2008 Audi Q7 - Intermittent Fuel Inj Issue
pauljs33
C?ID=385174
Hi there, I have a stock 2008 Audi Q7. I was getting a P0171 & P0174 - 004 - System Too Lean - MIL ON. I replaced the PVC valve on it which means I removed the intake manifold and replaced the "cylinder head cover" which contains the PVC valve in it. As confirmation, I disassembled the old PVC assembly and looked at the diaphragm on the PVC. It had a large hole in it and the rubber was very brittle, so it definitely needed replacing. After reassembling and clearing the engine light, the car no longer throws the engine light or this error. I also replaced the fuel filter as a follow-up since I have owned this car for a while and have never replaced it. I wanted to just make sure that there was no fuel blockage issue contributing to the system lean error. Here's where the fun begins.
A few days after all these repairs, I'm feeling pretty good about my accomplishment. I'm driving on the highway and I put my foot into it pretty seriously to pass someone. The car Misfires and is running pretty rough with lack of power. I did a scan and found this.
Monday,28,September,2020,20:47:16:04546
Dealer/Shop Name: Paul
VIN: WA1AY74L28D042453   License Plate:
Mileage: 249680km-155143mi   Repair Order: 15
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 42 46 47 4F 52 56
          61 62 65 6D 6F 72
VIN: WA1AY74L28D042453   Mileage: 249680km-155143miles
6F-Centr. Conv. II -- Status: Malfunction 0010
Address 01: Engine (BHK)       Labels: 03H-906-032-BLV.clb
   Part No SW: 03H 906 032 CA    HW: 03H 906 032 G
   Component: Q7 3.6-FSI-LEV2 G   1379
   Revision: 5CH05---    Serial number:
   Coding: 0001175
   Shop #: WSC 31414 790 00001
   VCID: 6393A8C17754A4332F1-8036
008518 - Supply Voltage for Fuel Injector Group A
               P2146 - 002 - Open Circuit - Intermittent
                    Mileage: 249658 km
                    Date: 2020.09.28
                    Time: 19:46:37
                    RPM: 4107 /min
                    Load: 92.5 %
                    Speed: 80.0 km/h
                    Temperature: 88.0°C
                    Temperature: 24.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.589 V
000628 - Fuel Injector #5 (N83)
               P0274 - 001 - Short to Plus - Intermittent
                    Fault Status: 00100001
                    Mileage: 249658 km
                    Date: 2020.09.28
                    Time: 19:46:37
                    RPM: 4107 /min
                    Load: 92.5 %
                    Speed: 80.0 km/h
                    Temperature: 88.0°C
                    Temperature: 24.0°C
                    Voltage: 13.589 V
               P0300 - 001 -  - Intermittent
                    Mileage: 249658 km
                    Date: 2020.09.28
                    Time: 19:46:37
                    RPM: 4230 /min
                    Load: 93.7 %
                    Speed: 81.0 km/h
                    Temperature: 88.0°C
                    Temperature: 24.0°C
                    Voltage: 13.716 V
000773 - Cylinder 5
               P0305 - 001 - Misfire Detected - Intermittent
                    Mileage: 249658 km
                    Date: 2020.09.28
                    Time: 19:46:37
                    RPM: 4230 /min
                    Load: 93.7 %
                    Speed: 81.0 km/h
                    Temperature: 88.0°C
                    Temperature: 24.0°C
                    Voltage: 13.716 V
                    Mileage: 249674 km
                    Date: 2020.09.28
                    Time: 20:06:55
                    RPM: 1475 /min
                    Load: 29.4 %
                    Speed: 64.0 km/h
                    Temperature: 88.0°C
                    Temperature: 26.0°C
                    Voltage: 13.716 V
000772 - Cylinder 4
               P0304 - 001 - Misfire Detected - Intermittent
                    Mileage: 249675 km
                    Date: 2020.09.28
                    Time: 20:08:41
                    RPM: 1774 /min
                    Load: 52.5 %
                    Speed: 76.0 km/h
                    Temperature: 92.0°C
                    Temperature: 23.0°C
                    Voltage: 13.589 V
Readiness: 0110 0100
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 4L0 910 156 B    HW: 0AT 927 156
   Component: AG6 0AT 3,6 FSI USA 0010
   Revision: --H04---    Serial number:        4035629
   Coding: 0000002
   VCID: 2809FFED4EF2076B3A3-807C
   Part No SW: 4L0 910 517 B    HW: 4L0 614 517 D
   Component: ESP ALLRAD MK25E1   0010
   Revision: 00H30001
   Coding: 0099345
   VCID: 290FFAE955F83E6325D-807C
                    Fault Status: 00101101
                    Reset counter: 180
                    Mileage: 249620 km
                    Date: 2020.09.26
                    Time: 15:28:02
                    Count: 8257
                    Count: 8193
                    Count: 48640
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0230
   Revision: 09010701    Serial number: 10601500957792
   Coding: 0000131
   Subsystem 1 - Part No: 4F0 910 131 J
   Component: FBSAUDIC6 EZS   H45 0080
   Subsystem 2 - Part No: 4F0 910 220 A
   Component: FBSAUDIC6 IDG   H01 0040
Address 07: Control Head        Labels: Redir Fail!
   Part No SW: 4L0 910 730 Q    HW: 4L0 035 730 C
   Component: MMI Cockpit     H80 0410
   Revision: C61120EU    Serial number: AUZ6Z2GBMD36I3
   Coding: 0444222
   VCID: 3537269989406A83B15-8060
   Component: Bedienteil MMIC6H01 0060
   Subsystem 2 - Serial number: 00000001337903
   Subsystem 3 - Serial number: 0123.06.090000000100010489ÿ
   Subsystem 4 - Serial number: 010489ÿ
   Part No SW: 4L0 910 043 B    HW: 4L0 820 043 L
   Component: KLIMABETAETIGUNGH07 0030
   Revision: 00---013    Serial number: 00000030075150
   Coding: 0524326
   VCID: 2313E8C137D4E4336F1-8076
   Part No SW: 4F0 910 279 K    HW: 4F0 907 279
   Component: ILM Fahrer      H18 0250
   Coding: 0010103
   VCID: 313F12897D2846A3EDD-8064
   Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H14 0100
   Coding: 00064792
   Shop #: WSC 31414
   Subsystem 2 - Part No: 4E0 910 557 B  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0100
   Coding: 00150059
   Shop #: WSC 31414
Address 0E: Media Player 1        Labels: None
   Coding: 0444222
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 K    HW: 4E0 035 593 F
   Component: SDAR SIRIUS     H07 0140
   Revision: 00000000    Serial number: AUZ4Z7G0215383
   Coding: 0000100
   VCID: 2F3B14F16B1C5053FB9-807A
                    Time Indication: 15
   Part No SW: 4L0 910 655 A    HW: 4L0 959 655 B
   Component: 73 AIRBAG AUDI8RH42 0230
   Revision: 06H42000    Serial number: 0038QD07AHFD
   Coding: 0014131
   VCID: 2B0300E15F042C73D71-807E
   Subsystem 1 - Part No: 4L0 910 339 A
   Component: BF-Gewichtsens. H03 0030
   Subsystem 2 - Serial number: 6332QSME474D250BL
   Subsystem 3 - Serial number: 6342QSME4B21413BD
   Subsystem 4 - Serial number: 6352QSME45182D47L
   Subsystem 5 - Serial number: 6362QSME506E3709M
   Subsystem 6 - Serial number: 63734SME49611F3B8
   Subsystem 7 - Serial number: 63834SME4B212911X
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
   Component: J0527               0410
   Revision: 00H03000    Serial number: 90055073260076
   Coding: 0002022
   VCID: 270BFCD143EC0813339-8072
   Component: E0221           H02 0030
Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
   Part No SW: 4F0 910 900 C    HW: 4L0 920 950 E
   Component: KOMBIINSTR. M73 H16 0240
   Revision: 00200000    Serial number: 65U11K4D7
   Coding: 1555283
   Shop #: WSC 01126 067 57207
   VCID: 2019E7CD26C2FF2B723-8074
Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
   Part No SW: 4L0 910 468 A    HW: 4L0 907 468 B
   Component: J533__Gateway   H06 0060
   Revision: 00H06000    Serial number: 1100B07B278015
   Coding: E557BE57700A0200
   VCID: 2D070EF961102243C95-8078
Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
   Part No SW: 4L0 910 110 A    HW: 4L0 035 110
   Component: MP3-Changer     H45 0350
   Revision: 00045007    Serial number: AUZ5ZBG1242540
   VCID: 1D67DE3911B0D2C3595-8048
Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
   Component: TSG FA          H12 0150
   Revision: 00-00000
   Coding: 0035403
   Part No SW: 4L0 910 289 F    HW: 4L0 907 289 C
   Component: Komfortgeraet   H07 0050
   Revision: 0050 ---    Serial number: 01084767680000
   Coding: 7370781
   VCID: 33331881873474B39F1-8066
01403 - Glass-Break Sensors; Rear
                    Reset counter: 143
Address 47: Sound System (J525)       Labels: Redir Fail!
   Part No SW: 4L0 910 223 H    HW: 4L0 035 223 C
   Component: DSP-AU716-RD  H07 0250
   Revision: S0900000
   Coding: 060000
   VCID: 290FFAE959F83E6325D-807C
   Part No SW: 4F0 910 280     HW: 4F0 907 280 D
   Component: ILM Beifahrer   H12 0100
   Revision:             Serial number: 00000000022253
   Coding: 0012001
   VCID: 5EE599355C3689DB00F-800A
Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
   Component: TSG BF          H12 0150
   Revision: 00-00000
   Coding: 0035403
Address 56: Radio        Labels: None
   Coding: 0444222
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4L0 910 181 A    HW: 4L0 915 181
   Component: J0644 BEM       H12 0690
   Revision: --------    Serial number: 00000000043063
   Shop #: WSC 07109 444 57830
   VCID: 2517F6D939E01A03015-8070
   Subsystem 1 - Part No: 4F0 915 105 C
   Component: von VA0  2711240739
   Coding: 344630393135313035432056413032373131323430373339
02256 - Quiescent Current
                    Reset counter: 171
                    Mileage: 249179 km
                    Date: 2020.09.05
                    Time: 22:08:11
Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
   Component: TSG HL          H21 0150
   Coding: 0035338
Address 65: Tire Pressure        Labels: 4F0-910-273-BA.lbl
   Part No SW: 4F0 910 273 B    HW: 4F0 907 273 A
   Component: Reifendruck 3   H05 0100
   Revision: 00050100    Serial number: 00000900061728
   Coding: 0062424
   VCID: 221DEDC528CEED3B647-8076
   Part No SW: 4L0 910 945     HW: 4L0 827 851 C
   Component: ValeoHeckdeckel H25 0290
   Revision: --H25001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6C81C3FD9A8AEB4B9EB-8038
   Subsystem 3 - Serial number: RD07.12.07--H25001001B0054ÿ
   Subsystem 4 - Serial number: 1B0054ÿ
   Component: ILM HINTEN 2    H05 0060
   Revision: AAH05061    Serial number: 003314871-----
   Coding: 0000009
   VCID: 2615F1D544E6111B08F-8072
02961 - Lamp in Bumper; Rear Right
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 97
                    Mileage: 248545 km
                    Date: 2020.07.12
                    Time: 12:50:32
                    Bin. Bits:  000 100
Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
   Component: TSG HR          H21 0150
   Coding: 0035338
End----------(Elapsed Time: 01:43, VBatt start/end: 14.0V/13.9V)-----------
I guess my thought is that the fuel injectors are bad, but before I address that, I wanted to get some input from the community experts. I guess it could also be some sort of lose connection in the wiring, but I've never seen this error code in the past. Hmmmm....
As a note, if I let the engine cool down and then restart it returns to normal. I can drive normally til the cows come home with no issues if I don't put my foot into the accelerator too hard. But what the heck! Why drive if you have that limitation?? Sometimes when I Push the accelerator hard, the engine light blinks a few times and things return back to normal if I back off on the accelerator quickly. If I clear the codes and take it out and do it again, it's not always the same cylinders which are misfiring. There may be a hint there....
Also, when I removed the intake manifold for the above maintenance, I had to remove the lower fuel rail to take it off. During reassembly, I replaced the old O-Rings on the fuel injectors. I didn't remove any of the electrical connectors from the fuel injectors. I also replaced all gaskets with new ones on the intake manifold and the Head cover during the original maintenance.
Lots of miles on this car. I have never replaced the injectors since I bought the car @ ~30K miles.
There is also an error code for the ABS brakes in the autoscan (also intermittent). Not sure what that's about.
Many thanks in advance for any suggestions or comments.
Paul
TFSI
Maryland, USA
C?ID=66650
          61 62 65 6D 6F 72
   Coding: 0001175
                    Mileage: 249658 km
                    Date: 2020.09.28
                    Time: 19:46:37
                    RPM: 4107 /min
                    Load: 92.5 %
                    Speed: 80.0 km/h
                    Temperature: 88.0°C
                    Temperature: 24.0°C
                    Voltage: 13.589 V
                    Mileage: 249658 km
                    Date: 2020.09.28
                    Time: 19:46:37
                    RPM: 4107 /min
                    Load: 92.5 %
                    Speed: 80.0 km/h
                    Temperature: 88.0°C
                    Temperature: 24.0°C
                    Voltage: 13.589 V
                    Mileage: 249658 km
                    Date: 2020.09.28
                    Time: 19:46:37
                    RPM: 4230 /min
                    Load: 93.7 %
                    Speed: 81.0 km/h
                    Temperature: 88.0°C
                    Temperature: 24.0°C
                    Voltage: 13.716 V
000773 - Cylinder 5
                    Mileage: 249658 km
                    Date: 2020.09.28
                    Time: 19:46:37
                    RPM: 4230 /min
                    Load: 93.7 %
                    Speed: 81.0 km/h
                    Temperature: 88.0°C
                    Temperature: 24.0°C
                    Voltage: 13.716 V
                    Mileage: 249674 km
                    Date: 2020.09.28
                    Time: 20:06:55
                    RPM: 1475 /min
                    Load: 29.4 %
                    Speed: 64.0 km/h
                    Temperature: 88.0°C
                    Temperature: 26.0°C
                    Voltage: 13.716 V
000772 - Cylinder 4
                    Mileage: 249675 km
                    Date: 2020.09.28
                    Time: 20:08:41
                    RPM: 1774 /min
                    Load: 52.5 %
                    Speed: 76.0 km/h
                    Temperature: 92.0°C
                    Temperature: 23.0°C
                    Voltage: 13.589 V
   Coding: 0000002
   Revision: 00H30001
   Coding: 0099345
                    Reset counter: 180
                    Mileage: 249620 km
                    Date: 2020.09.26
                    Time: 15:28:02
                    Count: 8257
                    Count: 8193
                    Count: 48640
   Coding: 0000131
   Coding: 0444222
   Coding: 0524326
   Coding: 0010103
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Coding: 0444222
   Coding: 0000100
                    Time Indication: 15
   Coding: 0014131
   Coding: 0002022
   Coding: 1555283
   Revision: 00-00000
   Coding: 0035403
   Coding: 7370781
                    Reset counter: 143
   Revision: S0900000
   Coding: 060000
   Coding: 0012001
   Revision: 00-00000
   Coding: 0035403
   Coding: 0444222
                    Reset counter: 171
                    Mileage: 249179 km
                    Date: 2020.09.05
                    Time: 22:08:11
   Coding: 0035338
   Coding: 0062424
   Coding: 0000009
                    Reset counter: 97
                    Mileage: 248545 km
                    Date: 2020.07.12
                    Time: 12:50:32
                    Bin. Bits:  000 100
   Coding: 0035338
Paul
Hi Paul
It look likely that injector #5 efficiency is below threshold and unable to meet injection quantity required by engine during sudden acceleration. take reading on engine electronics and MVBs 15 and 16 plus injection quantity registered on VCDS at both idling and under sudden load/accelerator pedal floored and lets see how frequent the misfire occurs. Cause could be faulty injector or partial injector nozzle blockage due to carbon.
NostraJackAss
Is there fuel in oil sump when checking and how are pumps for volume and pressure or filters?
What is the status of harness connections or HPP regulation + injectors are most likely smoked at this point of 155K no?
pauljs33
C?ID=385174
Hi T,
Thanks for the suggestion. One question. Should I log MVB's 15 & 16 while driving and flooring it? Or just sitting in my garage. Doing the idle is straight forward. If I floor it in the garage with no load I need to keep an eye on RPM to make sure I don't exceed any limits. I'm thinking I should do the flooring test while driving. That's where I know I can produce the problem. Is that what you're thinking? I assume I can log 15 & 16 while driving and doing the test. I'm not an expert at VCDS, but I'll read and figure out how to do that. I can set the laptop in the back seat belted in while I go for a drive.
I took about 5 mins of data in the garage at idle after the engine warmed up. No misfires on any cylinder. I did notice a few days ago when I looked at this that there might be an occasional misfire at idle when the engine is cold (prior to reaching normal operating temp). Interesting though: If a misfire pops up during this cold engine state, it clears after a short while. It's going to take me a day or 2 to get the road data, but I'm on it.
Idle data is below for MVB 14, 15, & 16: I couldn't get the columns to line up properly. No misfire faults though after 5 mins.
Sunday    4    October    2020    20:51:35:04546-VCID:6393A8C17754A4332F1-8036    VCDS Version: Release 20.4.2 (x64)    Data version: 20200730 DS317.0
03H 906 032 CA        Q7 3.6-FSI-LEV2 G   1379
    Group A:    '014                Group B:    '015                Group C:    '016
        Engine Speed    Engine Load    Misfire    Misfire        Misfire Counter    Misfire Counter    Misfire Counter    Misfire        Misfire Counter    Misfire Counter    Misfire Counter    Misfire
    TIME    (G28)        (total)    Recognition    TIME    Cylinder 1    Cylinder 2    Cylinder 3    Recognition    TIME    Cylinder 4    Cylinder 5    Cylinder 6    Recognition
Marker    STAMP     /min     %            STAMP                    STAMP
    0.24    680    15.8    0    Enabled    0.37    0    0    0    Enabled    0.11    0    0    0    Enabled
    0.61    680    15.8    0    Enabled    0.74    0    0    0    Enabled    0.48    0    0    0    Enabled
    0.99    680    15.8    0    Enabled    1.12    0    0    0    Enabled    0.86    0    0    0    Enabled
    1.36    680    15.8    0    Enabled    1.49    0    0    0    Enabled    1.24    0    0    0    Enabled
    1.74    680    15.8    0    Enabled    1.86    0    0    0    Enabled    1.61    0    0    0    Enabled
    2.11    680    15.8    0    Enabled    2.24    0    0    0    Enabled    1.99    0    0    0    Enabled
    2.48    680    15.8    0    Enabled    2.61    0    0    0    Enabled    2.36    0    0    0    Enabled
    2.86    680    15.8    0    Enabled    2.99    0    0    0    Enabled    2.74    0    0    0    Enabled
    3.25    680    15.8    0    Enabled    3.38    0    0    0    Enabled    3.12    0    0    0    Enabled
    3.63    680    15.8    0    Enabled    3.75    0    0    0    Enabled    3.5    0    0    0    Enabled
    4    680    15.8    0    Enabled    4.13    0    0    0    Enabled    3.88    0    0    0    Enabled
    4.38    680    15.8    0    Enabled    4.5    0    0    0    Enabled    4.25    0    0    0    Enabled
    4.75    680    15.8    0    Enabled    4.88    0    0    0    Enabled    4.63    0    0    0    Enabled
    5.12    680    15.8    0    Enabled    5.25    0    0    0    Enabled    5    0    0    0    Enabled
    5.49    680    15.8    0    Enabled    5.62    0    0    0    Enabled    5.37    0    0    0    Enabled
    5.88    640    15.8    0    Enabled    6.01    0    0    0    Enabled    5.75    0    0    0    Enabled
    6.26    680    15.8    0    Enabled    6.39    0    0    0    Enabled    6.13    0    0    0    Enabled
    6.64    680    15.8    0    Enabled    6.77    0    0    0    Enabled    6.51    0    0    0    Enabled
    7.02    680    15.8    0    Enabled    7.14    0    0    0    Enabled    6.89    0    0    0    Enabled
    7.39    680    15.8    0    Enabled    7.52    0    0    0    Enabled    7.27    0    0    0    Enabled
    7.77    640    15.8    0    Enabled    7.89    0    0    0    Enabled    7.64    0    0    0    Enabled
    8.14    680    15.8    0    Enabled    8.26    0    0    0    Enabled    8.02    0    0    0    Enabled
    8.51    680    15.8    0    Enabled    8.64    0    0    0    Enabled    8.39    0    0    0    Enabled
    8.89    680    15.8    0    Enabled    9.02    0    0    0    Enabled    8.77    0    0    0    Enabled
    9.28    680    15.8    0    Enabled    9.41    0    0    0    Enabled    9.16    0    0    0    Enabled
    9.66    680    15.8    0    Enabled    9.78    0    0    0    Enabled    9.54    0    0    0    Enabled
    10.04    680    15.8    0    Enabled    10.16    0    0    0    Enabled    9.91    0    0    0    Enabled
    10.41    680    15.8    0    Enabled    10.53    0    0    0    Enabled    10.28    0    0    0    Enabled
    10.78    680    15.8    0    Enabled    10.91    0    0    0    Enabled    10.66    0    0    0    Enabled
    11.16    680    15.8    0    Enabled    11.28    0    0    0    Enabled    11.03    0    0    0    Enabled
    11.53    680    15.8    0    Enabled    11.66    0    0    0    Enabled    11.41    0    0    0    Enabled
    11.91    680    15.8    0    Enabled    12.03    0    0    0    Enabled    11.78    0    0    0    Enabled
    12.29    680    15.8    0    Enabled    12.42    0    0    0    Enabled    12.17    0    0    0    Enabled
    12.67    680    15.8    0    Enabled    12.8    0    0    0    Enabled    12.55    0    0    0    Enabled
    13.05    680    15.8    0    Enabled    13.17    0    0    0    Enabled    12.92    0    0    0    Enabled
    13.42    680    15.8    0    Enabled    13.55    0    0    0    Enabled    13.29    0    0    0    Enabled
    13.8    680    15.8    0    Enabled    13.92    0    0    0    Enabled    13.68    0    0    0    Enabled
    14.18    680    15.8    0    Enabled    14.29    0    0    0    Enabled    14.05    0    0    0    Enabled
    14.55    680    15.8    0    Enabled    14.67    0    0    0    Enabled    14.43    0    0    0    Enabled
    14.92    680    15.8    0    Enabled    15.05    0    0    0    Enabled    14.8    0    0    0    Enabled
    15.31    680    15.8    0    Enabled    15.44    0    0    0    Enabled    15.19    0    0    0    Enabled
    15.69    680    15.8    0    Enabled    15.81    0    0    0    Enabled    15.57    0    0    0    Enabled
    16.06    680    15.8    0    Enabled    16.19    0    0    0    Enabled    15.94    0    0    0    Enabled
    16.44    680    15.8    0    Enabled    16.56    0    0    0    Enabled    16.31    0    0    0    Enabled
    16.82    680    15.8    0    Enabled    16.94    0    0    0    Enabled    16.69    0    0    0    Enabled
    17.19    680    15.8    0    Enabled    17.31    0    0    0    Enabled    17.06    0    0    0    Enabled
    17.56    680    15.8    0    Enabled    17.69    0    0    0    Enabled    17.44    0    0    0    Enabled
    17.94    680    15.8    0    Enabled    18.07    0    0    0    Enabled    17.82    0    0    0    Enabled
    18.31    680    15.8    0    Enabled    18.44    0    0    0    Enabled    18.19    0    0    0    Enabled
    18.69    680    15.8    0    Enabled    18.81    0    0    0    Enabled    18.56    0    0    0    Enabled
    19.06    680    15    0    Enabled    19.2    0    0    0    Enabled    18.94    0    0    0    Enabled
    19.45    680    15.8    0    Enabled    19.58    0    0    0    Enabled    19.33    0    0    0    Enabled
    19.83    680    15.8    0    Enabled    19.95    0    0    0    Enabled    19.7    0    0    0    Enabled
    20.2    680    15.8    0    Enabled    20.33    0    0    0    Enabled    20.08    0    0    0    Enabled
    20.58    680    15.8    0    Enabled    20.7    0    0    0    Enabled    20.46    0    0    0    Enabled
    20.95    680    15    0    Enabled    21.08    0    0    0    Enabled    20.83    0    0    0    Enabled
    21.33    680    15    0    Enabled    21.45    0    0    0    Enabled    21.21    0    0    0    Enabled
    21.7    680    15    0    Enabled    21.83    0    0    0    Enabled    21.58    0    0    0    Enabled
    22.07    680    15    0    Enabled    22.22    0    0    0    Enabled    21.95    0    0    0    Enabled
    22.47    680    15.8    0    Enabled    22.6    0    0    0    Enabled    22.34    0    0    0    Enabled
    22.85    680    15    0    Enabled    22.97    0    0    0    Enabled    22.72    0    0    0    Enabled
    23.22    680    15.8    0    Enabled    23.34    0    0    0    Enabled    23.1    0    0    0    Enabled
    23.59    680    15    0    Enabled    23.72    0    0    0    Enabled    23.47    0    0    0    Enabled
    23.97    680    15.8    0    Enabled    24.1    0    0    0    Enabled    23.84    0    0    0    Enabled
    24.34    680    15.8    0    Enabled    24.47    0    0    0    Enabled    24.22    0    0    0    Enabled
    24.72    680    15.8    0    Enabled    24.84    0    0    0    Enabled    24.6    0    0    0    Enabled
    25.1    680    15.8    0    Enabled    25.23    0    0    0    Enabled    24.97    0    0    0    Enabled
    25.48    680    15.8    0    Enabled    25.61    0    0    0    Enabled    25.36    0    0    0    Enabled
    25.86    680    15.8    0    Enabled    25.99    0    0    0    Enabled    25.74    0    0    0    Enabled
    26.24    680    15.8    0    Enabled    26.36    0    0    0    Enabled    26.11    0    0    0    Enabled
    26.61    680    15.8    0    Enabled    26.74    0    0    0    Enabled    26.49    0    0    0    Enabled
    26.99    680    15    0    Enabled    27.11    0    0    0    Enabled    26.86    0    0    0    Enabled
    27.36    680    15    0    Enabled    27.49    0    0    0    Enabled    27.24    0    0    0    Enabled
    27.74    680    15.8    0    Enabled    27.86    0    0    0    Enabled    27.61    0    0    0    Enabled
    28.11    680    15    0    Enabled    28.24    0    0    0    Enabled    27.98    0    0    0    Enabled
    28.49    680    15.8    0    Enabled    28.61    0    0    0    Enabled    28.36    0    0    0    Enabled
    28.86    680    15.8    0    Enabled    28.99    0    0    0    Enabled    28.73    0    0    0    Enabled
    29.25    680    15.8    0    Enabled    29.37    0    0    0    Enabled    29.11    0    0    0    Enabled
    29.63    680    15.8    0    Enabled    29.75    0    0    0    Enabled    29.5    0    0    0    Enabled
    30    640    15.8    0    Enabled    30.12    0    0    0    Enabled    29.87    0    0    0    Enabled
    30.38    680    15    0    Enabled    30.5    0    0    0    Enabled    30.25    0    0    0    Enabled
    30.75    680    15.8    0    Enabled    30.88    0    0    0    Enabled    30.62    0    0    0    Enabled
    31.13    680    15    0    Enabled    31.25    0    0    0    Enabled    31    0    0    0    Enabled
    31.5    680    15.8    0    Enabled    31.63    0    0    0    Enabled    31.38    0    0    0    Enabled
    31.88    680    15    0    Enabled    32    0    0    0    Enabled    31.75    0    0    0    Enabled
    32.27    680    15.8    0    Enabled    32.39    0    0    0    Enabled    32.13    0    0    0    Enabled
    32.64    680    15    0    Enabled    32.76    0    0    0    Enabled    32.52    0    0    0    Enabled
    33.01    680    15    0    Enabled    33.14    0    0    0    Enabled    32.89    0    0    0    Enabled
