2014 A8 D4 - Inner door light bar brightness
john1292
C?ID=288294
Hi hopefully this can be done. The brightness on the inner door bar lights are not bright enough. I can barely see them when on. Is there a way to adjust the brightness through adaptations. I can adjust the brightness of the other lights around the car through the MMI but not these ones.
South Molton, UK
Do we have a Auto-Scan of your A8? If not please post one.
siLc
Tallinn, Estonia
C?ID=330192
The ambient lights should be adjusted with the dash lighting dimmer dial on the light switch - is it turned to max?
john1292
C?ID=288294
Yes it is on Max. I was wondering if the brightness can be adjusted for the inner doors only.
VIN: WAUZZZ4H0FN012370   License Plate: VK6
Mileage: 61528km-38231mi   Repair Order:
Chassis Type: 4H-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 20 28 30 34 36 3B 42 44 46
          47 52 53 55 56 57 5F 62 6C 6D 6F 72 81 88 89 8F 90 AC
VIN: WAUZZZ4H0FN012370   Mileage: 61528km-38231miles
Address 01: Engine (J623-CTBA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4H0 997 401 E    HW: 4G0 907 401 E
   Component: 3.0TDI EDC17  H14 0002
   Revision: 58H14---
   Coding: 0A2A4032052601030800
   Shop #: WSC 56987 001 1048576
   ASAM Dataset: EV_ECM30TDI0114H0997401E 001002
   ROD: EV_ECM30TDI0114H0997401E.rod
   VCID: 2F6AC2D076382CFEA2-807A
   Part No SW: 4H1 927 158 CL    HW: 0BK 927 156 AD
   Component: 0BK 30TDIRdW  H18 1011
   Revision: --H18---
   VCID: 7CF0259CF7CE076657-8028
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 T    HW: 4H0 907 379 T
   Component: ESP PREMIUM   H10 0665
   Coding: 60E5AB8006A7D501E300
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremi 005024
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 43829E60CAB0B89E56-8016
   Part No SW: 4H0 907 064 FB    HW: 4H0 907 064 EB
   Component: BCM2 2.0      H36 0551
   Coding: 05B76F4E000000000000
   VCID: 6ED41FD4B9B265F6E9-803A
   Serial number: 0214000096215008
   Part No SW: 4H0 959 760 D    HW: 4H0 959 760 D
   Component: MEM-BFS       H08 0156
   Revision: AA000000    Serial number: 00000107698895
   Coding: 0038320000047201000001010101112131313333283333
   VCID: 3460CDBC971E0F26DF-8060
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 N    HW: 4H0 820 043 N
   Component: Klima 4 Zonen H20 0210
   Coding: 362100BE300000
   ASAM Dataset: EV_AirCondiFront 003001
   ROD: EV_AirCondiFront_002.rod
   VCID: 2B52D6C0422050DE8E-807E
   Part No SW: 4H0 907 063 AB    HW: 4H0 907 063 AB
   Component: BCM1 2.0      H20 0242
   Revision: 19020001    Serial number: 00000846087801
   Coding: 0105001440349FE0C9014087A0001800009DC30A2F080201800008946100170000400034030000
   VCID: 68D869CC9B56BBC6A3-803C
   Subsystem 1 - Part No SW: 4H2 955 119 C    HW: 4H2 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 140322  H36 0090
   Serial number:         140617221752
   Coding: 0045F7
   Serial number: 22835169
   Coding: 02004E
   Subsystem 3 - Part No SW: 4H0 941 531 B    HW: 4H0 941 531 B
   Component: E1 - LDS  H07 0044
   Serial number: 03 07 2014  00000706
   Component: EVLS-SG  H08 0300
   Serial number: WA108371000007682258
   Coding: 020300
   Serial number: 38584537000000000001
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1001JZFD
   Coding: 30333045313430303038554A305234483053
   VCID: 3B72E680B240C05E1E-806E
   Serial number: 3575HRB40552LPPK4OFA
   Serial number: 3585HRB40672MSOA586Q
   Serial number: 3515JRB405F2SIIAB0BL
   Serial number: 3525JRB405D2SIIAO0J+
