Lamborghini Huracan Gearbox Adapt
Geelondon
London, UK
C?ID=396753
Hi all
I have recently carried out a clutch pack change on the huracan (2015)
The reason for the clutch pack upgrade to a Dodson supersport was because of the addition of twin turbo install.
I did carry out a gear box oil level check as per manufacturers guidelines and drove the car gently to make sure all was well sure enough it was but after a week of occasional driving I find that the car will go into gear but feels like the clutch dont bite. I did get a gearbox malfunction on the display but it said ok to drive
I will get a auto scan of the car when I'm next near it but in the meantime i just wanted to know will the HEX-NET allow......
1. adapt gearbox?
2. make tweaks to the line pressures ?
currently posting whilst away from work please don't shoot me down
Many thanks in advance and I will follow up the post with an Auto scan
DrPeter
16.4905° S, 151.7375° W
1. adapt gearbox?
As you mentioned, an Auto-Scan would be great!
So, (1) can VCDS " adapt gearbox?", short answer is not exactly, there is no Adaptation that is needed.Only the Basic Setting called - [Basic setting of transmission].
And (2), can you make "tweaks to the line pressures?" - Simple answer is NO. There is no provision from the manufacture, either through Adaptation or other function that VCDS or for that mater the factory tool would be able to perform a change like that. Unless the factory scan tool can change the actual software of the transmission controller. Maybe a tuner can?
Hope this helps,
drpeter
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
What you asking in not VCDS job. You need to talk to TUNER to tune transmission software for more HP and Torque.
Geelondon
London, UK
C?ID=396753
thanks for the replies guys
That clears up the questions I had will update my findings here should anyone else ever have similar issues
Geelondon
London, UK
C?ID=396753
good morning guys so as promised here is the auto scan of the car.
what i did was cleared the errors drove the car (just did not select gears or when in gear felt like they were not engaging) am going to tear down the box as the clutch packs were changed want to see if there is any obvious mechanical issue. Any thoughts of the experienced guys on here of what their thoughts may be on this
Dealer/Shop Name: GV Performance
VIN:    License Plate: 16HV
Mileage: 49730km-30900mi   Repair Order: gear selection issue
Chassis Type: 4T0
Scan: 01 02 03 05 08 09 11 31 15 16 17 19 22 30 3B 42 44 46 52 53
          55 56 5F 65 6C C2 D0
   Mileage: 49730km-30900miles
56-Radio -- Status: Cannot be reached 0100
C2-Auto Trans 2 -- Status: OK 0000
D0-Frt Axle Lift -- Status: OK 0000
Address 01: Engine
Address 02: Auto Trans (J217)       Labels:. 0BH-927-711.clb
   Part No SW: 4T0 927 155     HW: 0BH 927 711 D
   Component: 0BZ_52FSI_RdW H09 0813
   Revision: 00H09V01
   ASAM Dataset: EV_TCMDL800041 001009
   ROD: EV_TCMDL800041_AU72.rod
   VCID: 75A2C4F5D4878E2E30-8020
20448 - Clutch 1 Pressure Engagement too Low
          P2857 00 [044] - -
                    Fault Frequency: 13
                    Mileage: 49728 km
                    Date: 2012.01.09
                    Time: 19:34:55
                    Engine speed: 1945.00 /min
                    Vehicle speed: 255 km/h
                    Coolant temperature: 215 °C
                    selected gear: GANG_UNDEFINIERT
                    Engine torque: 52 Nm
                    Transmission fluid temperature: 17 °C
                    Accelerator position: 13.6 %
                    DTC memory status: 255
20449 - Clutch 2 Pressure Engagement too Low
          P2858 00 [044] - -
                    Fault Frequency: 96
                    Mileage: 49728 km
                    Date: 2012.01.09
                    Time: 19:35:40
                    Engine speed: 1923.00 /min
                    Engine torque: 28 Nm
                    Transmission fluid temperature: 19 °C
                    Accelerator position: 15.2 %
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4S0 907 379     HW: 4S0 907 379
