A3 rétrofit MIB2
raiden95
Angy, France
C?ID=369252
I have an Audi A3 8V 2014 with bang Olufsen and small screen and MIB1. Someone who is used to retrofit, install on my car the MIB2 and the high screen. except I’m having trouble with the bang olufsen, the sound isn’t great and the subwoofer isn’t performing as it should.
I have Fault code U106A in gateway (Digital sound System control module
U106A 00 [009] - No Communication)
can you help me please?
Thank you
downtime
Finland
C?ID=280813
Can you please provide an autoscan from your car in current state done with english version of VCDS? Easier to help if we see how your MIB unit is coded. Also if possible, take an adaptation map from 5F unit. Part of the settings are there.
downtime
Finland
C?ID=280813
We need to see autoscan. But as Iam right Amp need to be changed for MIB2
Yes true, MIB1 and MIB2 systems have different digital amps for the sound systems
raiden95
Angy, France
C?ID=369252
Hello, here vcds log
thank you
Wednesday,07,October,2020,19:59:43:04654
VIN: WAUZZZ8V5EA146264   License Plate:
Mileage: 113329km-70419mi   Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 22 42 44 47 52 55 5F 69 6C BB BC
VIN: WAUZZZ8V5EA146264   Mileage: 113329km-70419miles
47-Sound System -- Status: Not registered 0011
Address 01: Engine (J623-CUNA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 ER    HW: 04L 907 309 A
   Component: R4 2,0L EDC   X22 7541
   Revision: 81X22---
   Coding: 021D0012043601082000
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM20TDI01104L906021ER 002007
   ROD: EV_ECM20TDI01104L906021ER.rod
   VCID: 79AFEC5EC958702315D-802C
Readiness: 0 0 0 0 X
   Part No SW: 0D9 300 011 P    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H52 4317
   Revision: 05852204    Serial number: TFK01401300574
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 221DEB32044ED3FB647-8076
   Revision: 00000000    Serial number: 60374000000C70
   Coding: 12F162A234240A720179070641C72948462C5080E08294F4026100788608
   Shop #: WSC 06314 790 00021
   ROD: EV_Brake1UDSContiMK100IPB_033.rod
   VCID: 7BA3F656C3644233071-802E
   Part No SW: 8V0 820 043 C    HW: 8V0 820 043 C
   Component: AC Automat    H13 0052
   Revision: 20026000    Serial number: 00000000243377
   Coding: 03000114002000011000000000001100
   VCID: 323D1B7254AE437B947-8066
   Serial number: E4680F07000000000001
197378 - Temperature Sensor for Right Vent
          B1088 15 [009] - Open or Short to Plus
                    Reset counter: 106
                    Mileage: 113329 km
                    Date: 2020.10.06
                    Time: 22:42:58
                    Outside air temperature: 14 °C
                    Voltage terminal 30: 13.5 V
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Serial number: 00011404103710
   Coding: 04161A42C24122FD43844004001C07A80000000000000000000000000000
   ROD: EV_BCMBOSCH_012.rod
   Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 140124  041 0580
   Serial number:         140126011719
   Coding: 0A47F7
   Serial number: 22236880
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 L    HW: 8V0 941 531 L
   Serial number: 15 05 2013  00000041
   Sun Roof:
   Subsystem 4 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.009  H02 0007
   Serial number:     WOO2697139B
   Coding: 901E00
   Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
   Component: AirbagVW20    011 0361
   Serial number: 003M2R054K96
   Coding: 98CCC0000C0000005C540000004800000065
   ROD: EV_AirbaVW20SMEVW37X_VW48.rod
   VCID: 4BC36696D34432B3F71-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 000 302 14
   Serial number: 357670000009DBF4DE0L
   Subsystem 2 - Part No SW: -----------    HW: 480 000 302 14
   Serial number: 3586700000066505DE0Z
   Subsystem 3 - Part No SW: -----------    HW: 480 400 602 14
   Serial number: 3516502B112AB1B502E5
   Subsystem 4 - Part No SW: -----------    HW: 480 400 602 14
   Serial number: 3526502AD12AB1B541BH
   Subsystem 5 - Part No SW: -----------    HW: 480 400 901 14
   Serial number: 3556502BD13013E3F2FL
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 402 001 14
   Component: PedP_Sensor_D  001 6149
   Serial number: 22865029D12FAE21C3CX
   Subsystem 7 - Part No SW: -----------    HW: 480 401 101 18
   Component: PedP_Sensor_P  000 6149
   Serial number: 2296501B72879086B52F
   Pedestrian Protection Center:
   Subsystem 8 - Part No SW: -----------    HW: 480 402 001 14
   Component: PedP_Sensor_C  001 6149
   Serial number: 2306502A512FAE25A0BH
   Part No SW: 8V0 953 521 BP    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 10021408490364
   Coding: A418
   ROD: EV_SMLSKLOMQB_009_AU37.rod
   VCID: 094F9C9E99B860A305D-805C
   Part No SW: 8V0 920 870 H    HW: 8V0 920 870 H
   Component: KOMBI         H03 2220
   Coding: 07A408082B8000080300E800100000
   VCID: 40D941BAEA02E1EB123-8014
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1164
   Revision: --------    Serial number: 0001521143
   Coding: 030100040B0876005B0002481C0B00000001000000000000000000000000
