Automatically enable front sensors in A3 Cabrio
bmfurtado
Portugal
C?ID=418665
I have an 2017 model year Audi A3 Cabrio that came with rear sensors and I had front sensors retrofitted. Everything works well with them but I was wondering if there's a way to make the front sensors activate automatically at low speed/high proximity (my Mk7 Golf does exactly that). Right now the front sensors only activate with the reverse gear or the dash button.
The car manual hints that this feature exists (on cars that come with front sensors from factory) and my MMI has an option to "Automatically activate" the parking aid but this doesn't seem to actually change the behavior. Does anyone know if there's something wrong with the current coding or module?
Here's the autoscan of the car right now:
Sunday,04,October,2020,00:21:46:55716
VIN: WAUZZZ8V1H1004529   License Plate:
Mileage: 39517km-24554mi   Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 26 42 44 52 5F
VIN: WAUZZZ8V1H1004529   Mileage: 39517km-24554miles
Address 01: Engine (J623-CXXB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 056 D    HW: 04L 907 445 B
   Component: R4 1.6l TDI   H06 6330
   Revision: 22004001
   Coding: 02194012432401092000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM16TDI03004L906056D 004013
   ROD: EV_ECM16TDI03004L906056_004.rod
   VCID: 2E050A06509ADF3BF0F-807A
Readiness: N/A
   Part No SW: 5Q0 614 517 BJ    HW: 5Q0 614 517 AG
   Component: ESC           H62 0636
   Revision: 00000000    Serial number: 61646000001983
   Coding: 11F162A224200A70497C0E0241CC2988462450927082947202410078800802
   VCID: 7AADF656DC52C39B1C7-802E
   Part No SW: 8V0 820 043 Q    HW: 8V0 820 043 Q
   Component: AC Automat    H03 0110
   Revision: 20001000    Serial number: 00000000962622
   Coding: 05000104002000011000000000001100
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008021
   VCID: 40D944BEFA0E594B123-8014
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0005
   Serial number: D798453800PAG0MUFU03
   Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H34 0236
   Serial number: 02001616700827
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7F5B0742C770E6B32B9-802A
   Component: WWS371 160602  043 0585
   Serial number:         160613052511
   Coding: 0A47F7
   Serial number: 61971934
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Serial number: 22 04 2016  00000416
   Part No SW: 5QA 919 294 G    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0061
   Serial number: 000150058320140
   Coding: 0470051001
   ASAM Dataset: EV_EPHVA18AU3700000 009046
   VCID: 50F974FE2A6EA9CB823-8004
   Part No SW: 5Q0 959 655 A    HW: 5Q0 959 655 A
   Component: AirbagVW20    010 0870
   Serial number: 003ESR011MAK
   Coding: 98C0C0000000A0005C5000CA004800000065
   ROD: EV_AirbaVW20SMEVW37X_VW48.rod
   VCID: 3E253A4680FA2FBB60F-806A
   Subsystem 1 - Part No SW: -----------    HW: 480 001 706 16
   Serial number: 3570000000000A553C18
   Subsystem 2 - Part No SW: -----------    HW: 480 001 706 16
   Serial number: 35800000000FF9553C1
   Subsystem 3 - Part No SW: -----------    HW: 480 011 905 16
   Component: SideSensor_Dr  004 0108
   Serial number: 351001A056C46B42DDDN
   Subsystem 4 - Part No SW: -----------    HW: 480 402 405 16
   Serial number: 3550002C32076353A26V
   Part No SW: 8V0 953 521 JD    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 16061604400593
   Coding: A008
   ROD: EV_SMLSKLOMQB_019_AU37.rod
   VCID: 055795AAA5ACBC63615-8050
   Part No SW: 8V0 920 861 D    HW: 8V0 920 861 D
   Component: KOMBI         H02 8315
   Coding: 07A411002B8000080600A8001001000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009054
   VCID: 3C21304E96E63DAB4EB-8068
1048578 - No Basic Setting
          B2010 00 [009] - -
          [Steuergerät keine oder falsche Grundeinstellung]
                    Reset counter: 244
                    Mileage: 38934 km
                    Date: 2020.09.18
                    Time: 17:08:14
16776980 - Databus
          [PLA_Status_01 keine Kommunikation]
                    Reset counter: 244
                    Mileage: 38934 km
                    Date: 2020.09.18
                    Time: 17:08:14
   Part No SW: 5Q0 907 530 AL    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2265
   Revision: --------    Serial number: 18061610520913
   Coding: 030100041F0873005B000248080B00000001010000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 7BA3F352D368FA93071-802E
   Subsystem 2 - Part No SW: 81A 951 523     HW: 81A 951 523
