MK7 Golf Sportwagen Rear hatch light on with rear lights?
StorableComa
C?ID=219649
Hello All,
Looking to see if it's possible with coding to have the rear hatch light come on when the overhead "Rear" Light button is pushed. Currently it seems the hatch light only comes on when the boot is open, but I frequently have my dogs back there and would welcome the extra light to check on them when driving.
Figure I may have to do some wire splicing to get this to work, but wanted to see if it was a simple code change first.
Autoscan - Ignore the errors, I had recently done some BCM work that triggered them.
Friday,02,October,2020,23:11:54:38692
VCDS Version: 20.4.2.0 (x64)  HEX-NET2 CB: 0.4527.4
VIN: 3VWC17AU4HM532202   License Plate:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75
VIN: 3VWC17AU4HM532202   Mileage: 66774km-41491miles
Address 01: Engine (J623-CXBB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 K    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 091A00122424002F0000
   Shop #: WSC 00066 790 00202
   ASAM Dataset: EV_ECM18TFS0208V0906264K 001004
   ROD: EV_ECM18TFS0208V0906264K.rod
   VCID: 44DA27434E12AD6B36B-8010
Readiness: 1110 1101
   Part No SW: 09G 927 158 AR    HW: 09G 927 158
   Component: AISIN AG6 G3  202 3198
   Coding: 010100000C000000000000000000000000000000
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_002_VW23.rod
   VCID: 0358E45F0B9C6A534F1-8056
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 AQ    HW: 5Q0 614 517 AF
   Component: ESC           H62 0400
   Revision: 00000000    Serial number: 50367000001346
   Coding: 04FA6AA12423096E4079020080C52920562490024001943400405050C002430000000012121212B835351919323200
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
   ROD: EV_Brake1UDSContiMK100ESP_036.rod
   VCID: 0052EB531A8A714B523-8054
0297 - Steering Angle Sensor
          B1168 F2 [137] - Not Initialized
                    Reset counter: 28
                    Mileage: 66774 km
                    Date: 2020.10.02
                    Time: 23:10:15
   Part No SW: 5GM 907 426 D    HW: 5GM 907 426 D
   Component: AC Manuell    H03 1801
   Revision: 00001K04
   Coding: 02020004200100000000000000000002
   VCID: 49C4367769307003C5D-801C
   Part No SW: 5Q0 937 087 AN    HW: 5Q0 937 087 AN
   Component: BCM PQ37BOSCH 032 0223
   Revision: --------    Serial number: C86413021700OT
   ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
   ROD: EV_BCMBOSCH_017.rod
   VCID: 0740F04F3FA44673139-8052
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    161129  043 0551
   Serial number: 97022066161212024516
   Serial number: 003GCR076DTR
   VCID: 47C0304F7F248673D39-8012
   Occupant Detection:
   Serial number: IBH000000000006OE3GN
   Coding: 303133
   Subsystem 2 - Part No SW: -----------    HW: 480 001 801 17
   Serial number: 35700000000D8841E02M
   Subsystem 3 - Part No SW: -----------    HW: 480 001 901 17
   Serial number: 35800000000C0D8CF02Z
   Subsystem 4 - Part No SW: -----------    HW: 480 402 701 17
   Serial number: 3510001BF248E89303FG
   Subsystem 5 - Part No SW: -----------    HW: 480 402 601 17
   Serial number: 3520001B7237EE245396
   Subsystem 6 - Part No SW: -----------    HW: 480 402 301 17
   Serial number: 3550002C723C4E33315+
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 301 17
   Serial number: 3560002C923C4E34A137
   Part No SW: 5Q0 953 507 GH    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 02031708491150
   Coding: 0410
   VCID: 0256E15B1486635B447-8056
   Part No SW: 5G1 920 840 B    HW: 5G1 920 840 B
   Component: KOMBI         244 8311
   Coding: 0BB5110AA180CF0502087A001000000000000000
   VCID: 261E9DCBD86E7F7B08F-8072
   Component: GW MQB High   518 5286
   Serial number: 14031910801185
   Coding: 0101000870085900FA0000081C0F00000001050000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 2F3078EFF7943E33FB9-807A
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0103
   Serial number: 27160003134840116474
   Coding: 31FFFF
   Serial number: 1012171YJ84946
   Coding: 001103205000020000000000
   VCID: 43D8245F4B1CAA530F1-8016
   Serial number: 00000000000005474626
   Coding: 011000
   Part No SW: 5QM 909 144 A    HW: 5QM 909 144 A
   Component: EPS_MQB_ZFLS  171 1072
   Coding: 0102
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 4FF0186F97545E339B9-801A
16275 - Steering Angle Sensor
          B1168 F2 [009] - Not Initialized
                    Reset counter: 28
                    Mileage: 66774 km
                    Date: 2020.10.02
                    Time: 23:10:14
                    Motor status: 00
                    Supply voltage: 12.00 V
                    Temperature: 37.0 °C
                    KFC: 3F
                    KFA: 00 93
                    Environmental conditions: 5F
                    uAdSensI_U1V2Filtered_gdu16: 1.19 V
                    uioUdNotFilt_xdu16: 11.98 V
                    uAdSensI_SwitchedKl30_xdu16: 11.99 V
                    NoInitCause_AsicSens: [0x12] ASC_CTRL_SAS_PERIOD_ERR - SASPERIOD content lost after last ignition off
                    NoInitCause_RackPos_Rohwert: 01 80
                    RP_VALCNTSAV: activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: activated
   Serial number: 2211181YJ83832
   Coding: 001103205C00020000000000
   VCID: 42D6215B5406A35B047-8016
   Serial number: 00000000000005464806
   Coding: 091000
   Part No SW: 3Q0 035 844 A    HW: 3Q0 035 844 A
   Component: MU-S-S-US     710 0751
   Coding: 02730200FF00000051220001001808009F0100D40120010002
   Shop #: WSC 00066 790 07025
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 2D0C62E7FD984C23C95-8078
   Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
   Component: ABT_Std-2  H53 1031
   Serial number: VWZ8Z9TJW024PY
          B11CF 53 [009] - Deactivated
                    Reset counter: 28
                    Mileage: 66774 km
                    Date: 2020.10.02
                    Time: 23:10:28
                    Voltage terminal 30: 12.0 V
                    SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
                    SDARS_tuner_status_2-Audio Signal: Not available
                    SDARS_tuner_status_2-Antenna current: 137 mA
                    SDARS_tuner_status_2-Reception quality: No_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
0008 - Connection between Antenna Amp 2 for Radio and Antenna
          B1273 13 [009] - Open Circuit
                    Reset counter: 28
                    Mileage: 66774 km
                    Date: 2020.10.02
                    Time: 23:10:16
                    Voltage terminal 30: 12.1 V
                    Status of antenna 2 for radio-Antenna current: 0 mA
                    Status of antenna 2 for radio-Connection between radio and antenna amplifier: Electrical OK
                    Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Open circuit
                    Status of antenna 2 for radio-Reception level antenna 2: 51 dBµV
   Coding: 02730202C2821A017F1E06000000
   ROD: EV_OCULowMQB.rod
End----------(Elapsed Time: 01:12, VBatt start/end: 12.2V/12.1V)-----------
Thanks,
Sean
@StorableComa : Sean, Hi. Mine is a bit of a long-shot suggestion, but I note the following adaptation channel in the BCM:
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten
My trusty browser add-on translator says that the German bit of the name means "Switch on the interior light with the trunk lid open". So I'm guessing that if this channel is set to active on your car, perhaps try changing to not active - maybe?
It's an easy try - so give it a go!