    33.4    680    15.8    0    Enabled    33.52    0    0    0    Enabled    33.27    0    0    0    Enabled
    33.77    680    15.8    0    Enabled    33.89    0    0    0    Enabled    33.64    0    0    0    Enabled
    34.14    680    15.8    0    Enabled    34.27    0    0    0    Enabled    34.02    0    0    0    Enabled
    34.52    680    15    0    Enabled    34.64    0    0    0    Enabled    34.39    0    0    0    Enabled
    34.89    680    15.8    0    Enabled    35.02    0    0    0    Enabled    34.77    0    0    0    Enabled
    35.28    680    15    0    Enabled    35.4    0    0    0    Enabled    35.14    0    0    0    Enabled
    35.66    680    15.8    0    Enabled    35.78    0    0    0    Enabled    35.53    0    0    0    Enabled
    36.03    640    15.8    0    Enabled    36.16    0    0    0    Enabled    35.91    0    0    0    Enabled
    36.41    680    15.8    0    Enabled    36.53    0    0    0    Enabled    36.28    0    0    0    Enabled
    36.78    680    15.8    0    Enabled    36.91    0    0    0    Enabled    36.66    0    0    0    Enabled
    37.15    680    15.8    0    Enabled    37.28    0    0    0    Enabled    37.03    0    0    0    Enabled
    37.53    680    15    0    Enabled    37.66    0    0    0    Enabled    37.41    0    0    0    Enabled
    37.9    680    15.8    0    Enabled    38.03    0    0    0    Enabled    37.78    0    0    0    Enabled
    38.29    680    15.8    0    Enabled    38.43    0    0    0    Enabled    38.16    0    0    0    Enabled
    38.68    680    15.8    0    Enabled    38.8    0    0    0    Enabled    38.54    0    0    0    Enabled
    39.05    680    15    0    Enabled    39.17    0    0    0    Enabled    38.93    0    0    0    Enabled
    39.42    680    15.8    0    Enabled    39.55    0    0    0    Enabled    39.29    0    0    0    Enabled
    39.8    680    15.8    0    Enabled    39.92    0    0    0    Enabled    39.67    0    0    0    Enabled
    40.17    680    15.8    0    Enabled    40.29    0    0    0    Enabled    40.05    0    0    0    Enabled
    40.55    680    15.8    0    Enabled    40.67    0    0    0    Enabled    40.42    0    0    0    Enabled
    40.92    680    15.8    0    Enabled    41.05    0    0    0    Enabled    40.8    0    0    0    Enabled
    41.3    680    15    0    Enabled    41.43    0    0    0    Enabled    41.17    0    0    0    Enabled
    41.67    680    15.8    0    Enabled    41.8    0    0    0    Enabled    41.55    0    0    0    Enabled
    42.05    640    15.8    0    Enabled    42.17    0    0    0    Enabled    41.92    0    0    0    Enabled
    42.44    680    15.8    0    Enabled    42.56    0    0    0    Enabled    42.31    0    0    0    Enabled
    42.81    680    15.8    0    Enabled    42.94    0    0    0    Enabled    42.69    0    0    0    Enabled
    43.19    640    15.8    0    Enabled    43.32    0    0    0    Enabled    43.06    0    0    0    Enabled
    43.56    680    15.8    0    Enabled    43.69    0    0    0    Enabled    43.44    0    0    0    Enabled
    43.94    680    15.8    0    Enabled    44.06    0    0    0    Enabled    43.82    0    0    0    Enabled
    44.33    680    15.8    0    Enabled    44.45    0    0    0    Enabled    44.19    0    0    0    Enabled
    44.7    680    15.8    0    Enabled    44.83    0    0    0    Enabled    44.58    0    0    0    Enabled
    45.08    680    15.8    0    Enabled    45.2    0    0    0    Enabled    44.95    0    0    0    Enabled
    45.45    680    15.8    0    Enabled    45.58    0    0    0    Enabled    45.33    0    0    0    Enabled
    45.83    680    15.8    0    Enabled    45.96    0    0    0    Enabled    45.7    0    0    0    Enabled
    46.2    680    15.8    0    Enabled    46.33    0    0    0    Enabled    46.08    0    0    0    Enabled
    46.58    680    15.8    0    Enabled    46.71    0    0    0    Enabled    46.45    0    0    0    Enabled
    46.96    680    15.8    0    Enabled    47.08    0    0    0    Enabled    46.83    0    0    0    Enabled
    47.35    680    15.8    0    Enabled    47.47    0    0    0    Enabled    47.21    0    0    0    Enabled
    47.72    680    15.8    0    Enabled    47.85    0    0    0    Enabled    47.59    0    0    0    Enabled
    48.1    680    15.8    0    Enabled    48.22    0    0    0    Enabled    47.97    0    0    0    Enabled
    48.47    680    15.8    0    Enabled    48.59    0    0    0    Enabled    48.34    0    0    0    Enabled
    48.85    680    15.8    0    Enabled    48.97    0    0    0    Enabled    48.72    0    0    0    Enabled
    49.22    680    15.8    0    Enabled    49.34    0    0    0    Enabled    49.09    0    0    0    Enabled
    49.59    680    15.8    0    Enabled    49.72    0    0    0    Enabled    49.47    0    0    0    Enabled
    49.97    680    15.8    0    Enabled    50.09    0    0    0    Enabled    49.85    0    0    0    Enabled
    50.36    680    15.8    0    Enabled    50.49    0    0    0    Enabled    50.22    0    0    0    Enabled
    50.73    680    15.8    0    Enabled    50.86    0    0    0    Enabled    50.61    0    0    0    Enabled
    51.1    680    15.8    0    Enabled    51.23    0    0    0    Enabled    50.98    0    0    0    Enabled
    51.48    680    15.8    0    Enabled    51.61    0    0    0    Enabled    51.35    0    0    0    Enabled
    51.85    680    15.8    0    Enabled    51.98    0    0    0    Enabled    51.73    0    0    0    Enabled
    52.23    680    15.8    0    Enabled    52.36    0    0    0    Enabled    52.1    0    0    0    Enabled
    52.61    680    15.8    0    Enabled    52.73    0    0    0    Enabled    52.48    0    0    0    Enabled
    52.99    680    15.8    0    Enabled    53.11    0    0    0    Enabled    52.85    0    0    0    Enabled
    53.37    680    15.8    0    Enabled    53.5    0    0    0    Enabled    53.24    0    0    0    Enabled
    53.75    680    15.8    0    Enabled    53.88    0    0    0    Enabled    53.63    0    0    0    Enabled
    54.13    680    15.8    0    Enabled    54.26    0    0    0    Enabled    54    0    0    0    Enabled
    54.5    680    15.8    0    Enabled    54.62    0    0    0    Enabled    54.37    0    0    0    Enabled
    54.88    680    15.8    0    Enabled    55    0    0    0    Enabled    54.75    0    0    0    Enabled
    55.25    680    15.8    0    Enabled    55.37    0    0    0    Enabled    55.13    0    0    0    Enabled
    55.62    680    15.8    0    Enabled    55.74    0    0    0    Enabled    55.5    0    0    0    Enabled
    55.99    680    15.8    0    Enabled    56.12    0    0    0    Enabled    55.87    0    0    0    Enabled
    56.37    680    15.8    0    Enabled    56.5    0    0    0    Enabled    56.25    0    0    0    Enabled
    56.75    680    15.8    0    Enabled    56.88    0    0    0    Enabled    56.63    0    0    0    Enabled
    57.12    680    15.8    0    Enabled    57.25    0    0    0    Enabled    57    0    0    0    Enabled
    57.52    680    15.8    0    Enabled    57.64    0    0    0    Enabled    57.39    0    0    0    Enabled
    57.89    680    15.8    0    Enabled    58.02    0    0    0    Enabled    57.77    0    0    0    Enabled
    58.27    680    15.8    0    Enabled    58.39    0    0    0    Enabled    58.14    0    0    0    Enabled
    58.64    680    15.8    0    Enabled    58.77    0    0    0    Enabled    58.52    0    0    0    Enabled
    59.02    680    15.8    0    Enabled    59.14    0    0    0    Enabled    58.89    0    0    0    Enabled
    59.39    680    15.8    0    Enabled    59.52    0    0    0    Enabled    59.27    0    0    0    Enabled
    59.77    680    15.8    0    Enabled    59.89    0    0    0    Enabled    59.64    0    0    0    Enabled
    60.14    680    15.8    0    Enabled    60.27    0    0    0    Enabled    60.02    0    0    0    Enabled
    60.53    680    15.8    0    Enabled    60.66    0    0    0    Enabled    60.41    0    0    0    Enabled
    60.91    680    15.8    0    Enabled    61.03    0    0    0    Enabled    60.78    0    0    0    Enabled
    61.28    680    15.8    0    Enabled    61.4    0    0    0    Enabled    61.16    0    0    0    Enabled
    61.66    680    15.8    0    Enabled    61.78    0    0    0    Enabled    61.53    0    0    0    Enabled
    62.03    680    15.8    0    Enabled    62.16    0    0    0    Enabled    61.91    0    0    0    Enabled
    62.41    680    15.8    0    Enabled    62.53    0    0    0    Enabled    62.28    0    0    0    Enabled
    62.79    680    15.8    0    Enabled    62.91    0    0    0    Enabled    62.65    0    0    0    Enabled
    63.16    680    15.8    0    Enabled    63.28    0    0    0    Enabled    63.03    0    0    0    Enabled
    63.54    680    15.8    0    Enabled    63.67    0    0    0    Enabled    63.42    0    0    0    Enabled
    63.92    680    15.8    0    Enabled    64.05    0    0    0    Enabled    63.79    0    0    0    Enabled
    64.29    680    15.8    0    Enabled    64.42    0    0    0    Enabled    64.17    0    0    0    Enabled
    64.67    680    15.8    0    Enabled    64.8    0    0    0    Enabled    64.55    0    0    0    Enabled
    65.05    680    15.8    0    Enabled    65.17    0    0    0    Enabled    64.92    0    0    0    Enabled
    65.42    680    15.8    0    Enabled    65.55    0    0    0    Enabled    65.3    0    0    0    Enabled
    65.8    680    15.8    0    Enabled    65.92    0    0    0    Enabled    65.67    0    0    0    Enabled
    66.17    680    15.8    0    Enabled    66.29    0    0    0    Enabled    66.05    0    0    0    Enabled
    66.56    680    15.8    0    Enabled    66.68    0    0    0    Enabled    66.44    0    0    0    Enabled
    66.94    680    15.8    0    Enabled    67.07    0    0    0    Enabled    66.81    0    0    0    Enabled
    67.31    680    15.8    0    Enabled    67.44    0    0    0    Enabled    67.19    0    0    0    Enabled
    67.69    680    15.8    0    Enabled    67.82    0    0    0    Enabled    67.57    0    0    0    Enabled
    68.07    680    15.8    0    Enabled    68.19    0    0    0    Enabled    67.94    0    0    0    Enabled
    68.44    680    15.8    0    Enabled    68.56    0    0    0    Enabled    68.31    0    0    0    Enabled
    68.82    680    15.8    0    Enabled    68.94    0    0    0    Enabled    68.69    0    0    0    Enabled
    69.19    680    15.8    0    Enabled    69.31    0    0    0    Enabled    69.06    0    0    0    Enabled
    69.58    680    15.8    0    Enabled    69.71    0    0    0    Enabled    69.45    0    0    0    Enabled
    69.96    680    15.8    0    Enabled    70.08    0    0    0    Enabled    69.83    0    0    0    Enabled
    70.33    680    15.8    0    Enabled    70.45    0    0    0    Enabled    70.2    0    0    0    Enabled
    70.7    680    15.8    0    Enabled    70.83    0    0    0    Enabled    70.58    0    0    0    Enabled
    71.08    680    15.8    0    Enabled    71.21    0    0    0    Enabled    70.95    0    0    0    Enabled
    71.46    680    15.8    0    Enabled    71.58    0    0    0    Enabled    71.33    0    0    0    Enabled
    71.83    680    15.8    0    Enabled    71.96    0    0    0    Enabled    71.7    0    0    0    Enabled
    72.2    680    15.8    0    Enabled    72.33    0    0    0    Enabled    72.08    0    0    0    Enabled
    72.6    680    15.8    0    Enabled    72.72    0    0    0    Enabled    72.47    0    0    0    Enabled
    72.97    680    15.8    0    Enabled    73.09    0    0    0    Enabled    72.85    0    0    0    Enabled
    73.34    680    15.8    0    Enabled    73.47    0    0    0    Enabled    73.22    0    0    0    Enabled
    73.72    680    15.8    0    Enabled    73.84    0    0    0    Enabled    73.59    0    0    0    Enabled
    74.09    680    15.8    0    Enabled    74.22    0    0    0    Enabled    73.97    0    0    0    Enabled
    74.47    680    15.8    0    Enabled    74.59    0    0    0    Enabled    74.34    0    0    0    Enabled
    74.85    680    15.8    0    Enabled    74.97    0    0    0    Enabled    74.73    0    0    0    Enabled
    75.22    680    15.8    0    Enabled    75.35    0    0    0    Enabled    75.09    0    0    0    Enabled
    75.61    680    15.8    0    Enabled    75.74    0    0    0    Enabled    75.49    0    0    0    Enabled
    75.99    680    15.8    0    Enabled    76.11    0    0    0    Enabled    75.86    0    0    0    Enabled
    76.36    680    15.8    0    Enabled    76.49    0    0    0    Enabled    76.24    0    0    0    Enabled
    76.73    680    15.8    0    Enabled    76.85    0    0    0    Enabled    76.61    0    0    0    Enabled
    77.11    680    15.8    0    Enabled    77.23    0    0    0    Enabled    76.98    0    0    0    Enabled
    77.48    680    15.8    0    Enabled    77.61    0    0    0    Enabled    77.36    0    0    0    Enabled
    77.86    680    15.8    0    Enabled    77.99    0    0    0    Enabled    77.74    0    0    0    Enabled
    78.23    680    15.8    0    Enabled    78.36    0    0    0    Enabled    78.11    0    0    0    Enabled
    78.63    680    15.8    0    Enabled    78.75    0    0    0    Enabled    78.5    0    0    0    Enabled
    79    680    15.8    0    Enabled    79.12    0    0    0    Enabled    78.87    0    0    0    Enabled
    79.37    680    15.8    0    Enabled    79.5    0    0    0    Enabled    79.25    0    0    0    Enabled
    79.75    680    15.8    0    Enabled    79.88    0    0    0    Enabled    79.63    0    0    0    Enabled
    80.13    680    15.8    0    Enabled    80.25    0    0    0    Enabled    80    0    0    0    Enabled
    80.5    680    15.8    0    Enabled    80.63    0    0    0    Enabled    80.38    0    0    0    Enabled
    80.88    680    15.8    0    Enabled    81    0    0    0    Enabled    80.75    0    0    0    Enabled
    81.25    680    15.8    0    Enabled    81.38    0    0    0    Enabled    81.13    0    0    0    Enabled
    81.63    680    15.8    0    Enabled    81.75    0    0    0    Enabled    81.5    0    0    0    Enabled
    82    680    15.8    0    Enabled    82.12    0    0    0    Enabled    81.87    0    0    0    Enabled
    82.38    680    15.8    0    Enabled    82.52    0    0    0    Enabled    82.25    0    0    0    Enabled
    82.77    680    15.8    0    Enabled    82.89    0    0    0    Enabled    82.64    0    0    0    Enabled
    83.14    680    15.8    0    Enabled    83.27    0    0    0    Enabled    83.02    0    0    0    Enabled
    83.51    680    15.8    0    Enabled    83.65    0    0    0    Enabled    83.4    0    0    0    Enabled
    83.89    680    15    0    Enabled    84.02    0    0    0    Enabled    83.77    0    0    0    Enabled
    84.27    680    15.8    0    Enabled    84.39    0    0    0    Enabled    84.14    0    0    0    Enabled
    84.64    680    15    0    Enabled    84.76    0    0    0    Enabled    84.51    0    0    0    Enabled
    85.02    680    15    0    Enabled    85.14    0    0    0    Enabled    84.89    0    0    0    Enabled
    85.39    680    15    0    Enabled    85.53    0    0    0    Enabled    85.27    0    0    0    Enabled
    85.78    680    15    0    Enabled    85.9    0    0    0    Enabled    85.66    0    0    0    Enabled
    86.16    680    15.8    0    Enabled    86.28    0    0    0    Enabled    86.03    0    0    0    Enabled
    86.53    680    15    0    Enabled    86.66    0    0    0    Enabled    86.41    0    0    0    Enabled
    86.91    680    15    0    Enabled    87.03    0    0    0    Enabled    86.78    0    0    0    Enabled
    87.28    680    15    0    Enabled    87.4    0    0    0    Enabled    87.15    0    0    0    Enabled
    87.65    680    15    0    Enabled    87.78    0    0    0    Enabled    87.53    0    0    0    Enabled
    88.03    680    15    0    Enabled    88.16    0    0    0    Enabled    87.91    0    0    0    Enabled
    88.41    680    15    0    Enabled    88.55    0    0    0    Enabled    88.28    0    0    0    Enabled
    88.8    680    15    0    Enabled    88.92    0    0    0    Enabled    88.67    0    0    0    Enabled
    89.17    680    15    0    Enabled    89.3    0    0    0    Enabled    89.05    0    0    0    Enabled
    89.55    680    15    0    Enabled    89.67    0    0    0    Enabled    89.42    0    0    0    Enabled
    89.92    680    15    0    Enabled    90.05    0    0    0    Enabled    89.8    0    0    0    Enabled
    90.3    680    15    0    Enabled    90.42    0    0    0    Enabled    90.17    0    0    0    Enabled
    90.67    680    15    0    Enabled    90.8    0    0    0    Enabled    90.55    0    0    0    Enabled
    91.05    680    15    0    Enabled    91.17    0    0    0    Enabled    90.92    0    0    0    Enabled
    91.42    680    15    0    Enabled    91.55    0    0    0    Enabled    91.29    0    0    0    Enabled
    91.8    680    15    0    Enabled    91.93    0    0    0    Enabled    91.67    0    0    0    Enabled
    92.17    680    15    0    Enabled    92.29    0    0    0    Enabled    92.05    0    0    0    Enabled
    92.56    680    15    0    Enabled    92.69    0    0    0    Enabled    92.43    0    0    0    Enabled
    92.94    680    15    0    Enabled    93.06    0    0    0    Enabled    92.81    0    0    0    Enabled
    93.31    640    15    0    Enabled    93.44    0    0    0    Enabled    93.19    0    0    0    Enabled
    93.69    680    15    0    Enabled    93.81    0    0    0    Enabled    93.56    0    0    0    Enabled
    94.06    680    15    0    Enabled    94.19    0    0    0    Enabled    93.94    0    0    0    Enabled
    94.44    680    15    0    Enabled    94.56    0    0    0    Enabled    94.31    0    0    0    Enabled
    94.81    680    15    0    Enabled    94.94    0    0    0    Enabled    94.69    0    0    0    Enabled
    95.19    680    15    0    Enabled    95.31    0    0    0    Enabled    95.06    0    0    0    Enabled
    95.57    680    15    0    Enabled    95.7    0    0    0    Enabled    95.44    0    0    0    Enabled
    95.95    680    15    0    Enabled    96.07    0    0    0    Enabled    95.82    0    0    0    Enabled
    96.33    680    15    0    Enabled    96.45    0    0    0    Enabled    96.2    0    0    0    Enabled
    96.7    680    15    0    Enabled    96.82    0    0    0    Enabled    96.57    0    0    0    Enabled
    97.08    680    15    0    Enabled    97.21    0    0    0    Enabled    96.95    0    0    0    Enabled
    97.45    680    15    0    Enabled    97.58    0    0    0    Enabled    97.33    0    0    0    Enabled
    97.83    680    15    0    Enabled    97.95    0    0    0    Enabled    97.7    0    0    0    Enabled
    98.2    680    15    0    Enabled    98.33    0    0    0    Enabled    98.08    0    0    0    Enabled
    98.6    680    15    0    Enabled    98.72    0    0    0    Enabled    98.45    0    0    0    Enabled
    98.97    680    15    0    Enabled    99.09    0    0    0    Enabled    98.84    0    0    0    Enabled
    99.34    680    15    0    Enabled    99.47    0    0    0    Enabled    99.23    0    0    0    Enabled
    99.72    680    15.8    0    Enabled    99.84    0    0    0    Enabled    99.59    0    0    0    Enabled
    100.09    680    15.8    0    Enabled    100.22    0    0    0    Enabled    99.97    0    0    0    Enabled
    100.47    680    15    0    Enabled    100.61    0    0    0    Enabled    100.35    0    0    0    Enabled
    100.86    680    15    0    Enabled    100.99    0    0    0    Enabled    100.74    0    0    0    Enabled
    101.24    680    15    0    Enabled    101.36    0    0    0    Enabled    101.11    0    0    0    Enabled
    101.61    680    15    0    Enabled    101.74    0    0    0    Enabled    101.48    0    0    0    Enabled
    101.99    680    15    0    Enabled    102.11    0    0    0    Enabled    101.86    0    0    0    Enabled
    102.36    680    15    0    Enabled    102.48    0    0    0    Enabled    102.23    0    0    0    Enabled
    102.73    680    15.8    0    Enabled    102.86    0    0    0    Enabled    102.61    0    0    0    Enabled
    103.11    680    15    0    Enabled    103.23    0    0    0    Enabled    102.98    0    0    0    Enabled
    103.48    680    15    0    Enabled    103.62    0    0    0    Enabled    103.37    0    0    0    Enabled
    103.88    680    15    0    Enabled    104    0    0    0    Enabled    103.75    0    0    0    Enabled
    104.25    680    15    0    Enabled    104.38    0    0    0    Enabled    104.13    0    0    0    Enabled
    104.62    680    15    0    Enabled    104.75    0    0    0    Enabled    104.5    0    0    0    Enabled
    105    680    15    0    Enabled    105.13    0    0    0    Enabled    104.88    0    0    0    Enabled
    105.38    680    15    0    Enabled    105.5    0    0    0    Enabled    105.25    0    0    0    Enabled
    105.75    680    15    0    Enabled    105.87    0    0    0    Enabled    105.62    0    0    0    Enabled
    106.12    680    15    0    Enabled    106.25    0    0    0    Enabled    106    0    0    0    Enabled
    106.5    680    15.8    0    Enabled    106.64    0    0    0    Enabled    106.37    0    0    0    Enabled
    106.89    680    15    0    Enabled    107.02    0    0    0    Enabled    106.76    0    0    0    Enabled
    107.27    680    15    0    Enabled    107.39    0    0    0    Enabled    107.14    0    0    0    Enabled
    107.64    680    15    0    Enabled    107.77    0    0    0    Enabled    107.51    0    0    0    Enabled
    108.02    680    15.8    0    Enabled    108.14    0    0    0    Enabled    107.89    0    0    0    Enabled
    108.4    680    15    0    Enabled    108.52    0    0    0    Enabled    108.27    0    0    0    Enabled
    108.77    680    15    0    Enabled    108.89    0    0    0    Enabled    108.64    0    0    0    Enabled
    109.14    680    15    0    Enabled    109.27    0    0    0    Enabled    109.02    0    0    0    Enabled
    109.52    680    15    0    Enabled    109.66    0    0    0    Enabled    109.39    0    0    0    Enabled
    109.91    680    15.8    0    Enabled    110.03    0    0    0    Enabled    109.78    0    0    0    Enabled
    110.28    680    15    0    Enabled    110.41    0    0    0    Enabled    110.16    0    0    0    Enabled
    110.66    680    15.8    0    Enabled    110.78    0    0    0    Enabled    110.53    0    0    0    Enabled
    111.03    680    15    0    Enabled    111.16    0    0    0    Enabled    110.91    0    0    0    Enabled
    111.41    680    15    0    Enabled    111.53    0    0    0    Enabled    111.28    0    0    0    Enabled
    111.79    680    15    0    Enabled    111.91    0    0    0    Enabled    111.66    0    0    0    Enabled
    112.16    680    15    0    Enabled    112.28    0    0    0    Enabled    112.03    0    0    0    Enabled
    112.53    680    15    0    Enabled    112.67    0    0    0    Enabled    112.41    0    0    0    Enabled
    112.93    680    15    0    Enabled    113.05    0    0    0    Enabled    112.8    0    0    0    Enabled
    113.29    680    15    0    Enabled    113.42    0    0    0    Enabled    113.17    0    0    0    Enabled
    113.67    680    15    0    Enabled    113.8    0    0    0    Enabled    113.55    0    0    0    Enabled
    114.05    680    15    0    Enabled    114.17    0    0    0    Enabled    113.92    0    0    0    Enabled
    114.42    680    15.8    0    Enabled    114.55    0    0    0    Enabled    114.3    0    0    0    Enabled
    114.8    680    15    0    Enabled    114.92    0    0    0    Enabled    114.67    0    0    0    Enabled
    115.17    680    15    0    Enabled    115.29    0    0    0    Enabled    115.05    0    0    0    Enabled
    115.55    680    15    0    Enabled    115.69    0    0    0    Enabled    115.42    0    0    0    Enabled
    115.94    680    15    0    Enabled    116.06    0    0    0    Enabled    115.81    0    0    0    Enabled
    116.31    680    15.8    0    Enabled    116.44    0    0    0    Enabled    116.19    0    0    0    Enabled
    116.69    680    15.8    0    Enabled    116.82    0    0    0    Enabled    116.57    0    0    0    Enabled
    117.06    680    15    0    Enabled    117.19    0    0    0    Enabled    116.94    0    0    0    Enabled
    117.44    680    15    0    Enabled    117.56    0    0    0    Enabled    117.31    0    0    0    Enabled
    117.81    680    15.8    0    Enabled    117.94    0    0    0    Enabled    117.69    0    0    0    Enabled
    118.19    680    15.8    0    Enabled    118.31    0    0    0    Enabled    118.06    0    0    0    Enabled
    118.56    680    15.8    0    Enabled    118.7    0    0    0    Enabled    118.44    0    0    0    Enabled
    118.95    680    15.8    0    Enabled    119.08    0    0    0    Enabled    118.83    0    0    0    Enabled
    119.33    680    15.8    0    Enabled    119.45    0    0    0    Enabled    119.2    0    0    0    Enabled
    119.7    680    15.8    0    Enabled    119.83    0    0    0    Enabled    119.58    0    0    0    Enabled
    120.08    680    15.8    0    Enabled    120.2    0    0    0    Enabled    119.95    0    0    0    Enabled
    120.46    680    15.8    0    Enabled    120.58    0    0    0    Enabled    120.33    0    0    0    Enabled
    120.83    680    15.8    0    Enabled    120.95    0    0    0    Enabled    120.71    0    0    0    Enabled
    121.21    680    15.8    0    Enabled    121.33    0    0    0    Enabled    121.08    0    0    0    Enabled
    121.58    680    15.8    0    Enabled    121.72    0    0    0    Enabled    121.46    0    0    0    Enabled
    121.96    640    15.8    0    Enabled    122.09    0    0    0    Enabled    121.84    0    0    0    Enabled
    122.35    680    15.8    0    Enabled    122.47    0    0    0    Enabled    122.22    0    0    0    Enabled
    122.72    720    15.8    0    Enabled    122.84    0    0    0    Enabled    122.59    0    0    0    Enabled
    123.09    680    15.8    0    Enabled    123.22    0    0    0    Enabled    122.97    0    0    0    Enabled
    123.47    680    15.8    0    Enabled    123.6    0    0    0    Enabled    123.34    0    0    0    Enabled
    123.84    680    15.8    0    Enabled    123.98    0    0    0    Enabled    123.72    0    0    0    Enabled
    124.22    680    15.8    0    Enabled    124.34    0    0    0    Enabled    124.1    0    0    0    Enabled
    124.59    680    16.5    0    Enabled    124.72    0    0    0    Enabled    124.47    0    0    0    Enabled
    124.97    680    16.5    0    Enabled    125.1    0    0    0    Enabled    124.85    0    0    0    Enabled
    125.34    680    15.8    0    Enabled    125.47    0    0    0    Enabled    125.22    0    0    0    Enabled
    125.73    680    16.5    0    Enabled    125.86    0    0    0    Enabled    125.6    0    0    0    Enabled
    126.11    680    16.5    0    Enabled    126.24    0    0    0    Enabled    125.99    0    0    0    Enabled
    126.48    680    16.5    0    Enabled    126.61    0    0    0    Enabled    126.36    0    0    0    Enabled
    126.86    680    16.5    0    Enabled    126.98    0    0    0    Enabled    126.73    0    0    0    Enabled
    127.23    680    16.5    0    Enabled    127.36    0    0    0    Enabled    127.11    0    0    0    Enabled
    127.61    680    16.5    0    Enabled    127.73    0    0    0    Enabled    127.48    0    0    0    Enabled
    127.99    680    16.5    0    Enabled    128.11    0    0    0    Enabled    127.86    0    0    0    Enabled
    128.36    680    16.5    0    Enabled    128.49    0    0    0    Enabled    128.23    0    0    0    Enabled
