ABS ESP 8.2 IBIZA 6J long coding help
sweddie76
Unverified
Liverpool, UK
LP/IP
I've changed coding somewhere? When I operate passenger window close it opens drivers window and vise versa can any1 explain what i might have changed in settings and how to fix this problem? Thanks.
bako61
danke zuerst.
Ich habe einen Sitz ibiza aus baujahr. 2009. 1.4tdi Motorcode: BMS. Brauche ein lange codierung. kann mir da jemend helfen BITTE.
Removed.  Data from a clone/pirate copy of VCDS is not acceptable here
Westbury, UK
danke zuerst.
The language of this forum is English, so please post in English and use the English version of VCDS - which can be installed alongside your German version.
bako61
Sorry
I bought the laptop like that. can you change it
iichel
Eindhoven, NB, NL
C?ID=284912
I think the bigger issue is the 12.12 version. ;)
bako61, if you're able to show an English scan of the latest VCDS version, I'll probably be able to compose a coding for your car.
