Seat alhambra handbrake module location
Radiosolutions
C?ID=178437
63 reg 2.0tdi. Chassis 7n. Can someone tell me were the parking brake module is located please ln this car.thanks
DrPeter
16.4905° S, 151.7375° W
Hello on a 2013 Volkswagen Sharron (7N1), as per the factory repair manuals, the "J540-Control unit for electromechanical parking brake" is located " Under centre console, near front arm rest".
We recommend to use the Official Factory Repair Information for the wiring diagrams/component locations and repair manuals.
Hope this helps.
drpeter
Radiosolutions
C?ID=178437
Not in centre. Got all console out.
DrPeter
Hello again,
Are you looking in the center of the dash/console? Both the [7N1] VW Sharron and the [710] Seat Alhambra Official Factory Repair Information show the J540 in the same place.
In the repair manuals for the Seat Alhambra 2010 > [71] , in the "Fitting Locations" diagram No.805/11, it says:
1.9 Control unit for electromechanical parking brake -J540-
1 - Control unit for electromechanical parking brake -J540-
Fitting location:
❑ Under centre console, near front armrest
Connector:
❑ -A- 30-pin connector -T30-
They use the same image too, [N97-11835], interesting... (sorry I can not post it, we do not have the re-print rights)
Maybe you need to post a a complete Auto-Scan of the vehicle in question, VIN and all.. That way we can confirm what we are looking at.
Thank you,
drpeter
drpeter
Radiosolutions
C?ID=178437
Hello again,
Thank you,
drpeter
drpeter
Radiosolutions
C?ID=178437
spoke to seat. apparently park brake module is incorporated into the abs module. i fitted a new one but have one fault left and the autohold button does not work or light up. can someone check the coding scan attached to see if something is coded incorrectly. thanks
Wednesday,14,October,2020,16:06:51:28694
VCDS Version: 20.4.2.0  HEX-V2 CB: 0.4513.4
Dealer/Shop Name: autoelec
VIN: VSSZZZ7NZGV728499   License Plate: KT16PZY
Mileage: 47420km-29465mi   Repair Order: ALAMBRA.7N.NEW
Chassis Type: 7N-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 20 25 36 42 44 46 4C 4F 52
          53 5F 61 62 6C 6D 72 BE BF
VIN: VSSZZZ7NZGV728499   Mileage: 47420km-29465miles
BE-Slid. Door Rear Left -- Status: OK 0000
BF-Slid. Door Rear Right -- Status: OK 0000
Address 01: Engine (J623-DFLA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 016 HE    HW: 04L 907 309 K
   Component: R4 2,0L EDC   H20 1624
   Revision: 8AH20---
   Coding: 011D001A042511082000
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_ECM20TDI01104L906016HE 001003
   ROD: EV_ECM20TDI01104L906016HD_001_VW36.rod
   VCID: 73B3D8A3EB3229F35F1-8026
   Part No SW: 02E 300 063 B    HW: 02E 927 770 AL
   Component: GSG DSG AG6     531 4904
   Revision: 06253104    Serial number: 00001604052322
   Shop #: WSC 00020 551 00000
   VCID: 1577C63BC98697C3915-8040
   Part No SW: 5N0 614 109 CR    HW: 5N0 614 109 CR
   Component: ESC-EBC460iV1 H15 0023
   Serial number: A01U6KY
   Coding: 11F0449A8922C274087B880922CC91431039170000014884
   ASAM Dataset: EV_Brake1ESCEPBTRW 006353
   ROD: EV_Brake1ESCEPBTRW_006.rod
   VCID: 7DA7FE9BDD766F83395-8028
0402 - Overboost Adapation Not Performed
          C1140 00 [009] - -
0559 - No Basic Setting
          B2010 00 [137] - -
          [PBC_EVENT_PBC_IN_ASSEMBLY_MODE]
                    Reset counter: 195
                    Mileage: 47425 km
                    Date: 2020.10.09
                    Time: 01:33:35
                    Additional_Codes: 00 00 00 0C D0 7F 00 48 0A
                    DTC: 00 02 2F
                    Additional2: 00 02 01 02 05 22 3B 00 3B 00
   Part No SW: 7N0 907 044 AN    HW: 7N0 907 044 AN
