2009 Audi A3 1.8L ABS Coding (MK60EC1)
Jaso
Brisbane,Australia
C?ID=250826
Hi guys,
I have a 2009 Audi A3 that i purchased and it seems that prior owner has replaced the abs module as I've got a dash light on for it and a couple other things. I don't know the previous models coding as it wasn't done by me or have access to previous scans.
I've had a look through the forums and tried to use the codes provided for similar models with no luck and i'm assuming it's because of vin number differences?
Any help would be greatly appreciated . Last scan provided below.
Friday,09,October,2020,17:13:59:10020
VCDS Version: 20.4.2.0 (x64)
VIN: WAUZZZ8P6AA027585   License Plate: AUUUU3
Mileage: 141440km-87886mi   Repair Order:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 47 52 56 62 72 77
VIN: WAUZZZ8P6AA027585   Mileage: 141440km-87886miles
04-Steering Angle -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Malfunction 1010
Address 01: Engine (CDA)       Labels:. 06J-907-115-CDA.clb
   Part No SW: 8P7 907 115 L    HW: 8P0 907 115 Q
   Component: 1.8l R4/4V TFSI     0030
   Revision: AAH03---    Serial number: AUX7Z0I6FN30BT
   Coding: 0103000C18070160
   Shop #: WSC 06314 000 00000
   VCID: 428B05F11DA8F59645-8016
049446 - No Communications with Steering Angle Sender (G85)
               U0126 - 000 -
                    Mileage: 141447 km
                    Date: 2019.03.05
                    Time: 16:36:21
                    RPM: 773 /min
                    Load: 13.7 %
                    Temperature: 99.0°C
                    Temperature: 71.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.462 V
049682 - Steering Column Control Module
               U0212 - 000 - No Communications - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 90.0°C
                    Temperature: 60.0°C
                    Voltage: 12.827 V
Readiness: 0010 0001
   Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 000000000000000000000000000000000000
   VCID: 7EF3B101E9D0517661-802A
03306 - Coding Not Valid
                    Reset counter: 165
                    Mileage: 141449 km
                    Date: 2019.03.06
                    Time: 15:46:16
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 4161
                    Count: 49408
                    Fault Status: 01100101
                    Reset counter: 165
                    Mileage: 141449 km
                    Date: 2019.03.06
                    Time: 15:40:24
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 279
                    Count: 49408
                    Reset counter: 165
                    Mileage: 141449 km
                    Date: 2019.03.06
                    Time: 15:40:24
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 295
                    Count: 49408
                    Reset counter: 165
                    Mileage: 141449 km
                    Date: 2019.03.06
                    Time: 15:40:24
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 270
                    Count: 49408
                    Reset counter: 165
                    Date: 2019.03.06
                    Time: 15:41:33
                    Count: 7
                    Count: 2
                    Count: 12800
                    Count: 195
                    Count: 49408
   Part No SW: 8P0 820 043 BK    HW: 8P0 820 043 BK
   Component: KlimavollautomatH09 0130
   Revision: 000889      Serial number: 8P0820043BK
   VCID: 76E3A92101E0193639-8022
                    Fault Frequency: 30
                    Reset counter: 205
                    Mileage: 141376 km
                    Date: 2019.01.30
                    Time: 10:44:32
   Part No SW: 8P0 907 063 A    HW: 8P0 907 063 A
   Component: BCM PQ35  M   104 0541
   Revision: 00104 AH
   Coding: 0E000A2CB0051AC0207040E00100015C417A29AA106DC929E40008800040
   VCID: 326B55316D084516D5-8066
   Subsystem 1 - Part No SW: 8P2 955 119 F    HW: 8P2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350  H10 0040
   Coding: 00DD13
   Subsystem 2 - Part No SW: 8K0 910 557     HW: 8K0 955 559 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSEN  H04 0003
   Coding: 024C2D
                    Reset counter: 164
                    Mileage: 141449 km
                    Date: 2019.03.06
                    Time: 14:32:20
                    Voltage: 14.10 V
                        Term 50 Off
                    Fault Frequency: 9
                    Reset counter: 205
                    Mileage: 141449 km
                    Date: 2019.03.06
                    Time: 14:41:37
                    Voltage: 14.10 V
                        Term 50 Off
Address 10: Park/Steer Assist (J446)       Labels:. 8P0-919-475-7X1.clb
