Help with MMI screen not coming up 2013 Audi A8L
MileHigh786
Dallas, USA
C?ID=419384
Hi Folks,
First time posting here and a new user with the VCDS tool.
I have a 2013 Audi A8L 4.0. I had the original battery on the car till June of this year. Given I was not driving a lot, it was parked for about a month.
Got in to drive and the car started fine but got the message in the dash that the battery is low. Also realized that the MMI screen did not come up.
Since then I have put a new battery in and coded it via the VCDS tool, hoping that the issue would be resolved but seems like it has had no impact.
Wondering what might be the issue? I scanned and cleared all the codes and also ran an optical diagnostics scan.
Ideas?
Tuesday,06,October,2020,22:10:36:29578
VIN: WAUR2AFD2DN018684   License Plate:
Mileage: 76887km-47775mi   Repair Order:
Gateway Installation List:  4H0 907 468 AC
17-Instruments -- Status: Cannot be reached 0100
47-Sound System -- Status: Cannot be reached 0100
48-Seat, Rear, DS -- Status: OK 0000
56-Radio -- Status: Cannot be reached 0100
5B-Seat,Rear,PS -- Status: OK 0000
7F-Inform. Electr. II -- Status: Cannot be reached 0100
8A-Multicont. Seat Rear,DS -- Status: OK 0000
8D-Multicont. Seat Rear,PS -- Status: OK 0000
Thursday,08,October,2020,22:41:50:29578
OPTICAL SCAN RESULTS:
Thursday,08,October,2020,22:24:03:29578
Control Module Part Number: 4H0 907 468 AC
  Component and/or Version: J533--Gateway H12 0037
Optical Bus Diagnostic : Standard
Controller              Electrical              Optical
CAN Gateway             OK                      OK
Information Electr.     OK                      OK
Instruments             OK                      OK
Inform. Electr. II      ERROR                   ERROR
Radio                   OK                      OK
Sound System            OK                      OK
Does this car really have:
Or is the gateway confused?
Have you got an older scans?
MileHigh786
Dallas, USA
C?ID=419384
Hi Uwe,
Not sure but I do have all the options for this particular model year (B&O, RSE, and Night Vision).
I do not have an older scan but only the one I took when I first started the battery coding process.
Attaching the first scan I did with VCDS a week or so ago.
thanks!
Thursday,01,October,2020,16:51:30:29578
Mileage: 76749km-47689mi   Repair Order:
Chassis Type: FD-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 10 13 15 16 17 19 20 28 34 36 3B 3C 42
          46 47 48 52 53 56 5B 5F 62 6C 6D 6F 72 7F 81 84 85 88 89 8A
          8B 8D 8E 8F 90 BA
VIN: WAUR2AFD2DN018684   Mileage: 76749km-47689miles
85-On Board Cam. -- Status: Malfunction 0010
Address 01: Engine (------CEUA)       Labels: Redir Fail!
   Part No SW: 4H0 906 014 L    HW: 4H0 906 014
   Component: 4.0l V8TFSI / H62 0005
   Revision: NCH62---
   Coding: 022A00326546010E1000
   Shop #: WSC 13452 002 1048576
   ASAM Dataset: EV_ECM40TFS0114H0906014L 001005
   ROD: EV_ECM40TFS0114H0906014L.rod
   VCID: 2C010075568C0FCBDEB-8078
   Part No SW: 4H1 927 158 EE    HW: 0BK 927 156 AG
   Component: 0BK 40TFSIUSA H16 1002
   Revision: --H16---
   Shop #: WSC 42950 000 1048576
   VCID: 77ABEF19DF4A7C13639-8022
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 E    HW: 4H0 907 379 E
   Component: ESP PREMIUM   H10 0352
   Coding: C4E5F30023A7CF00E200
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremi 005013
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 343118158EBC570B86B-8060
0717 - Tire Pressure Warning
          C102D 00 [009] - -
                    Fault Frequency: 81
                    Reset counter: 164
                    Mileage: 75265 km
                    Date: 2020.02.21
                    Time: 12:29:02
                    VzRef: 38
