Ignition Active Message, Actuator ------ No Display
TAL
Italy
C?ID=315529
Dear All,
just another time the question about how to turn off the buzzer when the driver's door is opened and the car is running.
My car is a T-ROC 2020 and following the procedure:
17- Instruments
Adaptation-10
The buzzer is still on.
Have you suggestion how to solve the problem?
The procedure to remove the seat belt buzzer works.
Thanks to all,
Wednesday,23,September,2020,14:55:55:51118
Dealer/Shop Name: RFENECH
VIN: WVGZZZA1ZLV100185   License Plate:
Mileage: 6454km-4010mi   Repair Order:
Chassis Type: A1-VW27 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 42 44 52 5F 69 A5 BB BC
VIN: WVGZZZA1ZLV100185   Mileage: 6454km-4010miles
Address 01: Engine (J623-DGTE)       Labels: None
   Part No SW: 04L 906 056 TH    HW: 04L 907 445 G
   Component: R4 1.6l TDI   H01 6987
   Revision: 22102001
   Coding: 0119403243541D092000
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_ECM16TDI03004L906056TH 004001
   ROD: EV_ECM16TDI03004L906056TH_VW27.rod
   VCID: 06546773D8AB57DB68F-8052
Readiness: N/A
   Part No SW: 5Q0 614 517 DK    HW: 5Q0 614 517 BN
   Component: ESC           H35 0113
   Revision: 00000000    Serial number: 60030000002685
   Coding: 46FA6A7D90200C6C4778060862C82562560930E26046A4733440F078D0224B0B00000523525212121035351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 049012
   ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
   VCID: 7DA6089F8D7D1403395-8028
   Part No SW: 5G0 907 044 FP    HW: 5G0 907 044 FP
   Component: Climatronic   H04 2401
   Revision: 00001K10
   Coding: 060201042021100D1105000000101032
   ASAM Dataset: EV_ACClimaBHBVW37X 006151
   ROD: EV_ACClimaBHBVW37X_006_VW27.rod
   VCID: 7AAC03839C53233B1C7-802E
   Air quality sensor:
   Part No SW: 5Q0 937 084 DE    HW: 5Q0 937 084 CD
   Component: BCM MQBAB B   H42 0312
   Serial number: 02002001300900
   ASAM Dataset: EV_BCMMQB 020001
   ROD: EV_BCMBOSCH_020.rod
   VCID: 7EA40F93807B0F1B20F-802A
   Subsystem 1 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  051  0206
   Serial number: SBY19M12D13H04M14S40
   Coding: 0018DD
   Steering Column Switch:
   Subsystem 2 - Part No SW: 5Q1 953 521     HW: 5Q1 953 569
   Component: Lenks.Modul  H03  0170
   Serial number: 0100080120200C203322
   Part No SW: 5QA 919 294 G    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0061
   Serial number: 000150058320012
   Coding: 0471051901
   ASAM Dataset: EV_EPHVA18AU3700000 009046
   ROD: EV_EPHVA18AU3700000_009_VW27.rod
   VCID: 50F8812B6A6F496B823-8004
   Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0372
   Coding: 2A04604A18FF8748949C810560408700000000000000000004
   ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
   VCID: 43D2BE67AB19A2F30F1-8016
   Part No SW: 3Q0 959 655 CM    HW: 3Q0 959 655 CM
   Component: Airbag VW21   006 0720
   Revision: --------    Serial number: 003Z2PS3R903
   Coding: 88CCC0C0000000005C5400CF000800000065
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 0B425647C3C92AB3371-805E
   Subsystem 1 - Part No SW: -----------    HW: 454 000 112 19
   Serial number: 35700000000B7745B34O
   Subsystem 2 - Part No SW: -----------    HW: 454 003 011 19
   Serial number: 35800000000CA41DC34W
   Subsystem 3 - Part No SW: -----------    HW: 454 802 611 19
   Serial number: 351008A84751A000000J
   Subsystem 4 - Part No SW: -----------    HW: 454 802 611 19
   Serial number: 35200E8105B1A000000H
   Subsystem 5 - Part No SW: -----------    HW: 454 802 411 19
   Serial number: 35500E751921A000000J
   Part No SW: 17A 920 790 B    HW: 17A 920 790 B
   Component: KOMBI         503 4193
   Coding: 05A4000067800008018823031001000000000906
   ASAM Dataset: EV_DashBoardVDDMQBA0 001042
   ROD: EV_DashBoardVDDMQBA0_VW27.rod
   VCID: 261407F3386B77DB08F-8072
9456433 - Key
          B104B 31 [008] - No Signal
                    Mileage: 993 km
                    Date: 2020.06.13
                    Time: 08:57:12
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   442 4388
   Revision: --------    Serial number: 0000555469