    128.75    680    16.5    0    Enabled    128.88    0    0    0    Enabled    128.61    0    0    0    Enabled
    129.13    680    16.5    0    Enabled    129.25    0    0    0    Enabled    129    0    0    0    Enabled
    129.5    680    16.5    0    Enabled    129.63    0    0    0    Enabled    129.38    0    0    0    Enabled
    129.88    680    16.5    0    Enabled    130    0    0    0    Enabled    129.75    0    0    0    Enabled
    130.25    680    16.5    0    Enabled    130.37    0    0    0    Enabled    130.13    0    0    0    Enabled
    130.62    680    16.5    0    Enabled    130.75    0    0    0    Enabled    130.5    0    0    0    Enabled
    131    680    16.5    0    Enabled    131.12    0    0    0    Enabled    130.88    0    0    0    Enabled
    131.38    680    16.5    0    Enabled    131.5    0    0    0    Enabled    131.25    0    0    0    Enabled
    131.76    680    16.5    0    Enabled    131.89    0    0    0    Enabled    131.63    0    0    0    Enabled
    132.13    680    16.5    0    Enabled    132.26    0    0    0    Enabled    132.02    0    0    0    Enabled
    132.51    680    16.5    0    Enabled    132.64    0    0    0    Enabled    132.4    0    0    0    Enabled
    132.89    680    15.8    0    Enabled    133.02    0    0    0    Enabled    132.77    0    0    0    Enabled
    133.27    680    15.8    0    Enabled    133.4    0    0    0    Enabled    133.14    0    0    0    Enabled
    133.64    680    15.8    0    Enabled    133.77    0    0    0    Enabled    133.51    0    0    0    Enabled
    134.02    680    15.8    0    Enabled    134.14    0    0    0    Enabled    133.89    0    0    0    Enabled
    134.39    680    15.8    0    Enabled    134.52    0    0    0    Enabled    134.27    0    0    0    Enabled
    134.77    680    15.8    0    Enabled    134.89    0    0    0    Enabled    134.64    0    0    0    Enabled
    135.14    680    15.8    0    Enabled    135.27    0    0    0    Enabled    135.02    0    0    0    Enabled
    135.52    680    15.8    0    Enabled    135.64    0    0    0    Enabled    135.4    0    0    0    Enabled
    135.9    680    15.8    0    Enabled    136.03    0    0    0    Enabled    135.78    0    0    0    Enabled
    136.28    640    15.8    0    Enabled    136.41    0    0    0    Enabled    136.16    0    0    0    Enabled
    136.65    680    15.8    0    Enabled    136.79    0    0    0    Enabled    136.53    0    0    0    Enabled
    137.04    680    15.8    0    Enabled    137.16    0    0    0    Enabled    136.9    0    0    0    Enabled
    137.41    680    15.8    0    Enabled    137.53    0    0    0    Enabled    137.28    0    0    0    Enabled
    137.78    680    15.8    0    Enabled    137.91    0    0    0    Enabled    137.66    0    0    0    Enabled
    138.16    680    15.8    0    Enabled    138.29    0    0    0    Enabled    138.03    0    0    0    Enabled
    138.54    680    15.8    0    Enabled    138.66    0    0    0    Enabled    138.41    0    0    0    Enabled
    138.91    680    15.8    0    Enabled    139.03    0    0    0    Enabled    138.78    0    0    0    Enabled
    139.28    680    15.8    0    Enabled    139.41    0    0    0    Enabled    139.16    0    0    0    Enabled
    139.66    680    15.8    0    Enabled    139.79    0    0    0    Enabled    139.53    0    0    0    Enabled
    140.05    680    15.8    0    Enabled    140.17    0    0    0    Enabled    139.93    0    0    0    Enabled
    140.42    680    15.8    0    Enabled    140.55    0    0    0    Enabled    140.3    0    0    0    Enabled
    140.8    680    15.8    0    Enabled    140.92    0    0    0    Enabled    140.67    0    0    0    Enabled
    141.17    680    15.8    0    Enabled    141.3    0    0    0    Enabled    141.05    0    0    0    Enabled
    141.55    680    15.8    0    Enabled    141.67    0    0    0    Enabled    141.43    0    0    0    Enabled
    141.94    680    15.8    0    Enabled    142.06    0    0    0    Enabled    141.82    0    0    0    Enabled
    142.31    680    15.8    0    Enabled    142.44    0    0    0    Enabled    142.19    0    0    0    Enabled
    142.69    680    15.8    0    Enabled    142.81    0    0    0    Enabled    142.56    0    0    0    Enabled
    143.06    680    15.8    0    Enabled    143.19    0    0    0    Enabled    142.94    0    0    0    Enabled
    143.44    680    15.8    0    Enabled    143.56    0    0    0    Enabled    143.31    0    0    0    Enabled
    143.81    680    15.8    0    Enabled    143.94    0    0    0    Enabled    143.69    0    0    0    Enabled
    144.19    680    15.8    0    Enabled    144.31    0    0    0    Enabled    144.06    0    0    0    Enabled
    144.57    680    15.8    0    Enabled    144.69    0    0    0    Enabled    144.44    0    0    0    Enabled
    144.96    680    15.8    0    Enabled    145.07    0    0    0    Enabled    144.83    0    0    0    Enabled
    145.33    680    15.8    0    Enabled    145.46    0    0    0    Enabled    145.21    0    0    0    Enabled
    145.71    680    15.8    0    Enabled    145.83    0    0    0    Enabled    145.58    0    0    0    Enabled
    146.08    680    15.8    0    Enabled    146.21    0    0    0    Enabled    145.96    0    0    0    Enabled
    146.45    680    15.8    0    Enabled    146.58    0    0    0    Enabled    146.33    0    0    0    Enabled
    146.83    680    15.8    0    Enabled    146.95    0    0    0    Enabled    146.7    0    0    0    Enabled
    147.2    680    15.8    0    Enabled    147.33    0    0    0    Enabled    147.08    0    0    0    Enabled
    147.58    680    15.8    0    Enabled    147.7    0    0    0    Enabled    147.45    0    0    0    Enabled
    147.95    680    16.5    0    Enabled    148.08    0    0    0    Enabled    147.83    0    0    0    Enabled
    148.32    680    16.5    0    Enabled    148.45    0    0    0    Enabled    148.21    0    0    0    Enabled
    148.7    680    16.5    0    Enabled    148.84    0    0    0    Enabled    148.58    0    0    0    Enabled
    149.1    680    16.5    0    Enabled    149.22    0    0    0    Enabled    148.97    0    0    0    Enabled
    149.47    680    16.5    0    Enabled    149.6    0    0    0    Enabled    149.35    0    0    0    Enabled
    149.85    680    16.5    0    Enabled    149.97    0    0    0    Enabled    149.72    0    0    0    Enabled
    150.22    680    16.5    0    Enabled    150.35    0    0    0    Enabled    150.09    0    0    0    Enabled
    150.59    680    16.5    0    Enabled    150.72    0    0    0    Enabled    150.47    0    0    0    Enabled
    150.97    680    16.5    0    Enabled    151.1    0    0    0    Enabled    150.84    0    0    0    Enabled
    151.34    680    16.5    0    Enabled    151.47    0    0    0    Enabled    151.22    0    0    0    Enabled
    151.72    680    16.5    0    Enabled    151.86    0    0    0    Enabled    151.59    0    0    0    Enabled
    152.11    680    15.8    0    Enabled    152.23    0    0    0    Enabled    151.99    0    0    0    Enabled
    152.48    680    16.5    0    Enabled    152.61    0    0    0    Enabled    152.37    0    0    0    Enabled
    152.86    680    16.5    0    Enabled    152.98    0    0    0    Enabled    152.73    0    0    0    Enabled
    153.23    680    15.8    0    Enabled    153.36    0    0    0    Enabled    153.11    0    0    0    Enabled
    153.61    680    15.8    0    Enabled    153.73    0    0    0    Enabled    153.49    0    0    0    Enabled
    153.99    680    15.8    0    Enabled    154.11    0    0    0    Enabled    153.86    0    0    0    Enabled
    154.36    680    16.5    0    Enabled    154.48    0    0    0    Enabled    154.23    0    0    0    Enabled
    154.74    640    16.5    0    Enabled    154.87    0    0    0    Enabled    154.61    0    0    0    Enabled
    155.13    680    16.5    0    Enabled    155.25    0    0    0    Enabled    155    0    0    0    Enabled
    155.5    680    15.8    0    Enabled    155.63    0    0    0    Enabled    155.37    0    0    0    Enabled
    155.88    680    15.8    0    Enabled    156    0    0    0    Enabled    155.75    0    0    0    Enabled
    156.25    680    16.5    0    Enabled    156.38    0    0    0    Enabled    156.13    0    0    0    Enabled
    156.68    680    16.5    0    Enabled    156.79    0    0    0    Enabled    156.5    0    0    0    Enabled
    157.04    680    16.5    0    Enabled    157.17    0    0    0    Enabled    156.92    0    0    0    Enabled
    157.43    680    15.8    0    Enabled    157.55    0    0    0    Enabled    157.3    0    0    0    Enabled
    157.8    680    15.8    0    Enabled    157.93    0    0    0    Enabled    157.68    0    0    0    Enabled
    158.17    680    16.5    0    Enabled    158.29    0    0    0    Enabled    158.05    0    0    0    Enabled
    158.55    680    15.8    0    Enabled    158.67    0    0    0    Enabled    158.43    0    0    0    Enabled
    158.92    680    15.8    0    Enabled    159.05    0    0    0    Enabled    158.8    0    0    0    Enabled
    159.3    680    15.8    0    Enabled    159.42    0    0    0    Enabled    159.17    0    0    0    Enabled
    159.67    680    15.8    0    Enabled    159.8    0    0    0    Enabled    159.55    0    0    0    Enabled
    160.05    680    15.8    0    Enabled    160.18    0    0    0    Enabled    159.92    0    0    0    Enabled
    160.42    680    15.8    0    Enabled    160.55    0    0    0    Enabled    160.3    0    0    0    Enabled
    160.8    680    15.8    0    Enabled    160.93    0    0    0    Enabled    160.67    0    0    0    Enabled
    161.18    680    15.8    0    Enabled    161.29    0    0    0    Enabled    161.05    0    0    0    Enabled
    161.54    680    15.8    0    Enabled    161.67    0    0    0    Enabled    161.42    0    0    0    Enabled
    161.92    680    15.8    0    Enabled    162.04    0    0    0    Enabled    161.79    0    0    0    Enabled
    162.29    680    15.8    0    Enabled    162.42    0    0    0    Enabled    162.17    0    0    0    Enabled
    162.67    640    15.8    0    Enabled    162.8    0    0    0    Enabled    162.54    0    0    0    Enabled
    163.05    680    15.8    0    Enabled    163.17    0    0    0    Enabled    162.92    0    0    0    Enabled
    163.42    680    15.8    0    Enabled    163.55    0    0    0    Enabled    163.29    0    0    0    Enabled
    163.8    680    15.8    0    Enabled    163.92    0    0    0    Enabled    163.67    0    0    0    Enabled
    164.17    680    15.8    0    Enabled    164.29    0    0    0    Enabled    164.05    0    0    0    Enabled
    164.55    680    15.8    0    Enabled    164.68    0    0    0    Enabled    164.42    0    0    0    Enabled
    164.93    680    15.8    0    Enabled    165.05    0    0    0    Enabled    164.8    0    0    0    Enabled
    165.29    680    15    0    Enabled    165.43    0    0    0    Enabled    165.18    0    0    0    Enabled
    165.68    680    15    0    Enabled    165.8    0    0    0    Enabled    165.55    0    0    0    Enabled
    166.04    680    15    0    Enabled    166.17    0    0    0    Enabled    165.92    0    0    0    Enabled
    166.42    680    15    0    Enabled    166.55    0    0    0    Enabled    166.3    0    0    0    Enabled
    166.8    680    15.8    0    Enabled    166.94    0    0    0    Enabled    166.67    0    0    0    Enabled
    167.19    680    15    0    Enabled    167.31    0    0    0    Enabled    167.06    0    0    0    Enabled
    167.56    680    15.8    0    Enabled    167.69    0    0    0    Enabled    167.44    0    0    0    Enabled
    167.94    680    15    0    Enabled    168.06    0    0    0    Enabled    167.81    0    0    0    Enabled
    168.31    680    15    0    Enabled    168.44    0    0    0    Enabled    168.19    0    0    0    Enabled
    168.69    680    15.8    0    Enabled    168.81    0    0    0    Enabled    168.56    0    0    0    Enabled
    169.06    680    15.8    0    Enabled    169.19    0    0    0    Enabled    168.94    0    0    0    Enabled
    169.44    680    15    0    Enabled    169.57    0    0    0    Enabled    169.31    0    0    0    Enabled
    169.82    680    15    0    Enabled    169.94    0    0    0    Enabled    169.69    0    0    0    Enabled
    170.18    680    15    0    Enabled    170.31    0    0    0    Enabled    170.07    0    0    0    Enabled
    170.57    680    15    0    Enabled    170.69    0    0    0    Enabled    170.44    0    0    0    Enabled
    170.95    680    15    0    Enabled    171.08    0    0    0    Enabled    170.81    0    0    0    Enabled
    171.33    680    15    0    Enabled    171.45    0    0    0    Enabled    171.2    0    0    0    Enabled
    171.7    680    15    0    Enabled    171.83    0    0    0    Enabled    171.58    0    0    0    Enabled
    172.08    680    15    0    Enabled    172.2    0    0    0    Enabled    171.95    0    0    0    Enabled
    172.45    680    15    0    Enabled    172.58    0    0    0    Enabled    172.33    0    0    0    Enabled
    172.83    680    15    0    Enabled    172.95    0    0    0    Enabled    172.7    0    0    0    Enabled
    173.21    680    15    0    Enabled    173.34    0    0    0    Enabled    173.08    0    0    0    Enabled
    173.58    680    15    0    Enabled    173.7    0    0    0    Enabled    173.45    0    0    0    Enabled
    173.97    680    15    0    Enabled    174.1    0    0    0    Enabled    173.83    0    0    0    Enabled
    174.35    680    15    0    Enabled    174.47    0    0    0    Enabled    174.22    0    0    0    Enabled
    174.72    680    15    0    Enabled    174.85    0    0    0    Enabled    174.6    0    0    0    Enabled
    175.1    680    15    0    Enabled    175.22    0    0    0    Enabled    174.97    0    0    0    Enabled
    175.47    680    15    0    Enabled    175.6    0    0    0    Enabled    175.34    0    0    0    Enabled
    175.85    680    15.8    0    Enabled    175.97    0    0    0    Enabled    175.72    0    0    0    Enabled
    176.22    680    15.8    0    Enabled    176.35    0    0    0    Enabled    176.09    0    0    0    Enabled
    176.6    680    15.8    0    Enabled    176.72    0    0    0    Enabled    176.47    0    0    0    Enabled
    176.98    680    15.8    0    Enabled    177.11    0    0    0    Enabled    176.84    0    0    0    Enabled
    177.36    680    15.8    0    Enabled    177.49    0    0    0    Enabled    177.23    0    0    0    Enabled
    177.74    680    15.8    0    Enabled    177.86    0    0    0    Enabled    177.61    0    0    0    Enabled
    178.11    680    15.8    0    Enabled    178.24    0    0    0    Enabled    177.99    0    0    0    Enabled
    178.48    680    15.8    0    Enabled    178.61    0    0    0    Enabled    178.36    0    0    0    Enabled
    178.86    680    15.8    0    Enabled    178.99    0    0    0    Enabled    178.74    0    0    0    Enabled
    179.24    680    15.8    0    Enabled    179.36    0    0    0    Enabled    179.11    0    0    0    Enabled
    179.61    680    15.8    0    Enabled    179.74    0    0    0    Enabled    179.49    0    0    0    Enabled
    179.99    680    15.8    0    Enabled    180.11    0    0    0    Enabled    179.86    0    0    0    Enabled
    180.36    680    15.8    0    Enabled    180.49    0    0    0    Enabled    180.24    0    0    0    Enabled
    180.73    680    15.8    0    Enabled    180.86    0    0    0    Enabled    180.61    0    0    0    Enabled
    181.12    680    15.8    0    Enabled    181.25    0    0    0    Enabled    181    0    0    0    Enabled
    181.5    680    15.8    0    Enabled    181.62    0    0    0    Enabled    181.38    0    0    0    Enabled
    181.88    680    15.8    0    Enabled    182    0    0    0    Enabled    181.75    0    0    0    Enabled
    182.25    680    15.8    0    Enabled    182.38    0    0    0    Enabled    182.13    0    0    0    Enabled
    182.63    680    15.8    0    Enabled    182.75    0    0    0    Enabled    182.5    0    0    0    Enabled
    183    680    15.8    0    Enabled    183.13    0    0    0    Enabled    182.88    0    0    0    Enabled
    183.38    680    15.8    0    Enabled    183.5    0    0    0    Enabled    183.25    0    0    0    Enabled
    183.75    680    15.8    0    Enabled    183.88    0    0    0    Enabled    183.63    0    0    0    Enabled
    184.14    680    15.8    0    Enabled    184.26    0    0    0    Enabled    184.01    0    0    0    Enabled
    184.51    680    15.8    0    Enabled    184.64    0    0    0    Enabled    184.39    0    0    0    Enabled
    184.89    680    15.8    0    Enabled    185.01    0    0    0    Enabled    184.76    0    0    0    Enabled
    185.26    680    15.8    0    Enabled    185.39    0    0    0    Enabled    185.14    0    0    0    Enabled
    185.64    680    15.8    0    Enabled    185.76    0    0    0    Enabled    185.52    0    0    0    Enabled
    186.02    680    15.8    0    Enabled    186.15    0    0    0    Enabled    185.89    0    0    0    Enabled
    186.39    680    15    0    Enabled    186.52    0    0    0    Enabled    186.27    0    0    0    Enabled
    186.76    680    15    0    Enabled    186.89    0    0    0    Enabled    186.64    0    0    0    Enabled
    187.14    680    15    0    Enabled    187.27    0    0    0    Enabled    187.02    0    0    0    Enabled
    187.52    680    15    0    Enabled    187.64    0    0    0    Enabled    187.39    0    0    0    Enabled
    187.89    680    15    0    Enabled    188.03    0    0    0    Enabled    187.77    0    0    0    Enabled
    188.28    680    15    0    Enabled    188.41    0    0    0    Enabled    188.16    0    0    0    Enabled
    188.66    680    15    0    Enabled    188.78    0    0    0    Enabled    188.53    0    0    0    Enabled
    189.03    680    15    0    Enabled    189.16    0    0    0    Enabled    188.91    0    0    0    Enabled
    189.4    680    15    0    Enabled    189.53    0    0    0    Enabled    189.28    0    0    0    Enabled
    189.79    680    15    0    Enabled    189.91    0    0    0    Enabled    189.66    0    0    0    Enabled
    190.17    680    15    0    Enabled    190.3    0    0    0    Enabled    190.05    0    0    0    Enabled
    190.55    680    15    0    Enabled    190.68    0    0    0    Enabled    190.43    0    0    0    Enabled
    190.92    680    15    0    Enabled    191.05    0    0    0    Enabled    190.8    0    0    0    Enabled
    191.29    680    15    0    Enabled    191.42    0    0    0    Enabled    191.17    0    0    0    Enabled
    191.67    680    15    0    Enabled    191.8    0    0    0    Enabled    191.55    0    0    0    Enabled
    192.05    680    15    0    Enabled    192.17    0    0    0    Enabled    191.92    0    0    0    Enabled
    192.42    680    15    0    Enabled    192.55    0    0    0    Enabled    192.3    0    0    0    Enabled
    192.8    640    15    0    Enabled    192.92    0    0    0    Enabled    192.67    0    0    0    Enabled
    193.17    680    15    0    Enabled    193.3    0    0    0    Enabled    193.05    0    0    0    Enabled
    193.55    680    15.8    0    Enabled    193.68    0    0    0    Enabled    193.42    0    0    0    Enabled
    193.92    680    15    0    Enabled    194.07    0    0    0    Enabled    193.79    0    0    0    Enabled
    194.32    680    15    0    Enabled    194.44    0    0    0    Enabled    194.19    0    0    0    Enabled
    194.69    680    15    0    Enabled    194.81    0    0    0    Enabled    194.57    0    0    0    Enabled
    195.06    680    15.8    0    Enabled    195.19    0    0    0    Enabled    194.94    0    0    0    Enabled
    195.44    680    15.8    0    Enabled    195.56    0    0    0    Enabled    195.31    0    0    0    Enabled
    195.81    680    15.8    0    Enabled    195.94    0    0    0    Enabled    195.69    0    0    0    Enabled
    196.19    680    15.8    0    Enabled    196.31    0    0    0    Enabled    196.06    0    0    0    Enabled
    196.56    680    15.8    0    Enabled    196.69    0    0    0    Enabled    196.44    0    0    0    Enabled
    196.94    680    15.8    0    Enabled    197.07    0    0    0    Enabled    196.81    0    0    0    Enabled
    197.33    680    15.8    0    Enabled    197.45    0    0    0    Enabled    197.2    0    0    0    Enabled
    197.7    680    15    0    Enabled    197.83    0    0    0    Enabled    197.57    0    0    0    Enabled
    198.08    680    15    0    Enabled    198.2    0    0    0    Enabled    197.95    0    0    0    Enabled
    198.46    680    15.8    0    Enabled    198.58    0    0    0    Enabled    198.33    0    0    0    Enabled
    198.83    680    15.8    0    Enabled    198.95    0    0    0    Enabled    198.71    0    0    0    Enabled
    199.2    680    15.8    0    Enabled    199.33    0    0    0    Enabled    199.08    0    0    0    Enabled
    199.58    680    15.8    0    Enabled    199.7    0    0    0    Enabled    199.45    0    0    0    Enabled
    199.95    680    15    0    Enabled    200.1    0    0    0    Enabled    199.83    0    0    0    Enabled
    200.34    680    15    0    Enabled    200.47    0    0    0    Enabled    200.22    0    0    0    Enabled
    200.72    680    15.8    0    Enabled    200.84    0    0    0    Enabled    200.59    0    0    0    Enabled
    201.09    680    15    0    Enabled    201.22    0    0    0    Enabled    200.97    0    0    0    Enabled
    201.47    680    15    0    Enabled    201.6    0    0    0    Enabled    201.35    0    0    0    Enabled
    201.85    680    15    0    Enabled    201.97    0    0    0    Enabled    201.72    0    0    0    Enabled
    202.22    680    15    0    Enabled    202.35    0    0    0    Enabled    202.09    0    0    0    Enabled
    202.59    680    15    0    Enabled    202.72    0    0    0    Enabled    202.47    0    0    0    Enabled
    202.97    680    15    0    Enabled    203.11    0    0    0    Enabled    202.84    0    0    0    Enabled
    203.36    680    15.8    0    Enabled    203.49    0    0    0    Enabled    203.24    0    0    0    Enabled
    203.73    680    15.8    0    Enabled    203.86    0    0    0    Enabled    203.61    0    0    0    Enabled
    204.11    680    15    0    Enabled    204.24    0    0    0    Enabled    203.99    0    0    0    Enabled
    204.49    680    15    0    Enabled    204.61    0    0    0    Enabled    204.36    0    0    0    Enabled
    204.86    680    15    0    Enabled    204.98    0    0    0    Enabled    204.74    0    0    0    Enabled
    205.24    680    15.8    0    Enabled    205.36    0    0    0    Enabled    205.11    0    0    0    Enabled
    205.61    680    15.8    0    Enabled    205.73    0    0    0    Enabled    205.48    0    0    0    Enabled
    205.98    680    15    0    Enabled    206.12    0    0    0    Enabled    205.86    0    0    0    Enabled
    206.38    680    15    0    Enabled    206.5    0    0    0    Enabled    206.25    0    0    0    Enabled
    206.75    680    15    0    Enabled    206.88    0    0    0    Enabled    206.63    0    0    0    Enabled
    207.13    640    15.8    0    Enabled    207.25    0    0    0    Enabled    207    0    0    0    Enabled
    207.5    680    15.8    0    Enabled    207.63    0    0    0    Enabled    207.38    0    0    0    Enabled
    207.88    680    15    0    Enabled    208    0    0    0    Enabled    207.75    0    0    0    Enabled
    208.27    680    15.8    0    Enabled    208.39    0    0    0    Enabled    208.14    0    0    0    Enabled
    208.64    680    15.8    0    Enabled    208.77    0    0    0    Enabled    208.52    0    0    0    Enabled
    209.02    680    15.8    0    Enabled    209.14    0    0    0    Enabled    208.89    0    0    0    Enabled
    209.39    680    15.8    0    Enabled    209.52    0    0    0    Enabled    209.27    0    0    0    Enabled
    209.76    680    15.8    0    Enabled    209.89    0    0    0    Enabled    209.64    0    0    0    Enabled
    210.14    680    15    0    Enabled    210.27    0    0    0    Enabled    210.02    0    0    0    Enabled
    210.51    680    15    0    Enabled    210.65    0    0    0    Enabled    210.39    0    0    0    Enabled
    210.89    680    15.8    0    Enabled    211.02    0    0    0    Enabled    210.77    0    0    0    Enabled
    211.27    680    15.8    0    Enabled    211.39    0    0    0    Enabled    211.14    0    0    0    Enabled
    211.64    680    15.8    0    Enabled    211.76    0    0    0    Enabled    211.52    0    0    0    Enabled
    212.02    680    15.8    0    Enabled    212.16    0    0    0    Enabled    211.89    0    0    0    Enabled
    212.41    680    15.8    0    Enabled    212.53    0    0    0    Enabled    212.28    0    0    0    Enabled
    212.78    680    15.8    0    Enabled    212.91    0    0    0    Enabled    212.65    0    0    0    Enabled
    213.16    680    15.8    0    Enabled    213.28    0    0    0    Enabled    213.03    0    0    0    Enabled
    213.53    680    15.8    0    Enabled    213.66    0    0    0    Enabled    213.41    0    0    0    Enabled
    213.91    680    15.8    0    Enabled    214.03    0    0    0    Enabled    213.78    0    0    0    Enabled
    214.29    680    15.8    0    Enabled    214.41    0    0    0    Enabled    214.16    0    0    0    Enabled
    214.66    680    15.8    0    Enabled    214.78    0    0    0    Enabled    214.54    0    0    0    Enabled
    215.03    680    15.8    0    Enabled    215.18    0    0    0    Enabled    214.91    0    0    0    Enabled
    215.43    680    15.8    0    Enabled    215.55    0    0    0    Enabled    215.3    0    0    0    Enabled
    215.8    680    15.8    0    Enabled    215.92    0    0    0    Enabled    215.68    0    0    0    Enabled
    216.17    680    15.8    0    Enabled    216.29    0    0    0    Enabled    216.05    0    0    0    Enabled
    216.55    680    15.8    0    Enabled    216.67    0    0    0    Enabled    216.42    0    0    0    Enabled
    216.92    680    15.8    0    Enabled    217.05    0    0    0    Enabled    216.8    0    0    0    Enabled
    217.3    640    15.8    0    Enabled    217.43    0    0    0    Enabled    217.17    0    0    0    Enabled
    217.67    680    15.8    0    Enabled    217.8    0    0    0    Enabled    217.55    0    0    0    Enabled
    218.05    680    15.8    0    Enabled    218.19    0    0    0    Enabled    217.92    0    0    0    Enabled
    218.44    680    15.8    0    Enabled    218.56    0    0    0    Enabled    218.31    0    0    0    Enabled
    218.82    680    15.8    0    Enabled    218.94    0    0    0    Enabled    218.69    0    0    0    Enabled
    219.19    680    15.8    0    Enabled    219.31    0    0    0    Enabled    219.07    0    0    0    Enabled
    219.57    680    15.8    0    Enabled    219.69    0    0    0    Enabled    219.44    0    0    0    Enabled
    219.94    680    15.8    0    Enabled    220.06    0    0    0    Enabled    219.81    0    0    0    Enabled
TFSI
Maryland, USA
C?ID=66650
Paul,
Its best to do the accelerator pedal flooring test while driving in the suggested MVBs just to try and reproduce the misfire and its frequency level of occurrence since your description suggests misfire occurs under heavy load.. This is where the injector will be 'challenged" to create the needed injection quantity on demand. Please NOTE that for safety reasons it is highly recommended that you get a second person with you in car to do this so one can focus on driving while the other takes the reading.