   Component: J453 MFL  H04 0003
   Serial number: 20160611121928 01400
   Serial number: 75410803001606022372
Address 26: Auto Roof (J256)       Labels:* None
   Part No SW: 8V7 959 255     HW: 8V7 959 255
   Component: VSG-AU375     H03 0040
   Coding: 400000
   ASAM Dataset: EV_ElectRoofContrMAQAU37X 001005
   ROD: EV_ElectRoofContrMAQAU37X.rod
   VCID: 08499C9E92BEA10B1A3-805C
   Serial number: 010616EF10140A
   Coding: 001C4B725C08040000001402
   VCID: 43D34BB2EB1842530F1-8016
   Subsystem 1 - Part No SW: 5Q0 959 812 C    HW: 5Q0 959 812 C
   Component: FOND_FHSG_DRV  002 0005
   Serial number: 00000000000009948730
   Coding: 110000
   Component: EPS_MQB_ZFLS  129 1072
   Coding: 8107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45D755AAE52C7C63215-8010
   Serial number: 040616EF405671
   Coding: 001C43725E08040000001402
   VCID: 42DD4EB6F4024B5B047-8016
   Subsystem 1 - Part No SW: 5Q0 959 811 C    HW: 5Q0 959 811 C
   Component: FOND_FHSG_PSG  002 0005
   Serial number: 00000000000009948250
   Coding: 090000
   Part No SW: 81A 035 183     HW: 81A 035 183
   Component: MU-HS-N-EU    045 0148
   Coding: 01730500FF00000011110001000A00002F002AC401F001000C
   ROD: EV_MUHigScl6C3DELP.rod
   VCID: 5EE59AC660BA0FBB00F-800A
   Subsystem 1 - Part No SW: 8V0 919 604 C    HW: 8V0 919 604 C
   Component: DU High  H49 0014
   Serial number: AUZ8Z9GY205R2U
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8V0 919 614 BE    HW: 8V0 919 614 BE
   Component: ControlUnit_B  H50 0103
   Serial number: ALJAL123041600010420
End----------(Elapsed Time: 01:03, VBatt start/end: 13.3V/13.2V)-----------
Hi and welcome.
Since you had the front sensors retrofitted, I think this belongs in Retrofits, not Tweaks. Moving.
Is the 8-channel J446 at address 10 the original one that came in the car or was it upgraded with the retrofit?
bmfurtado
Portugal
C?ID=418665
It was upgraded... there was a 4-channel one in (5QA 919 283) originally.
  • Informative
bmfurtado
Portugal
C?ID=418665
I was doing a bit more experimentation and found that setting Byte 3/Bit 4 to Active makes the MMI option appear, then the actual value of whether it is automatic or not is an Adaptation (which can be set from that particular MMI option).
Unfortunately, even with everything enabled, the sensors don't activate automatically. Could this be related with the firmware in the module, or the MMI version?
Could maybe this particular module just doesn't support that? Why would it accept the config and enable the adaptation and not work? I'm a bit confused about this and I'm very much not familiar with these things so I welcome any advice.
bmfurtado
Portugal
C?ID=418665
Alright, finally some progress...
I bought a different PDC controller (this time a 5Q0 919 294 K) and the automatic activation of the sensors now works...
Here's an autoscan of the working setup (ignore the minor faults, I hadn't reset them at the time):
Sunday,01,November,2020,17:04:57:55716
Mileage: 40883km-25403mi   Repair Order:
VIN: WAUZZZ8V1H1004529   Mileage: 40883km-25403miles
   Revision: 22004001
Readiness: N/A
   Coding: 0A47F7
   Coding: 00006C
929796 - Light Switch
          U110B 00 [008] - No Communcations
          [Lichtschalter-E1->Kein Signal/Kommunikation]
                    Reset counter: 95
                    Mileage: 40879 km
                    Date: 2020.11.01
                    Time: 15:31:24
   Revision: --------    Serial number: 39331615802671
   Coding: 0030051001
   Shop #: WSC 00788 648 00255
   Coding: A008
          B2010 00 [009] - -
                    Reset counter: 10
                    Mileage: 39576 km
                    Date: 2020.10.06
                    Time: 23:45:14
16777018 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_Audio_0x31 keine Kommunikation]
                    Reset counter: 94
                    Mileage: 40869 km
                    Date: 2020.10.31
                    Time: 19:32:26
16776980 - Databus
                    Reset counter: 10
                    Mileage: 39576 km
                    Date: 2020.10.06
                    Time: 23:45:14
   Coding: 400000
   Coding: 110000
   Coding: 8107
   Coding: 090000
          B1487 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 72
                    Mileage: 40118 km
                    Date: 2020.10.17
                    Time: 16:52:47
   Coding: 01730500FF00000011110001000A00002F002AC401F001000E
End----------(Elapsed Time: 01:02, VBatt start/end: 13.3V/13.3V)-----------