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 16
                    Bit Info 4: 12
                    F-Path: 47
                    F-Type: 04
                    Uz: B7
   Part No SW: 4H0 907 064 DD    HW: 4H0 907 064 CD
   Component: BCM2 2.0      H33 0510
   Coding: 0DA72046000000000000
   Shop #: WSC 53688 000 1048576
   VCID: 6E85CA7DA0903DDBB0F-803A
   Serial number: 2312000254051003
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Component: MEM-BFS       H08 0153
   Revision: AA000000    Serial number: 00000044952136
   Coding: C018B60085047201010001010101112131313333283333
   Shop #: WSC 02313 785 00200
   VCID: 3537251185464E03B15-8060
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 L    HW: 4H0 820 043 L
   Component: Klima 4 Zonen H20 0121
   Coding: 688122BE7C
   ASAM Dataset: EV_AirCondiFront 001050
   ROD: EV_AirCondiFront_001_AU64.rod
   VCID: 290FF961597E1AE325D-807C
0137 - Motor for  Right Side Window Defrost Flap
          B10D8 22 [009] - Signal Amplitude Too High
                    Fault Frequency: 122
                    Reset counter: 165
                    Mileage: 75708 km
                    Date: 2020.06.02
                    Time: 20:17:27
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001479374
   Coding: 09072091077C9FE38B000804A0003800009CD3088E0001218001085C7B00
   VCID: 6FBBD779A79A34D3BB9-803A
   Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 120922  H35 0080
   Serial number:         121103103849
   Coding: 0045F7
   Subsystem 2 - Part No SW: 8K0 955 559 C    HW: 8K0 955 559 C  Labels: 8K0-955-559.CLB
   Component: RLS  H04 0003
   Serial number: 10292214
   Coding: 025523
   Subsystem 3 - Part No SW: 4H0 941 531 C    HW: 4H0 941 531 C
   Component: E1 - LDS  H07 0044
   Serial number: 19 11 2012  00000949
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R3Z2Y02
   Subsystem 5 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A31 LED Mod1L  H03 0006
   Serial number: 00000020111200010318
   Coding: 100000
   Subsystem 6 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A27 LED Mod1R  H03 0006
   Serial number: 00000019111200010697
   Coding: 100000
   Subsystem 7 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA104521000002327734
   Coding: 020300
   Subsystem 8 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 76090B56000000000001
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61061232101709
   Coding: A80B0E
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: 71BFD101B12E2223ADD-8024
   Part No SW: 4H0 907 561 B    HW: 4H0 907 561
   Component: ACC3          H21 0410
   Coding: 7E01020101
   ASAM Dataset: EV_AdaptCruisContrAU64X 002021
   ROD: EV_AdaptCruisContrAU64X_002.rod
   VCID: 2A0D066D5C7811FB2C7-807E
93440 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_VIDEO_FAIL]
                    Reset counter: 186
                    Mileage: 76138 km
                    Date: 2020.08.16
                    Time: 13:07:27
                    Control Module temperature: 47 °C
                    Voltage terminal 15: 12.537 V
   Part No SW: 4H0 959 655 D    HW: 4H0 959 655 D
   Component: Airbag10.43   H44 0041
   Revision: --------    Serial number: 003JS001DLLK
   Coding: 303143303230303030314A55304C34483053
   VCID: 372B2F199FCABC13A39-8062
   Subsystem 1 - Part No SW: 4H0 959 339 A    HW: 4H0 959 339 A
   Component: BF-Gewichtss.  H03 0040
   Serial number: 5850000R12B050619R
   Serial number: 3575HRB40531LKFOD0MV
   Serial number: 3585HRB40551LKFO61OU
   Serial number: 3515JRB405P1O70U98O-
   Serial number: 3525JRB405P1O70UD0BK
   Serial number: 3554VRB40164UNQ4EQ2B
   Serial number: 3564VRB401A4UNQ4BQ5G
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90815LKC0001G
   Coding: 0004BC
