Hi there, I have a stock 2008 Audi Q7. I was getting a P0171 & P0174 - 004 - System Too Lean - MIL ON. I replaced the PVC valve on it which means I removed the intake manifold and replaced the "cylinder head cover" which contains the PVC valve in it. As confirmation, I disassembled the old PVC assembly and looked at the diaphragm on the PVC. It had a large hole in it and the rubber was very brittle, so it definitely needed replacing. After reassembling and clearing the engine light, the car no longer throws the engine light or this error. I also replaced the fuel filter as a follow-up since I have owned this car for a while and have never replaced it. I wanted to just make sure that there was no fuel blockage issue contributing to the system lean error. Here's where the fun begins.
A few days after all these repairs, I'm feeling pretty good about my accomplishment. I'm driving on the highway and I put my foot into it pretty seriously to pass someone. The car Misfires and is running pretty rough with lack of power. I did a scan and found this.
I guess my thought is that the fuel injectors are bad, but before I address that, I wanted to get some input from the community experts. I guess it could also be some sort of lose connection in the wiring, but I've never seen this error code in the past. Hmmmm....
As a note, if I let the engine cool down and then restart it returns to normal. I can drive normally til the cows come home with no issues if I don't put my foot into the accelerator too hard. But what the heck! Why drive if you have that limitation?? Sometimes when I Push the accelerator hard, the engine light blinks a few times and things return back to normal if I back off on the accelerator quickly. If I clear the codes and take it out and do it again, it's not always the same cylinders which are misfiring. There may be a hint there....
Also, when I removed the intake manifold for the above maintenance, I had to remove the lower fuel rail to take it off. During reassembly, I replaced the old O-Rings on the fuel injectors. I didn't remove any of the electrical connectors from the fuel injectors. I also replaced all gaskets with new ones on the intake manifold and the Head cover during the original maintenance.
Lots of miles on this car. I have never replaced the injectors since I bought the car @ ~30K miles.
There is also an error code for the ABS brakes in the autoscan (also intermittent). Not sure what that's about.
Many thanks in advance for any suggestions or comments.
Paul
Monday,28,September,2020,20:47:16:04546
VCDS Version: 20.4.2.0 (x64) HEX-V2 CB: 0.4513.4
Dealer/Shop Name: Paul
VIN: WA1AY74L28D042453 License Plate:
Mileage: 249680km-155143mi Repair Order: 15
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 42 46 47 4F 52 56
61 62 65 6D 6F 72
VIN: WA1AY74L28D042453 Mileage: 249680km-155143miles
Address 01: Engine (BHK) Labels: 03H-906-032-BLV.clb
Part No SW: 03H 906 032 CA HW: 03H 906 032 G
Component: Q7 3.6-FSI-LEV2 G 1379
Revision: 5CH05--- Serial number:
Coding: 0001175
Shop #: WSC 31414 790 00001
VCID: 6393A8C17754A4332F1-8036
008518 - Supply Voltage for Fuel Injector Group A
P2146 - 002 - Open Circuit - Intermittent
Mileage: 249658 km
Date: 2020.09.28
Time: 19:46:37
RPM: 4107 /min
Load: 92.5 %
Speed: 80.0 km/h
Temperature: 88.0°C
Temperature: 24.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.589 V
000628 - Fuel Injector #5 (N83)
P0274 - 001 - Short to Plus - Intermittent
Fault Status: 00100001
Mileage: 249658 km
Date: 2020.09.28
Time: 19:46:37
RPM: 4107 /min
Load: 92.5 %
Speed: 80.0 km/h
Temperature: 88.0°C
Temperature: 24.0°C
Voltage: 13.589 V
P0300 - 001 - - Intermittent
Mileage: 249658 km
Date: 2020.09.28
Time: 19:46:37
RPM: 4230 /min
Load: 93.7 %
Speed: 81.0 km/h
Temperature: 88.0°C
Temperature: 24.0°C
Voltage: 13.716 V
000773 - Cylinder 5
P0305 - 001 - Misfire Detected - Intermittent
Mileage: 249658 km
Date: 2020.09.28
Time: 19:46:37
RPM: 4230 /min
Load: 93.7 %
Speed: 81.0 km/h
Temperature: 88.0°C
Temperature: 24.0°C
Voltage: 13.716 V
Mileage: 249674 km
Date: 2020.09.28
Time: 20:06:55
RPM: 1475 /min
Load: 29.4 %
Speed: 64.0 km/h
Temperature: 88.0°C
Temperature: 26.0°C
Voltage: 13.716 V
000772 - Cylinder 4
P0304 - 001 - Misfire Detected - Intermittent
Mileage: 249675 km
Date: 2020.09.28
Time: 20:08:41
RPM: 1774 /min
Load: 52.5 %
Speed: 76.0 km/h
Temperature: 92.0°C
Temperature: 23.0°C
Voltage: 13.589 V
Readiness: 0110 0100
Part No SW: 4L0 910 156 B HW: 0AT 927 156
Component: AG6 0AT 3,6 FSI USA 0010
Revision: --H04--- Serial number: 4035629
VCID: 2809FFED4EF2076B3A3-807C
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 B HW: 4L0 614 517 D
Component: ESP ALLRAD MK25E1 0010
Revision: 00H30001
Coding: 0099345
VCID: 290FFAE955F83E6325D-807C
Fault Status: 00101101
Reset counter: 180
Mileage: 249620 km
Date: 2020.09.26
Time: 15:28:02
Count: 8257
Count: 8193
Count: 48640
Component: FBSAUDIC6 ELV H31 0230
Revision: 09010701 Serial number: 10601500957792
Coding: 0000131
Subsystem 1 - Part No: 4F0 910 131 J
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head Labels: Redir Fail!
