2020 Atlas Cross Sport - VCDS changes won't take effect
rocamet
Rancho Cucamonga, CA, USA
C?ID=419570
I was so excited to receive this software and Hex-V2 cable......all of the wonderful little tweaks I was going to make. Now it seems like it's the most horribly frustrating thing I've had to deal with.
I have spent hours, watched several videos and have been all over this forum, following all the instructions I can and watching things work for others but not me. I go to the correct module, change the correct channel, VCDS accepts the change, reads it again successfully, nut no change to the car.
For example, I made this change to the blinker when you push it down and release it, verified it worked for the other users, and still I get nothing. Do I need to do something besides click "Do It!"?
  1. [09-Cent. Elec.]
  2. ENG141649-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen
  3. Changed value from 3 to 5
  4. Marked "Soft reset
  5. Clicked "Do It!
  6. Car still only blinks 3 times
AutoScan:
Wednesday,07,October,2020,21:57:57:21681
VIN: 1V2NE2CA0LC213197   License Plate:
Chassis Type: CA-VW41 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 36 3C 42 44 47 4B 52 5F
          69 6C 6D 75 A5 CA D6 D7
VIN: 1V2NE2CA0LC213197   Mileage: 859km-533miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CDVC)       Labels: None
   Part No SW: 03H 906 026 AG    HW: 03H 907 309 K
   Component: VR6 3.6l FSI  H21 9970
   Revision: 52H21000
   Coding: 012A003244740108F0000000000000000000000000000000
   Shop #: WSC 06050 062 00200
   ASAM Dataset: EV_ECM36FSI01103H906026AG 001006
   ROD: EV_ECM36FSI01103H906026AG.rod
   VCID: 6A8DC661CCFAA24BEC7-803E
   CAN Converter 01:
22593 - Fuel Level Sensor Circuit
          P0461 00 [096] - Implausible Signal
                    Mileage: 203 km
                    Date: 2020.09.20
                    Time: 13:54:22
                    Engine speed: 1495.00 /min
                    Normed load value: 39.6 %
                    Vehicle speed: 85 km/h
                    Coolant temperature: 83 °C
                    Intake air temperature: 34 °C
                    Ambient air pressure: 940 mbar
                    Voltage terminal 30: 12.740 V
                    Unlearning counter according OBD: 18
                    Outside air temperature: 31 °C
                    Air mass: actual value:: 17.22 g/s
                    Engine torque: 133.1 Nm
                    Fuel: tank fill level: 70.0 l
                    Oxygen sensor bank 1 sensor 1: specified value: 1.0000
                    Intake camshaft bank1 active operating mode-Bits 0-7: 0
                    Overrun cut-off-Bits 0-7: 0
   Part No SW: 09G 927 158 DR    HW: 09G 927 158
   Component: AISIN AQ8     206 3742
   Coding: 0000000100000000000000000000000000000000
   ROD: EV_TCMAQ450031_VW37.rod
   VCID: 065592D1F8A2662B68F-8052
   Part No SW: 5Q0 614 517 DL    HW: 5Q0 614 517 BP
   Component: ESC           H35 0113
   Revision: 00000000    Serial number: 50410000000867
   Coding: 85FC6B8D80211A6FC5780309A2CA69A1D60158A3C045967638415058D2AA4A0B004023641C12141A1D8DDB45506CC8CF
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 049012
   ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
   VCID: 7EA5FA31A0723EEB20F-802A
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0536888289
   Coding: 1F20000723
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 45D755DD8524AD33215-8010
   Subsystem 1 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 14277850
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 3CM 907 044 B    HW: 3CM 907 044 B
   Component: Climatronic   H05 2401
   Revision: 00001K04
   Coding: 1402002620001C0C1104010C9210D52C
   ASAM Dataset: EV_ACClimaBHBVW416 002015
   ROD: EV_ACClimaBHBVW416.rod
   VCID: 3D273D3DEDF4E5F3795-8068
   Part No SW: 5Q0 937 085 CC    HW: 5Q0 937 085 BG
   Component: BCM MQBAB HNA H40 0312
   Serial number: 0032036602ÿÿÿÿ
   ASAM Dataset: EV_BCMMQB 020001
   ROD: EV_BCMBOSCH_020.rod
   VCID: 7CA1F039B66E2CFB0EB-8028
   Subsystem 1 - Part No SW: 5Q0 955 555 A    HW: 5Q0 955 555 A
   Component: RLHSS  051  0207
   Serial number: S7Y19M12D17H18M00S56
   Coding: 0018DD
   Steering Column Switch:
   Subsystem 2 - Part No SW: 5Q1 953 521 AC    HW: 5Q1 953 569 B
   Component: Lenks.Modul  H23  0170
   Serial number: 0300070220200C200538
