Tiptronic Fault PRND SOLID RED
cschmitz20
Verified VCDS-Lite User
C?ID=385099
Hello i have been havung issues with the tiptronic for about a year as when the PRND is all solid the tiptronic would not work
It wasnt on often so it wasnt a bother. VCDs just gives me the erro code the the tiptronic switch has an implausible signal. Now its pretty much like that all the time. I have seen posts about magnet issues within the shifting column that cause the issue. Not sure of its important or not. The car drives decent for.the most part although therte is jerking around and sputtering at times but not sute if thats related. Any insight would be great. not sure if replacing the tip switch would work or not and not sure.how difficult it is to swap out. Thanks
@cschmitz20 : Hi. Your previous 2 x posts were unrelated to VCDS - so an autoscan of the car was not needed. However, this matter might be a tad different - see here !
cschmitz20
C?ID=385099
VCDS-Lite Windows Based VAG/VAS Emulator Version: Release 1.2 www.Ross-Tech.com Workshop Code: 000 00000 Self-Diagnosis Log Wednesday, 19 August 2020, 15:15:04:11085 VIN Number: WAUAT48H63K022250 License Plate: Mileage: Repair Order: Chassis Type: 8H - Audi Cabrio B6 Scan: 01,02,03,08,09,0F,11,15,16,17,18,26,36,37,45,46,55,56,57,63,65,67,73,75,76,77 ------------------------------------------------------------------------------- Address 01: Engine Labels: 06C-909-559-ASN.LBL Controller: 8E0 909 559 E Component: 3.0L V6/5V G 0004 Coding: 0016584 Shop #: WSC 00672 VCID: 370183920655 No fault code found. Readiness: 0000 1100 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 01J-927-156.LBL Controller: 01J 927 156 FE Component: V30 01J 3.0l 5V USA 3031 Coding: 01001 Shop #: WSC 03213 VCID: 749B749E57A3 1 Fault Found: 18161 - Tiptronic Switch (F189): Implausible Signal P1753 - 35-10 - - - Intermittent ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-517.LBL Controller: 8E0 614 517 G Component: ABS/ESP front 2328 Coding: 04499 Shop #: WSC 00672 VCID: 2C2BACFECF13 No fault code found. ------------------------------------------------------------------------------- VCDS-Lite Self-Diagnosis Log Wednesday, 19 August 2020, 15:15:05:11085 Page 2 VIN Number: WAUAT48H63K022250 License Plate: Address 08: Auto HVAC Labels: 8E0-820-043.LBL Controller: 8E0 820 043 L Component: A4 Klimaautomat 1116 Coding: 00100 Shop #: WSC 00672 VCID: 2A27AAE6C5E7 5 Faults Found: 01274 - Air Flow Flap Positioning Motor (V71) 41-10 - Blocked or No Voltage - Intermittent 00975 - Heated Rear Window (Z1) 31-00 - Open or Short to Ground 00825 - Drivers Seat Heating Element (Z6) 31-10 - Open or Short to Ground - Intermittent 00826 - Passengers Seat Heating Element (Z8) 31-10 - Open or Short to Ground - Intermittent 00819 - High Pressure Sensor (G65) 30-00 - Open or Short to Plus ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL Controller: 8E0 907 279 E Component: int. Lastmodul USA 0305 Coding: 00013 Shop #: WSC 00672 VCID: 341BB49E1723 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8H0-959-655-84.LBL Controller: 8H0 959 655 B Component: Airbag 8.4EC 1015 Coding: 0010105 Shop #: WSC 00672 VCID: 390585AA3041 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.LBL Controller: 8E0 953 549 N Component: Lenksáulenmodul 0308 Coding: 02041 Shop #: WSC 00672 VCID: 3E0F96B6296F 1 Fault Found: 01304 - Radio 49-00 - No Communications ------------------------------------------------------------------------------- VCDS-Lite Self-Diagnosis Log Wednesday, 19 August 2020, 15:15:05:11085 Page 3 VIN Number: WAUAT48H63K022250 License Plate: Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL Controller: 8H0 920 950 E Component: KOMBI+WEGFAHRS. RB4 D16 Coding: 02201 Shop #: WSC 03213 VCID: 2E2FA6F6F90F WAUAT48H63K022250 AUZ6Z0B0400950 3 Faults Found: 00562 - Sensor for Oil Level/Temperature (G266) 30-00 - Open or Short to Plus 00562 - Sensor for Oil Level/Temperature (G266) 27-10 - Implausible Signal - Intermittent 01304 - Radio 49-00 - No Communications ------------------------------------------------------------------------------- Address 26: Auto Roof Labels: 8H0-959-255.LBL Controller: 8H0 959 255 B Component: VSG B6 CABRIO 7195 Coding: 0000000 Shop #: WSC 02101 VCID: 351D899A1C59 1 Fault Found: 02000 - Switch Position 008 - Implausible Signal - Intermittent ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Controller: 8H0 959 760 Component: Sitzmemory EE H04 X013 Coding: 00002 Shop #: WSC 00065 VCID: F49BF49ED7A3 1 Fault Found: 02010 - Left Entry Assistance Control Module (J572) 79-10 - Please Check Fault Codes - Intermittent ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL Controller: 8H0 959 433 C Component: Komfortgerát T7B 1412 Coding: 11788 Shop #: WSC 00672 VCID: 341BB49E1723 2 Faults Found: 01134 - Alarm Horn (H12) 49-10 - No Communications - Intermittent 00955 - Key 1 35-10 - - - Intermittent ------------------------------------------------------------------------------- VCDS-Lite Self-Diagnosis Log Wednesday, 19 August 2020, 15:15:05:11085 Page 4 VIN Number: WAUAT48H63K022250 License Plate: Address 55: Xenon Range Labels: 4Z7-907-357.LBL Controller: 4Z7 907 357 Component: dynamische LWR D09 Coding: 00070 Shop #: WSC 00672 VCID: 047B245E0703 No fault code found. ------------------------------------------------------------------------------- Address 63: Entry Assist,D Labels: None Controller: 8H0 959 760 A Component: EasyEntry F M H11 X023 Coding: 00006 Shop #: WSC 00065 VCID: 351D899A1C59 No fault code found. ------------------------------------------------------------------------------- Address 73: Entry Assist, P Labels: None Controller: 8H0 959 760 A Component: EasyEntry BF H11 X023 Coding: 00005 Shop #: WSC 00000 VCID: 351D899A1C59 4 Faults Found: 00668 - Supply Voltage Terminal 30 07-10 - Signal too Low - Intermittent 01900 - Passengers Seat Fore / Aft Adjusting Motor (V31) 44-00 - Short Circuit 01317 - Control Module in Instrument Cluster (J285) 49-10 - No Communications - Intermittent 01794 - Control Module - Incorrect Chassis (VIN)
cschmitz20
C?ID=385099
There is the scan. Notably showing the tiptronic signal issue. I am mostly trying to figure out if the tiptronic error means something is wrong with my transmission in general or just that I cant use the tiptronic which isn't a big deal not being able to drive the car like a manual tranny.
No, the problem isn't with the transmission itself but rather with the shifter and the switch(s) on the right hand side of the gate.
BTW, somehow most of the NewLine characters are missing from your scan. What software did it pass through on the way here?