   Component: ESP PREMIUM   H09 0087
   Coding: 21828141844181824B00
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004041
   ROD: EV_ESPPremiAU57X_AU72.rod
   VCID: 7AB8D7C9FD99E1565D-802E
0479 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [SCL_Gateway_05_TSG_FT_1_alt]
                    Reset counter: 56
                    Mileage: 49729 km
                    Date: 2012.01.12
                    Time: 04:08:25
                    VzRef: 00
                    Bit Info 1: 80
                    Bit Info 2: 0F
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 0E
                    Uz: 80
   Part No SW: 4H0 907 064 GB    HW: 4H0 907 064 GB
   Component: BCM2 2.0      H37 0572
   Coding: 01B03006000000000000
   VCID: 6FAEF69DBEDBB4FEFA-803A
   Serial number: 3215000104756002
                    Fault Status: 00101101
                    Reset counter: 56
                    Mileage: 49729 km
                    Date: 2012.01.11
                    Time: 22:41:08
   Part No SW: 4T0 820 043 E    HW: 4T0 820 043 E
   Component: KLIMA 1 ZONE  H03 0130
   Revision: A1015000    Serial number: 01050620150116
   Coding: 4A26008000
   VCID: 2E102B997951FDF6B1-807A
                    Reset counter: 56
                    Mileage: 49464 km
                    Date: 2012.01.01
                    Time: 10:59:54
                    Temperature: 10.0°C
                    RPM: 4280 /min
                    Speed: 90.0 km/h
                    Reset counter: 56
                    Mileage: 49729 km
                    Date: 2012.01.12
                    Time: 04:08:25
   Part No SW: 4H0 907 063 EK    HW: 4H0 907 063 EK
   Component: BCM1 2.0      H20 0367
   Revision: 25020001    Serial number: 00001092600302
   Coding: 00C90090402001202501C0C300000800001D47C8070602C10000081C0440100000400034010000
   VCID: 75A2C4F5DC878E2E30-8020
   Subsystem 1 - Part No SW: 4T2 955 114     HW: 955 114
   Component: WWS72x 150120  042 0015
   Serial number:         ????????????
   Coding: 0000F7
   Serial number: 24067586
   Coding: 02005D
   Subsystem 3 - Part No SW: 4T2 941 531 D    HW: 4T2 941 531 D
   Component: LCU  H02 0012
   Serial number: D178C8B7000000000001
02069 - Front Parking Aid Sensors
                    Reset counter: 16
                    Mileage: 49728 km
                    Date: 2012.01.08
                    Time: 05:04:54
Address 11: Engine II
   Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
   Component: Airbag10.43   H62 0086
   Revision: --------    Serial number: 003G0002AN0B
   Coding: 303333343033303030354A55304C34543053
   VCID: 342439F19F7DD726C7-8060
   Serial number: 3575HRB405N2R8P6DGPE
   Serial number: 3585HRB405L2R8P649M.
   Serial number: 3515JRB405V3GICEP0VF
   Serial number: 3525JRB405V3GICE81KW
   Serial number: 3554VRB405L3D7U881Q/
   Serial number: 3564VRB405N3D7U8O0SH
9443093 - Driver's Side Airbag Crash Sensor
          B1017 15 [136] - Open or Short to Plus
                    Mileage: 49729 km
                    Date: 2012.01.12
                    Time: 04:08:27
   Part No SW: 4T0 953 513     HW: 4T0 953 513
   Component: Lenks.Modul   H02 0090
   Revision: C0072465    Serial number: 90815OGE000AR
   VCID: 72A8FFE9ADE9991615-8026
   Subsystem 1 - Part No SW: 18G 959 542 B    HW: 18G 959 542 B
   Component: E221__MFL-TAS  H05 0012
   Serial number: 0005576 TAT 20150518
Address 17: Instruments (J285)       Labels:. 4T0-920-xxx-17.clb
   Part No SW: 4T0 920 900 B    HW: 4T0 920 900 B
   Component: KOMBIINSTR.   013 0159
   Revision: AA001001    Serial number: 25500113013MOC
   Coding: 21E8201483B122F0010000
03158 - Control Module for Information Electronics 1 (J794)
                    Fault Frequency: 99
                    Reset counter: 56
                    Mileage: 49430 km
                    Date: 2012.01.01
                    Time: 10:03:22
   Part No SW: 4T0 907 468 A    HW: 4S0 907 468
   Component: J533--Gateway H14 0065
   Revision: --------    Serial number: 00000001907795
   Coding: 000D071600
   ASAM Dataset: EV_GatewPkoUDS 001027