   Seat Backrest Fan 1 Front Left:
   Subsystem 3 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Component: SysNameFanLin  014  0101
   Serial number: ESE0646341
   Seat Cushion Fan 1 Front Left:
   Subsystem 4 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0567928
   Seat Backrest Fan 1 Front Right:
   Subsystem 5 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0935201
   Seat Cushion Fan 1 Front Right:
   Subsystem 6 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0537213
   Part No SW: 5QA 919 298 H    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H08 0061
   Serial number: 000259541119268
   Coding: 0271267951
   ASAM Dataset: EV_EPHVA2CAU3700000 009048
   ROD: EV_EPHVA2CAU3700000_VW41.rod
   VCID: 55F7859D75841DB3515-8000
   Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0372
   Coding: 320007CB58FF8728949C810530409700000000000000000004
   ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
   VCID: 43D34BC58B1093030F1-8016
0858 - Databus
          [FAULT_KAMERA_SYSTEMZUSTAND_KAMERA_IM_INIT]
                    Reset counter: 67
                    Mileage: 31 km
                    Date: 2020.04.16
                    Time: 18:36:25
                    Voltage terminal 15: 13.3 V
                    Control Module temperature: 43 °C
                    Vehicle speed: 4.16 m/s
                    Longitudinal acceleration: -0.03 m/s²
                    Adaptive distance regulation: status: ACC_StandBy
0836 - Databus
          [FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
                    Reset counter: 90
                    Mileage: 793 km
                    Date: 2020.10.03
                    Time: 18:48:31
                    Voltage terminal 15: 13.2 V
                    Control Module temperature: 74 °C
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: 0.03 m/s²
   Part No SW: 3Q0 959 655 DB    HW: 3Q0 959 655 DB
   Component: Airbag VW21   006 0720
   Revision: --------    Serial number: 00310M37QVXe
   Coding: 8CCCFC00000000005000001AC20840000065
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 015F81CDD18C41135DD-8054
   Occupant Detection:
   Component: Occ.Detection  H14 0022
   Serial number: IBH0000D19000CPOO00P
   Coding: 303030
   Subsystem 2 - Part No SW: -----------    HW: 454 002 711 19
   Serial number: 35700000000E1B3D224M
   Subsystem 3 - Part No SW: -----------    HW: 454 002 010 19
   Serial number: 358000000001B8600144
   Subsystem 4 - Part No SW: -----------    HW: 454 802 801 20
   Serial number: 3510003CF1F1B000000O
   Subsystem 5 - Part No SW: -----------    HW: 454 802 801 20
   Serial number: 3520096B99E1A000000-
   Subsystem 6 - Part No SW: -----------    HW: 454 802 801 20
   Serial number: 355000365161B0000003
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 454 802 801 20
   Component: FrontSensor_P  304 0149
   Serial number: 356004160161B0000001
   Part No SW: 3G0 920 890 E    HW: 3G0 920 890 E
   Component: KOMBI         503 4193
   Coding: 00A438086F8CCF050288630B50010000A0001009
   ASAM Dataset: EV_DashBoardVDDMQBA0 001042
   ROD: EV_DashBoardVDDMQBA0_VW37.rod
   VCID: 2B03036503807B43D71-807E
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5388
   Serial number: 07022000842261
   Coding: 0B0500347F087300FB03225A1E0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 70B9D409EA26589BA23-8024
   Component: 4-01-0e-01-04
   Subsystem 2 - Part No SW: 3G0 959 442 H    HW: 3G0 959 442 H
   Component: E221__MFL-PR6  H06 0110
   Serial number: PR6-0440036015201830
   Coding: 2E0B00
   Serial number: 0621947100
   Power Converter DC AC:
   Subsystem 4 - Part No SW: 3CN 907 155     HW: 3CN 907 155
   Component: U13DCAC  H23 0890
   Serial number: B060193
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00014.11.19
   Coding: 0101
   VCID: 4CC160F9A64E5C7BFEB-8018
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 E    HW: 5Q0 959 760 E
   Component: Sitzmemory    H09 0026
   Serial number: Y0007TA930554
   Coding: 0010000000000500018280808080000000008100000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   VCID: 3FDB4735E7F8F7E36B9-806A
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H06 0148
   Serial number: 11230022775113
   Coding: 62954640
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15.rod
   VCID: 392F292DF9DCD9D355D-806C
   Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