pauljs33
C?ID=385174
Hi T,
Many thanks for all the hand holding. I reproduced the issue here. The issue occurs every time I floor it. You will note that I also turned on MVS 003 so I could see that the misfire happens when I burry my foot in the pedal using the data. It's one thing for me to say it, but it's another for you to see it in the data. A few points regarding the data:
1) When I paste here the columns do not line up too well.
Column 1 is Time Stamp (Group A: 003)
Column 2 is Engine Speed
Column 3 is MAF
Column 4 is Throttle Valve Angle
Column 5 is Ignition Timing BTDC
Column 6 is Time Stamp (Group B: 015)
Column 7 is Misfire Counter Cylinder 1
Column 8 is Misfire Counter Cylinder 2
Column 9 is Misfire Counter Cylinder 3
Column 10 is Misfire Recognition
Column 11 is Time Stamp (Group C: 016)
Column 12 is Ignition Misfire Counter Cylinder 4
Column 13 is Ignition Misfire Counter Cylinder 5
Column 14 is Ignition Misfire Counter Cylinder 6
Column 15 is Misfire Recognition
2) Scroll to around time stamp 98 and you'll see the throttle open significantly and the MAF increase. This must be where I floored it.
3) If you scroll to time stamp 100 You'll see Cylinders 4 & 5 starting to have issue. Especially 5.
4) Interestingly, at around time stamp 124, the errors clear and don't show up for the rest of the drive. However, I can tell you the engine was missing for the entire remainder of the drive.
5) The Misfire Recognition switches regularly between Enabled and Disabled during the entire drive. I'm not sure if this is normal, but it seemed odd to a novice looking at the data.
Let me know your thoughts if you have a moment to look things over.
Again, thanks for your help.
Monday 5 October 2020 18:14:47:04546-VCID:6393A8C17754A4332F1-8036 VCDS Version: Release 20.4.2 (x64) Data version: 20200730 DS317.0
Group A: '003 Group B: '015 Group C: '016
Engine Speed Mass Air Flow Throttle Valve Angle Ignition Misfire Counter Misfire Counter Misfire Counter Misfire Misfire Counter Misfire Counter Misfire Counter Misfire
TIME (G28) (G70) Timing Angle TIME Cylinder 1 Cylinder 2 Cylinder 3 Recognition TIME Cylinder 4 Cylinder 5 Cylinder 6 Recognition
Marker STAMP /min g/s % °BTDC STAMP STAMP
0.18 680 3.69 2 10.5 0.3 0 0 0 Enabled 0.06 0 0 0 Enabled
0.55 680 3.69 2 12 0.68 0 0 0 Enabled 0.43 0 0 0 Enabled
0.93 680 3.69 2 12.8 1.05 0 0 0 Enabled 0.8 0 0 0 Enabled
1.32 680 3.69 2 12 1.44 0 0 0 Enabled 1.18 0 0 0 Enabled
1.69 680 3.69 2 12 1.82 0 0 0 Enabled 1.57 0 0 0 Enabled
2.07 680 3.69 2 11.3 2.19 0 0 0 Enabled 1.94 0 0 0 Enabled
2.44 680 3.69 2 9.8 2.57 0 0 0 Enabled 2.32 0 0 0 Enabled
2.82 680 3.69 2 11.3 2.94 0 0 0 Enabled 2.69 0 0 0 Enabled
3.2 680 3.67 2 12.8 3.33 0 0 0 Enabled 3.07 0 0 0 Enabled
3.58 680 3.69 2 9.8 3.71 0 0 0 Enabled 3.46 0 0 0 Enabled
3.96 680 3.67 2 10.5 4.08 0 0 0 Enabled 3.83 0 0 0 Enabled
4.33 680 3.67 2 11.3 4.46 0 0 0 Enabled 4.21 0 0 0 Enabled
4.71 680 3.67 2 11.3 4.83 0 0 0 Enabled 4.59 0 0 0 Enabled
5.08 680 3.67 2 12 5.21 0 0 0 Enabled 4.96 0 0 0 Enabled
5.46 680 3.67 2 11.3 5.58 0 0 0 Enabled 5.33 0 0 0 Enabled
5.83 640 4 2.4 28.5 5.96 0 0 0 Enabled 5.71 0 0 0 Enabled
6.21 720 4.14 2.4 8.3 6.33 0 0 0 Enabled 6.08 0 0 0 Enabled
6.58 680 3.64 2 6.8 6.71 0 0 0 Enabled 6.46 0 0 0 Enabled
6.96 680 3.61 2 9.8 7.09 0 0 0 Enabled 6.83 0 0 0 Enabled
7.35 680 3.58 2 11.3 7.47 0 0 0 Enabled 7.21 0 0 0 Enabled
7.73 680 3.56 2 12 7.85 0 0 0 Enabled 7.6 0 0 0 Enabled
8.1 680 3.61 2 12.8 8.22 0 0 0 Enabled 7.97 0 0 0 Enabled
8.47 680 3.64 2 12 8.6 0 0 0 Enabled 8.35 0 0 0 Enabled
8.85 680 3.67 2 11.3 8.97 0 0 0 Enabled 8.72 0 0 0 Enabled
9.23 680 3.64 2 12 9.35 0 0 0 Enabled 9.1 0 0 0 Enabled
9.6 680 3.67 2 9.8 9.72 0 0 0 Enabled 9.47 0 0 0 Enabled
9.97 680 3.64 2 10.5 10.1 0 0 0 Enabled 9.84 0 0 0 Enabled
10.36 680 3.64 2 10.5 10.49 0 0 0 Enabled 10.22 0 0 0 Enabled
10.74 680 3.64 2 11.3 10.86 0 0 0 Enabled 10.61 0 0 0 Enabled
11.12 680 3.64 2 9.8 11.24 0 0 0 Enabled 10.99 0 0 0 Enabled
11.49 680 3.64 2 10.5 11.62 0 0 0 Enabled 11.36 0 0 0 Enabled
11.87 680 3.64 2 10.5 11.99 0 0 0 Enabled 11.74 0 0 0 Enabled
12.24 680 3.58 2 10.5 12.38 0 0 0 Enabled 12.12 0 0 0 Enabled
12.63 680 3.56 2 13.5 12.75 0 0 0 Enabled 12.51 0 0 0 Enabled
13.01 680 3.56 2 11.3 13.13 0 0 0 Enabled 12.88 0 0 0 Enabled
13.38 680 3.56 2 15 13.5 0 0 0 Enabled 13.25 0 0 0 Enabled
13.76 680 3.64 2 12 13.88 0 0 0 Enabled 13.63 0 0 0 Enabled
14.13 680 3.64 2 11.3 14.25 0 0 0 Enabled 14 0 0 0 Enabled
14.51 680 3.64 2 11.3 14.63 0 0 0 Enabled 14.38 0 0 0 Enabled
14.88 680 3.64 2 10.5 15.01 0 0 0 Enabled 14.76 0 0 0 Enabled
15.26 680 3.64 2 12.8 15.4 0 0 0 Enabled 15.13 0 0 0 Enabled
15.65 680 3.64 2 11.3 15.77 0 0 0 Enabled 15.52 0 0 0 Enabled
16.02 680 3.64 2 11.3 16.15 0 0 0 Enabled 15.9 0 0 0 Enabled
16.4 680 3.64 2 10.5 16.52 0 0 0 Enabled 16.27 0 0 0 Enabled
16.77 680 3.64 2 12.8 16.9 0 0 0 Enabled 16.65 0 0 0 Enabled
17.14 680 3.67 2 12.8 17.27 0 0 0 Enabled 17.02 0 0 0 Enabled
17.52 680 3.78 2.4 12.8 17.64 0 0 0 Enabled 17.4 0 0 0 Enabled
17.9 680 6.89 3.5 6.8 18.02 0 0 0 Enabled 17.77 0 0 0 Enabled
18.27 640 5.83 3.5 0 18.4 0 0 0 Enabled 18.14 0 0 0 Enabled
18.65 680 6.67 3.9 3.8 18.77 0 0 0 Enabled 18.52 0 0 0 Enabled
19.02 720 6.31 3.5 0.8 19.14 0 0 0 Enabled 18.89 0 0 0 Enabled
19.41 680 6.86 3.9 20.3 19.53 0 0 0 Enabled 19.27 0 0 0 Enabled
19.79 720 6.75 3.9 14.3 19.91 0 0 0 Enabled 19.67 0 0 0 Enabled
20.16 720 6.5 3.5 3 20.29 0 0 0 Enabled 20.04 0 0 0 Enabled
20.54 720 6.03 3.1 3 20.66 0 0 0 Enabled 20.41 0 0 0 Enabled
20.91 720 5.89 3.5 7.5 21.04 0 0 0 Enabled 20.79 0 0 0 Enabled
21.29 680 6.22 3.5 15 21.41 0 0 0 Enabled 21.16 0 0 0 Enabled
21.66 680 8.03 4.7 17.3 21.78 0 0 0 Enabled 21.53 0 0 0 Enabled
22.04 720 5.83 3.1 0 22.16 0 0 0 Enabled 21.91 0 0 0 Enabled
22.43 680 5.67 3.1 1.5 22.55 0 0 0 Enabled 22.29 0 0 0 Enabled
22.81 680 5.53 3.1 3.8 22.93 0 0 0 Enabled 22.68 0 0 0 Enabled
23.18 680 5.58 3.1 16.5 23.3 0 0 0 Enabled 23.05 0 0 0 Enabled
23.56 720 5.61 3.1 7.5 23.68 0 0 0 Enabled 23.43 0 0 0 Enabled
23.92 680 5.64 3.1 10.5 24.05 0 0 0 Enabled 23.8 0 0 0 Enabled
24.3 680 5.67 3.1 9 24.44 0 0 0 Enabled 24.17 0 0 0 Enabled
24.69 720 5.67 3.1 8.3 24.82 0 0 0 Enabled 24.57 0 0 0 Enabled
25.07 720 5.64 3.1 9.8 25.19 0 0 0 Enabled 24.94 0 0 0 Enabled
25.44 720 5.61 3.1 8.3 25.57 0 0 0 Enabled 25.32 0 0 0 Enabled
25.82 680 5.58 3.1 11.3 25.94 0 0 0 Enabled 25.69 0 0 0 Enabled
26.19 720 5.56 3.1 8.3 26.32 0 0 0 Enabled 26.07 0 0 0 Enabled
26.57 720 5.53 3.1 8.3 26.69 0 0 0 Enabled 26.44 0 0 0 Enabled
26.94 720 5.5 3.1 6.8 27.07 0 0 0 Enabled 26.82 0 0 0 Enabled
27.32 760 6.97 3.9 12 27.44 0 0 0 Enabled 27.2 0 0 0 Enabled
27.69 880 7.53 3.9 0.8 27.82 0 0 0 Enabled 27.56 0 0 0 Enabled
28.07 800 6.97 4.3 12 28.19 0 0 0 Enabled 27.94 0 0 0 Enabled
28.46 800 7.5 4.3 3.8 28.58 0 0 0 Enabled 28.32 0 0 0 Enabled
28.83 760 8.83 5.5 21.8 28.96 0 0 0 Enabled 28.71 0 0 0 Enabled
29.21 920 10.94 6.3 21.8 29.33 0 0 0 Enabled 29.08 0 0 0 Enabled
29.58 1040 12 6.3 22.5 29.71 0 0 0 Enabled 29.46 0 0 0 Enabled
29.96 1160 21.17 10.2 23.3 30.08 0 0 0 Enabled 29.83 0 0 0 Enabled
30.33 1480 22 11.4 27 30.46 0 0 0 Enabled 30.21 0 0 0 Enabled
30.71 1720 24.92 13.3 27 30.83 0 0 0 Enabled 30.58 0 0 0 Enabled
31.08 1920 28.11 14.1 27 31.21 0 0 0 Enabled 30.95 0 0 0 Enabled
31.47 2160 30.14 14.1 27.8 31.6 0 0 0 Enabled 31.33 0 0 0 Enabled
31.85 2120 29.08 12.9 9 31.97 0 0 0 Enabled 31.72 0 0 0 Enabled
32.23 1600 20.39 9.8 20.3 32.35 0 0 0 Enabled 32.1 0 0 0 Enabled
32.6 1640 19.11 9.8 30.8 32.73 0 0 0 Enabled 32.48 0 0 0 Enabled
32.97 1640 19.69 9.8 30.8 33.1 0 0 0 Enabled 32.85 0 0 0 Enabled
33.35 1480 6.39 3.5 2.3 33.47 0 0 0 Disabled 33.22 0 0 0 Enabled
33.72 1480 7.61 4.3 9 33.85 0 0 0 Disabled 33.6 0 0 0 Disabled
34.1 1440 7.42 4.3 8.3 34.22 0 0 0 Disabled 33.98 0 0 0 Disabled
34.49 1400 7.25 4.3 9.8 34.61 0 0 0 Disabled 34.35 0 0 0 Disabled
34.87 1360 7.25 3.9 9.8 34.99 0 0 0 Disabled 34.74 0 0 0 Disabled
35.24 1280 7.03 3.9 10.5 35.36 0 0 0 Disabled 35.12 0 0 0 Disabled
35.62 1200 6.72 3.9 14.3 35.74 0 0 0 Disabled 35.49 0 0 0 Disabled
35.99 1040 6.58 3.5 18 36.12 0 0 0 Enabled 35.87 0 0 0 Disabled
36.37 920 6.17 3.5 21 36.49 0 0 0 Enabled 36.24 0 0 0 Enabled
36.74 800 5.42 3.1 16.5 36.87 0 0 0 Enabled 36.62 0 0 0 Enabled
37.11 760 5.08 2.7 15.8 37.24 0 0 0 Enabled 36.99 0 0 0 Enabled
37.5 680 5.72 3.5 27 37.63 0 0 0 Enabled 37.36 0 0 0 Enabled
37.88 720 5.28 3.1 13.5 38 0 0 0 Enabled 37.75 0 0 0 Enabled
38.25 720 5.28 3.1 12 38.38 0 0 0 Enabled 38.13 0 0 0 Enabled
38.63 720 5.56 3.5 25.5 38.75 0 0 0 Enabled 38.51 0 0 0 Enabled
39.01 720 5.64 3.5 25.5 39.13 0 0 0 Enabled 38.88 0 0 0 Enabled
39.38 720 5.53 2.7 24.8 39.52 0 0 0 Enabled 39.25 0 0 0 Enabled
39.77 800 19.53 9.4 3.8 39.9 0 0 0 Enabled 39.65 0 0 0 Enabled
40.15 1200 16.78 9 14.3 40.27 0 0 0 Enabled 40.02 0 0 0 Enabled
40.52 1360 19.06 9.8 27 40.65 0 0 0 Enabled 40.39 0 0 0 Enabled
40.9 1400 19.28 10.6 26.3 41.02 0 0 0 Enabled 40.77 0 0 0 Enabled
41.27 1560 21.5 11.8 28.5 41.39 0 0 0 Enabled 41.15 0 0 0 Enabled
41.65 1640 23.47 12.5 27.8 41.77 0 0 0 Enabled 41.52 0 0 0 Enabled
42.02 1720 24.97 13.3 27.8 42.14 0 0 0 Enabled 41.9 0 0 0 Enabled
42.39 1800 26.86 14.1 28.5 42.52 0 0 0 Enabled 42.27 0 0 0 Enabled
42.77 1880 28.25 14.1 27.8 42.9 0 0 0 Enabled 42.64 0 0 0 Enabled
43.15 1880 20.89 10.2 28.5 43.27 0 0 0 Enabled 43.02 0 0 0 Enabled
43.53 1880 21.47 10.2 32.3 43.66 0 0 0 Enabled 43.39 0 0 0 Enabled
43.91 1880 20.36 9.4 21.8 44.03 0 0 0 Enabled 43.79 0 0 0 Enabled
44.29 1480 19.25 9.4 9 44.41 0 0 0 Enabled 44.16 0 0 0 Enabled
44.66 1440 18.22 9 23.3 44.79 0 0 0 Enabled 44.54 0 0 0 Enabled
45.04 1520 19.89 10.2 30 45.16 0 0 0 Enabled 44.91 0 0 0 Enabled
45.41 1600 20.39 10.6 30.8 45.54 0 0 0 Enabled 45.29 0 0 0 Enabled
45.78 1600 21.19 11 30.8 45.91 0 0 0 Enabled 45.66 0 0 0 Enabled
46.16 1640 21.94 11.4 30 46.28 0 0 0 Enabled 46.03 0 0 0 Enabled
46.55 1680 22.64 11.4 28.5 46.68 0 0 0 Enabled 46.41 0 0 0 Enabled
46.93 1680 23.28 11.8 28.5 47.05 0 0 0 Enabled 46.8 0 0 0 Enabled
47.3 1720 17.53 7.8 24 47.43 0 0 0 Enabled 47.18 0 0 0 Enabled
47.68 1360 9.53 3.9 5.3 47.81 0 0 0 Enabled 47.55 0 0 0 Enabled
48.05 1280 6.97 3.9 6 48.18 0 0 0 Disabled 47.92 0 0 0 Enabled
48.43 1240 6.81 3.9 5.3 48.56 0 0 0 Disabled 48.3 0 0 0 Disabled
48.8 1160 6.5 3.5 3 48.93 0 0 0 Disabled 48.68 0 0 0 Disabled
49.18 1080 5.75 3.1 1.5 49.3 0 0 0 Disabled 49.05 0 0 0 Disabled
49.57 1000 5.14 2.7 9.8 49.69 0 0 0 Disabled 49.43 0 0 0 Disabled
49.94 920 5 2.7 16.5 50.07 0 0 0 Disabled 49.82 0 0 0 Disabled
50.32 880 4.97 2.7 19.5 50.44 0 0 0 Disabled 50.19 0 0 0 Disabled
50.69 800 4.64 2.7 16.5 50.82 0 0 0 Disabled 50.57 0 0 0 Disabled
51.07 760 4.61 2.7 19.5 51.19 0 0 0 Disabled 50.94 0 0 0 Disabled
51.44 680 4.61 3.1 28.5 51.57 0 0 0 Enabled 51.32 0 0 0 Enabled
51.82 760 5.72 3.1 2.3 51.94 0 0 0 Enabled 51.69 0 0 0 Enabled
52.2 760 5.94 3.5 6 52.32 0 0 0 Enabled 52.07 0 0 0 Enabled
52.59 800 8.06 4.3 15.8 52.71 0 0 0 Enabled 52.44 0 0 0 Enabled
52.96 1040 18.39 10.2 -0.8 53.08 0 0 0 Enabled 52.83 0 0 0 Enabled
53.33 1560 30.89 16.1 21.8 53.46 0 0 0 Enabled 53.21 0 0 0 Enabled
53.71 1720 31.58 17.3 23.3 53.83 0 0 0 Enabled 53.58 0 0 0 Enabled
54.08 1800 31.92 17.3 23.3 54.21 0 0 0 Enabled 53.96 0 0 0 Enabled
54.46 1880 33.14 17.3 24 54.58 0 0 0 Enabled 54.33 0 0 0 Enabled
54.83 1960 34.44 17.6 24 54.96 0 0 0 Enabled 54.71 0 0 0 Enabled
55.21 2040 36.36 18.4 24.8 55.33 0 0 0 Enabled 55.08 0 0 0 Enabled
55.6 2160 41.72 20.4 24.8 55.72 0 0 0 Enabled 55.46 0 0 0 Enabled
55.98 2320 46.83 23.9 22.5 56.1 0 0 0 Enabled 55.85 0 0 0 Enabled
56.35 2440 47.61 23.1 23.3 56.47 0 0 0 Enabled 56.23 0 0 0 Enabled
56.73 2360 53.61 31.8 6 56.85 0 0 0 Enabled 56.6 0 0 0 Enabled
57.1 2080 50.36 41.2 14.3 57.22 0 0 0 Enabled 56.97 0 0 0 Enabled
57.47 2280 51.33 40.4 21 57.6 0 0 0 Enabled 57.35 0 0 0 Enabled
57.85 2320 52.75 37.3 22.5 57.97 0 0 0 Enabled 57.72 0 0 0 Enabled
58.22 2360 53.42 37.6 23.3 58.35 0 0 0 Enabled 58.1 0 0 0 Enabled
58.61 2440 55.53 37.6 23.3 58.74 0 0 0 Enabled 58.47 0 0 0 Enabled
58.99 2480 54.58 34.5 23.3 59.11 0 0 0 Enabled 58.86 0 0 0 Enabled
59.36 2480 55.81 34.5 23.3 59.49 0 0 0 Enabled 59.24 0 0 0 Enabled
59.74 2560 57.69 36.1 23.3 59.87 0 0 0 Enabled 59.61 0 0 0 Enabled
60.11 2640 59.47 35.3 23.3 60.24 0 0 0 Enabled 59.98 0 0 0 Enabled
60.49 2640 52.31 28.2 23.3 60.61 0 0 0 Enabled 60.36 0 0 0 Enabled
60.87 2640 50.28 23.5 24 60.99 0 0 0 Enabled 60.74 0 0 0 Enabled
61.24 2320 44.61 20.8 6.8 61.37 0 0 0 Enabled 61.12 0 0 0 Enabled
61.63 2040 39.17 19.6 24.8 61.76 0 0 0 Enabled 61.49 0 0 0 Enabled
62 2080 26.25 12.9 27.8 62.13 0 0 0 Enabled 61.88 0 0 0 Enabled
62.38 2120 28.36 13.3 30 62.5 0 0 0 Enabled 62.25 0 0 0 Enabled
62.76 1720 26.81 12.2 21.8 62.88 0 0 0 Enabled 62.63 0 0 0 Enabled
63.13 1640 23.97 11.8 27 63.25 0 0 0 Enabled 63 0 0 0 Enabled
63.5 1640 24.06 12.2 27.8 63.65 0 0 0 Enabled 63.38 0 0 0 Enabled
63.9 1640 24.33 12.5 27.8 64.03 0 0 0 Enabled 63.77 0 0 0 Enabled
64.27 1680 25.08 12.9 27 64.39 0 0 0 Enabled 64.15 0 0 0 Enabled
64.64 1680 25.78 13.3 27 64.77 0 0 0 Enabled 64.52 0 0 0 Enabled
65.02 1680 25.33 11.8 27 65.15 0 0 0 Enabled 64.9 0 0 0 Enabled
65.4 1680 6.94 4.3 9.8 65.52 0 0 0 Disabled 65.27 0 0 0 Enabled
65.77 1440 8.06 4.3 8.3 65.9 0 0 0 Disabled 65.65 0 0 0 Disabled
66.15 1320 7.11 3.9 -6 66.27 0 0 0 Disabled 66.02 0 0 0 Disabled
66.52 1280 6.89 3.9 -3 66.66 0 0 0 Disabled 66.4 0 0 0 Disabled
66.91 1280 6.81 3.9 -3 67.03 0 0 0 Disabled 66.79 0 0 0 Disabled
67.28 1280 6.69 3.9 -1.5 67.41 0 0 0 Disabled 67.16 0 0 0 Disabled
67.66 1280 6.69 3.9 -0.8 67.79 0 0 0 Disabled 67.53 0 0 0 Disabled
68.04 1280 6.78 3.9 12.8 68.16 0 0 0 Disabled 67.91 0 0 0 Disabled
68.41 1280 6.81 3.9 36 68.53 0 0 0 Disabled 68.28 0 0 0 Disabled
68.79 1280 6.83 3.9 35.3 68.91 0 0 0 Disabled 68.65 0 0 0 Enabled
69.16 1280 12.03 5.5 32.3 69.29 0 0 0 Enabled 69.03 0 0 0 Enabled
69.54 1320 9.44 5.1 32.3 69.68 0 0 0 Enabled 69.41 0 0 0 Enabled
69.93 1280 9.64 5.1 30.8 70.05 0 0 0 Enabled 69.8 0 0 0 Enabled
70.3 1280 8.61 4.7 21 70.42 0 0 0 Enabled 70.18 0 0 0 Enabled
70.68 1280 7.97 4.3 15 70.8 0 0 0 Enabled 70.55 0 0 0 Enabled
71.05 1280 7.39 3.9 17.3 71.17 0 0 0 Enabled 70.93 0 0 0 Enabled
71.42 1280 7.17 3.9 23.3 71.55 0 0 0 Enabled 71.3 0 0 0 Enabled
71.8 1240 7.08 3.9 33.8 71.92 0 0 0 Enabled 71.67 0 0 0 Enabled
72.18 1240 6.97 3.9 34.5 72.3 0 0 0 Enabled 72.05 0 0 0 Enabled
72.55 1240 6.94 3.9 34.5 72.69 0 0 0 Enabled 72.43 0 0 0 Enabled
72.94 1240 6.94 3.9 34.5 73.07 0 0 0 Enabled 72.82 0 0 0 Enabled
73.32 1240 6.94 3.9 34.5 73.45 0 0 0 Enabled 73.19 0 0 0 Enabled
73.69 1240 6.86 3.9 27.8 73.82 0 0 0 Enabled 73.57 0 0 0 Enabled
74.07 1240 6.72 3.5 27.8 74.19 0 0 0 Enabled 73.94 0 0 0 Enabled
74.44 1240 6.64 3.5 29.3 74.57 0 0 0 Enabled 74.32 0 0 0 Enabled