   Serial number: 3554VRB400E52L7E7HLQ
   Serial number: 3564VRB400E52L7EJ1PR
   Revision: --------    Serial number: 01335NG40016P
   Coding: 000034
   VCID: 377AFAB08668E43EFA-8062
   Subsystem 1 - Part No SW: 4H0 951 528 A    HW: 4H0 951 528 A
   Serial number: 16 05 2014  E0404115
   Part No SW: 4H0 920 910 P    HW: 4H0 920 910 P
   Component: TDieGB------- H53 0707
   Revision: 37081202    Serial number: 658030714592022
   Coding: 33A608001B412600010000
   ASAM Dataset: EV_RBD4K 004050
   ROD: EV_RBD4K_AU64.rod
   VCID: 316EC4A8600C3A0EB4-8064
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 Q    HW: 4H0 919 204 Q
   Component: Analoguhr D4  H05 0225
   Serial number: 2140613000158
   Part No SW: 4H0 907 468 AF    HW: 4H0 907 468 AC
   Revision: --------    Serial number: 00000001458644
   Coding: C0CD078108
   VCID: 75E630B8D4E4562E28-8020
   Subsystem 1 - Part No SW: 4H0 915 181 F    HW: 4H0 915 181 F
   Component: J367-BDM  H08 0181
   Serial number: 51167757381911393258
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 C    HW: 8K0 959 663 C
   Serial number: 14182003481021200410
Address 20: High Beam Assist. (J844)       Labels: None
   Part No SW: 4H0 857 511     HW: 4H0 857 511
   Component: FLA           H04 0020
   Revision: AA001002
   Coding: 04028B6B74745D545420363E00
   VCID: 67DA6AF09648B4BEAA-8032
Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
   Part No SW: 4H0 919 158 K    HW: 4H0 919 158 K
   Component: Klima Fond    H16 0200
   Coding: 2800000000
   ASAM Dataset: EV_AirCondiHeck 002001
   ROD: EV_AirCondiHeck.rod
   VCID: 3878F98C8376EB46F3-806C
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000061133
   Coding: 01010101000000000001000202
   VCID: 64C07DFC677EDFA68F-8030
   Coding: 008000
   ROD: EV_AirSuspe_VW51.rod
   Component: MEM-FS        H08 0156
   Revision: AA000000    Serial number: 00000107699072
   Coding: 00383B0000057201000001010101112131313333203333
Address 3B: Sensor Elect. (J849)       Labels: None
   Part No SW: 4H0 907 637 K    HW: 4H0 907 637 F
   Component: SARA 6D       H03 0056
   Revision: --------    Serial number: EJ1BPA7701XB3D
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 377AFAB08E68E43EFA-8062
   Part No SW: 4H0 959 793 S    HW: 4H0 959 793 H
   Component: TSG FA        H07 0280
   Revision: --------    Serial number: 0000099537368
   Coding: 011F12015E01628202083002
   VCID: 499E8C48E09C62CE9C-801C
   Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
   Component: RCEPS         H41 0011
   Revision: 00001000    Serial number: 0027721498
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 009010
   ROD: EV_RCEPS_009.rod
   VCID: 3362CEA09A10081EC6-8066
   Revision: 00002001    Serial number: 0338055991
   Coding: 011B0E2280B93881B320C784080316470000000000000000000000000000
   Subsystem 1 - Part No: 4H0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 3 - Part No SW: 4H0 947 135 A    HW: 4H0 947 135 A
   Component: Dachelektroni  H13 0080
   Serial number: A2014000000000802314
   Subsystem 4 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93260572
   Revision: CJ007001    Serial number: 00000000116369
   Coding: 030000
   VCID: 1D3608180494AE6E00-8048
   Part No SW: 4H0 959 792 H    HW: 4H0 959 792 H
   Component: TSG BF        H06 0280
   Revision: --------    Serial number: 0000105535178
   VCID: 3D76E898A454CE6E20-8068
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001127612
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D56D8D87C345EEE90-8078