   VCID: 3B3612CDB223185E06-806E
   Subsystem 1 - Part No SW: 8K0 915 181 M    HW: 8K0 915 181 M
   Component: J367-BDM  H08 0190
   Serial number: 62166026403371249009
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 C    HW: 8K0 959 663 C
   Serial number: 15188000310021200410
5072 - Door Control Module - Driver's Door
          U0199 00 [008] - No Communications
                    Reset counter: 56
                    Mileage: 49729 km
                    Date: 2012.01.12
                    Time: 04:08:25
                    Voltage terminal 30: 11.2 V
                    Voltage terminal 15: 11.3 V
                    Control Module temperature: 23 °C
                    System status: Terminal 15 on
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
5073 - Door Control Module - Passenger's Door
          U0200 00 [008] - No Communications
                    Reset counter: 56
                    Date: 2012.01.11
                    Time: 22:40:33
                    Voltage terminal 30: 11.9 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 20 °C
                    System status: Awake_Timer_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
0267 - Optical data bus
          U1049 00 [009] - Open circuit
                    Reset counter: 16
                    Mileage: 49729 km
                    Date: 2012.01.13
                    Time: 01:21:31
                    Voltage terminal 30: 11.6 V
                    Control Module temperature: 22 °C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
Address 22: AWD (J492)       Labels: 4T0-907-160.clb
   Part No SW: 4T0 907 160     HW: 4T0 907 160
   Component: 4 Wheel Drive H02 0006
   Revision: 00001002    Serial number: BBM1LP2
   ASAM Dataset: EV_AllWheelContrBORGLB724 004010
   ROD: EV_AllWheelContrBORGLB724_004.rod
   VCID: 6FAEF69DB6DBB4FEFA-803A
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000073268
   Coding: 01010100000000000001020102
   Shop #: WSC 52569 001 1048576
   VCID: 648489B1671D07A697-8030
   Component: SARA 6D red   H04 0056
   Revision: --------    Serial number: EJ1BPA7E01M0LG
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 373E0EFD8E0B3C3EE2-8062
   Part No SW: 4T0 959 793 H    HW: 4T0 959 793 H
   Component: TSG FA        H07 0801
   Revision: --------    Serial number: 0000155715562
   Coding: 011C4B025001620100081102
   VCID: 4AD84709E5F9B1D68D-801E
02124 - Exterior Door Handle Switch
                    Reset counter: 56
                    Mileage: 49728 km
                    Date: 2012.01.09
                    Time: 20:58:09
01705 - Selection Switch for Mirror-Adjust (E48)
                    Reset counter: 56
                    Mileage: 49729 km
                    Date: 2012.01.11
                    Time: 19:01:05
00109 - Left Mirror Turn Signal Lamp (L131)
                    Fault Status: 00101100
                    Reset counter: 56
                    Mileage: 49729 km
                    Date: 2012.01.11
                    Time: 22:41:10
                    Reset counter: 56
                    Mileage: 49729 km
                    Date: 2012.01.11
                    Time: 22:41:13
   Part No SW: 4S0 909 144 G    HW: 4S0 909 144 B
   Component: EPS           H13 0904
   Revision: 00000000    Serial number:      L00088733
   Coding: 0800
   ASAM Dataset: EV_EPSZFAU72X 002010
   ROD: EV_EPSZFAU72X_002.rod
   VCID: 393A08C5B81F2A4E14-806C
   Revision: 00002001    Serial number: 0371541924
   Coding: 011B069A18B10881A030C804000503470000000000000000000000000000
   Subsystem 1 - Part No: 8J0 951 177
   Component: DWA-Sensor  H03 0030
                    Reset counter: 56
                    Mileage: 49729 km
                    Date: 2012.01.11
                    Time: 22:41:08
02615 - Fuel Tank Cap; Lock
                    Fault Status: 00101001
                    Reset counter: 56
                    Mileage: 49729 km
                    Date: 2012.01.12
                    Time: 02:53:39
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 56
                    Mileage: 49729 km