   Component: Clima-Sharan  H03 0606
   Revision: 00001K05
   Coding: 021010C549
   VCID: 7CA1F39FC66C668B0EB-8028
   Slave 1:
   Subsystem 1 - Part No SW: 7N0 907 049 C    HW: 7N0 907 049 C
   Component: KBT-H  004 0103
   Serial number: 20160419000000052190
   Part No SW: 5K0 937 086 T    HW: 5K0 937 086 T
   Component: BCM PQ35 M    122 0183
   Revision: BC122001
   Coding: 40590A3F8925E1C0508800C8B400817403D10008636D2D226480C72000C1
   Shop #: WSC 00020 790 00000
   VCID: 45D7567BF5A6E743215-8010
   Subsystem 1 - Part No SW: 7N2 955 119 B    HW: 7N2 955 119 B  Labels: 1KX-955-119.CLB
   Component: WWS428 120216  024 0644
   Serial number: 16020903004611
   Coding: 004DBD
   Component: RLHS  037 0059
   Serial number: S3Y16M04D24H22M53S31
   Coding: 0228DD
   Part No SW: 1K8 919 472 B    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0479
   Revision: --------    Serial number: 39331611408896
   Coding: 0031151011
   ASAM Dataset: EV_EPHVA18VW364GP00 001006
   ROD: EV_EPHVA18VW364GP00_VW32.rod
   VCID: 363521B7B8C07CDBB8F-8062
   Part No SW: 7N0 959 655 D    HW: 7N0 959 655 D
   Component: VW10Airbag10D H15 0016
   Serial number: 003PWP6XP69Z
   Coding: 003044
   ASAM Dataset: EV_AirbaVW10TS6VW428 A01010
   ROD: EV_AirbaVW10TS6VW428.rod
   VCID: 40D9476FEA04C26B123-8014
   Serial number: 3493ETS60B7547C1C9D5
   Serial number: 3503ETS60C11C811C9DT
   Serial number: 3513ETS6075747C1C9D.
   Serial number: 3523ETS60C50F7E1C9D6
   Serial number: 35540TS60B4067C1CDDU
   Part No SW: 5K0 953 521 FN    HW: 5K0 953 569 BD
   Revision: FF010042    Serial number: 20160422301246
   Coding: 1892240000
   ROD: EV_SMLSNGVOLWSR8C.rod
   Subsystem 1 - Part No SW: 7N5 919 719     HW: 7N5 919 719   Labels: 3C8-959-537.CLB
   Serial number: 000000000B1176290316
   Coding: 011000
   Part No SW: 7N5 920 980 A    HW: 7N5 920 980 A
   Component: KOMBI         H04 1007
   Coding: 440F010000
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
   VCID: 372B2CB3BFCA85D3A39-8062
   Part No: 7N0 963 271 G
   Component: Zuheizer        051 3041
   Revision: 00051000    Serial number: 09028242000000
   Coding: 0000041
   VCID: 38292F8FBE548AABAA3-806C
   Part No SW: 7N0 907 530 BF    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1673
   Revision:   H55       Serial number: 240416F1001992
   Coding: 468233
   Shop #: WSC 00020 790 12345
   VCID: 75B7E6BBE5C637C3715-8020
Address 20: High Beam Assist. (J844)       Labels:| 8S0-857-511.clb
   Part No SW: 3G0 857 511 AJ    HW: 3G0 857 511 G
   Component: FLA           H10 0003
   Revision: AA001001
   Coding: 010101F800000100000000
   ASAM Dataset: EV_HighBeamAssisAU316 001004
   ROD: EV_HighBeamAssisAU316.rod
   VCID: 70B9D7AF9A2412EBA23-8024
   Component: IMMO          H04 1007
   VCID: 6A8DC5C7BCF8E83BEC7-803E
   Part No SW: 3C8 959 760 E    HW: 3C8 959 760 E
   Component: Sitzmemory    H05 3101
   Revision: 00H05000
   Coding: 000018
   Shop #: WSC 12336 024 394758
   VCID: 372B2CB3BF4A85D3A39-8062
   Part No SW: 7N0 959 793 J    HW: 7N0 959 793 G
   Component: TSG FA        H05 0561
   Revision:             Serial number: 0000195268877
   Coding: 01112E209E01411001
   VCID: 49CF5A4BD9BE0323C5D-801C
   Part No: 7N0 909 144 R
   Component: EPS_ZFLS Kl. 278    3501
   Revision: 00H21000
   VCID: 42DD4D67E888D07B047-8016
Address 4C: Tire Pressure II
   Component: EZE_2         H55 1673
   Coding: 050B0500
   VCID: 6FBBD4D3879A0D13BB9-803A
   Subsystem 1 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H04 0090
   Subsystem 2 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H04 0090
   Part No SW: 7N0 959 792 J    HW: 7N0 959 792 G
   Component: TSG BF        H05 0561