Part No SW: 4L0 910 730 Q HW: 4L0 035 730 C
Component: MMI Cockpit H80 0410
Revision: C61120EU Serial number: AUZ6Z2GBMD36I3
Coding: 0444222
VCID: 3537269989406A83B15-8060
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000001337903
Subsystem 3 - Serial number: 0123.06.090000000100010489ÿ
Subsystem 4 - Serial number: 010489ÿ
Part No SW: 4L0 910 043 B HW: 4L0 820 043 L
Component: KLIMABETAETIGUNGH07 0030
Revision: 00---013 Serial number: 00000030075150
Coding: 0524326
VCID: 2313E8C137D4E4336F1-8076
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H18 0250
Coding: 0010103
VCID: 313F12897D2846A3EDD-8064
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H14 0100
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0100
Coding: 00150059
Shop #: WSC 31414
Address 0E: Media Player 1 Labels: None
Coding: 0444222
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 K HW: 4E0 035 593 F
Component: SDAR SIRIUS H07 0140
Revision: 00000000 Serial number: AUZ4Z7G0215383
Coding: 0000100
VCID: 2F3B14F16B1C5053FB9-807A
Time Indication: 15
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH42 0230
Revision: 06H42000 Serial number: 0038QD07AHFD
Coding: 0014131
VCID: 2B0300E15F042C73D71-807E
Subsystem 1 - Part No: 4L0 910 339 A
Component: BF-Gewichtsens. H03 0030
Subsystem 2 - Serial number: 6332QSME474D250BL
Subsystem 3 - Serial number: 6342QSME4B21413BD
Subsystem 4 - Serial number: 6352QSME45182D47L
Subsystem 5 - Serial number: 6362QSME506E3709M
Subsystem 6 - Serial number: 63734SME49611F3B8
Subsystem 7 - Serial number: 63834SME4B212911X
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H03000 Serial number: 90055073260076
Coding: 0002022
VCID: 270BFCD143EC0813339-8072
Component: E0221 H02 0030
Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
Part No SW: 4F0 910 900 C HW: 4L0 920 950 E
Component: KOMBIINSTR. M73 H16 0240
Revision: 00200000 Serial number: 65U11K4D7
Coding: 1555283
Shop #: WSC 01126 067 57207
VCID: 2019E7CD26C2FF2B723-8074
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B07B278015
Coding: E557BE57700A0200
VCID: 2D070EF961102243C95-8078
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4L0 910 110 A HW: 4L0 035 110
Component: MP3-Changer H45 0350
Revision: 00045007 Serial number: AUZ5ZBG1242540
VCID: 1D67DE3911B0D2C3595-8048
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0150
Revision: 00-00000
Coding: 0035403
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 F HW: 4L0 907 289 C
Component: Komfortgeraet H07 0050
Revision: 0050 --- Serial number: 01084767680000
Coding: 7370781
VCID: 33331881873474B39F1-8066
01403 - Glass-Break Sensors; Rear
Fault Status: 01101011
Reset counter: 143
Address 47: Sound System (J525) Labels: Redir Fail!
Part No SW: 4L0 910 223 H HW: 4L0 035 223 C
Component: DSP-AU716-RD H07 0250
Revision: S0900000
Coding: 060000
VCID: 290FFAE959F83E6325D-807C
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000022253
Coding: 0012001
VCID: 5EE599355C3689DB00F-800A
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0150
Revision: 00-00000
Coding: 0035403
Address 56: Radio Labels: None
Coding: 0444222
Part No SW: 4L0 910 181 A HW: 4L0 915 181
Component: J0644 BEM H12 0690
Revision: -------- Serial number: 00000000043063
Shop #: WSC 07109 444 57830
VCID: 2517F6D939E01A03015-8070
Subsystem 1 - Part No: 4F0 915 105 C
Component: von VA0 2711240739
Coding: 344630393135313035432056413032373131323430373339
02256 - Quiescent Current
Reset counter: 171
Mileage: 249179 km
Date: 2020.09.05
Time: 22:08:11
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0150
Coding: 0035338
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000900061728
Coding: 0062424
VCID: 221DEDC528CEED3B647-8076
Address 6D: Trunk Elect. Labels: 4L0-910-945.clb
Part No SW: 4L0 910 945 HW: 4L0 827 851 C
Component: ValeoHeckdeckel H25 0290
Revision: --H25001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6C81C3FD9A8AEB4B9EB-8038
Subsystem 3 - Serial number: RD07.12.07--H25001001B0054ÿ
Subsystem 4 - Serial number: 1B0054ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 003314871-----
Coding: 0000009
VCID: 2615F1D544E6111B08F-8072
02961 - Lamp in Bumper; Rear Right
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 97
Mileage: 248545 km
Date: 2020.07.12
Time: 12:50:32
Bin. Bits: 000 100
Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
Component: TSG HR H21 0150
Coding: 0035338
End----------(Elapsed Time: 01:43, VBatt start/end: 14.0V/13.9V)-----------
Paul
