09.29
                    Time: 20:19:03
                    Voltage: 11.80 V
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0162
   Revision: --------    Serial number: 0000114572062
   Coding: 011C06200001251005080000
   VCID: 3A7B0872B5C0D3561D-806E
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
   Component: RDKBERU25     H09 0008
   Serial number: 10000000115978
   ASAM Dataset: EV_RDKBERU25 003006
   ROD: EV_RDKBERU25_VW52.rod
Address 69: Trailer (J345)       Labels: Redir Fail!
   Part No SW: 7P0 907 383 G    HW: 7P0 907 383 C
   Component: Anhaenger     H09 0110
   Revision: 5H001001    Serial number: 00000145858187
   Coding: 0106040000000000
   Component: TSG HR        H09 0162
   Revision: --------    Serial number: 0000114570625
End-------------------------(Elapsed Time: 05:04)--------------------------
Let's get the new sensor installed. Then clear fault codes and see where you are at at that point.
My guess is you'll have to re-calibrate the ride height. That's done by entering measured values into Adaptation channels, but via Basic Settings.
lee1234
C?ID=68622
Thanks Uwe. So are you saying that if I do need to do re-calibrating, I will be able to do it with the HEX-USB+CAN?
I think so, but don't have a procedure for that specific suspension module handy at the moment.
lee1234
C?ID=68622
Hi all
I'm getting a liitle concerned that I'm going to have to take the car to the dealers after I refit the level sensors since I can't yet find any way to calibrate the suspension. Would like to know in advance rather than wait until Wednesday and then have to phone the dealer on Thursday.
I cannot find any post here or on mytreg.com or on clubtouareg.com or on YouTube indicating that anyone has successfully calibrated a 7P. Maybe it is all automatic, but again I can find no confirmation.
If I need to get a HEX-V2, again would like to know sooner rather than later.
The procedure here -
7L_procedure
is for 7L Touareg (non UDS), so no use to us.
UDS_procedure
refers to UDS modules like on 7P, but 7P is not mentioned.
There is also a guy asking about 7P in that thread and also here - Thread_from_2018 , but he appears to have got no answer. I will try to PM him.
Here are the screens in my VCDS to compare differences with the UDS instructions above.
Security access - 16
Code I have is different. I didn't record it, but it is not 20103 as shown in above instructions.
Basic Settings - 04
Instructions above refer to
IDE03751 Activate level control
IDE03761 Delete calibration for level control
IDE03802 Start up to reference level
IDE03762 Calibrate level control
I have these -
Basic_Settings_1
Adaptation - 10
IDE02001 through IDE02004 Body height right/left front/rear wheel house edge
I have these -
Adaptation_1
As you see, not the same codes or descriptions. But we can see some similarities -
For IDE03751 Activate level control, perhaps we should use IDE02938 complete height calibration ?
For IDE03761 Delete calibration for level control? Maybe no equivalent. Not needed?
For IDE03802 Start up to reference level? Maybe no equivalent. Not needed?
For IDE03762 Calibrate level control? Maybe no equivalent. Not needed?
For IDE02001 through IDE02004 Body height right/left front/rear wheel house edge, maybe we should use IDE03850 through IDE04148 left/right front/rear level ctrl sys sensor : adaptation value (zero pos)?
Anyone got any confirmation of any of the above please?
I cannot think of any reason you would need a HEX-V2 rather than the HEX+CAN you currently have.
Part of the problem with us not having a detailed procedure is that air suspension simply wasn't an option on the 7P T'reg in the US.
lee1234
C?ID=68622
Ah. That makes sense. I wasn't aware of that. But that explains the lack of internet results. So a much rarer car than I thought.
I did send in module maps last month for the car (primarily to try to help identify issues with the diff lock referred to in a different thread). Dana then suggested I try sending debug and blockmap information (due to communication error) which I also did.
Not sure if they may be of any help in any way with this issue?
Lee
lee1234
C?ID=68622
I just found this thread which I somehow missed,
Another_Thread
which suggests that this module, although UDS, acts like the older modules. So I think we might be OK. Using your suggestion Uwe of "Suggestion: Go to [Advanced Measuring Values], put 'height deviation' (without the quotes) into the search/filter box, and show us what it says?"
I will have to take a look in Advanced Measuring Values tomorrow.
lee1234
C?ID=68622
Hi.
I had a look in the Advanced Measuring Values and here is what I found. Sorry on the first photo I did not get the full codes. These were the only values where I found any numbers which looked like they might be relevant.