   VCID: 38292C259254B36BAA3-806C
   Subsystem 1 - Part No SW: 4H0 951 528 L    HW: 4H0 951 528 L
   Component: E221 - MFL  H09 0010
   Serial number: 12 09 2012  D1068764
   Part No SW: 4H0 920 880 F    HW: 4H0 920 880 F
   Component: TBenUSAACCNV- H50 0515
   Revision: 34081076    Serial number: 658101112592041
   Coding: 0B4608015740D705020000
   ASAM Dataset: EV_RBD4K 004046
   ROD: EV_RBD4K_AU64.rod
   VCID: 2D070D716D9606C3C95-8078
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 G    HW: 4H0 919 204 G
   Component: Analoguhr D4  H05 0225
   Serial number: 1121026001652
   Part No SW: 4H0 907 468 AC    HW: 4H0 907 468 AC
   Component: J533--Gateway H12 0037
   Revision: --------    Serial number: 00000000750152
   Coding: 00ED074800
   ASAM Dataset: EV_GatewPkoUDS 001018
   VCID: 72BDDE0DB428193B547-8026
   Subsystem 1 - Part No SW: 4H0 915 181 F    HW: 4H0 915 181 F
   Component: J367-BDM  H08 0181
   Serial number: 00000000004970564933
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 A    HW: 8K0 959 663 A
   Serial number: 12319000406011200181
6681 - Voltage Regulator Stage 2
          C10AF F5 [008] - Short to GND
                    Reset counter: 185
                    Mileage: 76138 km
                    Date: 2020.08.11
                    Time: 19:19:39
                    Voltage terminal 30: 11.7 V
                    Voltage terminal 15: 11.8 V
                    Control Module temperature: 43 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
0267 - Optical data bus
          U1049 00 [008] - Open circuit
                    Reset counter: 194
                    Mileage: 76138 km
                    Date: 2020.08.11
                    Time: 19:00:45
                    Voltage terminal 30: 12.0 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 46 °C
                    System status: Awake_Timer_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
0269 - Optical data bus
          U104A 00 [009] - No Communication
                    Reset counter: 165
                    Mileage: 75953 km
                    Date: 2020.07.12
                    Time: 21:26:28
                    Control Module temperature: 27 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
          U140B 00 [008] - -
          [Powermanagement active]
                    Reset counter: 177
                    Mileage: 75953 km
                    Date: 2020.07.29
                    Time: 20:03:41
                    Voltage terminal 30: 11.2 V
                    Control Module temperature: 29 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 1
   Part No SW: 8K0 857 511 G    HW: 8K0 857 511 G
   Component: FLA           H04 0020
   Revision: AB001001
   Coding: 04018B6B74745D545420363E00
Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
   Part No SW: 4H0 919 158 K    HW: 4H0 919 158 K
   Component: Klima Fond    H16 0121
   Coding: 2000000000
   ASAM Dataset: EV_AirCondiHeck 001039
   ROD: EV_AirCondiHeck.rod
   VCID: 38292C2592D4B36BAA3-806C
   Part No SW: 4H0 907 553 E    HW: 4H0 907 553
   Component: LUFE-DAEMPFER H17 0099
   Coding: 008002
   ASAM Dataset: EV_AirSuspe 003024
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2E050A7D60907DDBF0F-807A
          C10C8 00 [008] - -
                    Reset counter: 172
                    Mileage: 75355 km
                    Date: 2020.02.22
                    Time: 14:01:42
   Component: MEM-FS        H08 0153
   Revision: AA000000    Serial number: 00000044957807
   Coding: C018BF8085857201030001010101112131313333203333
Address 3B: Sensor Elect. (J849)       Labels: None
   Part No SW: 4H0 907 637 K    HW: 4H0 907 637 F
   Component: SARA 6D       H02 0053
   Revision: --------    Serial number: EJ1BPA7700B7B.