   Part No SW: 4H4 907 357 B    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0049
   Coding: 02F6021022630200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 004002
   ROD: EV_HeadlRegulAUDIMXBAU64X_004_AU64.rod
   Subsystem 1 - Part No SW: 7PP 941 472 F    HW: 7PP 941 472 F  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 7530
   Coding: E00200
   Subsystem 2 - Part No SW: 7PP 941 472 G    HW: 7PP 941 472 G  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 7540
   Coding: E00200
   Part No SW: 4G0 035 061 N    HW: 4G0 035 061
   Component: Radio U DAB   H60 0139
   Revision: AB001007    Serial number: 109G10E7944850
   Coding: 010103010000000001
   VCID: 285829CC5BD67BC663-807C
Address 57: TV Tuner (R78)       Labels: None
   Part No SW: 4G0 919 129 C    HW: 4G0 919 129
   Component: NGTV-DVB      H04 0690
   Revision: R0043000    Serial number: 06801301405001
   Coding: 03000000
   VCID: 2D56D8D874345EEE90-8078
   Part No SW: 4H0 035 666 R    HW: 4H0 035 666 N
   Component: H-BN-EU       H47 0814
   Revision: --------    Serial number: 178GZ0EB001334
   Coding: 02010100000BF1EF45908B1E00000003E00001020000000000
   VCID: 3878F98C8B76EB46F3-806C
   Subsystem 1 - Part No: 8R0 060 884 BT
   Component: EUR 2014  1903
   Subsystem 2 - Part No SW: 4H0 919 604 G    HW: 4H0 919 604 G
   Component: DU8 D4 SV NB  H48 0021
   Serial number: AUZ8ZDEC901LKWP
   Subsystem 3 - Part No SW: 4H2 919 600 H    HW: 4H2 919 600
   Component: E380 BDT D4  H09 0065
   Serial number: 00000000163688
   Component: CD-Database  5950
   Part No SW: 4H0 959 795 E    HW: 4H0 959 795 E
   Component: TSG HL        H06 0280
   Revision: --------    Serial number: 0000105537294
   Coding: 010F12014000628202083002
   Part No SW: 4S0 907 441 B    HW: 5Q0 907 441 A
   Component: D4-PA RVC Mid H07 0050
   Coding: 024601010201000300
   ASAM Dataset: EV_CamSysRearPANAAU914 002002
   ROD: EV_CamSysRearPANAAU914.rod
   VCID: 326CCBA4650A0116CD-8066
Address 6D: Trunk Elect. (----)       Labels:* None
   Part No SW: 4H0 959 107 AC    HW: 4H0 959 107 AC
   Component: HDSG-Modul    H12 0049
   Revision: 10012001    Serial number: 173401591
   Coding: 021004C020
   ASAM Dataset: EV_DeckLidContrUnit 001032
   ROD: EV_DeckLidContrUnit.rod
   VCID: 6FEA02D0B6B86CFEE2-803A
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000156007
   Coding: 220000
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 63C27EE06A70D89E76-8036
   Component: TSG HR        H06 0280
   Revision: --------    Serial number: 0000105536924
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 4H2 927 731 A    HW: 4H2 927 731 A
   Component: GSM-RL        H09 0083
   Revision: 0R0D5015    Serial number: SN140531  0086
   ROD: EV_GSM2x3Mono_AU64.rod
   VCID: 2C50D5DC472E57E687-8078
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00016971192901
   Coding: 672FF2
   ROD: EV_IVBDriveSideFrnt.rod
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 00016971189201
   Coding: 272FF2
   Coding: 00060000031F030000030800424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW51.rod
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R_VW51.rod
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 141630386
   ROD: EV_RDCMA00100.rod
End-------------------------(Elapsed Time: 06:58)----------
john1292
C?ID=288294
Found that by aďjusting the brightness if the footwell light the inner ďoor light bars adjust also. Can these be adapted separately through VCDS.