   Component: TSG FS002 0325
   Serial number: YA008TAO00GC1
   Coding: 003B1B205200020000040000
   VCID: 49CF59EDA93C4953C5D-801C
   Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000005277632
   Coding: 011000
   Part No SW: 3QF 909 144 B    HW: 3QF 909 144 A
   Component: EPS_MQB_ZFLS  570 1582
   Coding: 9B1F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 47CB5FD5BF28BF23D39-8012
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1KMD06V9D+
   Coding: 2200000002A2AAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 2E050A7130920E6BF0F-807A
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 27012000840740
   Coding: 000000070900135202112300030000000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_003_VW41.rod
   VCID: 372B2F15CFC8CFA3A39-8062
Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
   Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
   Component: TSG BFS002 0325
   Serial number: YA008TBD002X6
   Coding: 003B13205E00020000040000
   VCID: 48C95CE9B236B05BDA3-801C
   Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000005273537
   Coding: 091000
   Part No SW: 2GM 035 876 C    HW: 2GM 035 876 C
   Component: MU-S-NS-US    854 0523
   Coding: 022436020000000051220002001808211F0500E40120040586
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 46D552D1B822A62B28F-8012
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  261 8214
   Serial number: VWZ6ZMX0465846
   Subsystem 2 - Part No SW: 5NA 919 866 AF    HW: -----------
   Component: NAR 2020  --- 1320
Address 69: Trailer (J345)       Labels:* None
   Part No SW: 5H0 907 383     HW: 5H0 907 383
   Component: Anhaenger     H09 0040
   Serial number: 000000000005379
   Coding: 0200000200001300
   ASAM Dataset: EV_TrailFunctGener3Hella 001009
   ROD: EV_TrailFunctGener3Hella_VW27.rod
   VCID: 6B83C365C300BB43971-803E
   Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
   Component: Areaview 2    H13 0608
   Serial number: C854707JG068730
   Coding: 01140600A30F20003000400C
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   ROD: EV_CamSysRVAV2ARCE2MQBAB.rod
   Part No SW: 5Q0 959 107 S    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0271
   Revision: --------    Serial number: A2-C758-8680-4
   Coding: 2F88
   Part No SW: 5WA 035 283     HW: 5WA 035 283
   Component: OCUGen3Low    H10 0295
   Serial number: 0000000911NVWP6
   Coding: 0241602019682C208005461160500607
   ASAM Dataset: EV_OCUGen3Low 002036
   ROD: EV_OCUGen3Low_002_VW41.rod
   VCID: 025D8EC1D48A5A0B447-8056
1644017 - Online Services
          B1915 F1 [008] - Temporary Function Restriction due to Battery Budget
          [Functional restriction due to insufficient power budget]
                    Reset counter: 4
                    Voltage terminal 30: 12.2 V
                    Remaining long term energy budget: 0 mAh
                    Remaining short term energy budget: 936 mAh
                    Wake up cycles counter: 115
   Part No SW: 2Q0 980 653     HW: 2Q0 980 653
   Component: MQB MFK 3.0   H11 1029
   Serial number: E33417011193400
   Coding: 00000A081178C020B09F00001020002000210000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005035
   ROD: EV_MFK3ValeoMQB_005_VW27.rod
   VCID: 72BDDE01E42A6A8B547-8026
1124198 - Development code 1
          B2F01 00 [008] - -
          [VZF_Init]
                    Fault Priority: 9
                    Reset counter: 26
                    Mileage: 164 km
                    Date: 2020.09.17
                    Time: 09:19:33
   Coding: 00804074161C
   ROD: EV_SunRoofCONTIAU736_009_VW37.rod
   VCID: 75B7E51D95447DB3715-8020
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 992 941 572 AA    HW: 992 941 572 A
   Component: LED1L         H08 9002
   ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
   VCID: 629DAE4134CAFA0B247-8036
Address D7: Light Ctrl Right 2 (A27)       Labels: None
   Component: LED1R         H08 9002
End----------(Elapsed Time: 01:52, VBatt start/end: 12.2V/12.2V)-----------
@rocamet : Hi - I've never heard of Rancho Cucamonga (it looks very nice)
The excitement and sense of eager anticipation in playing with your new toy is palpable in your writing (especially since it's emphasised by the bolded text :D) - entirely understandable and it's no doubt reminiscent for the experience of many other forum colleagues here !!