Note that at the moment I have the back of the car jacked up on axle stands with the front of the car on the ground. Jacking mode is active. Both rear level sensors are disconnected. I don't see why there are differences between front right and front left in the attached photos.
So, we do have some Advanced Measuring Values which mght be helpful, but sorry I don't see how we can adjust them. As far as i understand with my limited VCDS knowledge, these values are only for viewing, logging or graphing, not for editing? Measuring Blocks is greyed out.
I don't see where dean001 managed to input the actual heights.....
AMV1
AMV2
I would expect it to be the following Adaptation channels:
IDE03850-MAS02230 -- Left front level ctrl sys sensor: adaptation value (zero pos) - Height
IDE03858-MAS02230 -- Right front level ctrl sys sensor: adaptation value (zero pos) - Height
IDE03866-MAS02230 -- Left rear level ctrl sys sensor: adaptation value (zero pos) - Height
IDE04148-MAS02230 -- Right rear level ctrl sys sensor: adaptation value (zero pos) - Height
lee1234
C?ID=68622
Thanks Uwe. Hopefully the replacement sensor will turn up today. Will let you know how I get on.
Lee
lee1234
C?ID=68622
Well the sensor did not turn on Wednesday...... or Thursday......
Since it is the 'pole' which snapped (as usual) rather than a faulty sensor, I made up a new pole out of a bit of steel bar lying around the garage and a few bolts nots and washers. With a little wiggle room in the joints so that it will hopefully last until sensor does turn up.
So I have in fact temporarily put the same sensors back in the same places.
After taking the car off the axle stands and turning jacking mode off, the car sorted itself out more or less, as expected since there is currently no new sensor.
However, I did notice that there is a small difference in height from wheel to wheelarch across the rear, so still keen to establish how exactly to modify the height by corner.
I took a look at Adaptation channels -
and they are currently all the same, set at 470mm like the screenprint below.
Adaptation
I had engine running, in Neutral, with doors closed.
In this screen I changed right front and left front to 490mm. Both were saved successfully. After exiting the module I checked the car whwelarch measurements and they had not changed.
I changed the adaptation channels both back to 470mm.
In the 7L procedure it says -
[Read]
Wait until the car goes into 2 different levels.
This then settles the car into the correct position for measuring.
I wonder if there is an equivalent in my module, which needs to be done before making changes in the above Adaptation channels?
There's another channel called:
IDE02938-MAS01601 -- Complete height calibration - save
I would think this is involved, but I'm not sure what else is necessary.
lee1234
C?ID=68622
Thanks Uwe
I'll try that. But I suspect there must be also something to be done before measuring? Otherwise it will make a difference depending which of the 5 levels I have selected initially. I don't really want to experiment by randomly selecting various adaptions which might sound right to me, but you might have seen those descriptions before and know to stay away.
Lee
I would think so too, but that one isn't obvious or apparent to me.
lee1234
C?ID=68622
I tried the adaptation -
IDE02938-Complete height calibration
There are 2 settings available - Yes or No. Initial setting is Yes, so it seems logical to set it to No to start the changes, and then set it back to Yes after heights are finished?
So with 3/4 tank of fuel, all doors closed, height set to 'Normal', engine running. With security code entered, I try to change it to No. But I get error message. So I have tried in Neutral or Park, handrake on or off, height in Normal or Sport, engine running or not, but still same error message - 'Conditions not correct or request sequence error'.
Module_34_error
Any ideas?
lee1234
C?ID=68622
Had an idea overnight which might be relevant. Might be an obvious oversight on my part. Since I was only trying to find the correct combination of actions, I was not bothered about actual measurements, so I was sat in the car! Sounds obvious now. Seat occupied sensors may need to be all 'off'. I will try again later without being in the car.
lee1234
C?ID=68622
Hi. I tried while being outside the car. But still no luck. Handbrake on, in Park, engine running, all doors, boot(trunk) and bonnet(hood) closed. After entering security code, still cannot change IDE02938-Complete height calibration to No. Anyway tried changing heights again in IDE08350 etc. Values again are accepted, but nothing happens. Then I also tried IDE02938-Complete height calibration after changing the numbers. This time I overwrote Yes with Yes. Dashboard comes up still with error, but VCDS says value accepted. But still nothing changed. I tried a few times, each time closing controller, then security, then make the changes, but nothing has moved. I was using various combinations of 470 and 490 but still nothing.
  • Informative