   ASAM Dataset: EV_GatewLear 010015
   ROD: EV_GatewLear_010.rod
   VCID: 3FDB424697FC9E136B9-806A
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Serial number: 24 01 2014  E0329576
   Serial number: 4445112503
131695 - Digital sound System control module
          U106A 00 [008] - No Communication
          [Timeout Knoten 0x6F / 47 - Steuergerät für digitales Soundpaket]
                    Reset counter: 146
                    Mileage: 113329 km
                    Date: 2020.10.06
                    Time: 22:48:24
                    Supply voltage: Terminal 30: 13.7 V
                    Terminal 15: On
   Part No SW: 0CQ 907 554 D    HW: 0CQ 907 554 D
   Component: Haldex4Motion H52 7076
   Serial number: HA1-00009.01.14
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_002.rod
   VCID: 46D557A2C826CFDB28F-8012
   Serial number: 28011402091525
   Coding: 005D0E204000040000001002
   Component: EPS_MQB_ZFLS  122 1043
   Coding: 8103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41DF44BEE108E8E31DD-8014
   Part No SW: 8V0 035 465 B    HW: 8V0 035 465
   Component: MIBAMP1ALPINE H11 0400
   Serial number: AUZ8ZADN9004FG-
   Coding: 01030300AAAA2AAA01
   ASAM Dataset: EV_AMPMst16C1ALPI 004024
   ROD: EV_AMPMst16C1ALPI_004_AU37.rod
   VCID: 372B2A66BFCCA653A39-8062
1564 - Microphone for Vehicle/Ambient Noise
          B13BB 13 [143] - Open Circuit
                    Reset counter: 106
                    Mileage: 113329 km
                    Date: 2020.10.06
                    Time: 22:43:00
   Serial number: 29011402090530
   Coding: 005D06204000040000001002
   Coding: 01AA000001000000
   VCID: 75B7E06EE5401443715-8020
   Part No SW: 81A 035 193 E    HW: 81A 035 193
   Component: MU-HS-LN-EU   050 0235
   Coding: 017363010000000011110002000A00102F002AE401F008000E
   Shop #: WSC 00046 123 12345
   ROD: EV_MUHigScl6C3DELP.rod
   VCID: 2411ED2A1E5ADDCB16B-8070
   Subsystem 1 - Part No SW: 8W0 919 866 AB    HW: -----------
   Component: ECE 2018  --- 0032
   Component: DU High  H49 0014
   Serial number: AUZ8Z9K1Y0L62H
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 BK    HW: 8V0 919 614 BK
   Component: ControlUnit_H  H85 0855
   Serial number: ALJAL122031900050052
          B201A 00 [009] - -
                    Reset counter: 106
                    Mileage: 113329 km
                    Date: 2020.10.06
                    Time: 22:42:58
                    Voltage terminal 30: 13.6 V
                    Status_Software_Version_Management-module_name: C
3073 - Cellular Antenna
          B1053 13 [009] - Open Circuit
          [GSM/UMTS aerial - open circuit]
                    Reset counter: 106
                    Mileage: 113329 km
                    Date: 2020.10.06
                    Time: 22:42:58
3084 - GSM antenna 2
          B1533 13 [009] - Open Circuit
                    Reset counter: 106
                    Mileage: 113329 km
                    Date: 2020.10.06
                    Time: 22:42:58
1564 - Microphone 1
          B129B 13 [009] - Open Circuit
                    Reset counter: 106
                    Mileage: 113329 km
                    Date: 2020.10.06
                    Time: 22:42:59
7178 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Park assist OPS (0x0A) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 106
                    Mileage: 113329 km
                    Date: 2020.10.06
                    Time: 22:43:01
                    BAP-BAP_Function_ID: 02
7179 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Rear-view camera (0x0B) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 106
                    Mileage: 113329 km
                    Date: 2020.10.06
                    Time: 22:43:01
   Part No SW: 5Q0 907 383     HW: 5Q0 907 383
   Component: Anhaenger     H11 0030
   Revision: 6A001003    Serial number: 00000324970795
   Coding: 0101000200000000
   ASAM Dataset: EV_TrailFunctDemouHella 001001
   ROD: EV_TrailFunctDemouHella.rod
   VCID: 74B1DD6AEE3A0D4B46B-8020
   Coding: 0000000000000000000000
   VCID: 392F2C5E89D8B02355D-806C
10490624 - No End-of-Line Programming
          B2013 00 [009] - -
          [ECU no DataSet]
                    Reset counter: 106
                    Mileage: 113329 km
                    Date: 2020.10.06
                    Time: 22:42:58
13636352 - Control module not coded
          U1013 00 [009] - -
          [ECU not coded]
                    Reset counter: 106
                    Mileage: 113329 km
                    Date: 2020.10.06
                    Time: 22:42:58
10489856 - No Basic Setting
          B2010 00 [009] - -
                    Reset counter: 106
                    Mileage: 113329 km
                    Date: 2020.10.06
                    Time: 22:42:58
   Part No SW: 5Q0 959 395 B    HW: 5Q0 959 395 B
   Component: TSG HFS       020 0025
   Serial number: 22011401100425
   Coding: 004D06204000040000001002
   Component: TSG HBFS      020 0025
   Serial number: 22011402090416
End----------(Elapsed Time: 01:24, VBatt start/end: 12.2V/12.4V)-----------
