@cschmitz20 : Hi. Your previous 2 x posts were unrelated to - so an autoscan of the car was not needed. However, this matter might be a tad different - see
here !
here !
-Lite Windows Based VAG/VAS Emulator Version: Release 1.2
www.Ross-Tech.com Workshop Code: 000 00000 Self-Diagnosis Log Wednesday, 19 August 2020, 15:15:04:11085 VIN Number: WAUAT48H63K022250 License Plate: Mileage: Repair Order: Chassis Type: 8H - Audi Cabrio B6 Scan: 01,02,03,08,09,0F,11,15,16,17,18,26,36,37,45,46,55,56,57,63,65,67,73,75,76,77 ------------------------------------------------------------------------------- Address 01: Engine Labels: 06C-909-559-ASN.LBL Controller: 8E0 909 559 E Component: 3.0L V6/5V G 0004 Coding: 0016584 Shop #: 00672 VCID: 370183920655 No fault code found. Readiness: 0000 1100 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 01J-927-156.LBL Controller: 01J 927 156 FE Component: V30 01J 3.0l 5V USA 3031 Coding: 01001 Shop #: 03213 VCID: 749B749E57A3 1 Fault Found: 18161 - Tiptronic Switch (F189): Implausible Signal P1753 - 35-10 - - - Intermittent ------------------------------------------------------------------------------- Address 03: Brakes Labels: 8E0-614-517.LBL Controller: 8E0 614 517 G Component: /ESP front 2328 Coding: 04499 Shop #: 00672 VCID: 2C2BACFECF13 No fault code found. ------------------------------------------------------------------------------- -Lite Self-Diagnosis Log Wednesday, 19 August 2020, 15:15:05:11085 Page 2 VIN Number: WAUAT48H63K022250 License Plate: Address 08: Auto HVAC Labels: 8E0-820-043.LBL Controller: 8E0 820 043 L Component: A4 Klimaautomat 1116 Coding: 00100 Shop #: 00672 VCID: 2A27AAE6C5E7 5 Faults Found:
01274 - Air Flow Flap Positioning Motor (V71) 41-10 - Blocked or No Voltage - Intermittent 00975 - Heated Rear Window (Z1) 31-00 - Open or Short to Ground 00825 - Drivers Seat Heating Element (Z6) 31-10 - Open or Short to Ground - Intermittent 00826 - Passengers Seat Heating Element (Z8) 31-10 - Open or Short to Ground - Intermittent
00819 - High Pressure Sensor (G65) 30-00 - Open or Short to Plus ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL Controller: 8E0 907 279 E Component: int. Lastmodul USA 0305 Coding: 00013 Shop #: 00672 VCID: 341BB49E1723 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8H0-959-655-84.LBL Controller: 8H0 959 655 B Component: Airbag 8.4EC 1015 Coding: 0010105 Shop #: 00672 VCID: 390585AA3041 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.LBL Controller: 8E0 953 549 N Component: Lenksáulenmodul 0308 Coding: 02041 Shop #: 00672 VCID: 3E0F96B6296F 1 Fault Found:
01304 - Radio 49-00 - No Communications ------------------------------------------------------------------------------- -Lite Self-Diagnosis Log Wednesday, 19 August 2020, 15:15:05:11085 Page 3 VIN Number: WAUAT48H63K022250 License Plate: Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL Controller: 8H0 920 950 E Component: KOMBI+WEGFAHRS. RB4 D16 Coding: 02201 Shop #: 03213 VCID: 2E2FA6F6F90F WAUAT48H63K022250 AUZ6Z0B0400950 3 Faults Found: 00562 - Sensor for Oil Level/Temperature (G266) 30-00 - Open or Short to Plus 00562 - Sensor for Oil Level/Temperature (G266) 27-10 - Implausible Signal - Intermittent
01304 - Radio 49-00 - No Communications ------------------------------------------------------------------------------- Address 26: Auto Roof Labels: 8H0-959-255.LBL Controller: 8H0 959 255 B Component: VSG B6 CABRIO 7195 Coding: 0000000 Shop #: 02101 VCID: 351D899A1C59 1 Fault Found:
02000 - Switch Position 008 - Implausible Signal - Intermittent ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Controller: 8H0 959 760 Component: Sitzmemory EE H04 X013 Coding: 00002 Shop #: 00065 VCID: F49BF49ED7A3 1 Fault Found: 02010 - Left Entry Assistance Control Module (J572) 79-10 - Please Check Fault Codes - Intermittent ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL Controller: 8H0 959 433 C Component: Komfortgerát T7B 1412 Coding: 11788 Shop #: 00672 VCID: 341BB49E1723 2 Faults Found:
01134 - Alarm Horn (H12) 49-10 - No Communications - Intermittent
00955 - Key 1 35-10 - - - Intermittent ------------------------------------------------------------------------------- -Lite Self-Diagnosis Log Wednesday, 19 August 2020, 15:15:05:11085 Page 4 VIN Number: WAUAT48H63K022250 License Plate: Address 55: Xenon Range Labels: 4Z7-907-357.LBL Controller: 4Z7 907 357 Component: dynamische LWR D09 Coding: 00070 Shop #: 00672 VCID: 047B245E0703 No fault code found. ------------------------------------------------------------------------------- Address 63: Entry Assist,D Labels: None Controller: 8H0 959 760 A Component: EasyEntry F M H11 X023 Coding: 00006 Shop #: 00065 VCID: 351D899A1C59 No fault code found. ------------------------------------------------------------------------------- Address 73: Entry Assist, P Labels: None Controller: 8H0 959 760 A Component: EasyEntry BF H11 X023 Coding: 00005 Shop #: 00000 VCID: 351D899A1C59 4 Faults Found:
00668 - Supply Voltage Terminal 30 07-10 - Signal too Low - Intermittent 01900 - Passengers Seat Fore / Aft Adjusting Motor (V31) 44-00 - Short Circuit
01317 - Control Module in Instrument Cluster (J285) 49-10 - No Communications - Intermittent
01794 - Control Module - Incorrect Chassis (VIN)