   Part No SW: 8P0 919 475 G    HW: 8P0 919 475
   Component: PARKHILFE 4K  H06 0120
   Revision: 11001001    Serial number: 93640918302551
   Coding: 000003
   VCID: 428B05F1DDA8F59645-8016
Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 P    HW: 8P0 959 655 P
   Component: Airbag AU1042 H06 0140
   Revision: --------    Serial number: 003FB0021BPP
   Coding: 30314238303830303037554A305238503053
   ROD: EV_Airba10AURB4.rod
   VCID: 4FAD3CC516FA08FEDA-801A
   Serial number: 3572DRB4000090D5131I
   Serial number: 3582DRB4000090C8F0A+
   Serial number: 35128RB400004EC9E982
   Serial number: 35228RB400004EC92D3X
   Serial number: 35547RB400004E3715CQ
   Serial number: 35647RB400004E37242H
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Coding: 0004042
   VCID: 468319E13180C9B669-8012
   Component: E0221           H06 0030
   Part No SW: 8P0 920 932 D    HW: 8P0 920 932 D
   Component: KOMBIINSTR. VDO H02 0980
   Revision: D0H02002    Serial number: 2246I002010639
   Coding: 0004710
   Shop #: WSC 00000 011 205300
   VCID: 35616E2D5C66522EF0-8060
00003 - Control Module
            014 - Defective
                    Fault Status: 01101110
                    Mileage: 156784 km
                    Date: 2016.06.15
                    Time: 11:21:46
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H16 0222
   Revision:   H16       Serial number: 4020K0970612D0
   Coding: E9A07F06100602000103
   Shop #: WSC 06314 123 12345
   VCID: 66C3F9615140E9B689-8032
                    Reset counter: 165
                    Mileage: 141449 km
                    Reset counter: 205
                    Mileage: 141449 km
   Revision: D0H02002    Serial number: AUX7Z0I6FN30BT
   Part No SW: 8P0 959 801 N    HW: 8P0 959 801 N
   Component: Tuer-SG         H04 0100
   Coding: 0000660
02071 - Local Databus
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 232    2901
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 2F6D5C45BE3A68FEBA-807A
                    Fault Status: 11100101
                    Mileage: 141449 km
                    Date: 2019.03.06
                    Time: 14:32:20
                    Battery Volts: 14.1 V
                        DU
                    Temperature: 34.0°C
                    Count: 3
                    Steering Angle: 0.00°
                        SteerAng n.Init
Address 47: Sound System        Labels: 8Px-035-382.lbl
   Part No SW: 8P4 035 382 E    HW: 8P4 035 382 E
   Component: AB2 SUBWOOFERBOXH07 0180
   Revision: 00006       Serial number: 92158949284522
   VCID: 3663692141605936F9-8062
   Part No SW: 8P0 959 802 N    HW: 8P0 959 802 N
   Coding: 0000660
   VCID: 479D14E5368AD0BE92-8012
   Part No SW: 8P0 035 186 S    HW: 8P0 035 186 S
   Component: R Concert2+     H02 0280
   Revision: 00H02000    Serial number: AUZ1Z3I5129018
   Coding: 0710111
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
   Component: Tuer-SG         H04 0050
   Coding: 0000144
   Shop #: WSC 06314 000 1012544
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
   Coding: 0000144
   VCID: 438500F502B2FC9E4E-8016
   Part No SW: 8P0 862 335 AA    HW: 8P0 862 335 S
   Component: FSE_256x BT     H34 0600
   Revision: 00000000    Serial number: 00000005104427
   Coding: 0001292
   VCID: 75E1AE2D1CE6122E30-8020
End-------------------------(Elapsed Time: 02:44)--------------------------
DrPeter
16.4905° S, 151.7375° W
This ABS coding is VIN dependent, so trying just any coding will not work and is not advised.
Speaking of VINs, I have a couple questions....
Question (1) - Is this the true VIN on the vehicle's VIN plate? - [WAUZZZ8P6AA027585]
Question (2) - The "Status" of the [04-Steering Ange] is "Cannot be reached" Did any one replace the J500-Power Steering Rack/Control module or try to alter the adaptation channels for the J500, address [44-Steering Assist]?
You should verify that the Adaptation Channel [009] in the [44-Steering Assist] controller has a value of:
[0] = Internal Steering Angle Sensor active.
If there is a concern with the G85-Steering Angle Sensor, you may not be able to complete the Basic Settings for the G85.
So, if the VIN number is correct, then ABS coding should be as follows:
 1342401209240001C81002EC901E00813800
Please copy and paste the coding value above into the 'New Coding' box for the ABS controller.
Once the coding is accepted, the Basic Settings for the ABS controller need to be completed, see this Ross-Tech wiki page for more info: Brake Electronics (MK60EC1)
Please let us know how this works out for you or if you have any questions,
drpeter
Jaso
Brisbane,Australia
C?ID=250826
Hi @DrPeter ,
Thank you for the coding my friend the ABS accepted it first go and the VIN number is correct.