74.82 1240 6.53 3.5 34.5 74.94 0 0 0 Enabled 74.69 0 0 0 Enabled
75.19 1240 6.5 3.5 35.3 75.32 0 0 0 Enabled 75.07 0 0 0 Enabled
75.57 1160 6.42 3.5 3 75.69 0 0 0 Disabled 75.44 0 0 0 Disabled
75.94 1160 6.19 3.5 0.8 76.07 0 0 0 Disabled 75.82 0 0 0 Disabled
76.31 1160 5.78 3.1 -2.3 76.44 0 0 0 Disabled 76.19 0 0 0 Disabled
76.71 1160 5.89 3.5 -0.8 76.84 0 0 0 Disabled 76.57 0 0 0 Disabled
77.09 1120 5.86 3.1 -0.8 77.21 0 0 0 Disabled 76.96 0 0 0 Disabled
77.46 1120 5.86 3.1 0.8 77.59 0 0 0 Disabled 77.33 0 0 0 Disabled
77.83 1080 5.81 3.1 0.8 77.96 0 0 0 Disabled 77.71 0 0 0 Disabled
78.21 1040 5.58 3.1 1.5 78.33 0 0 0 Disabled 78.08 0 0 0 Disabled
78.58 1040 5.47 2.7 1.5 78.71 0 0 0 Disabled 78.46 0 0 0 Disabled
78.96 1080 5.19 2.7 -0.8 79.08 0 0 0 Disabled 78.83 0 0 0 Disabled
79.33 1200 5.75 3.5 -0.8 79.46 0 0 0 Disabled 79.21 0 0 0 Disabled
79.73 1120 6.14 3.5 0 79.85 0 0 0 Disabled 79.58 0 0 0 Disabled
80.1 1080 5.78 3.1 1.5 80.22 0 0 0 Disabled 79.97 0 0 0 Disabled
80.47 1080 5.42 2.7 1.5 80.6 0 0 0 Disabled 80.35 0 0 0 Disabled
80.85 1120 5.53 3.1 1.5 80.97 0 0 0 Disabled 80.72 0 0 0 Disabled
81.23 1160 5.86 3.5 0.8 81.35 0 0 0 Disabled 81.1 0 0 0 Disabled
81.6 1120 5.89 3.5 8.3 81.73 0 0 0 Disabled 81.48 0 0 0 Disabled
81.97 1400 18.53 9 19.5 82.1 0 0 0 Enabled 81.85 0 0 0 Disabled
82.35 1560 18.44 8.6 35.3 82.47 0 0 0 Enabled 82.22 0 0 0 Enabled
82.74 1560 12.17 6.3 18.8 82.86 0 0 0 Enabled 82.6 0 0 0 Enabled
83.11 1600 11.08 5.9 21 83.24 0 0 0 Enabled 82.99 0 0 0 Enabled
83.49 1600 10.89 5.5 20.3 83.61 0 0 0 Enabled 83.36 0 0 0 Enabled
83.86 1600 10.64 5.5 35.3 83.99 0 0 0 Enabled 83.74 0 0 0 Enabled
84.24 1600 15.08 7.8 35.3 84.36 0 0 0 Enabled 84.12 0 0 0 Enabled
84.62 1680 22.5 10.2 35.3 84.76 0 0 0 Enabled 84.49 0 0 0 Enabled
85.01 1680 21.39 10.2 30.8 85.13 0 0 0 Enabled 84.88 0 0 0 Enabled
85.38 1720 21.47 10.6 30.8 85.51 0 0 0 Enabled 85.26 0 0 0 Enabled
85.76 1760 22.17 10.6 31.5 85.88 0 0 0 Enabled 85.63 0 0 0 Enabled
86.13 1840 22.81 11 31.5 86.26 0 0 0 Enabled 86.01 0 0 0 Enabled
86.5 1600 23.17 11.4 8.3 86.63 0 0 0 Enabled 86.38 0 0 0 Enabled
86.88 1440 22.36 11.4 26.3 87.01 0 0 0 Enabled 86.76 0 0 0 Enabled
87.25 1480 21.28 10.6 27 87.38 0 0 0 Enabled 87.13 0 0 0 Enabled
87.63 1480 20.36 11.4 27.8 87.75 0 0 0 Enabled 87.51 0 0 0 Enabled
88 1520 24.25 12.9 27 88.13 0 0 0 Enabled 87.88 0 0 0 Enabled
88.38 1560 24.53 12.9 26.3 88.51 0 0 0 Enabled 88.26 0 0 0 Enabled
88.77 1560 21.42 11 27.8 88.9 0 0 0 Enabled 88.63 0 0 0 Enabled
89.15 1600 21.47 10.6 28.5 89.27 0 0 0 Enabled 89.02 0 0 0 Enabled
89.52 1640 21.56 10.6 28.5 89.65 0 0 0 Enabled 89.4 0 0 0 Enabled
89.9 1640 21.89 11 29.3 90.02 0 0 0 Enabled 89.77 0 0 0 Enabled
90.27 1680 22.61 11.4 30 90.4 0 0 0 Enabled 90.15 0 0 0 Enabled
90.65 1720 32.03 16.1 25.5 90.77 0 0 0 Enabled 90.52 0 0 0 Enabled
91.02 1760 31 16.1 24.8 91.14 0 0 0 Enabled 90.9 0 0 0 Enabled
91.4 1800 30.78 15.3 25.5 91.52 0 0 0 Enabled 91.27 0 0 0 Enabled
91.77 1840 30.39 14.9 26.3 91.9 0 0 0 Enabled 91.64 0 0 0 Enabled
92.15 1880 30.31 14.9 27 92.27 0 0 0 Enabled 92.02 0 0 0 Enabled
92.52 1920 30.61 14.9 26.3 92.64 0 0 0 Enabled 92.39 0 0 0 Enabled
92.91 1960 31.39 15.3 26.3 93.04 0 0 0 Enabled 92.79 0 0 0 Enabled
93.29 2000 32.83 15.7 27 93.41 0 0 0 Enabled 93.16 0 0 0 Enabled
93.66 2040 33.53 16.1 26.3 93.79 0 0 0 Enabled 93.54 0 0 0 Enabled
94.04 2040 34.36 16.1 26.3 94.16 0 0 0 Enabled 93.9 0 0 0 Enabled
94.41 1760 32.64 15.3 6 94.54 0 0 0 Enabled 94.29 0 0 0 Enabled
94.8 1600 28.89 14.5 24 94.93 0 0 0 Enabled 94.66 0 0 0 Enabled
95.18 1640 26.67 14.1 24.8 95.3 0 0 0 Enabled 95.05 0 0 0 Enabled
95.55 1640 26.44 13.7 25.5 95.68 0 0 0 Enabled 95.43 0 0 0 Enabled
95.93 1640 26.61 14.1 26.3 96.05 0 0 0 Enabled 95.8 0 0 0 Enabled
96.3 1680 27.33 14.9 26.3 96.43 0 0 0 Enabled 96.18 0 0 0 Enabled
96.68 1680 28.31 15.3 26.3 96.8 0 0 0 Enabled 96.55 0 0 0 Enabled
97.06 1720 29.28 15.7 26.3 97.17 0 0 0 Enabled 96.92 0 0 0 Enabled
97.43 1720 29.78 16.1 24.8 97.55 0 0 0 Enabled 97.3 0 0 0 Enabled
97.8 1760 29.81 15.7 24.8 97.93 0 0 0 Enabled 97.68 0 0 0 Enabled
98.18 1760 29.89 15.7 25.5 98.3 0 0 0 Enabled 98.05 0 0 0 Enabled
98.55 1800 49.28 22.4 24.8 98.68 0 0 0 Enabled 98.43 0 0 0 Enabled
98.94 2480 71.42 75.3 15.8 99.07 0 0 0 Enabled 98.82 0 0 0 Enabled
99.32 3560 118.56 93.3 7.5 99.44 0 0 0 Enabled 99.19 0 0 0 Enabled
99.69 3600 121.08 98 10.5 99.82 0 0 0 Enabled 99.57 0 0 0 Enabled
100.07 3480 18.17 8.6 23.3 100.19 0 0 0 Disabled 99.94 0 0 0 Enabled
100.44 2880 16.58 7.8 13.5 100.57 0 0 0 Disabled 100.32 0 0 0 Disabled
100.82 2840 105.5 51.4 22.5 100.94 0 0 0 Enabled 100.69 0 0 0 Disabled
101.19 3440 99.53 85.5 18 101.32 0 0 0 Enabled 101.07 0 0 0 Enabled
101.57 3680 123.47 95.7 9.8 101.69 0 0 0 Enabled 101.44 0 5 0 Enabled
101.96 3560 120.69 99.2 8.3 102.09 0 0 0 Enabled 101.83 1 9 0 Enabled
102.33 3600 21.42 9.4 32.3 102.46 0 0 0 Disabled 102.21 1 9 0 Enabled
102.71 3040 17.17 8.2 39.8 102.83 0 0 0 Disabled 102.58 1 9 0 Disabled
103.08 2640 13.33 6.7 12.8 103.21 0 0 0 Disabled 102.96 1 9 0 Disabled
103.46 2560 12.89 6.7 40.5 103.58 0 0 0 Disabled 103.33 1 9 0 Disabled
103.85 2200 10.08 5.5 4.5 103.97 0 0 0 Disabled 103.71 1 9 0 Disabled
104.23 1960 21.78 9.8 38.3 104.35 0 0 0 Disabled 104.1 1 9 0 Disabled
104.6 2040 36.83 15.3 30 104.72 0 0 0 Disabled 104.47 1 9 0 Disabled
104.98 1640 33.06 16.5 26.3 105.1 0 0 0 Enabled 104.85 1 9 0 Enabled
105.35 1600 28.83 16.1 25.5 105.48 0 0 0 Enabled 105.23 1 9 0 Enabled
105.73 1600 24.06 14.1 27 105.85 0 0 0 Enabled 105.6 1 9 0 Enabled
106.1 1560 24.78 13.3 27.8 106.22 0 0 0 Enabled 105.98 1 9 0 Enabled
106.48 1600 24.81 13.3 27.8 106.6 0 0 0 Enabled 106.35 1 9 0 Enabled
106.85 1520 24.97 13.7 27 106.97 0 0 0 Enabled 106.72 1 9 0 Enabled
107.22 1560 31.53 17.6 26.3 107.35 0 0 0 Enabled 107.1 1 9 0 Enabled
107.6 1520 32.81 22.7 24 107.72 0 0 0 Enabled 107.47 1 9 0 Enabled
107.99 1520 39.03 47.5 15.8 108.11 0 0 0 Enabled 107.86 1 9 0 Enabled
108.36 1600 37.5 36.1 7.5 108.49 0 0 0 Enabled 108.24 1 9 0 Enabled
108.74 1560 32 22 12.8 108.86 0 0 0 Enabled 108.61 1 9 0 Enabled
109.11 1480 33.75 34.1 14.3 109.24 0 0 0 Enabled 108.99 1 9 0 Enabled
109.49 1680 42.39 70.2 6 109.61 0 0 0 Enabled 109.36 1 9 0 Enabled
109.87 1600 40.19 46.7 6.8 109.99 0 0 0 Enabled 109.74 1 9 0 Enabled
110.24 1560 39.75 36.9 8.3 110.37 0 0 0 Enabled 110.12 1 9 0 Enabled
110.62 1640 40.44 34.1 6.8 110.74 0 0 0 Enabled 110.49 1 9 0 Enabled
111 1600 42.08 36.5 11.3 111.13 0 0 0 Enabled 110.87 1 9 0 Enabled
111.38 1560 40.67 34.9 9.8 111.5 0 0 0 Enabled 111.25 1 9 0 Enabled
111.75 1560 40.67 34.1 9 111.88 0 0 0 Enabled 111.63 1 9 0 Enabled
112.13 1640 40.19 33.7 12 112.25 0 0 0 Enabled 112 1 9 0 Enabled
112.5 1560 40.39 33.7 11.3 112.63 0 0 0 Enabled 112.38 1 9 0 Enabled
112.88 1600 39.94 32.5 7.5 113.01 0 0 0 Enabled 112.75 1 9 0 Enabled
113.26 1520 39.11 33.3 12 113.38 0 0 0 Enabled 113.13 1 9 0 Enabled
113.63 1520 40.14 34.9 9.8 113.75 0 0 0 Enabled 113.5 1 9 0 Enabled
114.02 1520 39.58 33.3 12 114.14 0 0 0 Enabled 113.9 1 9 0 Enabled
114.4 1520 33.81 23.5 16.5 114.52 0 0 0 Enabled 114.27 1 9 0 Enabled
114.77 1520 32.83 23.5 20.3 114.9 0 0 0 Enabled 114.65 1 9 0 Enabled
115.15 1520 35.11 25.9 20.3 115.27 0 0 0 Enabled 115.02 1 9 0 Enabled
115.52 1520 33.19 24.7 12 115.65 0 0 0 Enabled 115.4 1 9 0 Enabled
115.9 1520 32.47 23.9 12.8 116.02 0 0 0 Enabled 115.77 1 9 0 Enabled
116.27 1560 4.06 1.6 17.3 116.4 0 0 0 Enabled 116.15 1 9 0 Enabled
116.64 1320 5.17 2.7 30.8 116.77 0 0 0 Enabled 116.52 1 9 0 Enabled
117.03 1400 7.03 3.9 34.5 117.14 0 0 0 Disabled 116.9 1 9 0 Disabled
117.4 1320 7.33 3.9 -4.5 117.52 0 0 0 Disabled 117.27 1 9 0 Disabled
117.77 1360 7.17 3.9 -3.8 117.91 0 0 0 Disabled 117.64 1 9 0 Disabled
118.16 1320 7.31 3.9 -4.5 118.29 0 0 0 Disabled 118.04 1 9 0 Disabled
118.54 1320 7.11 3.9 -4.5 118.66 0 0 0 Disabled 118.41 1 9 0 Disabled
118.91 1280 7 3.9 -3 119.04 0 0 0 Disabled 118.79 1 9 0 Disabled
119.29 1280 6.92 3.5 -3 119.41 0 0 0 Disabled 119.16 1 9 0 Disabled
119.66 1280 6.83 3.5 -3 119.79 0 0 0 Disabled 119.54 1 9 0 Disabled
120.05 1200 17.67 8.6 33 120.18 0 0 0 Disabled 119.92 1 9 0 Disabled
120.42 1280 17.53 8.6 24 120.55 0 0 0 Enabled 120.3 1 9 0 Enabled
120.8 1240 17.56 8.6 27 120.92 0 0 0 Enabled 120.68 1 9 0 Enabled
121.18 1240 21.75 10.2 26.3 121.3 0 0 0 Enabled 121.05 1 9 0 Enabled
121.55 1280 19.75 9.8 24.8 121.68 0 0 0 Enabled 121.43 1 9 0 Enabled
121.93 1280 16.31 8.6 25.5 122.05 0 0 0 Enabled 121.8 1 9 0 Enabled
122.3 1200 16.47 8.6 25.5 122.43 0 0 0 Enabled 122.18 1 9 0 Enabled
122.68 1200 12.92 7.1 25.5 122.8 0 0 0 Enabled 122.55 1 9 0 Enabled
123.07 1200 13.33 6.7 28.5 123.19 0 0 0 Enabled 122.94 1 9 0 Enabled
123.44 1200 7.58 3.9 28.5 123.57 0 0 0 Enabled 123.32 1 9 0 Enabled
123.82 1200 9.22 4.7 30.8 123.94 0 0 0 Enabled 123.69 0 0 0 Enabled
124.19 1160 8.61 4.3 32.3 124.31 0 0 0 Enabled 124.06 0 0 0 Enabled
124.57 1120 8.5 4.3 28.5 124.69 0 0 0 Enabled 124.44 0 0 0 Enabled
124.94 1160 6.22 3.5 30 125.07 0 0 0 Disabled 124.82 0 0 0 Disabled
125.32 1120 5.97 3.1 30.8 125.45 0 0 0 Disabled 125.19 0 0 0 Disabled
125.7 1160 5.86 3.1 32.3 125.82 0 0 0 Disabled 125.57 0 0 0 Disabled
126.09 1360 6.86 3.9 36.8 126.21 0 0 0 Disabled 125.96 0 0 0 Disabled
126.46 1360 7.06 3.9 35.3 126.59 0 0 0 Disabled 126.34 0 0 0 Disabled
126.83 1360 7.08 3.9 36.8 126.96 0 0 0 Disabled 126.71 0 0 0 Disabled
127.21 1320 7.03 3.9 -2.3 127.33 0 0 0 Disabled 127.08 0 0 0 Disabled
127.58 1280 7.06 3.9 0 127.71 0 0 0 Disabled 127.46 0 0 0 Disabled
127.97 1240 6.69 3.5 4.5 128.1 0 0 0 Disabled 127.83 0 0 0 Disabled
128.35 1200 6.64 3.5 18 128.47 0 0 0 Disabled 128.22 0 0 0 Disabled
128.72 1120 6.36 3.1 33 128.85 0 0 0 Disabled 128.6 0 0 0 Disabled
129.1 1080 6.03 3.1 33 129.22 0 0 0 Disabled 128.97 0 0 0 Disabled
129.47 1040 5.61 2.7 33.8 129.6 0 0 0 Disabled 129.35 0 0 0 Disabled
129.85 1080 5.39 2.7 33 129.98 0 0 0 Disabled 129.72 0 0 0 Disabled
130.23 1200 5.64 3.1 26.3 130.35 0 0 0 Disabled 130.1 0 0 0 Disabled
130.6 1160 6.11 3.5 34.5 130.73 0 0 0 Disabled 130.48 0 0 0 Disabled
130.97 1160 6.06 3.5 33.8 131.1 0 0 0 Disabled 130.85 0 0 0 Disabled
131.35 1200 5.86 3.5 34.5 131.47 0 0 0 Disabled 131.23 0 0 0 Disabled
131.73 1120 7.67 4.3 33 131.85 0 0 0 Disabled 131.6 0 0 0 Disabled
132.11 1480 7.86 4.3 35.3 132.24 0 0 0 Disabled 131.99 0 0 0 Disabled
132.49 2040 28 11.4 36 132.61 0 0 0 Disabled 132.36 0 0 0 Disabled
132.87 2000 18.89 8.6 37.5 132.99 0 0 0 Disabled 132.74 0 0 0 Disabled
133.24 1960 20.31 9.4 37.5 133.36 0 0 0 Disabled 133.11 0 0 0 Disabled
133.62 2040 45.64 20.4 26.3 133.74 0 0 0 Enabled 133.49 0 0 0 Disabled
133.99 2000 46.14 31.8 22.5 134.12 0 0 0 Enabled 133.86 0 0 0 Enabled
134.37 2000 43.22 29.4 18.8 134.49 0 0 0 Enabled 134.24 0 0 0 Enabled
134.74 2000 42.72 27.5 24 134.87 0 0 0 Enabled 134.62 0 0 0 Enabled
135.13 2040 43.31 30.2 21 135.26 0 0 0 Enabled 135 0 0 0 Enabled
135.5 2040 49.25 47.1 21.8 135.63 0 0 0 Enabled 135.38 0 0 0 Enabled
135.88 2120 46.97 38.8 20.3 136 0 0 0 Enabled 135.76 0 0 0 Enabled
136.26 2160 43.33 25.5 24 136.38 0 0 0 Enabled 136.13 0 0 0 Enabled
136.63 2120 45.72 27.5 24 136.75 0 0 0 Enabled 136.5 0 0 0 Enabled
137.02 2200 45.17 27.1 23.3 137.14 0 0 0 Enabled 136.88 0 0 0 Enabled
137.4 2160 45.47 25.9 24 137.52 0 0 0 Enabled 137.27 0 0 0 Enabled
137.77 2160 45.47 26.3 24 137.9 0 0 0 Enabled 137.65 0 0 0 Enabled
138.15 2200 46.72 27.1 24 138.27 0 0 0 Enabled 138.02 0 0 0 Enabled
138.52 2240 46.39 27.1 24.8 138.65 0 0 0 Enabled 138.4 0 0 0 Enabled
138.9 2240 46.78 27.8 24 139.02 0 0 0 Enabled 138.77 0 0 0 Enabled
139.27 2240 49.47 33.7 24.8 139.4 0 0 0 Enabled 139.15 0 0 0 Enabled
139.65 2320 50.89 37.3 24 139.77 0 0 0 Enabled 139.52 0 0 0 Enabled
140.02 2320 66.11 76.1 11.3 140.14 0 0 0 Enabled 139.9 0 0 0 Enabled
140.39 2400 64.28 94.1 11.3 140.52 0 0 0 Enabled 140.27 0 0 0 Enabled
140.81 2400 65.81 98 12 140.94 0 0 0 Enabled 140.65 0 0 0 Enabled
141.19 2440 67.33 99.6 20.3 141.32 0 0 0 Enabled 141.06 0 0 0 Enabled
141.57 2560 73 99.6 10.5 141.69 0 0 0 Enabled 141.44 0 0 0 Enabled
141.94 2560 75.14 99.6 6.8 142.06 0 0 0 Enabled 141.82 0 0 0 Enabled
142.32 2600 74.92 99.6 5.3 142.44 0 0 0 Enabled 142.19 0 0 0 Enabled
142.69 2640 78.56 99.6 6.8 142.82 0 0 0 Enabled 142.57 0 0 0 Enabled
143.07 2680 80.75 99.6 5.3 143.19 0 0 0 Enabled 142.95 0 0 0 Enabled
143.44 2680 81.42 99.6 5.3 143.57 0 0 0 Enabled 143.32 0 0 0 Enabled
143.82 2760 84.22 99.6 6.8 143.94 0 0 0 Enabled 143.69 0 0 0 Enabled
144.19 2800 82.92 99.6 5.3 144.32 0 0 0 Enabled 144.07 0 0 0 Enabled
144.57 2800 80.86 99.6 11.3 144.69 0 0 0 Enabled 144.44 0 0 0 Enabled
144.95 2840 80.5 99.6 12.8 145.07 0 0 0 Enabled 144.81 0 0 0 Enabled
145.31 2880 81.39 99.6 13.5 145.44 0 0 0 Enabled 145.19 0 0 0 Enabled
145.69 2880 81.56 99.6 14.3 145.81 0 0 0 Enabled 145.56 0 0 0 Enabled
146.06 3000 83.47 99.6 13.5 146.19 0 0 0 Enabled 145.94 0 0 0 Enabled
146.44 3000 85.33 99.6 13.5 146.56 0 0 0 Enabled 146.31 0 0 0 Enabled
146.81 3000 86.06 99.6 13.5 146.94 0 0 0 Enabled 146.68 0 0 0 Enabled
147.19 3040 87.28 99.6 23.3 147.32 0 0 0 Enabled 147.06 0 0 0 Enabled
147.57 3120 88.94 99.6 22.5 147.69 0 0 0 Enabled 147.44 0 0 0 Enabled
147.94 3160 89.22 99.6 15 148.07 0 0 0 Enabled 147.82 0 0 0 Enabled
148.32 2240 64.03 99.6 12.8 148.44 0 0 0 Enabled 148.19 0 0 0 Enabled
148.69 2200 56.33 99.6 11.3 148.81 0 0 0 Enabled 148.57 0 0 0 Enabled
149.06 2160 62.06 99.6 15.8 149.19 0 0 0 Enabled 148.94 0 0 0 Enabled
149.44 2120 58.56 99.6 15.8 149.57 0 0 0 Enabled 149.31 0 0 0 Enabled
149.82 2200 57.58 99.6 10.5 149.94 0 0 0 Enabled 149.69 0 0 0 Enabled
150.21 2200 60.14 99.6 10.5 150.34 0 0 0 Enabled 150.08 0 0 0 Enabled
150.58 2200 60.28 99.6 9 150.7 0 0 0 Enabled 150.46 0 0 0 Enabled
150.96 2160 61.94 99.6 9 151.09 0 0 0 Enabled 150.84 0 0 0 Enabled
151.33 2200 60.42 99.6 9 151.46 0 0 0 Enabled 151.21 0 0 0 Enabled
151.71 2200 60.42 99.6 8.3 151.83 0 0 0 Enabled 151.58 0 0 0 Enabled
152.08 2240 59.72 99.6 9 152.21 0 0 0 Enabled 151.96 0 0 0 Enabled
152.46 2240 60.89 99.6 11.3 152.58 0 0 0 Enabled 152.33 0 0 0 Enabled
152.83 2240 63.14 99.6 12 152.96 0 0 0 Enabled 152.71 0 0 0 Enabled
153.22 2240 61.17 99.6 18.8 153.35 0 0 0 Enabled 153.1 0 0 0 Enabled
153.6 2280 63.31 99.6 12.8 153.73 0 0 0 Enabled 153.47 0 0 0 Enabled
153.97 2280 62.25 99.6 13.5 154.1 0 0 0 Enabled 153.85 0 0 0 Enabled
154.35 2320 63.19 99.6 12.8 154.48 0 0 0 Enabled 154.22 0 0 0 Enabled
154.73 2280 67 99.6 16.5 154.85 0 0 0 Enabled 154.6 0 0 0 Enabled
155.1 2440 72.28 99.6 9.8 155.23 0 0 0 Enabled 154.98 0 0 0 Enabled
155.48 2480 71.78 99.6 9.8 155.6 0 0 0 Enabled 155.35 0 0 0 Enabled
155.85 3080 91.78 99.6 18 155.97 0 0 0 Enabled 155.72 0 0 0 Enabled
156.23 3680 122.44 99.6 9 156.35 0 0 0 Enabled 156.1 0 0 0 Enabled
156.6 3600 94.67 58.8 23.3 156.72 0 0 0 Enabled 156.47 0 0 0 Enabled
