I have an 2017 model year Audi A3 Cabrio that came with rear sensors and I had front sensors retrofitted. Everything works well with them but I was wondering if there's a way to make the front sensors activate automatically at low speed/high proximity (my Mk7 Golf does exactly that). Right now the front sensors only activate with the reverse gear or the dash button.
The car manual hints that this feature exists (on cars that come with front sensors from factory) and my MMI has an option to "Automatically activate" the parking aid but this doesn't seem to actually change the behavior. Does anyone know if there's something wrong with the current coding or module?
Here's the autoscan of the car right now:
Sunday,04,October,2020,00:21:46:55716
VIN: WAUZZZ8V1H1004529 License Plate:
Mileage: 39517km-24554mi Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 26 42 44 52 5F
VIN: WAUZZZ8V1H1004529 Mileage: 39517km-24554miles
Address 01: Engine (J623-CXXB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 056 D HW: 04L 907 445 B
Component: R4 1.6l TDI H06 6330
Revision: 22004001
Coding: 02194012432401092000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM16TDI03004L906056D 004013
ROD: EV_ECM16TDI03004L906056_004.rod
VCID: 2E050A06509ADF3BF0F-807A
Readiness: N/A
Part No SW: 5Q0 614 517 BJ HW: 5Q0 614 517 AG
Component: ESC H62 0636
Revision: 00000000 Serial number: 61646000001983
Coding: 11F162A224200A70497C0E0241CC2988462450927082947202410078800802
VCID: 7AADF656DC52C39B1C7-802E
Part No SW: 8V0 820 043 Q HW: 8V0 820 043 Q
Component: AC Automat H03 0110
Revision: 20001000 Serial number: 00000000962622
Coding: 05000104002000011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008021
VCID: 40D944BEFA0E594B123-8014
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0005
Serial number: D798453800PAG0MUFU03
Part No SW: 5Q0 937 084 CG HW: 5Q0 937 084 CG
Component: BCM MQBAB H H34 0236
Serial number: 02001616700827
ROD: EV_BCMBOSCH_017.rod
VCID: 7F5B0742C770E6B32B9-802A
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 160602 043 0585
Serial number: 160613052511
Coding: 0A47F7
Component: G397_RLFS H06 0004
Serial number: 61971934
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Serial number: 22 04 2016 00000416
Part No SW: 5QA 919 294 G HW: 5QA 919 294
Component: PDC 8 Kanal H08 0061
Serial number: 000150058320140
Coding: 0470051001
ASAM Dataset: EV_EPHVA18AU3700000 009046
VCID: 50F974FE2A6EA9CB823-8004
Part No SW: 5Q0 959 655 A HW: 5Q0 959 655 A
Component: AirbagVW20 010 0870
Serial number: 003ESR011MAK
Coding: 98C0C0000000A0005C5000CA004800000065
ROD: EV_AirbaVW20SMEVW37X_VW48.rod
VCID: 3E253A4680FA2FBB60F-806A
Subsystem 1 - Part No SW: ----------- HW: 480 001 706 16
Serial number: 3570000000000A553C18
Subsystem 2 - Part No SW: ----------- HW: 480 001 706 16
Serial number: 35800000000FF9553C1
Subsystem 3 - Part No SW: ----------- HW: 480 011 905 16
Component: SideSensor_Dr 004 0108
Serial number: 351001A056C46B42DDDN
Subsystem 4 - Part No SW: ----------- HW: 480 402 405 16
Serial number: 3550002C32076353A26V
Part No SW: 8V0 953 521 JD HW: 5Q0 953 549 E
Revision: -------- Serial number: 16061604400593
Coding: A008
ROD: EV_SMLSKLOMQB_019_AU37.rod
VCID: 055795AAA5ACBC63615-8050
Part No SW: 8V0 920 861 D HW: 8V0 920 861 D
Component: KOMBI H02 8315
Coding: 07A411002B8000080600A8001001000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009054
VCID: 3C21304E96E63DAB4EB-8068
1048578 - No Basic Setting
B2010 00 [009] - -
[Steuergerät keine oder falsche Grundeinstellung]
Reset counter: 244
Mileage: 38934 km
Date: 2020.09.18
Time: 17:08:14
16776980 - Databus
[PLA_Status_01 keine Kommunikation]
Reset counter: 244
Mileage: 38934 km
Date: 2020.09.18
Time: 17:08:14
Part No SW: 5Q0 907 530 AL HW: 5Q0 907 530 L
Component: GW MQB Mid 211 2265
Revision: -------- Serial number: 18061610520913
Coding: 030100041F0873005B000248080B00000001010000000000000000000000
ROD: EV_GatewConti_013.rod
VCID: 7BA3F352D368FA93071-802E
Subsystem 2 - Part No SW: 81A 951 523 HW: 81A 951 523
Component: J453 MFL H04 0003
Serial number: 20160611121928 01400
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Serial number: 75410803001606022372
Address 26: Auto Roof (J256) Labels:* None
Part No SW: 8V7 959 255 HW: 8V7 959 255
Component: VSG-AU375 H03 0040
Coding: 400000
ASAM Dataset: EV_ElectRoofContrMAQAU37X 001005
ROD: EV_ElectRoofContrMAQAU37X.rod
VCID: 08499C9E92BEA10B1A3-805C
Component: TSG FS 020 0041
Serial number: 010616EF10140A
Coding: 001C4B725C08040000001402
VCID: 43D34BB2EB1842530F1-8016
Subsystem 1 - Part No SW: 5Q0 959 812 C HW: 5Q0 959 812 C
Component: FOND_FHSG_DRV 002 0005
Serial number: 00000000000009948730
Coding: 110000
Component: EPS_MQB_ZFLS 129 1072
Coding: 8107
ROD: EV_SteerAssisMQB_013.rod
VCID: 45D755AAE52C7C63215-8010
Component: TSG BFS 020 0041
Serial number: 040616EF405671
Coding: 001C43725E08040000001402
VCID: 42DD4EB6F4024B5B047-8016
Subsystem 1 - Part No SW: 5Q0 959 811 C HW: 5Q0 959 811 C
Component: FOND_FHSG_PSG 002 0005
Serial number: 00000000000009948250
Coding: 090000
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 81A 035 183 HW: 81A 035 183
Component: MU-HS-N-EU 045 0148
Coding: 01730500FF00000011110001000A00002F002AC401F001000C
ROD: EV_MUHigScl6C3DELP.rod
VCID: 5EE59AC660BA0FBB00F-800A
Subsystem 1 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9GY205R2U
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 8V0 919 614 BE HW: 8V0 919 614 BE
Component: ControlUnit_B H50 0103
Serial number: ALJAL123041600010420
End----------(Elapsed Time: 01:03, VBatt start/end: 13.3V/13.2V)-----------
