Hi guys, how are yall. I want the abs coding and login for this passat.I was about to do it but dont know why people keep ripping the pr sticker off its really annoying.
here is the autoscan. Also i know i need to update but been a lil lazy. thanks!
Saturday,03,October,2020,14:35:52:50280
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4508.4
VIN: WVWZZZ3BZ5E005728 License Plate:
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
VIN: WVWZZZ3BZ5E005728 Mileage: 196350km-122006miles
Address 01: Engine Labels: 038-906-019-AVB.lbl
Part No: 038 906 019 KC
Component: 1,9l R4 EDC G000SG 4896
Coding: 00002
Shop #: WSC 05314
VCID: E288F2D76C8B595F51-4B1E
WVWZZZ3BZ5E005728 VWZ7Z0D9783356
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-10 - - Intermittent
19586 - EGR System
P3130 - 35-10 - Regulation Range Exceeded - Intermittent
18057 - Powertrain Data Bus
P1649 - 35-00 - Missing Message from ABS Controller
Readiness: 1 1 0 0 0
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 G
Component: ABS/ESP front 3428
Coding: 00000
VCID: A502A9CB3D25EE6774-51CE
66-10 - Not Matched - Intermittent
35-00 - -
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 K
Component: CLIMATRONIC B5GP 0010
Coding: 17000
Shop #: WSC 05311
VCID: A91AA5FB513DCA0750-5184
80-10 - Single-Wire Operation - Intermittent
Part No: 1C0 909 605 C
Component: 0E AIRBAG VW61 04 0003
Coding: 12357
Shop #: WSC 05311
VCID: A404B4CF361F176F63-513C
Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
Part No: 1J0 907 487 A
Component: Lenkradelektronik 0005
Coding: 00118
Shop #: WSC 05311
VCID: AF2E4BE36FD9A4378E-5184
80-00 - Single-Wire Operation
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 849 A
Component: KOMBI+WEGFAHRSP VDO V04
Coding: 21115
Shop #: WSC 07268
VCID: A600AEC74023E57F7D-513C
30-00 - Open or Short to Plus
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 05311
VCID: F0AC889FB267FBCFD7-513C
49-00 - No Communications
Address 37: Navigation Labels: 3B0-919-887.lbl
Part No: 3B0 919 887 H
Component: Navigation BNO 0102
VCID: B73E738397896CF7D6-4B00
00-00 - -
Part No: 1C0 959 799 B
Component: 85 Komfortgerát HLO 0004
Coding: 00259
Shop #: WSC 05311
VCID: B6207E87908395FFCD-4B1E
Subsystem 1 - Part No: 1C1959801
Component: 85 Tõrsteuer.FS KLO 0202
Subsystem 2 - Part No: 1C1959802
Component: 85 Tõrsteuer.BF KLO 0202
Subsystem 3 - Part No: 1C0959811
Component: 6T Tõrsteuer.HL KLO 0009
Subsystem 4 - Part No: 1C0959812
Component: 85 Tõrsteuer.HR KLO 0202
Address 56: Radio Labels: 3B0-035-186.lbl
Part No: 3B0 035 186 D
Component: Radio BNO 0102
Coding: 05407
Shop #: WSC 05311
VCID: A00CB8DF22070B4F07-4B00
00852 - Loudspeaker(s); Front
36-00 - Open Circuit
00853 - Loudspeaker(s); Rear
00855 - Connection to CD changer
00-00 - -
End----------(Elapsed Time: 04:30, VBatt start/end: 14.0V/14.3V)-----------