156.97 3640 109.69 88.6 12.8 157.11 0 0 0 Enabled 156.85 0 0 0 Enabled
157.37 3640 111.67 96.9 12.8 157.49 0 0 0 Enabled 157.24 0 0 0 Enabled
157.74 3680 112.44 99.2 17.3 157.86 0 0 0 Enabled 157.62 0 0 0 Enabled
158.12 2920 85.47 99.6 15.8 158.24 0 0 0 Enabled 157.99 0 0 0 Enabled
158.48 2440 68.94 99.6 12.8 158.61 0 0 0 Enabled 158.37 0 0 0 Enabled
158.87 2480 68.72 99.6 15 158.99 0 0 0 Enabled 158.74 0 0 0 Enabled
159.24 2440 67.81 99.6 21.8 159.37 0 0 0 Enabled 159.12 0 0 0 Enabled
159.62 2480 70.28 99.6 21.8 159.74 0 0 0 Enabled 159.49 0 0 0 Enabled
159.99 2520 69.86 99.6 22.5 160.13 0 0 0 Enabled 159.87 0 0 0 Enabled
160.38 1920 53.97 99.6 13.5 160.5 0 0 0 Enabled 160.25 0 0 0 Enabled
160.75 1920 53.36 99.6 12 160.88 0 0 0 Enabled 160.63 0 0 0 Enabled
161.13 1880 54.78 99.6 9.8 161.25 0 0 0 Enabled 161 0 0 0 Enabled
161.5 1880 55.11 99.6 9.8 161.63 0 0 0 Enabled 161.38 0 0 0 Enabled
161.88 1960 53.89 99.6 9.8 162 0 0 0 Enabled 161.75 0 0 0 Enabled
162.25 1880 55 99.6 9 162.37 0 0 0 Enabled 162.13 0 0 0 Enabled
162.63 1960 59 99.6 11.3 162.75 0 0 0 Enabled 162.5 0 0 0 Enabled
163 1960 55.5 99.6 3 163.14 0 0 0 Enabled 162.87 0 0 0 Enabled
163.39 2400 65.36 99.6 11.3 163.52 0 0 0 Enabled 163.26 0 0 0 Enabled
163.76 2600 79.36 99.6 5.3 163.89 0 0 0 Enabled 163.65 0 0 0 Enabled
164.15 2520 78.61 99.6 15 164.27 0 0 0 Enabled 164.02 0 0 0 Enabled
164.52 2520 78.28 99.6 16.5 164.64 0 0 0 Enabled 164.4 0 0 0 Enabled
164.9 2560 77.28 99.6 16.5 165.02 0 0 0 Enabled 164.77 0 0 0 Enabled
165.27 2640 78.03 99.6 7.5 165.39 0 0 0 Enabled 165.15 0 0 0 Enabled
165.65 2600 78.11 99.6 6 165.77 0 0 0 Enabled 165.52 0 0 0 Enabled
166.02 2640 78.86 99.6 5.3 166.16 0 0 0 Enabled 165.9 0 0 0 Enabled
166.42 2640 79.89 99.6 6 166.53 0 0 0 Enabled 166.29 0 0 0 Enabled
166.79 2600 80.5 99.6 3.8 166.91 0 0 0 Enabled 166.66 0 0 0 Enabled
167.16 2640 81.11 99.6 15 167.29 0 0 0 Enabled 167.03 0 0 0 Enabled
167.54 2680 84.39 99.6 4.5 167.66 0 0 0 Enabled 167.41 0 0 0 Enabled
167.91 3000 91.42 99.6 5.3 168.04 0 0 0 Enabled 167.79 0 0 0 Enabled
168.29 3760 119.86 99.6 15.8 168.41 0 0 0 Enabled 168.16 0 0 0 Enabled
168.66 4040 133.19 99.6 14.3 168.78 0 0 1 Enabled 168.53 0 0 0 Enabled
169.04 4080 132.36 99.6 11.3 169.18 0 0 1 Enabled 168.91 0 0 0 Enabled
169.43 4080 133.36 99.6 12.8 169.55 0 0 1 Enabled 169.3 0 0 0 Enabled
169.8 4120 134.56 99.6 15 169.93 0 0 1 Enabled 169.68 0 0 0 Enabled
170.18 4200 135.89 99.6 14.3 170.3 0 0 1 Enabled 170.05 0 0 0 Enabled
170.56 4200 137.81 99.6 14.3 170.68 0 0 1 Enabled 170.43 0 0 0 Enabled
170.93 4240 139.19 99.6 14.3 171.05 0 0 1 Enabled 170.8 0 0 0 Enabled
171.3 3440 112.53 99.6 14.3 171.43 0 0 1 Disabled 171.18 0 0 0 Enabled
171.68 2840 85.08 99.6 15 171.8 0 0 1 Enabled 171.55 0 0 0 Disabled
172.05 2840 90.28 99.6 7.5 172.2 0 0 1 Enabled 171.92 0 0 0 Enabled
172.45 2800 92.94 99.6 4.5 172.57 0 0 1 Enabled 172.32 0 0 0 Enabled
172.82 2840 93.81 99.6 3.8 172.94 0 0 1 Enabled 172.7 0 0 0 Enabled
173.19 2880 94.83 99.6 3 173.32 0 0 1 Enabled 173.07 0 0 0 Enabled
173.57 2880 94.97 99.6 2.3 173.69 0 0 1 Enabled 173.44 0 0 0 Enabled
173.94 2880 95.31 99.6 3.8 174.07 0 0 1 Enabled 173.82 0 0 0 Enabled
174.32 2880 96.47 99.6 4.5 174.44 0 0 1 Enabled 174.19 0 0 0 Enabled
174.69 2880 96.64 99.6 4.5 174.82 0 0 1 Enabled 174.57 0 0 0 Enabled
175.07 2920 97.33 99.6 7.5 175.19 0 0 1 Enabled 174.94 0 0 0 Enabled
175.44 2920 97.89 99.6 6.8 175.57 0 0 1 Enabled 175.31 0 0 0 Enabled
175.82 2920 98.31 99.6 6.8 175.94 0 0 1 Enabled 175.69 0 0 0 Enabled
176.21 2960 98.94 99.6 6.8 176.33 0 0 1 Enabled 176.07 0 0 0 Enabled
176.58 3000 99.22 99.6 5.3 176.71 0 0 1 Enabled 176.46 0 0 0 Enabled
176.96 2960 99.92 99.6 6 177.08 0 0 1 Enabled 176.83 0 0 0 Enabled
177.34 2960 101 99.6 6.8 177.46 0 0 1 Enabled 177.21 0 0 0 Enabled
177.71 3000 101.44 99.6 6.8 177.83 0 0 1 Enabled 177.59 0 0 0 Enabled
178.08 3040 101.83 99.6 7.5 178.22 0 0 0 Enabled 177.96 0 0 0 Enabled
178.47 3040 102.67 99.6 7.5 178.6 0 0 0 Enabled 178.35 0 0 0 Enabled
178.85 3040 102.53 99.6 4.5 178.97 0 0 0 Enabled 178.72 0 0 0 Enabled
179.22 3040 102.78 99.6 11.3 179.35 0 0 0 Enabled 179.1 0 0 0 Enabled
179.6 3080 102.22 99.6 12 179.72 0 0 0 Enabled 179.47 0 0 0 Enabled
179.97 3080 101.75 99.6 5.3 180.1 0 0 0 Enabled 179.85 0 0 0 Enabled
180.35 3120 101.97 99.6 6.8 180.47 0 0 0 Enabled 180.22 0 0 0 Enabled
180.72 3080 102.22 99.6 12.8 180.85 0 0 0 Enabled 180.6 0 0 0 Enabled
181.1 3120 102.61 99.6 12.8 181.24 0 0 0 Enabled 180.98 0 0 0 Enabled
181.49 3080 104.39 99.6 12 181.62 0 0 0 Enabled 181.37 0 0 0 Enabled
181.87 3120 105.08 99.6 12 181.99 0 0 0 Enabled 181.74 0 0 0 Enabled
182.24 3160 104.28 99.6 12.8 182.36 0 0 0 Enabled 182.12 0 0 0 Enabled
182.61 3200 105.58 99.6 6.8 182.74 0 0 0 Enabled 182.49 0 0 0 Enabled
182.99 3160 106.61 99.6 12.8 183.12 0 0 0 Enabled 182.86 0 0 0 Enabled
183.37 3200 107.06 99.6 12 183.49 0 0 0 Enabled 183.24 0 0 0 Enabled
183.74 3200 107.17 99.6 12.8 183.86 0 0 0 Enabled 183.62 0 0 0 Enabled
184.11 3200 107.33 99.6 12.8 184.25 0 0 0 Enabled 183.99 0 0 0 Enabled
184.5 3280 108.53 99.6 8.3 184.63 0 0 0 Enabled 184.38 0 0 0 Enabled
184.88 3280 108.36 99.6 8.3 185 0 0 0 Enabled 184.76 0 0 0 Enabled
185.26 3280 108.58 99.6 8.3 185.38 0 0 0 Enabled 185.13 0 0 0 Enabled
185.63 3280 109.28 99.6 9 185.76 0 0 0 Enabled 185.51 0 0 0 Enabled
186.01 3320 108.81 99.6 9.8 186.13 0 0 0 Enabled 185.88 0 0 0 Enabled
186.38 2880 99 99.6 6 186.5 0 0 0 Enabled 186.26 0 0 0 Enabled
186.75 2440 76.67 99.6 6 186.88 0 0 0 Enabled 186.63 0 0 0 Enabled
187.13 2480 74.86 99.6 8.3 187.27 0 0 0 Enabled 187.01 0 0 0 Enabled
187.52 2520 72.31 99.6 9 187.65 0 0 0 Enabled 187.4 0 0 0 Enabled
187.9 2480 73.92 99.6 6 188.02 0 0 0 Enabled 187.77 0 0 0 Enabled
188.27 2480 75.64 99.6 6 188.39 0 0 0 Enabled 188.14 0 0 0 Enabled
188.65 2520 74.61 99.6 6.8 188.77 0 0 0 Enabled 188.52 0 0 0 Enabled
189.02 2520 75.31 99.6 6.8 189.15 0 0 0 Enabled 188.9 0 0 0 Enabled
189.4 2560 76.75 99.6 6.8 189.52 0 0 0 Enabled 189.27 0 0 0 Enabled
189.77 2560 75.39 99.6 7.5 189.9 0 0 0 Enabled 189.65 0 0 0 Enabled
190.15 2560 75.47 99.6 8.3 190.29 0 0 0 Enabled 190.02 0 0 0 Enabled
190.54 2600 76.5 99.6 9 190.66 0 0 0 Enabled 190.41 0 0 0 Enabled
190.91 2600 79.14 99.6 7.5 191.04 0 0 0 Enabled 190.79 0 0 0 Enabled
191.29 2600 77.36 99.6 5.3 191.41 0 0 0 Enabled 191.16 0 0 0 Enabled
191.66 2600 78 99.6 18 191.78 0 0 0 Enabled 191.54 0 0 0 Enabled
192.04 2560 78.92 99.6 16.5 192.16 0 0 0 Enabled 191.91 0 0 0 Enabled
192.41 2600 79.44 99.6 4.5 192.53 0 0 0 Enabled 192.29 0 0 0 Enabled
192.78 2600 80.25 99.6 3.8 192.92 0 0 0 Enabled 192.66 0 0 0 Enabled
193.17 2640 81.61 99.6 15 193.29 0 0 0 Enabled 193.04 0 0 0 Enabled
193.54 2680 81.31 99.6 5.3 193.67 0 0 0 Enabled 193.41 0 0 0 Enabled
193.91 2640 82.11 99.6 6 194.04 0 0 0 Enabled 193.79 0 0 0 Enabled
194.3 2680 82.97 99.6 3.8 194.43 0 0 0 Enabled 194.16 0 0 0 Enabled
194.68 2680 84.33 99.6 15.8 194.8 0 0 0 Enabled 194.55 0 0 0 Enabled
195.06 2680 84.5 99.6 4.5 195.18 0 0 0 Enabled 194.93 0 0 0 Enabled
195.43 2760 84.47 99.6 6.8 195.55 0 0 0 Enabled 195.3 0 0 0 Enabled
195.8 2760 84.89 99.6 5.3 195.93 0 0 0 Enabled 195.68 0 0 0 Enabled
196.18 2760 85.92 99.6 5.3 196.32 0 0 0 Enabled 196.05 0 0 0 Enabled
196.57 2760 87.19 99.6 4.5 196.69 0 0 0 Enabled 196.44 0 0 0 Enabled
196.94 2800 86.5 99.6 1.5 197.07 0 0 0 Enabled 196.82 0 0 0 Enabled
197.32 2800 87.5 99.6 10.5 197.44 0 0 0 Enabled 197.19 0 0 0 Enabled
197.7 2840 88 99.6 0 197.82 0 0 0 Enabled 197.57 0 0 0 Enabled
198.07 2800 89.08 99.6 0 198.19 0 0 0 Enabled 197.95 0 0 0 Enabled
198.45 2800 89.42 99.6 0.8 198.57 0 0 0 Enabled 198.32 0 0 0 Enabled
198.82 2840 90.31 99.6 0 198.94 0 0 0 Enabled 198.69 0 0 0 Enabled
199.19 2800 89.97 99.6 8.3 199.32 0 0 0 Enabled 199.07 0 0 0 Enabled
199.57 2840 91.06 99.6 9 199.69 0 0 0 Enabled 199.44 0 0 0 Enabled
199.94 2840 91.39 99.6 9 200.06 0 0 0 Enabled 199.82 0 0 0 Enabled
200.34 2200 62.69 99.6 3 200.46 0 0 0 Enabled 200.19 0 0 0 Enabled
200.71 2200 64.78 99.6 3.8 200.83 0 0 0 Enabled 200.58 0 0 0 Enabled
201.08 2160 64.17 99.6 10.5 201.21 0 0 0 Enabled 200.95 0 0 0 Enabled
201.46 2200 62.75 99.6 11.3 201.58 0 0 0 Enabled 201.33 0 0 0 Enabled
201.84 2200 64.81 99.6 9.8 201.96 0 0 0 Enabled 201.71 0 0 0 Enabled
202.21 2240 64.28 99.6 8.3 202.33 0 0 0 Enabled 202.09 0 0 0 Enabled
202.58 2160 61.94 99.6 5.3 202.71 0 0 0 Enabled 202.46 0 0 0 Enabled
202.96 2240 63.75 99.6 5.3 203.08 0 0 0 Enabled 202.83 0 0 0 Enabled
203.35 2200 64.94 99.6 10.5 203.47 0 0 0 Enabled 203.21 0 0 0 Enabled
203.72 2240 64.61 99.6 10.5 203.84 0 0 0 Enabled 203.6 0 0 0 Enabled
204.1 2200 63.67 99.6 10.5 204.22 0 0 0 Enabled 203.97 0 0 0 Enabled
204.47 2200 64.92 99.6 11.3 204.6 0 0 0 Enabled 204.35 0 0 0 Enabled
204.85 2280 62.72 99.6 10.5 204.97 0 0 0 Enabled 204.72 0 0 0 Enabled
205.22 2280 63.42 99.6 9.8 205.35 0 0 0 Enabled 205.1 0 0 0 Enabled
205.6 2360 63.44 99.6 10.5 205.72 0 0 0 Enabled 205.47 0 0 0 Enabled
205.98 2360 65.19 99.6 12 206.1 0 0 0 Enabled 205.85 0 0 0 Enabled
206.37 2320 67.08 99.6 12.8 206.49 0 0 0 Enabled 206.23 0 0 0 Enabled
206.74 2360 65.69 99.6 17.3 206.87 0 0 0 Enabled 206.62 0 0 0 Enabled
207.12 2560 68.08 99.6 15.8 207.24 0 0 0 Enabled 206.99 0 0 0 Enabled
207.49 3120 85.58 99.6 15.8 207.61 0 0 0 Enabled 207.36 0 0 0 Enabled
207.86 3120 89.06 99.6 12.8 207.99 0 0 0 Enabled 207.74 0 0 0 Enabled
208.24 3040 89.75 99.6 18.8 208.36 0 0 0 Enabled 208.11 0 0 0 Enabled
208.62 3040 88.94 99.6 14.3 208.74 0 0 0 Enabled 208.49 0 0 0 Enabled
208.99 3080 88 99.6 15.8 209.11 0 0 0 Enabled 208.86 0 0 0 Enabled
209.38 3080 89.89 99.6 15.8 209.51 0 0 0 Enabled 209.24 0 0 0 Enabled
209.76 3040 90.56 99.6 17.3 209.88 0 0 0 Enabled 209.63 0 0 0 Enabled
210.13 3120 91.06 99.6 12 210.25 0 0 0 Enabled 210.01 0 0 0 Enabled
210.51 3080 91.06 99.6 12 210.63 0 0 0 Enabled 210.38 0 0 0 Enabled
210.88 3120 91.78 99.6 12 211.01 0 0 0 Enabled 210.76 0 0 0 Enabled
211.26 3160 92.19 99.6 12 211.38 0 0 0 Enabled 211.13 0 0 0 Enabled
211.63 3120 91.86 99.6 18 211.75 0 0 0 Enabled 211.51 0 0 0 Enabled
212 3160 92.28 99.6 12.8 212.13 0 0 0 Enabled 211.88 0 0 0 Enabled
212.39 3120 93.61 99.6 16.5 212.52 0 0 0 Enabled 212.25 0 0 0 Enabled
212.77 3200 93.97 99.6 12 212.9 0 0 0 Enabled 212.65 0 0 0 Enabled
213.14 3160 94 99.6 16.5 213.27 0 0 0 Enabled 213.02 0 0 0 Enabled
213.52 3160 94.75 99.6 16.5 213.64 0 0 0 Enabled 213.4 0 0 0 Enabled
213.9 3160 95.81 99.6 15.8 214.02 0 0 0 Enabled 213.77 0 0 0 Enabled
214.27 3160 95.44 99.6 15.8 214.4 0 0 0 Enabled 214.15 0 0 0 Enabled
214.65 3160 95.22 99.6 16.5 214.77 0 0 0 Enabled 214.52 0 0 0 Enabled
215.02 3200 95.67 99.6 15.8 215.15 0 0 0 Enabled 214.9 0 0 0 Enabled
215.4 3160 96.17 99.6 15.8 215.52 0 0 0 Enabled 215.27 0 0 0 Enabled
215.77 3160 96.22 99.6 15.8 215.89 0 0 0 Enabled 215.65 0 0 0 Enabled
216.15 3200 96.56 99.6 15.8 216.27 0 0 0 Enabled 216.02 0 0 0 Enabled
216.54 3200 97.28 99.6 12 216.66 0 0 0 Enabled 216.41 0 0 0 Enabled
216.91 3160 96.47 99.6 12 217.03 0 0 0 Enabled 216.78 0 0 0 Enabled
217.29 3200 96.72 99.6 12.8 217.41 0 0 0 Enabled 217.16 0 0 0 Enabled
217.66 3200 96.92 99.6 13.5 217.79 0 0 0 Enabled 217.54 0 0 0 Enabled
218.04 3200 97.56 99.6 12.8 218.16 0 0 0 Enabled 217.9 0 0 0 Enabled
218.42 3200 97.61 99.6 15 218.55 0 0 0 Enabled 218.29 0 0 0 Enabled
218.8 3160 97.33 99.6 15 218.92 0 0 0 Enabled 218.68 0 0 0 Enabled
219.18 3200 97.56 99.6 15 219.3 0 0 0 Enabled 219.06 0 0 0 Enabled
219.55 3160 97.42 99.6 15 219.67 0 0 0 Enabled 219.43 0 0 0 Enabled
219.92 3200 97.28 99.6 10.5 220.05 0 0 0 Enabled 219.8 0 0 0 Enabled
220.3 3200 96.44 99.6 15 220.43 0 0 0 Enabled 220.18 0 0 0 Enabled
220.67 3200 96.19 99.6 15.8 220.8 0 0 0 Enabled 220.55 0 0 0 Enabled
221.05 3160 96.44 99.6 15.8 221.18 0 0 0 Enabled 220.93 0 0 0 Enabled
221.44 3200 96.44 99.6 10.5 221.57 0 0 0 Enabled 221.3 0 0 0 Enabled
221.82 3200 96.28 99.6 12 221.95 0 0 0 Enabled 221.69 0 0 0 Enabled
222.2 3160 97 99.6 11.3 222.32 0 0 0 Enabled 222.07 0 0 0 Enabled
222.57 3160 95.92 99.6 12 222.69 0 0 0 Enabled 222.45 0 0 0 Enabled
222.95 3160 95.72 99.6 12 223.07 0 0 0 Enabled 222.82 0 0 0 Enabled
223.32 3200 95.64 99.6 12 223.44 0 0 0 Enabled 223.19 0 0 0 Enabled
223.69 3160 95.61 99.6 12.8 223.82 0 0 0 Enabled 223.57 0 0 0 Enabled
224.07 3160 95.39 99.6 13.5 224.19 0 0 0 Enabled 223.94 0 0 0 Enabled
224.46 3160 95.67 99.6 15.8 224.58 0 0 0 Enabled 224.32 0 0 0 Enabled
224.83 3200 95.75 99.6 12.8 224.96 0 0 0 Enabled 224.71 0 0 0 Enabled
225.21 3160 96.08 99.6 15.8 225.33 0 0 0 Enabled 225.08 0 0 0 Enabled
225.58 3200 95.25 99.6 12.8 225.71 0 0 0 Enabled 225.46 0 0 0 Enabled
225.96 3200 95.86 99.6 13.5 226.08 0 0 0 Enabled 225.83 0 0 0 Enabled
226.34 3200 96.31 99.6 12.8 226.46 0 0 0 Enabled 226.21 0 0 0 Enabled
226.71 3200 96.19 99.6 12.8 226.84 0 0 0 Enabled 226.59 0 0 0 Enabled
227.09 3200 96.33 99.6 12.8 227.21 0 0 0 Enabled 226.96 0 0 0 Enabled
227.47 3160 96.64 99.6 15 227.6 0 0 0 Enabled 227.33 0 0 0 Enabled
227.85 3160 96.72 99.6 15 227.97 0 0 0 Enabled 227.72 0 0 0 Enabled
228.23 3160 96.89 99.2 15 228.35 0 0 0 Enabled 228.1 0 0 0 Enabled
228.6 3160 95.19 67.8 15.8 228.72 0 0 0 Enabled 228.47 0 0 0 Enabled
228.97 3160 50.33 18.8 24.8 229.1 0 0 0 Enabled 228.85 0 0 0 Enabled
229.35 3160 52.61 18 25.5 229.47 0 0 0 Enabled 229.22 0 0 0 Enabled
229.73 3160 52.17 18.4 25.5 229.85 0 0 0 Enabled 229.6 0 0 0 Enabled
230.1 3080 18.53 8.2 34.5 230.22 0 0 0 Enabled 229.97 0 0 0 Enabled
230.49 3120 59.42 18.8 34.5 230.62 0 0 0 Enabled 230.35 0 0 0 Enabled
230.86 3120 88.72 42.7 21.8 230.99 0 0 0 Enabled 230.74 0 0 0 Enabled
231.23 3120 92.14 52.9 16.5 231.36 0 0 0 Enabled 231.11 0 0 0 Enabled
231.61 3120 91.58 53.7 15.8 231.74 0 0 0 Enabled 231.49 0 0 0 Enabled
231.99 3080 92 54.5 15.8 232.11 0 0 0 Enabled 231.86 0 0 0 Enabled
232.36 3120 91.53 51.4 15.8 232.49 0 0 0 Enabled 232.24 0 0 0 Enabled
232.74 3080 90.31 46.7 16.5 232.86 0 0 0 Enabled 232.61 0 0 0 Enabled
233.11 3120 88.97 43.9 17.3 233.24 0 0 0 Enabled 232.99 0 0 0 Enabled
233.49 3080 91.67 69 15 233.62 0 0 0 Enabled 233.36 0 0 0 Enabled
233.86 3080 94.25 91.4 12.8 233.99 0 0 0 Enabled 233.74 0 0 0 Enabled
234.24 3120 93 97.6 12.8 234.36 0 0 0 Enabled 234.11 0 0 0 Enabled
234.63 3080 93.31 99.2 15.8 234.75 0 0 0 Enabled 234.51 0 0 0 Enabled
235.01 3080 93.44 99.6 15.8 235.13 0 0 0 Enabled 234.88 0 0 0 Enabled
235.38 3080 94.14 99.6 13.5 235.51 0 0 0 Enabled 235.26 0 0 0 Enabled
235.76 3160 94.25 99.6 13.5 235.88 0 0 0 Enabled 235.63 0 0 0 Enabled
236.13 3080 94.94 99.6 15.8 236.25 0 0 0 Enabled 236.01 0 0 0 Enabled
236.52 3120 95.08 99.6 12.8 236.65 0 0 0 Enabled 236.38 0 0 0 Enabled
236.9 3120 95 99.6 15 237.02 0 0 0 Enabled 236.77 0 0 0 Enabled
237.27 3120 95.56 99.6 15 237.4 0 0 0 Enabled 237.14 0 0 0 Enabled
237.65 3160 95.92 99.6 13.5 237.77 0 0 0 Enabled 237.52 0 0 0 Enabled