As for your tweak instructions - I suspect that there is just one step missing; the tweak is normally completed with an additional "in-car" procedure.
With the changes that you identify made - try this:
  1. Press the Car button on the RHS of the discover/composition media head.
  2. Press Set-up on the bottom RHS of the screen
  3. In the Vehicle Setting screen, press the Factory Settings panel (it's at the very end of the list at the bottom of the screen)
  4. In the Factory Settings screen, under Reset individual settings/data, press Vehicle
  5. Press Reset tab in the window that says Reset "Vehicle" settings-are you sure?
Unfortunately, the consequence of resetting Vehicle to factory settings is (not surprisingly) that any previously stored personal settings will be lost, so you will have to re-establish these values.
rocamet
C?ID=419570
Thank you Don.
I assume the dealer does not alter any settings and reverting back to "factory" settings will be the same as when I took possession of the car from the dealer?
TBAx
C?ID=287144
Depends on your dealer. My car came with radio station logos and some useful settings preset, which the dealer stated where things most people want to have by default.
rocamet
C?ID=419570
@DV52 Don, I'm a little afraid to revert to factory settings for fear of changing something the dealer did. Could I do a restore from the original auto scan hex file that I created before I made any changes to module 09? Would that accomplish the same thing?
@rocamet: I understand your reticence but the stuff that's reset to factory values are your personal settings like opening all the doors instead of the only the driver's door - which can be easily reinstated via the MENU screen.
Anyhow, If you want to narrow down the risks - in Factory settings, there's a list of sub-options like this:
– Vehicle (All settings)
– Driver assist systems
– Parking/manoeuvring
– Light
– Mirrors and wipers
– Opening/closing
– Multifunction display
Try selecting Lights instead of Vehicle in step 4 above - this should limit the scope of any possible changes to the light-function only.
And, if you want to further minimize the impact of a possible reset of your personal settings - here's the list of places in the MENU where you may have inputted your personal settings for the Light function (I thieved this from an on-line owner's manual for a Golf mk7, so it may be a little different on your car)
Light settingsLight AssistThe following functions can be activated or deactivated:
– Dynamic Light Assist
– Dynamic bend lighting
– Automatic dipped headlights (when raining)
– Lane change flash.
The following functions can be set:
– Switch-on time for the automatic headlight control
– Travel mode (right-hand or left-hand drive).
Interior lightingThe following functions can be set:
– Courtesy light (instruments and switches)
– Background lighting in the doors
– Footwell lighting.
Coming Home/Leaving Home functionThe following functions can be set:
– Switch-on period of the Coming Home function
–Switch-on period of the Leaving Home function.
Scroll through each option and jot-down your values BEFORE you do the factory reset. Then AFTER the factory reset - go back through the list and reinstate your previous values
@DV52 Could I do a restore from the original auto scan hex file that I created before I made any changes to module 09? Would that accomplish the same thing?
I-would-bet-London-to-a-brick that the handy-dandy restore files that are generated by VCDS address "lower order" data than the personal setting database - meaning that whilst they will reinstate the long-code string and adaptation channel values of the module back to the state when the file was generated, they don't record any personal-settings that may have been established in the MENU. Perhaps one of the deities from Ross-Tech could confirm?
I've no hand-on experience with the exact infotainment system in the OP's vehicle, but I'd be inclined to agree. That said, anything personalization he's done via the menus it that system can certainly be re-done. I mean he did it once and can do it again, right?
@Uwe: unquestionably, without doubt and indubitably correct !!
I'm not sure if OP's reluctance to proceed is driven by the term "factory reset" and the horror stories that abound on this and other forums regarding a similarly named facility in basic -settings on some modules. If so, then OP should rest assured that the MENU based function bearing this name is much more benign than its counterpart within VCDS, proper - which for the latter and similar to cliches, should be avoided like the plague:)!!!
But ultimately whether to proceed (or not) is really a personal judgement about risk/reward - I guess (personally, I would be more worried about stuffing-up the process for the adaptation channel change than the risk of the "in-car" procedure going pear-shape!)
rocamet
C?ID=419570
I just reset the "Lights" factory settings via the in car menu and it accepted the blinker changes. I didn't even have to go back and verify the change in VCDS.
Thank you everyone, much appreciated!