   ASAM Dataset: EV_SARA2 005011
   ROD: EV_SARA2.rod
   Part No SW: 4H0 907 566 A    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0040
   Revision: 00H02000    Serial number: 6PZ 010 287-07
   Coding: 0000002
   VCID: 2E050A7D6C107DDBF0F-807A
   Subsystem 1 - Part No: 4H0 907 568 A
   Component: J770  SWA Slave H02 0040
   Subsystem 2 - Serial number: 6PZ 010 287-27
   Subsystem 3 - Serial number: 5F14.11.1200H02000AMS14243ÿ
   Subsystem 4 - Serial number: S14243ÿ
   Part No SW: 4H0 959 793 R    HW: 4H0 959 793 G
   Component: TSG FA        H06 0263
   Revision: --------    Serial number: 0000132485991
   Coding: 011F1F005E0062C202003017
   Shop #: WSC 02312 785 00200
   VCID: 48C95CE5E2B4C3EBDA3-801C
   Revision: 00002001    Serial number: 0187683382
   Coding: 0106023A00FA759FB0B0C784020301070000000000000000000000000000
   Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
   Component: GTO BF  H01 0080
   Serial number: 00000000000000117395
   Subsystem 3 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J245  007C  H06 0005
   Serial number: 245400008534
   Coding: 020200
   Subsystem 4 - Part No SW: 4H0 947 135 BR    HW: 4H0 947 135 BR
   Component: Dachelektroni  H11 0080
   Serial number: A2012000000000653982
   Coding: 070000
   Subsystem 5 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J394  0014  H06 0005
   Serial number: 245400009013
   Coding: 020200
   Subsystem 6 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J392  006A  H06 0005
   Serial number: 245400008514
   Coding: 020200
   Subsystem 7 - Part No SW: 4H4 959 591     HW: 4H4 959 591
   Component: J867  00E0  H06 0005
   Serial number: 245400008996
   Coding: 020200
   Subsystem 8 - Part No SW: 3AA 962 243     HW: 3AA 962 243
   Component: GEB.F.Heckoef  H12 0719
   Serial number: 84324832
03634 - Switch for Window Shade Illumination; Front
                    Fault Status: 00101100
                    Reset counter: 205
                    Mileage: 75397 km
                    Date: 2020.02.24
                    Time: 15:36:19
Address 47: Sound System
Address 48: Seat, Rear, DS (J876)       Labels: None
   Part No SW: 4H0 959 860     HW: 4H0 959 860
   Component: MEM-FS-Fond   H06 0155
   Revision: AA000000    Serial number: 00000043540325
   Coding: 001892800000700D0A00392038193A2039203B3B202020
   VCID: 71BFD101B1AE2223ADD-8024
   Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
   Component: TSG BF        H06 0261
   Revision: --------    Serial number: 0000132409839
   Coding: 011F1F005E0062C202003007
   VCID: 3C213035A66C9F4B4EB-8068
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000532745
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2B030369538208F3D71-807E
Address 56: Radio
Address 5B: Seat,Rear,PS (J877)       Labels: None
   Component: MEM-BFS-Fond  H06 0155
   Revision: AA000000    Serial number: 00000043540748
   Coding: 001896800000700D0A00392038193A2039203B3B382020
   Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
   Component: TSG HL        H06 0262
   Revision: --------    Serial number: 0000132332534
   Coding: 010F1F00420062C202003007
   Part No SW: 4H0 907 428 A    HW: 7P6 907 441 D
   Component: TopView       H05 0111
   Revision: 11001001    Serial number: 82330JF0063468
   Coding: 020A000001010000000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 005022
   ROD: EV_CamerSysteTopViewAUDI_005.rod
Address 6D: Trunk Elect. (----)       Labels:* None
   Part No SW: 4H0 959 107 AB    HW: 4H0 959 107 M
   Component: HDSG-Modul    H11 0043
   Revision: 10011001    Serial number: 305200446
   Coding: 0210044100
   ASAM Dataset: EV_DeckLidContrUnit 001032
   ROD: EV_DeckLidContrUnit.rod
   VCID: 6E85CA7DA0103DDBB0F-803A
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000090703
   Coding: 200000
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 6393AB497BD280B32F1-8036
   Component: TSG HR        H06 0262
   Revision: --------    Serial number: 0000132090645
Address 7F: Inform. Electr. II
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
   Component: GSM-LL        H08 0083
   Revision: 0L0D5014    Serial number: SN120822  0026
   ROD: EV_GSM2x3Mono_AU64.rod
Address 84: Night Vision (J853)       Labels:| 4H0-907-547.clb
   Part No SW: 4H0 907 547 F    HW: 4H0 907 547
   Component: NV-ECU-Gen1   H09 0042
   Serial number: 0K84AE40083549
   Coding: 1200
   ASAM Dataset: EV_NightVisioGen1 001002
   ROD: EV_NightVisioGen1.rod
   VCID: 323D1E0D74A8593B947-8066
   Night vision system camera:
   Subsystem 1 - Part No SW: 4H0 980 552 A    HW: 4H0 980 552
   Component: NV-CAM-Gen1  H08 0008