238.03 3120 95.83 99.6 15 238.15 0 0 0 Enabled 237.9 0 0 0 Enabled
238.4 3120 96.72 99.6 12.8 238.52 0 0 0 Enabled 238.27 0 0 0 Enabled
238.77 3160 97.92 99.6 13.5 238.89 0 0 0 Enabled 238.64 0 0 0 Enabled
239.15 3160 97.39 99.6 14.3 239.27 0 0 0 Enabled 239.02 0 0 0 Enabled
239.54 3160 97.08 99.6 15 239.66 0 0 0 Enabled 239.4 0 0 0 Enabled
239.91 3200 96.97 99.6 11.3 240.04 0 0 0 Enabled 239.79 0 0 0 Enabled
240.29 3160 96.97 99.6 18.8 240.41 0 0 0 Enabled 240.16 0 0 0 Enabled
240.66 3200 96.56 99.6 15.8 240.78 0 0 0 Enabled 240.53 0 0 0 Enabled
241.03 3200 95.11 99.6 13.5 241.16 0 0 0 Enabled 240.91 0 0 0 Enabled
241.41 3200 94.78 99.6 20.3 241.53 0 0 0 Enabled 241.28 0 0 0 Enabled
241.78 3240 94.44 99.6 13.5 241.91 0 0 0 Enabled 241.66 0 0 0 Enabled
242.16 3200 95.19 99.6 20.3 242.28 0 0 0 Enabled 242.03 0 0 0 Enabled
242.53 3200 96.39 99.6 20.3 242.66 0 0 0 Enabled 242.41 0 0 0 Enabled
242.91 3200 95.72 99.6 20.3 243.03 0 0 0 Enabled 242.78 0 0 0 Enabled
243.29 3240 95.89 99.6 14.3 243.41 0 0 0 Enabled 243.16 0 0 0 Enabled
243.68 3240 96.31 99.6 14.3 243.8 0 0 0 Enabled 243.55 0 0 0 Enabled
244.05 3240 96.58 99.6 14.3 244.18 0 0 0 Enabled 243.93 0 0 0 Enabled
244.43 3200 96.47 99.6 20.3 244.55 0 0 0 Enabled 244.3 0 0 0 Enabled
244.8 3200 96.14 99.6 20.3 244.93 0 0 0 Enabled 244.68 0 0 0 Enabled
245.18 3240 97.14 99.6 15 245.3 0 0 0 Enabled 245.05 0 0 0 Enabled
245.57 3240 96.97 99.6 15 245.69 0 0 0 Enabled 245.42 0 0 0 Enabled
245.94 3240 97.03 99.6 20.3 246.07 0 0 0 Enabled 245.82 0 0 0 Enabled
246.32 3280 97.14 99.6 15 246.45 0 0 0 Enabled 246.19 0 0 0 Enabled
246.69 3240 97.69 99.6 15 246.82 0 0 0 Enabled 246.57 0 0 0 Enabled
247.07 3280 98.33 99.6 15 247.19 0 0 0 Enabled 246.94 0 0 0 Enabled
247.45 3240 97.89 99.6 19.5 247.56 0 0 0 Enabled 247.32 0 0 0 Enabled
247.82 3280 99.22 99.6 15 247.94 0 0 0 Enabled 247.69 0 0 0 Enabled
248.19 3280 100.11 99.6 14.3 248.32 0 0 0 Enabled 248.07 0 0 0 Enabled
248.58 3320 100.69 99.6 14.3 248.71 0 0 0 Enabled 248.45 0 0 0 Enabled
248.96 3320 99.69 99.6 15 249.09 0 0 0 Enabled 248.83 0 0 0 Enabled
249.33 3280 100.25 99.6 18.8 249.46 0 0 0 Enabled 249.21 0 0 0 Enabled
249.71 3280 101.17 99.6 18.8 249.83 0 0 0 Enabled 249.59 0 0 0 Enabled
250.09 3280 99.11 99.6 12.8 250.21 0 0 0 Enabled 249.96 0 0 0 Enabled
250.46 3280 100.08 95.3 18.8 250.59 0 0 0 Enabled 250.34 0 0 0 Enabled
250.84 3320 82.03 35.3 19.5 250.96 0 0 0 Enabled 250.71 0 0 0 Enabled
251.21 3320 82.58 36.5 20.3 251.34 0 0 0 Enabled 251.09 0 0 0 Enabled
251.6 3280 84.14 36.5 20.3 251.73 0 0 0 Enabled 251.46 0 0 0 Enabled
251.97 3320 84.53 36.5 16.5 252.1 0 0 0 Enabled 251.85 0 0 0 Enabled
252.35 3320 85.39 36.9 17.3 252.47 0 0 0 Enabled 252.22 0 0 0 Enabled
252.72 3320 85.86 36.9 16.5 252.85 0 0 0 Enabled 252.6 0 0 0 Enabled
253.1 3400 87.56 37.3 17.3 253.22 0 0 0 Enabled 252.97 0 0 0 Enabled
253.47 4440 117.08 35.3 20.3 253.6 0 0 0 Disabled 253.35 0 0 0 Enabled
253.85 4360 115.75 35.3 20.3 253.97 0 0 0 Enabled 253.72 0 0 0 Disabled
254.23 3280 82.14 36.1 24.8 254.35 0 0 0 Enabled 254.1 0 0 0 Enabled
254.61 3320 95.06 43.1 21.8 254.74 0 0 0 Enabled 254.47 0 0 0 Enabled
254.99 3360 100.39 64.7 15.8 255.12 0 0 0 Enabled 254.86 0 0 0 Enabled
255.37 3320 100.25 88.6 13.5 255.49 0 0 0 Enabled 255.24 0 0 0 Enabled
255.74 3240 99.14 96.1 19.5 255.87 0 0 0 Enabled 255.62 0 0 0 Enabled
256.11 2560 75.39 83.9 12.8 256.24 0 0 0 Enabled 255.99 0 0 0 Enabled
256.49 2520 74.36 80 11.3 256.61 0 0 0 Enabled 256.37 0 0 0 Enabled
256.86 2480 73.92 92.9 19.5 256.99 0 0 0 Enabled 256.74 0 0 0 Enabled
257.24 2480 73.39 98 19.5 257.36 0 0 0 Enabled 257.12 0 0 0 Enabled
257.63 2520 72.58 99.2 11.3 257.75 0 0 0 Enabled 257.49 0 0 0 Enabled
258.01 2480 73.11 99.6 20.3 258.13 0 0 0 Enabled 257.88 0 0 0 Enabled
258.38 2520 70.83 99.6 9.8 258.5 0 0 0 Enabled 258.25 0 0 0 Enabled
258.76 2520 73.08 99.6 9 258.88 0 0 0 Enabled 258.63 0 0 0 Enabled
259.13 2480 71.14 99.6 9 259.26 0 0 0 Enabled 259 0 0 0 Enabled
259.51 2480 70.89 90.6 7.5 259.63 0 0 0 Enabled 259.38 0 0 0 Enabled
259.88 2520 73.78 74.1 9 260.01 0 0 0 Enabled 259.76 0 0 0 Enabled
260.25 2440 73.92 59.2 19.5 260.38 0 0 0 Enabled 260.13 0 0 0 Enabled
260.65 2480 71.39 49.4 7.5 260.77 0 0 0 Enabled 260.51 0 0 0 Enabled
261.02 2480 70.42 45.9 18 261.15 0 0 0 Enabled 260.9 0 0 0 Enabled
261.4 2480 66.69 38.8 21 261.52 0 0 0 Enabled 261.27 0 0 0 Enabled
261.77 2480 62.14 33.3 13.5 261.9 0 0 0 Enabled 261.65 0 0 0 Enabled
262.14 2440 69.08 48.2 9.8 262.27 0 0 0 Enabled 262.02 0 0 0 Enabled
262.53 2480 71.11 45.1 9 262.65 0 0 0 Enabled 262.4 0 0 0 Enabled
262.9 2520 70.06 42.4 9.8 263.02 0 0 0 Enabled 262.77 0 0 0 Enabled
263.27 2480 69.61 40.8 18 263.4 0 0 0 Enabled 263.15 0 0 0 Enabled
263.66 2440 69 39.2 19.5 263.79 0 0 0 Enabled 263.52 0 0 0 Enabled
264.04 2480 67.83 35.7 19.5 264.16 0 0 0 Enabled 263.91 0 0 0 Enabled
264.41 2480 53.14 25.9 15.8 264.54 0 0 0 Enabled 264.29 0 0 0 Enabled
264.79 2440 50.75 22.7 17.3 264.91 0 0 0 Enabled 264.66 0 0 0 Enabled
265.16 2480 50.5 22 18 265.28 0 0 0 Enabled 265.04 0 0 0 Enabled
265.54 2440 24.92 11 27 265.66 0 0 0 Enabled 265.41 0 0 0 Enabled
265.91 2440 10.97 5.5 36.8 266.04 0 0 0 Disabled 265.79 0 0 0 Enabled
266.28 2440 11.94 5.9 4.5 266.41 0 0 0 Disabled 266.16 0 0 0 Disabled
266.68 2400 12.11 5.9 4.5 266.8 0 0 0 Disabled 266.53 0 0 0 Disabled
267.05 2360 12.06 5.9 4.5 267.18 0 0 0 Disabled 266.93 0 0 0 Disabled
267.43 2360 11.67 5.9 4.5 267.55 0 0 0 Disabled 267.3 0 0 0 Disabled
267.8 2320 11.58 5.5 5.3 267.93 0 0 0 Disabled 267.68 0 0 0 Disabled
268.18 2280 11.36 5.5 5.3 268.3 0 0 0 Disabled 268.05 0 0 0 Disabled
268.55 2280 11.44 5.5 4.5 268.68 0 0 0 Disabled 268.43 0 0 0 Disabled
268.93 2240 11.17 5.5 4.5 269.05 0 0 0 Disabled 268.8 0 0 0 Disabled
269.3 2240 10.97 5.5 4.5 269.42 0 0 0 Disabled 269.18 0 0 0 Disabled
269.69 2360 12.97 6.7 39.8 269.82 0 0 0 Disabled 269.55 0 0 0 Disabled
270.07 2800 14.61 6.7 40.5 270.19 0 0 0 Disabled 269.94 0 0 0 Disabled
270.44 2800 14.28 7.1 15.8 270.57 0 0 0 Disabled 270.32 0 0 0 Disabled
270.82 2800 13.69 6.7 5.3 270.95 0 0 0 Disabled 270.69 0 0 0 Disabled
271.2 2760 13.36 6.7 4.5 271.32 0 0 0 Disabled 271.07 0 0 0 Disabled
271.56 2760 13.31 6.3 5.3 271.7 0 0 0 Disabled 271.45 0 0 0 Disabled
271.94 2720 13.31 6.3 4.5 272.07 0 0 0 Disabled 271.82 0 0 0 Disabled
272.32 2680 13.17 6.3 5.3 272.44 0 0 0 Disabled 272.19 0 0 0 Disabled
272.71 2640 13.11 6.3 6 272.83 0 0 0 Disabled 272.57 0 0 0 Disabled
273.08 2640 12.83 6.3 6.8 273.21 0 0 0 Disabled 272.96 0 0 0 Disabled
273.46 2600 12.64 6.3 6.8 273.58 0 0 0 Disabled 273.33 0 0 0 Disabled
273.83 2560 12.69 6.3 6 273.96 0 0 0 Disabled 273.71 0 0 0 Disabled
274.21 2520 12.72 6.3 6.8 274.33 0 0 0 Disabled 274.08 0 0 0 Disabled
274.58 2480 12.69 6.3 6 274.71 0 0 0 Disabled 274.46 0 0 0 Disabled
274.96 2480 12.5 5.9 5.3 275.08 0 0 0 Disabled 274.83 0 0 0 Disabled
275.33 2440 12.28 5.9 5.3 275.46 0 0 0 Disabled 275.21 0 0 0 Disabled
275.73 2360 11.94 5.5 6 275.85 0 0 0 Disabled 275.59 0 0 0 Disabled
276.1 2320 11.58 5.5 6 276.23 0 0 0 Disabled 275.98 0 0 0 Disabled
276.47 2320 11.33 5.5 6 276.6 0 0 0 Disabled 276.35 0 0 0 Disabled
276.85 2280 11.06 5.5 6 276.97 0 0 0 Disabled 276.73 0 0 0 Disabled
277.22 2200 10.83 5.5 6 277.35 0 0 0 Disabled 277.1 0 0 0 Disabled
277.6 2160 10.58 5.5 6 277.72 0 0 0 Disabled 277.47 0 0 0 Disabled
277.97 2120 10.44 5.1 6 278.1 0 0 0 Disabled 277.85 0 0 0 Disabled
278.35 2080 10.31 5.1 6 278.47 0 0 0 Disabled 278.22 0 0 0 Disabled
278.72 2040 10.17 5.1 6 278.85 0 0 0 Disabled 278.6 0 0 0 Disabled
279.1 2040 10.03 5.1 42 279.22 0 0 0 Disabled 278.97 0 0 0 Disabled
279.48 2000 9.97 5.1 42.8 279.6 0 0 0 Disabled 279.35 0 0 0 Disabled
279.87 1960 13.36 6.7 41.3 279.99 0 0 0 Enabled 279.74 0 0 0 Disabled
280.24 1960 27.5 11.8 31.5 280.37 0 0 0 Enabled 280.12 0 0 0 Enabled
280.62 2000 27.11 11.8 32.3 280.74 0 0 0 Enabled 280.49 0 0 0 Enabled
280.99 1960 38.36 15.7 27.8 281.11 0 0 0 Enabled 280.86 0 0 0 Enabled
281.36 2040 41.81 20.4 24.8 281.49 0 0 0 Enabled 281.24 0 0 0 Enabled
281.74 1960 41.53 21.2 24.8 281.86 0 0 0 Enabled 281.61 0 0 0 Enabled
282.11 1960 41.75 22 24 282.24 0 0 0 Enabled 281.99 0 0 0 Enabled
282.49 1960 40.5 21.2 24.8 282.61 0 0 0 Enabled 282.36 0 0 0 Enabled
282.88 1960 39.94 20.8 24.8 283 0 0 0 Enabled 282.75 0 0 0 Enabled
283.25 1920 39.25 19.6 24.8 283.38 0 0 0 Enabled 283.13 0 0 0 Enabled
283.63 1920 37.28 18 24.8 283.75 0 0 0 Enabled 283.5 0 0 0 Enabled
284.01 1920 36.44 17.3 26.3 284.13 0 0 0 Enabled 283.88 0 0 0 Enabled
284.38 1880 30.94 14.9 27 284.51 0 0 0 Enabled 284.26 0 0 0 Enabled
284.75 1880 30.78 14.5 27.8 284.88 0 0 0 Enabled 284.63 0 0 0 Enabled
285.13 1920 38.56 18.8 26.3 285.25 0 0 0 Enabled 285 0 0 0 Enabled
285.51 1880 42.58 24.7 23.3 285.63 0 0 0 Enabled 285.38 0 0 0 Enabled
285.9 1880 50.64 69.8 10.5 286.02 0 0 0 Enabled 285.77 0 0 0 Enabled
286.27 1880 53.28 54.5 9 286.4 0 0 0 Enabled 286.14 0 0 0 Enabled
286.64 1920 50.94 38.8 8.3 286.77 0 0 0 Enabled 286.52 0 0 0 Enabled
287.02 1920 48.11 33.3 9.8 287.15 0 0 0 Enabled 286.89 0 0 0 Enabled
287.4 1880 45.97 30.2 12 287.52 0 0 0 Enabled 287.27 0 0 0 Enabled
287.77 1920 47.56 29.4 14.3 287.9 0 0 0 Enabled 287.64 0 0 0 Enabled
288.15 1960 47.61 29.8 15.8 288.27 0 0 0 Enabled 288.02 0 0 0 Enabled
288.52 1960 50.56 33.7 15 288.65 0 0 0 Enabled 288.4 0 0 0 Enabled
288.91 2400 67.78 46.7 16.5 289.04 0 0 0 Enabled 288.79 0 0 0 Enabled
289.29 2600 74.64 82 15 289.41 0 0 0 Enabled 289.16 0 0 0 Enabled
289.66 2600 75.42 95.3 22.5 289.78 0 0 0 Enabled 289.54 0 0 0 Enabled
290.04 2520 74 99.2 21.8 290.16 0 0 0 Enabled 289.91 0 0 0 Enabled
290.41 2600 71.61 99.6 18 290.53 0 0 0 Enabled 290.29 0 0 0 Enabled
290.78 2600 74.86 99.6 18 290.91 0 0 0 Enabled 290.66 0 0 0 Enabled
291.17 2600 75.36 99.6 18.8 291.29 0 0 0 Enabled 291.04 0 0 0 Enabled
291.54 2600 75.89 99.6 15 291.67 0 0 0 Enabled 291.41 0 0 0 Enabled
291.93 2640 74.97 99.6 22.5 292.06 0 0 0 Enabled 291.8 0 0 0 Enabled
292.3 2640 76.97 99.6 15.8 292.43 0 0 0 Enabled 292.18 0 0 0 Enabled
292.68 2680 75.28 99.6 16.5 292.8 0 0 0 Enabled 292.55 0 0 0 Enabled
293.05 2640 78.08 99.6 22.5 293.18 0 0 0 Enabled 292.92 0 0 0 Enabled
293.43 2640 74.81 99.6 17.3 293.55 0 0 0 Enabled 293.3 0 0 0 Enabled
293.8 2680 76.53 99.6 23.3 293.93 0 0 0 Enabled 293.68 0 0 0 Enabled
294.18 2720 79.14 99.6 16.5 294.3 0 0 0 Enabled 294.05 0 0 0 Enabled
294.55 2680 78.22 99.6 22.5 294.68 0 0 0 Enabled 294.43 0 0 0 Enabled
294.94 2720 80.56 99.6 21.8 295.07 0 0 0 Enabled 294.82 0 0 0 Enabled
295.32 2720 81.56 99.6 16.5 295.44 0 0 0 Enabled 295.19 0 0 0 Enabled
295.69 2760 82.42 89.4 12.8 295.82 0 0 0 Enabled 295.57 0 0 0 Enabled
296.07 2760 66.89 29 24 296.19 0 0 0 Enabled 295.94 0 0 0 Enabled
296.44 2800 29.44 12.5 23.3 296.57 0 0 0 Enabled 296.32 0 0 0 Enabled
296.82 2800 52.75 18 24 296.94 0 0 0 Enabled 296.69 0 0 0 Enabled
297.19 2800 53.64 20 21 297.32 0 0 0 Enabled 297.07 0 0 0 Enabled
297.57 2800 53.81 20.8 21.8 297.69 0 0 0 Enabled 297.44 0 0 0 Enabled
297.94 2760 29.42 12.9 28.5 298.07 0 0 0 Enabled 297.82 0 0 0 Enabled
298.32 2760 20.39 9 35.3 298.44 0 0 0 Enabled 298.19 0 0 0 Enabled
298.69 2800 51.56 17.3 30.8 298.83 0 0 0 Enabled 298.57 0 0 0 Enabled
299.08 2720 21.14 9.4 31.5 299.21 0 0 0 Enabled 298.96 0 0 0 Enabled
299.46 2720 12.47 6.3 38.3 299.58 0 0 0 Disabled 299.33 0 0 0 Enabled
299.84 2640 13.14 6.3 5.3 299.96 0 0 0 Disabled 299.71 0 0 0 Disabled
300.21 2600 13.06 6.3 5.3 300.34 0 0 0 Disabled 300.09 0 0 0 Disabled
300.59 2560 49.92 17.3 39.8 300.71 0 0 0 Enabled 300.46 0 0 0 Disabled
300.96 2480 16.69 7.8 32.3 301.08 0 0 0 Enabled 300.84 0 0 0 Enabled
301.33 2480 38.81 14.1 33.8 301.46 0 0 0 Enabled 301.21 0 0 0 Enabled
301.71 2480 44.92 17.3 27.8 301.85 0 0 0 Enabled 301.58 0 0 0 Enabled
302.1 2480 44.22 17.6 27.8 302.22 0 0 0 Enabled 301.97 0 0 0 Enabled
302.47 2440 48.56 19.6 27.8 302.6 0 0 0 Enabled 302.35 0 0 0 Enabled
302.85 2440 50.75 22.7 26.3 302.97 0 0 0 Enabled 302.72 0 0 0 Enabled
303.22 2440 50.03 23.9 25.5 303.35 0 0 0 Enabled 303.1 0 0 0 Enabled
303.6 2400 49.86 24.3 26.3 303.72 0 0 0 Enabled 303.47 0 0 0 Enabled
303.98 2400 50.61 25.9 26.3 304.1 0 0 0 Enabled 303.85 0 0 0 Enabled
304.35 2360 58.11 43.5 24.8 304.48 0 0 0 Enabled 304.22 0 0 0 Enabled
304.73 2360 59.53 38 20.3 304.87 0 0 0 Enabled 304.6 0 0 0 Enabled
305.12 2400 57.92 32.9 20.3 305.24 0 0 0 Enabled 304.99 0 0 0 Enabled
305.49 2400 53.25 28.2 21.8 305.61 0 0 0 Enabled 305.36 0 0 0 Enabled
305.86 2440 53.03 28.6 22.5 305.99 0 0 0 Enabled 305.74 0 0 0 Enabled
306.24 2840 62.31 31.8 24.8 306.36 0 0 0 Enabled 306.11 0 0 0 Enabled
306.61 3640 90.25 41.2 23.3 306.74 0 0 0 Enabled 306.49 0 0 0 Enabled
306.99 3600 88.72 36.5 25.5 307.11 0 0 0 Enabled 306.86 0 0 0 Enabled
307.37 3640 107.25 47.5 19.5 307.49 0 0 0 Enabled 307.24 0 0 0 Enabled
307.74 3600 115.83 72.2 17.3 307.88 0 0 0 Enabled 307.61 0 0 0 Enabled
308.13 3640 117.58 91.8 12.8 308.26 0 0 0 Enabled 308.01 0 0 0 Enabled
308.51 3720 117.17 97.6 12.8 308.63 0 0 0 Enabled 308.38 0 0 0 Enabled
308.88 3720 118.53 99.2 12.8 309.01 0 0 0 Enabled 308.76 0 0 0 Enabled
309.25 3760 120.72 99.6 12.8 309.38 0 0 0 Enabled 309.13 0 0 0 Enabled
309.63 3760 122.5 99.6 13.5 309.76 0 0 0 Enabled 309.51 0 0 0 Enabled
310 3800 123.94 99.6 13.5 310.13 0 0 0 Enabled 309.88 0 0 0 Enabled
310.38 3800 124.03 99.6 13.5 310.5 0 0 0 Enabled 310.26 0 0 0 Enabled
310.75 2520 76.31 99.6 12.8 310.88 0 0 0 Enabled 310.63 0 0 0 Enabled
311.13 2520 75.94 99.6 18 311.25 0 0 0 Enabled 311.01 0 0 0 Enabled
311.51 2560 72.97 99.6 22.5 311.63 0 0 0 Enabled 311.38 0 0 0 Enabled
311.89 2600 74.14 99.6 16.5 312.02 0 0 0 Enabled 311.75 0 0 0 Enabled
312.27 2600 76.25 99.6 15.8 312.39 0 0 0 Enabled 312.14 0 0 0 Enabled
312.64 2560 72.69 99.6 16.5 312.77 0 0 0 Enabled 312.52 0 0 0 Enabled
313.02 2560 72.94 99.6 16.5 313.15 0 0 0 Enabled 312.9 0 0 0 Enabled
313.4 2640 76.33 99.6 15.8 313.52 0 0 0 Enabled 313.27 0 0 0 Enabled
313.77 2600 74.64 99.6 22.5 313.9 0 0 0 Enabled 313.65 0 0 0 Enabled
314.14 2600 74.22 99.6 21.8 314.27 0 0 0 Enabled 314.02 0 0 0 Enabled
314.52 2640 74.31 99.6 17.3 314.65 0 0 0 Enabled 314.4 0 0 0 Enabled
314.91 2600 74.5 99.6 22.5 315.04 0 0 0 Enabled 314.77 0 0 0 Enabled
315.28 2600 79.83 99.6 22.5 315.41 0 0 0 Enabled 315.16 0 0 0 Enabled
315.66 2640 76.75 99.6 15 315.79 0 0 0 Enabled 315.54 0 0 0 Enabled
316.04 2680 77.47 99.6 15 316.16 0 0 0 Enabled 315.91 0 0 0 Enabled
316.41 2640 75.89 99.6 21.8 316.54 0 0 0 Enabled 316.29 0 0 0 Enabled
316.79 2640 78.86 99.6 15 316.91 0 0 0 Enabled 316.67 0 0 0 Enabled
317.16 2760 78.44 99.6 23.3 317.29 0 0 0 Enabled 317.04 0 0 0 Enabled
317.54 2920 81.03 99.6 24 317.66 0 0 0 Enabled 317.41 0 0 0 Enabled
317.93 3680 111.53 99.6 9 318.05 0 0 0 Enabled 317.79 0 0 0 Enabled
318.3 4080 138.33 99.6 13.5 318.43 0 0 0 Enabled 318.18 0 0 0 Enabled