   Revision:             Serial number: 0000194193714
   Coding: 01112C209E01411001
   VCID: 48C95F4FC2B4FA2BDA3-801C
Address 53: Parking Brake
Address 5F: Information Electr. (J794)       Labels:| 5F0-035-MIB-STD2.clb
   Part No SW: 7N5 035 680 A    HW: 7N5 035 680 A
   Component: MU-S-ND-ER    H22 0245
   Serial number: SEZAZ2S5004403
   Coding: 04240801FF00000011111101008808001F01038600200100C6
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 313F12AB51AE5BE3EDD-8064
   Subsystem 1 - Part No SW: 6P0 919 866 D    HW: -----------
   Component: ECE 2016  --- 0521
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AM
   Component: Batt.regelung H55 1673
   Coding: 030F7873
   VCID: 71BFD2AB91AE1BE3ADD-8024
   Component: J367-BDM  H07 0180
   Serial number: 43105N55171491946678
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
   Part No SW: 7N0 959 794 L    HW: 7N0 959 794 H
   Component: TSG HL        H03 0561
   Revision:             Serial number: 0000195473554
   Coding: 01006C200001411001
   VCID: 4CC1635FD6CC160BFEB-8018
   Part No SW: 7N0 907 441 B    HW: 7N0 907 441 B
   Component: VW428 RVC Mid H04 0040
   Coding: 012408012201000700
   Shop #: WSC 00020 999 39850
   ASAM Dataset: EV_CamSysRearPANAVW428 002002
   ROD: EV_CamSysRearPANAVW428.rod
   VCID: 303917AF5AA452EBE23-8064
Address 6D: Trunk Elect. (J605)       Labels:| 7N0-959-107.clb
   Part No SW: 7N0 959 107 G    HW: 7N0 959 107 A
   Component: HDSG-Modul    H11 0250
   Revision: 41011001    Serial number: 096601909
   Coding: 0733334002
   ASAM Dataset: EV_HDSGVW428 201138
   ROD: EV_HDSGVW428_VW36.rod
   VCID: 3B23308383E2A1B3471-806E
   Component: TSG HR        H03 0561
   Revision:             Serial number: 0000195473555
Address BE: Slid. Door Rear Left (J558)       Labels: 7N0-959-244.clb
   Part No SW: 7N0 959 244 B    HW: 7N0 959 244 B
   Component: Schiebetuer_l 005 2414
   Serial number: 16162096
   ASAM Dataset: EV_AST A03704
   ROD: EV_AST.rod
   VCID: 38292F8FB2D48AABAA3-806C
Address BF: Slid. Door Rear Right (J731)       Labels: 7N0-959-244.clb
   Component: Schiebetuer_r 005 2414
   Serial number: 16161889
   ROD: EV_AST.rod
End----(Elapsed Time: 02:20, VBatt start/end: 11.9V/11.9V. VIgn 12.0V)-----
Address 03,5N0 614 109 CR,channel IDE04643-Overboost in brake system,adapted from,Unknown (16),to,1 ,
Address 03: DTCs cleared
MartinsX
Riga, Latvia
C?ID=268515
If You were asked Your question with included autoscan in first post, I and a lot of others here were be able to answer correctly from the first view at Your scan ;)
          C1140 00 [009] - -
          B2010 00 [137] - -
                    Reset counter: 195
                    Mileage: 47425 km
                    Date: 2020.10.09
                    Time: 01:33:35
                    DTC: 00 02 2F
I think problem is not in coding, fault codes are self-explaining. Some specific required adaptations and basic settings are missing/not performed or not finished successfully. Unfortunately no label file in VCDS for this module. But, as it is UDS based module and VCDS has dataset and *.rod file for it, it is possible the needed things may be found under Basic Settings and Adaptations. Maybe someone from RT can give You exact instructions. I can't without having my own hands on on Your or very similar car.
Radiosolutions
C?ID=178437
I managed to sort out the overboost adaptation. Just cannot find what to do with the basic setting fault. Can anyone help
Radiosolutions
C?ID=178437
Anyone please.
Radiosolutions
C?ID=178437
I use odis online. In the test plan. Just went through activations. Like handbrake on and off. Then fault was cleared. Thanks for the help