                    Date: 2012.01.12
                    Time: 02:53:42
                    Reset counter: 56
                    Mileage: 49729 km
                    Date: 2012.01.12
                    Time: 04:08:28
   Part No SW: 4T0 959 792 H    HW: 4T0 959 792 H
   Component: TSG BF        H07 0801
   Revision: --------    Serial number: 0000153913570
   Coding: 011C4B825001620100081100
   VCID: 49DA7805E0FFBACE84-801C
00110 - Right Mirror Turn Signal Lamp (L132)
                    Reset counter: 56
                    Mileage: 49729 km
                    Date: 2012.01.12
                    Time: 02:53:41
                    Reset counter: 56
                    Mileage: 49729 km
                    Date: 2012.01.12
                    Time: 04:08:29
                    Fault Status: 01101100
                    Reset counter: 16
                    Mileage: 49729 km
                    Date: 2012.01.13
                    Time: 04:07:39
   Part No SW: 4S0 907 801     HW: 8K0 907 801 J
   Component: EPB-4         H02 0001
   Revision: --------    Serial number: 20000000000950
   ROD: EV_ParkiBrake_AU72.rod
   VCID: 70ACF5E1ABE5AB06E3-8024
467968 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FC_SIGNAL_TSG_FT_1_ALT_OUT_OF_DATE]
                    Reset counter: 56
                    Mileage: 49729 km
                    Date: 2012.01.12
                    Time: 04:08:25
                    Voltage terminal 30: 11.3 V
                    Internal Fault ID: 208
                    Function light in parking brake button: On
                    Red operating lamp: On
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    RWU: not active
                    DSD: not active
                    HTR: active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: static
                    Status ParkingBrake left: Set
                    Status ParkingBrake right: Set
Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
   Part No SW: 4T0 907 357 A    HW: 4H4 907 357 A
   Component: ....AFS13.... H01 0003
   Serial number: 150710-0004-026
   Coding: 7184BF6118000300
   ASAM Dataset: EV_AFSLEDHELLALB72X 006131
   ROD: EV_AFSLEDHELLALB72X.rod
   VCID: 383C0DC183153346EB-806C
   Subsystem 1 - Part No SW: 7PP 941 329 S    HW: 7PP 941 329 S
H01 7020
   Coding: 150000
   Subsystem 2 - Part No SW: 7PP 941 329 S    HW: 7PP 941 329 S
H01 7020
   Coding: 150000
Address 56: Radio
Address 65: Tire Pressure (-----)       Labels: 3Y0-907-273.clb
   Part No SW: 4H0 907 273 B    HW: 4H0 907 273 B
   Component: RDKBERU25     H10 0820
   Serial number: 10000000017309
   ASAM Dataset: EV_RDKBERU25 003014
   ROD: EV_RDKBERU25_AU57.rod
   VCID: 2A1827894DB991D66D-807E
12652551 - Tire Pressure Monitoring
          C10DC 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 16
                    Mileage: 49728 km
                    Date: 2012.01.08
                    Time: 04:52:55
   Part No SW: 4T0 907 441     HW: 5Q0 907 441 A
   Component: LB72x RVC Mid H07 0030
   Coding: 080004010201000300
   ASAM Dataset: EV_CamSysRearPANAAU914 002002
   ROD: EV_CamSysRearPANAAU914.rod
   VCID: 71AAF0E5A0EFA20EEC-8024
9661203 - Cable for Video Signal from Rear View Camera
          B136B 13 [009] - Open Circuit
                    Reset counter: 16
                    Mileage: 49728 km
                    Date: 2012.01.08
                    Time: 04:52:56
                    passive
Address C2: Auto Trans 2 (J217)       Labels: None
   Part No SW: 4T0 927 109     HW: 4T0 927 109
   Component: DL800 ZSG     H28 0006
   Revision: --H28---    Serial number: 0000000114
   ASAM Dataset: EV_TCMDL800421 001019
   ROD: EV_TCMDL800.rod
   VCID: 74A4F9F1DFFD972607-8020
Address D0: Frt Axle Lift (J988)       Labels: None
   Part No SW: 4S0 959 257     HW: 4S0 959 257
   Component: Lift-VA006 1980
   Revision: 00000000    Serial number: 151490777
   Coding: 030607
   ASAM Dataset: EV_LiftVA003 001001
   ROD: EV_LiftVA003.rod
   VCID: 7CB4D1D1F7ADDF664F-8028
End----(Elapsed Time: 01:53, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
