Dear All,
just another time the question about how to turn off the buzzer when the driver's door is opened and the car is running.
My car is a T-ROC 2020 and following the procedure:
17- Instruments
Adaptation-10
Ignition Active Message, Actuator ------ No Display
The buzzer is still on.
Have you suggestion how to solve the problem?
The procedure to remove the seat belt buzzer works.
Thanks to all,
17- Instruments
Adaptation-10
Thanks to all,
Wednesday,23,September,2020,14:55:55:51118
Dealer/Shop Name: RFENECH
VIN: WVGZZZA1ZLV100185 License Plate:
Mileage: 6454km-4010mi Repair Order:
Chassis Type: A1-VW27 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 42 44 52 5F 69 A5 BB BC
VIN: WVGZZZA1ZLV100185 Mileage: 6454km-4010miles
Address 01: Engine (J623-DGTE) Labels: None
Part No SW: 04L 906 056 TH HW: 04L 907 445 G
Component: R4 1.6l TDI H01 6987
Revision: 22102001
Coding: 0119403243541D092000
Shop #: WSC 00020 999 00000
ASAM Dataset: EV_ECM16TDI03004L906056TH 004001
ROD: EV_ECM16TDI03004L906056TH_VW27.rod
VCID: 06546773D8AB57DB68F-8052
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 5Q0 614 517 DK HW: 5Q0 614 517 BN
Component: ESC H35 0113
Revision: 00000000 Serial number: 60030000002685
Coding: 46FA6A7D90200C6C4778060862C82562560930E26046A4733440F078D0224B0B00000523525212121035351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 049012
ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
VCID: 7DA6089F8D7D1403395-8028
Part No SW: 5G0 907 044 FP HW: 5G0 907 044 FP
Component: Climatronic H04 2401
Revision: 00001K10
Coding: 060201042021100D1105000000101032
ASAM Dataset: EV_ACClimaBHBVW37X 006151
ROD: EV_ACClimaBHBVW37X_006_VW27.rod
VCID: 7AAC03839C53233B1C7-802E
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 084 DE HW: 5Q0 937 084 CD
Component: BCM MQBAB B H42 0312
Serial number: 02002001300900
ASAM Dataset: EV_BCMMQB 020001
ROD: EV_BCMBOSCH_020.rod
VCID: 7EA40F93807B0F1B20F-802A
Subsystem 1 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 051 0206
Serial number: SBY19M12D13H04M14S40
Coding: 0018DD
Steering Column Switch:
Subsystem 2 - Part No SW: 5Q1 953 521 HW: 5Q1 953 569
Component: Lenks.Modul H03 0170
Serial number: 0100080120200C203322
Part No SW: 5QA 919 294 G HW: 5QA 919 294
Component: PDC 8 Kanal H08 0061
Serial number: 000150058320012
Coding: 0471051901
ASAM Dataset: EV_EPHVA18AU3700000 009046
ROD: EV_EPHVA18AU3700000_009_VW27.rod
VCID: 50F8812B6A6F496B823-8004
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Coding: 2A04604A18FF8748949C810560408700000000000000000004
ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
VCID: 43D2BE67AB19A2F30F1-8016
Part No SW: 3Q0 959 655 CM HW: 3Q0 959 655 CM
Component: Airbag VW21 006 0720
Revision: -------- Serial number: 003Z2PS3R903
Coding: 88CCC0C0000000005C5400CF000800000065
ROD: EV_AirbaVW21TS6VW48X.rod
VCID: 0B425647C3C92AB3371-805E
Subsystem 1 - Part No SW: ----------- HW: 454 000 112 19
Serial number: 35700000000B7745B34O
Subsystem 2 - Part No SW: ----------- HW: 454 003 011 19
Serial number: 35800000000CA41DC34W
Subsystem 3 - Part No SW: ----------- HW: 454 802 611 19
Serial number: 351008A84751A000000J
Subsystem 4 - Part No SW: ----------- HW: 454 802 611 19
Serial number: 35200E8105B1A000000H
Subsystem 5 - Part No SW: ----------- HW: 454 802 411 19
Serial number: 35500E751921A000000J
Part No SW: 17A 920 790 B HW: 17A 920 790 B
Component: KOMBI 503 4193
Coding: 05A4000067800008018823031001000000000906
ASAM Dataset: EV_DashBoardVDDMQBA0 001042
ROD: EV_DashBoardVDDMQBA0_VW27.rod
VCID: 261407F3386B77DB08F-8072
9456433 - Key
B104B 31 [008] - No Signal
Mileage: 993 km
Date: 2020.06.13
Time: 08:57:12
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 442 4388
Revision: -------- Serial number: 0000555469
Coding: 030100344F08730022000258080F00010001070000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 70B821ABCA2F696BA23-8024
Component: 4-01-13-01-04
Subsystem 2 - Part No SW: 5NA 959 442 B HW: 5NA 959 442 B
Component: E221__MFL-TAT H06 0025
Serial number: 3471918315801787FJ2B
Coding: 2C0000
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 4908453605
Address 42: Door Elect, Driver (J386) Labels:* Redir Fail!
Part No SW: 5Q4 959 593 K HW: 5Q4 959 593 K
Component: TSG FS 007 0485
Serial number: 0000399853811
Coding: 003B0320D000028000001000
VCID: 4DC6985F7D5D6483E95-8018
Subsystem 1 - Part No SW: 5Q0 959 407 HW: 5Q0 959 163
Component: FOND_FHSG_DRV 007 0010
Serial number: 00000000000037106576
Part No SW: 5Q0 909 144 AB HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 130 1082
Coding: 151F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 74B02DBBBE37554B46B-8020
Address 52: Door Elect, Pass. (J387) Labels:* Redir Fail!
Part No SW: 5Q4 959 592 K HW: 5Q4 959 592 K
Component: TSG BFS 007 0485
Serial number: 0000400573613
Coding: 003B0120DC00028000001000
VCID: 4CC0955B86476D8BFEB-8018
Subsystem 1 - Part No SW: 5Q0 959 408 HW: 5Q0 959 164
Component: FOND_FHSG_PSG 007 0010
Serial number: 00000000000036995865
Coding: 190000
Part No SW: 3Q0 035 842 C HW: 3Q0 035 842 C
Component: MU-S-D-ER 724 0876
Coding: 02720600BE0000004111010100880A001F0500E40120000003
ROD: EV_MUStd4CDELP_VW27.rod
VCID: 2D06F8DF1D9D4483C95-8078
Subsystem 1 - Part No SW: 5G6 919 605 A HW: 5G6 919 605 A
Component: ABT_Std-2 H61 8214
Serial number: VWZ6ZJX0151301
Part No SW: 5Q0 907 383 L HW: 5Q0 907 383 L
Component: Anhaenger H27 0260
Revision: 8C001005 Serial number: 0537768487
Coding: 0100000202000000
ROD: EV_TrailFunctGener2Hella_VW27.rod
VCID: 40D8B16BBA0FB9EB123-8014
Part No SW: 3Q0 980 654 L HW: 3Q0 980 654 A
Component: MQB_B_MFK H12 0610
Serial number: 09012015K11190
Coding: 0002070600000401002200458150A90084000E00000000
ROD: EV_MFKBoschMQBB_002.rod
Address BB: Door Rear Drv
Address BC: Door Rear Pass
End----------(Elapsed Time: 01:34, VBatt start/end: 12.1V/12.1V)-----------
