2014 VW Passat NMS - TDI Tweaks
TDIPower
Mississauga, Canada
C?ID=419235
Hello everybody! I have a '14 Passat TDI ComfortLine that I couldn't reset the service from the MFI so I bought a VCDS. Now that I reset that, I'm thinking about some tweaks. Of course, I will post the auto scan, where I have some issues, maybe you guys can help me out in order to read them properly.
The mirror turn signal, I will replace it once I will find one, since they are hard to get in the local scrapyard, and aliexpress does not have any dynamic blinkers for my NMS. I did upgrade the radio to an RCD330 from LemonShark so I can benefit from the CarPlay feature. No issues so far, sound-wise I would say it's even better than the stock genuine one. It's even coded for reverse (tries to turn on the camera when I put it in reverse, even though I didn't install a camera yet. I have it in my garage...maybe one day.
As for the tweaks, I'm looking at a couple of them:
- Service Reset - Done successfully
- Needle Sweep - Done successfully
- Passenger Mirror dipping while in reverse ( I went Cent. Elec -> Coding -> Long coding helper -> Byte 4 -> Bit 3 Mirror lowering with reverse rear -> Exit helper -> Do It! -> Start the car, nothing happens when in reverse, even though the mirror knob is on R)
- Windows up from remote
- Windows up / Sunroof closing rain sensor
I am open to more tweaks since I feel the sky is the limit with VCDS.
Monday,05,October,2020,13:52:47:08384
VIN: 1VWBN7A3XEC039760   License Plate: TDIPOWER
Mileage: 115100km-71519mi   Repair Order: 05102020
Chassis Type: A3-VW41 (7N0)
          77
VIN: 1VWBN7A3XEC039760   Mileage: 115100km-71519miles
   Component: R4 2.0l TDI   H24 9982
   Revision: 71H24---    Serial number:
   Coding: 001D0012842400000000
   Shop #: WSC 99916 999 00000
   ROD: EV_ECM20TDI01103L997009H.rod
   VCID: 3B233322D3E7ACD3471-806E
17262 - Terminal 30
          U140A 00 [032] - Open Circuit
          [Terminal 30Open circuit]
4629 - ECM Power Relay Load Circuit
          P068A 00 [032] - Opens Too Early
   Component: GSG DSG AG6     521 9437
   Revision: 05652104    Serial number: 00001306200620
   Shop #: WSC 09003 957 00200
   VCID: 1471B89E927983ABE6B-8040
   Revision: 00H31001
   Coding: C54BC0F549250003A31203EA92190042271000
   VCID: 7DA7FD3A8DF362E3395-8028
   Part No SW: 561 907 044 AB    HW: 561 907 044 AB
   Component: Climatronic   H03 0505
   Revision: 00001K01
   Coding: 0030019002
   VCID: 57EB8F924F8F68B3439-8002
   Part No SW: 5K0 937 087 AE    HW: 5K0 937 087 AE
   Component: BCM PQ35 H+   122 0173
   Revision: BL122001
   Coding: EF200E1B802B2AD4088800011600854800F1A08640801520648060000C70
   VCID: 78A9EC2EA2D147CB6A3-802C
00897 - Windshield Washer Pump (V5)
                    Fault Status: 00101100
                    Fault Frequency: 9
                    Reset counter: 77
                    Mileage: 114759 km
                    Date: 2020.10.03
                    Time: 10:23:37
                    Voltage: 14.40 V
                    Fault Status: 00101011
                    Fault Frequency: 9
                    Reset counter: 77
                    Mileage: 114759 km
                    Date: 2020.10.03
                    Time: 10:23:37
                    Voltage: 14.40 V
                    Reset counter: 75
                    Mileage: 113697 km
                    Date: 2020.09.19
                    Time: 15:27:19
                        Term 15 Off
                    Voltage: 12.55 V
                    Reset counter: 75
                    Mileage: 113697 km
                    Date: 2020.09.19
                    Time: 15:27:19
                        Term 15 Off
                    Voltage: 12.55 V
   Serial number: 003MWM032Y9+
   Coding: 00005033
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 75B7E51AB5433AA3715-8020
   Serial number: 6940000Y130000YM690%
   Coding: 303046
   Serial number: 3572MSME0774037CZZZX
   Serial number: 3582MSME5372037CZZZX
   Serial number: 3516KSME7F214727ZZZY
   Serial number: 3526KSME1D164727ZZZV
   Serial number: 3556LSME27551628ZZZU
   Serial number: 3566LSME3D4D1628ZZZ2
   Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
   Revision: FF010042    Serial number: 20130726301520
   Coding: 089A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 76B5E216A84531BB78F-8022
   Coding: E30000
   Part No SW: 561 920 870 E    HW: 561 920 870 E
   Coding: 331E01
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW41.rod
   VCID: 1B63D3A27327CCD3A71-804E
   Part No SW: 7N0 907 530 AM    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1642
   Revision:   H55       Serial number: 23091303000663
   Coding: 461000
   VCID: 7BA3F32293E76CD3071-802E
   Part No SW: 561 919 965     HW: 561 919 965
   Component: Kompass         002 0001
   Revision: 00002000    Serial number: 1829227R4G5106
   Coding: 0000002
   VCID: 6393AB420757B4132F1-8036
   VCID: 6A8DC666ECFDE55BEC7-803E
Address 2E: Media Player 3
   Revision: 13110009    Serial number: 0007311044
   Coding: 0404F5
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 5BE393A233A78CD3671-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  006 5470
   Serial number: 14202630131007083917
   Coding: 800000
67589 - Turn Signal in Exterior Mirror
          B11FD 01 [009] - Electrical Failure
                    Reset counter: 46
                    Mileage: 100005 km
                    Date: 2019.11.20
                    Time: 18:39:48
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 290    3501
   Revision: 00H22000
   VCID: 392F292AD55B9EC355D-806C
   Component: EZE_2         H55 1642
   Coding: 01030108
   VCID: 6FBBD772D79F0073BB9-803A
   Serial number: 53388786011311601455
   Coding: 181100
   Revision: 15110009    Serial number: 0007295423
   Coding: 0404F4
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 5CE190BE36A98BEB6EB-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  006 5470
   Serial number: 14102631130930153158
   Coding: 800000
   Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
   Component: MIB2-S-R-CN   036 0317
   Revision: -----001    Serial number: VWZ6Z2S7526198
   Coding: 1600044004000A
   Shop #: WSC 00081 790 00133
   VCID: 46D552D698A5E13B28F-8012
10 Faults Found:
00856 - Radio Antenna
                    Reset counter: 186
00877 - Treble Speaker Rear Right (R16)
                    Reset counter: 73
                    Reset counter: 73
00875 - Treble Speaker Front Right (R22)
                    Reset counter: 73
                    Reset counter: 73
                    Reset counter: 186
                    Reset counter: 186
00871 - Bass Speaker Front Right (R23)
                    Reset counter: 186
                    Reset counter: 186
00625 - Vehicle Speed Signal
                    Reset counter: 45
                    Mileage: 13 km
                    Date: 2015.05.08
                    Time: 16:32:08
   Part No SW: 5N0 035 729 A    HW: 5N0 035 729 A
   Component: TELEFON       H05 0592
   Revision: 1B001001    Serial number: 00007665169857
   Coding: 0A10030080010110
   ROD: EV_UHVUMI.rod
   VCID: 2E050A761095497BF0F-807A
          B104F 13 [009] - Short to GND
                    Reset counter: 146
                    Mileage: 101828 km
                    Date: 2020.02.24
                    Time: 18:10:35
          B104E 13 [009] - Short to GND
                    Reset counter: 146
                    Mileage: 101828 km
                    Date: 2020.02.24
                    Time: 18:10:35
End----(Elapsed Time: 01:04, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
@TDIPower : hi.
I'm very confused and I desperately need your help to salve my addled brain!! :facepalm: Here's a bit of your scan report for the passenger side module:
   Coding: 0404F4
   Slave Passenger:
   Coding: 800000
Notice the long code string is 0404F4. I can assure you that I did pass my hexadecimal math exams albeit, now many years ago - but doesn't this module have only 3 x bytes (i.e. max is Byte 2)? What am I missing?
And why the mention of "rear' - isn't the dip-on-reverse tweak imposed on the front passenger-side mirror (does a '14 Passat TDI ComfortLine' even have a rear door mirror)?