I do not know the history of the vehicle unfortunately. It appears that previous owner/mechanic for some reason had replaced the original steering wheel for what i believe is a TT steering wheel or S3 from same gen with the flat bottom.
After ABS coding provided was accepted i proceeded with the necessary basic adaptation which successfully turned off the illuminated ABS light and steering wheel light on dash but not the ESP light. As suspected G85 was giving me the issues and in [44-Steering Assist] [009] Adaptation Channel the value was 1 for some reason. I proceeded to change it to value of 0 and did the basic adaptation which turned off the illuminated ESP error on dash.
Below i provide two scans for reference and any further suggestions on my remaining few codes.
Scan after correct coding was provided and basic adaptation was carried out for G200 and G201 from memory but ESP was still illuminated on dash:
Saturday,10,October,2020,11:13:10:10020
VIN: WAUZZZ8P6AA027585   License Plate: AUDIA3
Mileage: 141450km-87892mi   Repair Order:
VIN: WAUZZZ8P6AA027585   Mileage: 141450km-87892miles
               U0126 - 000 -
                    Mileage: 141450 km
                    Date: 2019.03.07
                    Time: 10:26:45
                    RPM: 773 /min
                    Load: 14.1 %
                    Temperature: 99.0°C
                    Temperature: 56.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.462 V
Readiness: 0110 0001
   Revision: 00H45001
   Coding: 1342401209240001C81002EC901E00813800
                    Reset counter: 166
                    Mileage: 141450 km
                    Date: 2019.03.07
                    Time: 10:31:18
                    Count: 2
                    Count: 2
                    Count: 12800
                    Count: 166
                    Count: 49408
                    Reset counter: 166
                    Mileage: 141450 km
                    Date: 2019.03.07
                    Time: 10:31:18
                    Count: 2
                    Count: 2
                    Count: 12800
                    Count: 295
                    Count: 49408
                    Fault Frequency: 34
                    Reset counter: 206
                    Mileage: 141376 km
                    Date: 2019.01.30
                    Time: 10:44:32
   Revision: 00104 AH
   Coding: 00DD13
   Coding: 024C2D
                    Reset counter: 166
                    Mileage: 141450 km
                    Date: 2019.03.07
                    Time: 10:31:17
                    Voltage: 13.85 V
                        Term 50 Off
   Coding: 000003
   Coding: 0004042
   Coding: 0004710
            014 - Defective
                    Mileage: 156784 km
                    Date: 2016.06.15
                    Time: 11:21:46
                    Reset counter: 166
                    Mileage: 141450 km
   Coding: 0000660
   Revision: 00H17000
   Coding: 0000660
   Coding: 0710111
   Coding: 0000144
   Coding: 0000144
   Coding: 0001292
End-------------------------(Elapsed Time: 02:05)--------------------------
Below is final scan after carrying out
[0] = Internal Steering Angle Sensor active - And doing basic adaptation from Brake Electronics (MK60EC1) for G85 which turned off my ESP light on dash. Currently no errors on dash.
Saturday,10,October,2020,11:40:01:10020
VIN: WAUZZZ8P6AA027585   License Plate: A3
               U0126 - 000 -  - Intermittent
                    Mileage: 141450 km
                    Date: 2019.03.07
                    Time: 10:26:45
                    RPM: 773 /min
                    Load: 14.1 %
                    Temperature: 99.0°C
                    Temperature: 56.0°C
                    Voltage: 13.462 V
   Revision: 00H45001
                    Fault Frequency: 34
                    Reset counter: 206
                    Mileage: 141376 km
                    Date: 2019.01.30
                    Time: 10:44:32
   Revision: 00104 AH
   Coding: 00DD13
   Coding: 024C2D
   Coding: 000003
   Coding: 0004042
   Coding: 0004710
            014 - Defective
                    Mileage: 156784 km
                    Date: 2016.06.15
                    Time: 11:21:46
   Coding: 0000660
   Revision: 00H17000
   Coding: 0000660
   Coding: 0710111
   Coding: 0000144
   Coding: 0000144
   Coding: 0001292
End-------------------------(Elapsed Time: 02:04)--------------------------
United States
Thanks for the detailed update and scans! The Intermittent DTCs in Addresses 01 and 08 should clear.
Address 17: Instruments 00003 - Control Module - Defective isn't a great sign. I would not replace the 17/25 module unless there's an actual problem. However, if this vehicle suffers from reoccurring lost ABS coding, Immobilizer problems or cluster functionality issues (malfunctioning gauges, etc) .. it may be necessary to replace it at some point in time. VCDS cannot match this generation Immo system so a trip to the dealer (assuming you don't have a mobile locksmith in the area with an online Immobilizer operation subscription) would be necessary.
Best,