   Serial number: 00000000001229100054
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H25 0038
   Coding: E9060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2615F25D4860359B08F-8072
0001 - Front Heater for Lane-Holding Assist
          C1101 15 [008] - Open or Short to Plus
                    Reset counter: 172
                    Mileage: 75685 km
                    Date: 2020.05.31
                    Time: 11:43:07
                    Outside air temperature: -34.5 °C
                    Voltage terminal 15: 14.0 V
                    Control Module temperature: 71.0 °C
0260 - Function limitation due to excessive temperature
          B1050 00 [008] - -
          [Functional_restrictions_high_temperature]
                    Reset counter: 186
                    Mileage: 76138 km
                    Date: 2020.08.16
                    Time: 13:07:21
                    Outside air temperature: -28.5 °C
                    Voltage terminal 15: 12.6 V
                    Control Module temperature: 90.0 °C
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00008768120002
   Coding: 766FF2
   ROD: EV_IVBDriveSideFrnt.rod
   VCID: 2F3B1779679A74D3FB9-807A
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 00008768103101
   Coding: 366FF2
Address 8A: Multicont. Seat Rear,DS (J875)       Labels:* None
   Part No SW: 4H0 907 182 G    HW: 4H0 907 182 G
   Component: IVB           H08 0042
   Serial number: 00008689116002
   Coding: 202F00
   ASAM Dataset: EV_IVBDriveSideRear 001003
   Part No SW: 4H0 907 541 B    HW: 4H0 907 541
   Component: ACC3          H19 0400
   Coding: 7E01020101
   ASAM Dataset: EV_AdaptCruisContr2AU64X 002018
   ROD: EV_AdaptCruisContr2AU64X_002.rod
   VCID: 2809FC65427423EB3A3-807C
Address 8D: Multicont. Seat Rear,PS (J874)       Labels:* None
   Serial number: 00008689064101
   Coding: 202F00
   ASAM Dataset: EV_IVBPasseSideRear 001003
   Part No SW: 4G0 907 107 E    HW: 4H0 907 107
   Component: BV-SG         H31 0041
   Serial number: 005000121311127
   Coding: 02A19A000111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
0080 - Video Cable for Image Processing
          C1107 02 [008] - Signal Failure
          [No_connection_to_camera]
                    Reset counter: 186
                    Mileage: 76138 km
                    Date: 2020.08.16
                    Time: 13:07:27
                    Outside air temperature: 43.5 °C
                    Voltage terminal 15: 12.9 V
                    Control Module temperature: 46.0 °C
   Coding: 0066F609031F0376070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW51.rod
   VCID: 313F110171AE6223EDD-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R_VW51.rod
   Part No SW: 4H0 907 145     HW: 4H0 907 145
   Component: AEM - LEAR    H05 0006
   Revision: 00001001    Serial number: 97804001025204
   ASAM Dataset: EV_AEMLearAU64X 002014
   ROD: EV_AEMLearAU64X.rod
   VCID: 6695B25D88E0F59BC8F-8032
End----------(Elapsed Time: 03:11, VBatt start/end: 11.8V/13.7V)-----------
MileHigh786
Dallas, USA
C?ID=419384
Hi,
As I research this area it seems like, my main driver MMI maybe a function of the Rear Seat entertainment (RSE) ring. I was able to access the Electronics diagram with the help of a friend which highlited that the MMI Display Unit 1 Y22 and the MMI Display Unit 2 Y23 are accessed via the Information Electronics Module 2 J829. The RSE screen comes on but is really not being responsive except for maybe toggling between Media and Radio, and neither work. Not sure if J829 has any dependence on the trailer hitch as I remember seeing a post around that! Maybe just a wild goose chase.
MileHigh786
Dallas, USA
C?ID=419384
Folks,
pinging the thread again to see if anyone has any thoughts or ideas?
MartinsX
Riga, Latvia
C?ID=268515
                    Reset counter: 194
                    Mileage: 76138 km
                    Date: 2020.08.11
                    Time: 19:00:45
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
                    Reset counter: 165
                    Mileage: 75953 km
                    Date: 2020.07.12
                    Time: 21:26:28
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
I guess problem is somewhere here.
Try to run optical bus diagnosis
Try to exclude modules from optical ring one by one using test loop adapters and see when all modules left in the ring start to communicate.
MileHigh786
Dallas, USA
C?ID=419384
Thanks MartinsX! Got busy with work hence did not respond earlier.
will have to get an optical test loop first. To confirm, I will have to pull the front dash out to access the loop, correct?
thanks.