Apropos of your cliche - my advice: reach for the stars, but keep your feet firmly on the ground! how's that for a mixed metaphor?:facepalm:
TDIPower
Mississauga, Canada
C?ID=419235
@TDIPower : hi.
   Coding: 0404F4
   Slave Passenger:
   Coding: 800000
Hi Don,
First of all, thanks for your reply; indeed, I'm reaching daily for the stars, while flying a GA plane. Didn't reached them yet, will see.
As for the code, I don't know where you're coming from, and why would you have a hexadecimal math exam, but kudos to you! I've followed the steps from this video (
) which I found pretty straightforward. Will try to play with it tomorrow, maybe clear all the old codes and see what pops up again.
Cheers!
Hi Don,
Cheers!
TDI Power: My bad and my apology
TDIPower
Mississauga, Canada
C?ID=419235
Don, no worries. I'm still trying to find ways around these tweaks.
I've cleared the previous errors, will see from now on. I still get radio issues now. What is the deal with this Treble and Bass speakers? How about the telephone issues? Can that be just because I installed a new radio?
Cheers!
Wednesday,07,October,2020,12:59:13:08384
Mileage: 115190km-71575mi   Repair Order: 07102020-restored
          77
VIN: 1VWBN7A3XEC039760   Mileage: 115190km-71575miles
Readiness: 0 0 0 1 1
   Revision: 00H31001
   Revision: 00001K01
   Coding: 0030019002
   Revision: BL122001
   Coding: EF200E1B882B2AD4088800011600854800F1A08640801520648060000C70
   Coding: 00005033
   Coding: 303046
   Coding: 089A140000
   Coding: E30000
   Coding: 331E01
   Coding: 461000
   Coding: 0000002
   Coding: 0404F5
   Slave Driver:
   Coding: 800000
   Revision: 00H22000
   Coding: 01030108
   Coding: 181100
   Coding: 0404F4
   Slave Passenger:
   Coding: 800000
10 Faults Found:
                    Reset counter: 186
                    Reset counter: 73
                    Reset counter: 73
                    Reset counter: 73
                    Reset counter: 73
                    Reset counter: 85
                    Reset counter: 85
                    Reset counter: 85
                    Reset counter: 85
                    Reset counter: 45
                    Mileage: 13 km
                    Date: 2015.05.08
                    Time: 16:32:08
   ROD: EV_UHVUMI.rod
                    Reset counter: 45
                    Mileage: 115193 km
                    Date: 2020.10.07
                    Time: 12:57:34
                    Reset counter: 45
                    Mileage: 115193 km
                    Date: 2020.10.07
                    Time: 12:57:34
End----(Elapsed Time: 01:03, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
dieseldub
Bay Area, CA
C?ID=28764
Cheers!
          77
   Revision: 00H31001
   Revision: 00001K01
   Coding: 0030019002
   Revision: BL122001
   Coding: 00005033
   Coding: 303046
   Coding: 089A140000
   Coding: E30000
   Coding: 331E01
   Coding: 461000
   Coding: 0000002
   Coding: 0404F5
   Slave Driver:
   Coding: 800000
   Revision: 00H22000
   Coding: 01030108
   Coding: 181100
   Coding: 0404F4
   Slave Passenger:
   Coding: 800000
10 Faults Found:
                    Reset counter: 186
                    Reset counter: 73
                    Reset counter: 73
                    Reset counter: 73
                    Reset counter: 73
                    Reset counter: 85
                    Reset counter: 85
                    Reset counter: 85
                    Reset counter: 85
                    Reset counter: 45
                    Mileage: 13 km
                    Date: 2015.05.08
                    Time: 16:32:08
   ROD: EV_UHVUMI.rod
                    Reset counter: 45
                    Mileage: 115193 km
                    Date: 2020.10.07
                    Time: 12:57:34
                    Reset counter: 45
                    Mileage: 115193 km
                    Date: 2020.10.07
                    Time: 12:57:34
That's DEFINITELY from the radio you've put in. Looks like a Chinese Market RCD330. Maybe it's not coded correctly or the adapter not seated fully?
Also, I believe that radio has built in bluetooth, which makes your address 77 J412 Telephone redundant. I'd unplug that module and remove it from the CAN Gateway installation list, that will at least take care of those two codes.