   Coding: 030100344F08730022000258080F00010001070000000000000000000000
   ROD: EV_GatewNF_VW27.rod
   VCID: 70B821ABCA2F696BA23-8024
   Component: 4-01-13-01-04
   Subsystem 2 - Part No SW: 5NA 959 442 B    HW: 5NA 959 442 B
   Component: E221__MFL-TAT  H06 0025
   Serial number: 3471918315801787FJ2B
   Coding: 2C0000
   Serial number: 4908453605
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 5Q4 959 593 K    HW: 5Q4 959 593 K
   Component: TSG FS        007 0485
   Serial number: 0000399853811
   Coding: 003B0320D000028000001000
   VCID: 4DC6985F7D5D6483E95-8018
   Subsystem 1 - Part No SW: 5Q0 959 407     HW: 5Q0 959 163
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000037106576
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  130 1082
   Coding: 151F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 74B02DBBBE37554B46B-8020
Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
   Part No SW: 5Q4 959 592 K    HW: 5Q4 959 592 K
   Component: TSG BFS       007 0485
   Serial number: 0000400573613
   Coding: 003B0120DC00028000001000
   VCID: 4CC0955B86476D8BFEB-8018
   Subsystem 1 - Part No SW: 5Q0 959 408     HW: 5Q0 959 164
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000036995865
   Coding: 190000
   Part No SW: 3Q0 035 842 C    HW: 3Q0 035 842 C
   Component: MU-S-D-ER     724 0876
   Coding: 02720600BE0000004111010100880A001F0500E40120000003
   ROD: EV_MUStd4CDELP_VW27.rod
   VCID: 2D06F8DF1D9D4483C95-8078
   Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
   Component: ABT_Std-2  H61 8214
   Serial number: VWZ6ZJX0151301
   Part No SW: 5Q0 907 383 L    HW: 5Q0 907 383 L
   Component: Anhaenger     H27 0260
   Revision: 8C001005    Serial number: 0537768487
   Coding: 0100000202000000
   ROD: EV_TrailFunctGener2Hella_VW27.rod
   VCID: 40D8B16BBA0FB9EB123-8014
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H12 0610
   Serial number: 09012015K11190
   Coding: 0002070600000401002200458150A90084000E00000000
   ROD: EV_MFKBoschMQBB_002.rod
Address BB: Door Rear Drv
Address BC: Door Rear Pass
End----------(Elapsed Time: 01:34, VBatt start/end: 12.1V/12.1V)-----------
@TAL: HI.
My understanding of how this tweak works on MQB platform cars is in the name of the adaptation channel; specifically the word "ignition". So - if you select "No Display" for this channel , the factory set beep will be disabled when the ignition is turned-on. Importantly, the beep is not disabled when the engine is running. I'm not aware of a tweak for this latter situation
TAL
Italy
C?ID=315529
Thanks Don, if this is the situation I proceed with an hammer.
Mika_M
Finland
C?ID=183725
First time I've heard about this kind of behaviour. My both MQB cars (MY14 A3 and MY17 Kodiaq) with this "No Display" adaptation keep silent when I open driver's door. Doesn't matter if engine is running or not.
Maybe it's different in MY20 cars then?
downtime
Finland
C?ID=280813
I have the same behaviour as Mika. The ignition actuator channel dictates what is will you see or hear when the drivers door is opened if ignition is on or engine running. Setting it to no display removes the warning from the cluster and silences the annoying beeping sound you'll hear.
And forgot. Same behaviour on MY13 Leon and MY17 Tiguan.
TAL
Italy
C?ID=315529
I have spoken with VW dealer and this buzzer for safety reason it is not possible to deactivate. :(:(:(
downtime
Finland
C?ID=280813
Just for interest, ask them if it's been like that always. Most likely they'll say yes which is a load of bull and at the same time invalidates everything they've said so far.
TAL
Italy
C?ID=315529
This safety requirement has been implemented from 2019, they said.
rocamet
Rancho Cucamonga, CA, USA
C?ID=419570
Amazing that for safety reasons, you can remove the seat belt warning but you CAN'T remove the open door warning. You can't even change the volume. That makes a lot of sense!
Every time I open my door, I feel like the car is going to explode, single most annoying feature of my new car.
TAL
Italy
C?ID=315529
We have to hope that some smart guy find the solution. The buzzer is a nightmare.
