DRL off when parking brake is on (Audi A4 8E)
draugen
Norway
C?ID=400067
I'm searching for a way to activate the function that caused the DRL (low beams) to turn off when the parking brake (hand brake) is on. I have looked at the wiki-page for my car, but didn't find any adaptation that does that specifically. I see that this is a function that is pretty standard in the US, but not here in Norway. I would think it would be possible to change this in the coding? Any suggestions are appreciated.
Wednesday,16,September,2020,12:46:00:48853
VIN: WAUZZZ8E36Axxxxxx   License Plate:
Mileage: 147130km-91422mi   Repair Order:
          67 69 75 76 77
VIN: WAUZZZ8E36Axxxxxx   Mileage: 147130km-91422miles
Address 01: Engine        Labels: 03G-906-016-BKE.clb
   Part No SW: 03G 906 016 FE    HW: 028 101 212 7
   Component: R4 1,9L EDC 0000SG  9820
   Revision: 12345678    Serial number: AUX6Z0E0142358
   Coding: 0000071
   Shop #: WSC 00030 218 81387
   VCID: 6B83C17E9F9E1D03971-5184
   Part No SW: 8E0 910 517 D    HW: 8E0 614 517 AK
   Component: ESP8 front      H05 0120
   Coding: 0004401
   Shop #: WSC 06325 000 00000
   VCID: 2809FE724EF8F61B3A3-807C
   Part No: 8E0 820 043 BK
   Component:   A4 Klimaautomat   2832
   Coding: 00000
   VCID: 6B83C17E9A9E1D03971-513C
   Part No: 8E0 907 279 L
   Component: int. Lastmodul  NDL 0504
   Coding: 11012
   Shop #: WSC 65536
   VCID: 3B23313EAA7E4D83471-4B00
   Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
   Component:    Airbag 9.41  H11 3530
   Revision: 91H1135    Serial number: 0036M007R5C$
   Coding: 0033622
   VCID: 3B23313EAF6E4D83471-806E
   Subsystem 1 - Serial number: 6332DRB40228CE14Q
   Subsystem 2 - Serial number: 6342DRB402314E0DL
   Subsystem 3 - Serial number: 6352ARB40061D5D7R
   Subsystem 4 - Serial number: 6362ARB4007CA41CT
   Subsystem 5 - Serial number: 63729RB400BAA9FD8
   Subsystem 6 - Serial number: 63829RB400BAAA92-
   Part No: 8E0 953 549 S
   Component: Lenks·ulenmodul     0611
   Coding: 01012
   Shop #: WSC 06325
   VCID: 43D349DED28E35430F1-4B00
   Part No SW: 8E0 920 901 B    HW: 8E0 920 901 B
   Component: KOMBI+WFS 3     H12 0110
   Revision: 0110        Serial number: AUX6Z0E0142358
   Coding: 0006141
   Shop #: WSC 80093 222 69422
   VCID: 2411EA4232C0127B16B-5184
   Coding: 0006141
   Part No: 8E0 959 433 BQ
   Component: Komfortger·t T01    3332
   Coding: 06992
   Shop #: WSC 00027
   VCID: 015F83D68812E7535DD-4B00
   Subsystem 1 - Part No: 8E1959801H
   Component: Tırsteuer.FS BRM 0506
   Subsystem 2 - Part No: 8E1959802B
   Component: Tırsteuer.BF BRM 0205
   Component: Tırsteuer.HL BRM 0506
   Subsystem 4 - Part No: 8E0959802E
   Component: Tırsteuer.HR BRM 0506
   Part No: 8E0 035 186 D
   Component: concert II  GRO    0004
   Coding: 01001
   Shop #: WSC 06325
   VCID: 2809FE724BD8F61B3A3-4B1E
End----(Elapsed Time: 05:24, VBatt start/end: 12.1V/11.8V. VIgn 11.8V)-----
The 8E electronics, being an almost 20 year old design, aren't terribly smart or flexible.
You could try changing the the country in the last digit of the coding in the 09-Cent.Elect. module. Right now it's a '2' for Nordic Countries without Bi-Xenon. I would try '4' for "Canada without Bi-Xenon". Canada did require DRLs back then. However, I suspect you will lose the rear DRLs that I think are mandatory in Norway, whereas only front DRLs were mandatory in Canada.
draugen
Norway
C?ID=400067
Hi, thanks for the suggestion, I'll try that out :)