318.68 4120 138.67 99.6 13.5 318.8 0 0 0 Enabled 318.56 0 0 0 Enabled
319.05 4120 138.33 99.6 15 319.18 0 0 0 Enabled 318.93 0 0 0 Enabled
319.43 4160 140.31 99.6 12 319.55 0 0 0 Enabled 319.3 0 0 0 Enabled
319.8 4200 141.19 99.6 12 319.93 0 0 0 Enabled 319.68 0 0 0 Enabled
320.18 4240 143.64 99.6 12 320.3 0 0 0 Enabled 320.05 0 0 0 Enabled
320.55 4280 144.67 99.6 17.3 320.68 0 0 0 Enabled 320.43 0 0 0 Enabled
320.94 4320 146.39 99.6 12 321.07 0 0 0 Enabled 320.81 0 0 0 Enabled
321.32 4320 147.5 99.6 13.5 321.44 0 0 0 Enabled 321.2 0 0 0 Enabled
321.69 4320 148.06 99.6 18 321.82 0 0 0 Enabled 321.57 0 0 0 Enabled
322.07 4360 150.03 99.6 13.5 322.19 0 0 0 Enabled 321.94 0 0 0 Enabled
322.44 4400 151.92 99.6 13.5 322.57 0 0 0 Enabled 322.32 0 0 0 Enabled
322.82 4400 152.58 99.6 14.3 322.94 0 0 0 Enabled 322.69 0 0 0 Enabled
323.19 4280 150.83 99.6 17.3 323.32 0 0 0 Disabled 323.07 0 0 0 Enabled
323.57 2920 60.31 24.3 24 323.69 0 0 0 Enabled 323.44 0 0 0 Disabled
323.96 2920 89.36 68.2 14.3 324.08 0 0 0 Enabled 323.82 0 0 0 Enabled
324.33 2880 87.42 91.8 19.5 324.46 0 0 0 Enabled 324.21 0 0 0 Enabled
324.71 2880 86.58 97.6 21 324.83 0 0 0 Enabled 324.58 0 0 0 Enabled
325.08 2920 86.94 99.2 15 325.21 0 0 0 Enabled 324.96 0 0 0 Enabled
325.46 2920 86.89 99.6 14.3 325.58 0 0 0 Enabled 325.33 0 0 0 Enabled
325.83 2920 86.39 99.6 15.8 325.96 0 0 0 Enabled 325.71 0 0 0 Enabled
326.21 2920 87.47 99.6 21.8 326.33 0 0 0 Enabled 326.09 0 0 0 Enabled
326.58 3000 88.14 99.6 11.3 326.71 0 0 0 Enabled 326.46 0 0 0 Enabled
326.97 2960 87.22 99.6 20.3 327.1 0 0 0 Enabled 326.83 0 0 0 Enabled
327.35 2960 88 99.6 13.5 327.47 0 0 0 Enabled 327.22 0 0 0 Enabled
327.72 3000 88 99.6 13.5 327.85 0 0 0 Enabled 327.6 0 0 0 Enabled
328.1 3000 88.72 99.6 15 328.22 0 0 0 Enabled 327.97 0 0 0 Enabled
328.47 3000 88.28 99.6 15.8 328.6 0 0 0 Enabled 328.34 0 0 0 Enabled
328.85 3000 89.92 99.6 20.3 328.99 0 0 0 Enabled 328.72 0 0 0 Enabled
329.24 3040 89.97 99.6 21 329.37 0 0 0 Enabled 329.12 0 0 0 Enabled
329.62 3080 90.97 99.6 16.5 329.74 0 0 0 Enabled 329.49 0 0 0 Enabled
329.99 3120 91.47 99.6 16.5 330.12 0 0 0 Enabled 329.87 0 0 0 Enabled
330.37 3080 92.36 99.6 20.3 330.49 0 0 0 Enabled 330.24 0 0 0 Enabled
330.74 3120 92.53 99.6 16.5 330.87 0 0 0 Enabled 330.62 0 0 0 Enabled
331.11 3120 93.14 99.6 16.5 331.24 0 0 0 Enabled 330.98 0 0 0 Enabled
331.49 3120 93.69 99.6 14.3 331.61 0 0 0 Enabled 331.36 0 0 0 Enabled
331.87 3160 95.33 99.6 14.3 331.99 0 0 0 Enabled 331.74 0 0 0 Enabled
332.24 3160 95.67 99.6 14.3 332.37 0 0 0 Enabled 332.11 0 0 0 Enabled
332.61 3200 96.28 99.6 14.3 332.74 0 0 0 Enabled 332.49 0 0 0 Enabled
333 3200 97.44 99.6 20.3 333.13 0 0 0 Enabled 332.86 0 0 0 Enabled
333.38 3280 97.78 99.6 15 333.5 0 0 0 Enabled 333.25 0 0 0 Enabled
333.76 3320 99.31 99.6 13.5 333.88 0 0 0 Enabled 333.63 0 0 0 Enabled
334.13 3280 100.39 99.6 18.8 334.26 0 0 0 Enabled 334.01 0 0 0 Enabled
334.51 3320 101.11 99.6 13.5 334.63 0 0 0 Enabled 334.38 0 0 0 Enabled
334.88 3320 100.94 99.6 18.8 335.02 0 0 0 Enabled 334.76 0 0 0 Enabled
335.27 3360 102.36 99.6 18.8 335.4 0 0 0 Enabled 335.14 0 0 0 Enabled
335.65 3400 105.75 99.6 13.5 335.77 0 0 0 Enabled 335.52 0 0 0 Enabled
336.02 3440 106.61 99.6 13.5 336.14 0 0 0 Enabled 335.9 0 0 0 Enabled
336.4 3440 86.86 31.4 23.3 336.52 0 0 0 Enabled 336.27 0 0 0 Enabled
336.77 3440 77.42 31 28.5 336.9 0 0 0 Enabled 336.64 0 0 0 Enabled
337.15 3480 62.28 22.7 24 337.27 0 0 0 Enabled 337.02 0 0 0 Enabled
337.52 3480 16.19 7.8 38.3 337.65 0 0 0 Disabled 337.4 0 0 0 Enabled
337.9 3440 17.97 8.2 9.8 338.04 0 0 0 Disabled 337.77 0 0 0 Disabled
338.29 3400 17.97 8.2 9 338.41 0 0 0 Disabled 338.16 0 0 0 Disabled
338.66 3360 17.67 7.8 9 338.79 0 0 0 Disabled 338.54 0 0 0 Disabled
339.04 3360 17.36 7.8 8.3 339.16 0 0 0 Disabled 338.91 0 0 0 Disabled
339.41 3320 17.22 7.8 8.3 339.53 0 0 0 Disabled 339.28 0 0 0 Disabled
339.79 3280 16.94 7.8 7.5 339.91 0 0 0 Disabled 339.66 0 0 0 Disabled
340.16 3280 16.56 7.8 8.3 340.28 0 0 0 Disabled 340.04 0 0 0 Disabled
340.54 3080 20.06 9 41.3 340.66 0 0 0 Disabled 340.41 0 0 0 Disabled
340.91 2880 56.19 18 29.3 341.05 0 0 0 Disabled 340.78 0 0 0 Disabled
341.31 2440 47.33 19.6 27 341.43 0 0 0 Enabled 341.18 0 0 0 Disabled
341.68 2480 49.75 20.4 27 341.8 0 0 0 Enabled 341.56 0 0 0 Enabled
342.05 2520 54.44 24.7 26.3 342.18 0 0 0 Enabled 341.92 0 0 0 Enabled
342.43 2520 74.75 69.8 12 342.55 0 0 0 Enabled 342.3 0 0 0 Enabled
342.8 2480 76 75.3 10.5 342.93 0 0 0 Enabled 342.68 0 0 0 Enabled
343.18 2560 74.67 79.2 12.8 343.3 0 0 0 Enabled 343.05 0 0 0 Enabled
343.55 2520 75.69 64.7 10.5 343.68 0 0 0 Enabled 343.43 0 0 0 Enabled
343.92 2560 76.69 52.5 9.8 344.07 0 0 0 Enabled 343.8 0 0 0 Enabled
344.31 2560 72.61 40.8 20.3 344.44 0 0 0 Enabled 344.19 0 0 0 Enabled
344.69 2600 70.64 36.1 15.8 344.82 0 0 0 Enabled 344.57 0 0 0 Enabled
345.07 2640 70.86 34.9 15 345.19 0 0 0 Enabled 344.94 0 0 0 Enabled
345.45 2640 71.36 34.5 21.8 345.57 0 0 0 Enabled 345.31 0 0 0 Enabled
345.82 2640 71.44 34.1 22.5 345.94 0 0 0 Enabled 345.69 0 0 0 Enabled
346.2 2640 71.97 34.1 17.3 346.31 0 0 0 Enabled 346.07 0 0 0 Enabled
346.57 2640 72.11 34.1 22.5 346.69 0 0 0 Enabled 346.44 0 0 0 Enabled
346.94 2680 71.92 34.1 22.5 347.08 0 0 0 Enabled 346.82 0 0 0 Enabled
347.33 2680 72.11 34.1 23.3 347.46 0 0 0 Enabled 347.21 0 0 0 Enabled
347.71 2680 72.47 34.5 17.3 347.83 0 0 0 Enabled 347.58 0 0 0 Enabled
348.08 2680 72.22 34.1 15 348.21 0 0 0 Enabled 347.96 0 0 0 Enabled
348.46 2640 73.06 34.5 21.8 348.59 0 0 0 Enabled 348.33 0 0 0 Enabled
348.83 2640 73.42 34.9 14.3 348.96 0 0 0 Enabled 348.71 0 0 0 Enabled
349.21 2680 73.36 35.3 22.5 349.33 0 0 0 Enabled 349.08 0 0 0 Enabled
349.58 2640 73.39 35.3 14.3 349.71 0 0 0 Enabled 349.46 0 0 0 Enabled
349.96 2680 73.19 35.3 15 350.09 0 0 0 Enabled 349.83 0 0 0 Enabled
350.34 2600 73.33 35.3 21.8 350.46 0 0 0 Enabled 350.21 0 0 0 Enabled
350.71 2640 72.69 35.7 14.3 350.84 0 0 0 Enabled 350.59 0 0 0 Enabled
351.1 2600 71.69 35.7 21.8 351.22 0 0 0 Enabled 350.96 0 0 0 Enabled
351.47 2560 71.83 35.7 21 351.6 0 0 0 Enabled 351.35 0 0 0 Enabled
351.85 2600 72 35.7 15 351.97 0 0 0 Enabled 351.72 0 0 0 Enabled
352.22 2560 70.61 35.7 12 352.35 0 0 0 Enabled 352.1 0 0 0 Enabled
352.6 2520 69.97 36.1 12 352.72 0 0 0 Enabled 352.47 0 0 0 Enabled
352.97 2520 70.28 36.5 11.3 353.1 0 0 0 Enabled 352.85 0 0 0 Enabled
353.35 2520 58.83 25.9 14.3 353.47 0 0 0 Enabled 353.22 0 0 0 Enabled
353.72 2520 54.89 28.6 16.5 353.85 0 0 0 Enabled 353.6 0 0 0 Enabled
354.12 2520 54.44 29.4 17.3 354.24 0 0 0 Enabled 353.97 0 0 0 Enabled
354.49 2480 54.19 29.4 16.5 354.62 0 0 0 Enabled 354.36 0 0 0 Enabled
354.87 2480 54.31 29.4 17.3 354.99 0 0 0 Enabled 354.74 0 0 0 Enabled
355.24 2480 55 30.2 16.5 355.37 0 0 0 Enabled 355.11 0 0 0 Enabled
355.62 2520 55 29.4 18.8 355.74 0 0 0 Enabled 355.49 0 0 0 Enabled
355.99 2480 54.67 29.4 23.3 356.12 0 0 0 Enabled 355.86 0 0 0 Enabled
356.37 2440 54.11 29 18.8 356.49 0 0 0 Enabled 356.24 0 0 0 Enabled
356.74 2440 55.31 30.2 20.3 356.86 0 0 0 Enabled 356.61 0 0 0 Enabled
357.11 2480 54.89 29.8 20.3 357.24 0 0 0 Enabled 356.99 0 0 0 Enabled
357.49 2440 54.53 29.4 24 357.61 0 0 0 Enabled 357.36 0 0 0 Enabled
357.86 2480 54.94 29.4 21.8 357.99 0 0 0 Enabled 357.74 0 0 0 Enabled
358.25 2440 55.11 29.4 22.5 358.38 0 0 0 Enabled 358.13 0 0 0 Enabled
358.63 2440 55.19 29.4 23.3 358.76 0 0 0 Enabled 358.51 0 0 0 Enabled
359.01 2440 57.39 40.8 23.3 359.13 0 0 0 Enabled 358.88 0 0 0 Enabled
359.38 2440 66.31 47.8 18 359.51 0 0 0 Enabled 359.26 0 0 0 Enabled
359.75 2520 66.06 40.4 12.8 359.88 0 0 0 Enabled 359.63 0 0 0 Enabled
360.13 2440 67.89 38.4 12.8 360.26 0 0 0 Enabled 360 0 0 0 Enabled
360.5 2480 68.47 37.3 12 360.63 0 0 0 Enabled 360.38 0 0 0 Enabled
360.88 2520 68.86 37.6 12.8 361.01 0 0 0 Enabled 360.75 0 0 0 Enabled
361.28 2480 68.19 36.9 14.3 361.4 0 0 0 Enabled 361.15 0 0 0 Enabled
361.65 2520 67 36.5 17.3 361.77 0 0 0 Enabled 361.52 0 0 0 Enabled
362.03 2480 67.94 36.1 15.8 362.15 0 0 0 Enabled 361.9 0 0 0 Enabled
362.4 2480 68.11 36.5 17.3 362.52 0 0 0 Enabled 362.27 0 0 0 Enabled
362.77 2480 68.25 36.5 12 362.9 0 0 0 Enabled 362.65 0 0 0 Enabled
363.15 2480 67.86 36.9 12.8 363.27 0 0 0 Enabled 363.02 0 0 0 Enabled
363.52 2520 67.53 35.7 13.5 363.65 0 0 0 Enabled 363.4 0 0 0 Enabled
363.9 2520 67.36 35.7 14.3 364.02 0 0 0 Enabled 363.77 0 0 0 Enabled
364.28 2520 67.69 35.7 14.3 364.41 0 0 0 Enabled 364.16 0 0 0 Enabled
364.66 2480 67.78 36.1 14.3 364.79 0 0 0 Enabled 364.53 0 0 0 Enabled
365.04 2520 68.53 35.7 14.3 365.16 0 0 0 Enabled 364.91 0 0 0 Enabled
365.41 2520 67.94 35.7 14.3 365.53 0 0 0 Enabled 365.29 0 0 0 Enabled
365.78 2560 68.61 35.7 15 365.91 0 0 0 Enabled 365.66 0 0 0 Enabled
366.16 2520 59.33 28.6 21.8 366.28 0 0 0 Enabled 366.03 0 0 0 Enabled
366.53 2560 56 29.4 20.3 366.66 0 0 0 Enabled 366.41 0 0 0 Enabled
366.91 2520 55.36 29.8 24 367.04 0 0 0 Enabled 366.79 0 0 0 Enabled
367.3 2520 56.61 30.2 22.5 367.43 0 0 0 Enabled 367.18 0 0 0 Enabled
367.68 2520 55.28 28.2 23.3 367.8 0 0 0 Enabled 367.55 0 0 0 Enabled
368.05 2560 54.86 28.6 24 368.18 0 0 0 Enabled 367.93 0 0 0 Enabled
368.43 2560 55.42 29 24.8 368.55 0 0 0 Enabled 368.3 0 0 0 Enabled
368.8 2560 55.5 29.4 24.8 368.93 0 0 0 Enabled 368.68 0 0 0 Enabled
369.18 2560 56.31 29.4 24.8 369.3 0 0 0 Enabled 369.05 0 0 0 Enabled
369.55 2600 56.92 29.8 24.8 369.68 0 0 0 Enabled 369.43 0 0 0 Enabled
369.93 2600 57.14 29.8 24.8 370.05 0 0 0 Enabled 369.8 0 0 0 Enabled
370.32 2600 57.28 29.8 24.8 370.45 0 0 0 Enabled 370.2 0 0 0 Enabled
370.7 2600 57.25 29.8 24.8 370.82 0 0 0 Enabled 370.57 0 0 0 Enabled
371.07 2600 57.78 29.8 24.8 371.19 0 0 0 Enabled 370.95 0 0 0 Enabled
371.44 2600 17.42 8.2 31.5 371.57 0 0 0 Enabled 371.32 0 0 0 Enabled
371.82 2600 11.19 5.5 37.5 371.94 0 0 0 Disabled 371.69 0 0 0 Enabled
372.19 2560 12.58 6.3 6 372.32 0 0 0 Disabled 372.07 0 0 0 Disabled
372.57 2560 17.36 8.2 40.5 372.69 0 0 0 Disabled 372.44 0 0 0 Disabled
372.94 2600 46.97 17.3 28.5 373.07 0 0 0 Enabled 372.82 0 0 0 Enabled
373.33 2560 47.36 18.4 29.3 373.46 0 0 0 Enabled 373.21 0 0 0 Enabled
373.71 2520 47.39 18.8 28.5 373.83 0 0 0 Enabled 373.58 0 0 0 Enabled
374.08 2560 47.53 19.2 27.8 374.21 0 0 0 Enabled 373.96 0 0 0 Enabled
374.46 2520 57.83 25.5 26.3 374.58 0 0 0 Enabled 374.33 0 0 0 Enabled
374.83 2520 63.28 40.4 21.8 374.96 0 0 0 Enabled 374.71 0 0 0 Enabled
375.21 2480 60.44 33.3 21.8 375.33 0 0 0 Enabled 375.09 0 0 0 Enabled
375.58 2520 58.75 30.6 23.3 375.71 0 0 0 Enabled 375.46 0 0 0 Enabled
375.95 2480 57.47 30.2 24 376.08 0 0 0 Enabled 375.83 0 0 0 Enabled
376.35 2480 56.08 29.4 24 376.47 0 0 0 Enabled 376.22 0 0 0 Enabled
376.72 2480 52 27.8 23.3 376.85 0 0 0 Enabled 376.6 0 0 0 Enabled
377.1 2440 53.06 28.2 24.8 377.22 0 0 0 Enabled 376.97 0 0 0 Enabled
377.47 2440 52.69 28.2 24 377.6 0 0 0 Enabled 377.35 0 0 0 Enabled
377.85 2400 52.28 28.2 24.8 377.97 0 0 0 Enabled 377.72 0 0 0 Enabled
378.22 2440 52.06 28.2 24.8 378.35 0 0 0 Enabled 378.1 0 0 0 Enabled
378.6 2400 52.19 28.6 23.3 378.73 0 0 0 Enabled 378.48 0 0 0 Enabled
378.98 2360 51.61 28.6 24 379.1 0 0 0 Enabled 378.85 0 0 0 Enabled
379.37 2400 52.33 28.6 24 379.49 0 0 0 Enabled 379.24 0 0 0 Enabled
379.74 2680 54.14 28.6 25.5 379.87 0 0 0 Enabled 379.62 0 0 0 Enabled
380.12 3120 74.31 33.7 26.3 380.24 0 0 0 Enabled 379.99 0 0 0 Enabled
380.49 3120 70.58 32.9 22.5 380.61 0 0 0 Enabled 380.36 0 0 0 Enabled
380.86 3120 70.11 33.3 23.3 380.99 0 0 0 Enabled 380.74 0 0 0 Enabled
381.24 3040 71.78 42 24.8 381.36 0 0 0 Enabled 381.11 0 0 0 Enabled
381.62 3040 88.89 61.6 12 381.74 0 0 0 Enabled 381.49 0 0 0 Enabled
382 3040 90.92 57.6 11.3 382.11 0 0 0 Enabled 381.87 0 0 0 Enabled
382.38 3040 91.08 63.1 15.8 382.51 0 0 0 Enabled 382.25 0 0 0 Enabled
382.76 3000 91.47 59.2 11.3 382.88 0 0 0 Enabled 382.63 0 0 0 Enabled
383.13 3040 90.67 54.5 15.8 383.25 0 0 0 Enabled 383.01 0 0 0 Enabled
383.51 3000 91.39 53.7 12 383.63 0 0 0 Enabled 383.38 0 0 0 Enabled
383.88 3000 90.36 50.6 15.8 384.01 0 0 0 Enabled 383.76 0 0 0 Enabled
384.25 3000 90 47.5 12 384.38 0 0 0 Enabled 384.13 0 0 0 Enabled
384.63 3000 89.25 46.3 15.8 384.75 0 0 0 Enabled 384.51 0 0 0 Enabled
385.01 3000 88.36 44.3 12.8 385.13 0 0 0 Enabled 384.88 0 0 0 Enabled
385.4 3000 87.61 41.2 14.3 385.52 0 0 0 Enabled 385.27 0 0 0 Enabled
385.77 3000 87.33 40.8 17.3 385.9 0 0 0 Enabled 385.65 0 0 0 Enabled
386.14 3040 87.58 42.7 14.3 386.27 0 0 0 Enabled 386.02 0 0 0 Enabled
386.52 3000 87.72 42 17.3 386.65 0 0 0 Enabled 386.4 0 0 0 Enabled
386.9 3040 87.28 40.4 14.3 387.02 0 0 0 Enabled 386.76 0 0 0 Enabled
387.27 2960 86.33 39.6 15 387.4 0 0 0 Enabled 387.15 0 0 0 Enabled
387.65 2960 86.28 38.8 18 387.77 0 0 0 Enabled 387.52 0 0 0 Enabled
388.02 3000 86.39 38.4 15.8 388.15 0 0 0 Enabled 387.9 0 0 0 Enabled
388.41 2960 86.03 39.6 17.3 388.54 0 0 0 Enabled 388.29 0 0 0 Enabled
388.79 2960 86.36 40 15 388.91 0 0 0 Enabled 388.66 0 0 0 Enabled
389.16 2960 86.17 40.4 17.3 389.29 0 0 0 Enabled 389.03 0 0 0 Enabled
389.54 2920 84.81 38.8 17.3 389.66 0 0 0 Enabled 389.41 0 0 0 Enabled
389.91 2920 83.22 37.3 17.3 390.03 0 0 0 Enabled 389.79 0 0 0 Enabled
390.29 2960 83.14 36.9 18 390.41 0 0 0 Enabled 390.16 0 0 0 Enabled
390.66 2960 82.83 36.9 19.5 390.79 0 0 0 Enabled 390.54 0 0 0 Enabled
391.04 2960 82.31 36.9 18 391.16 0 0 0 Enabled 390.91 0 0 0 Enabled
391.43 2920 82.56 36.9 19.5 391.55 0 0 0 Enabled 391.3 0 0 0 Enabled
391.8 2960 81.81 36.9 18.8 391.93 0 0 0 Enabled 391.68 0 0 0 Enabled
392.18 2920 82.31 36.9 18.8 392.3 0 0 0 Enabled 392.05 0 0 0 Enabled
392.55 2880 81.17 36.5 18.8 392.68 0 0 0 Enabled 392.43 0 0 0 Enabled
392.93 2920 80.94 36.5 19.5 393.05 0 0 0 Enabled 392.8 0 0 0 Enabled
393.3 2920 81.47 36.9 19.5 393.42 0 0 0 Enabled 393.17 0 0 0 Enabled
393.68 3000 81.97 36.5 15.8 393.8 0 0 0 Enabled 393.55 0 0 0 Enabled
394.05 3640 97.83 38 15.8 394.18 0 0 0 Enabled 393.93 0 0 0 Enabled
394.44 4440 129.56 42.4 19.5 394.57 0 0 0 Enabled 394.32 0 0 0 Enabled
394.82 4320 84.97 24.3 24.8 394.94 0 0 0 Disabled 394.69 0 0 0 Enabled
395.19 4280 103.17 30.2 24 395.32 0 0 0 Disabled 395.07 0 0 0 Disabled
395.57 4240 104.39 31.8 19.5 395.69 0 0 0 Disabled 395.45 0 0 0 Disabled
395.94 3800 99.08 31.4 22.5 396.07 0 0 0 Disabled 395.82 0 0 0 Disabled
396.32 2720 65.39 30.2 23.3 396.45 0 0 0 Enabled 396.2 0 0 0 Disabled
396.69 2720 80.94 54.1 14.3 396.82 0 0 0 Enabled 396.56 0 0 0 Enabled
397.07 2680 79.67 47.5 15 397.19 0 0 0 Enabled 396.95 0 0 0 Enabled
397.44 2680 82.61 69 11.3 397.57 0 0 0 Enabled 397.32 0 0 0 Enabled
397.82 2720 83.92 90.6 9 397.94 0 0 0 Enabled 397.69 0 0 0 Enabled
398.19 2720 80.25 97.6 12 398.33 0 0 0 Enabled 398.07 0 0 0 Enabled
398.58 2640 82.69 99.2 10.5 398.71 0 0 0 Enabled 398.46 0 0 0 Enabled
398.96 2680 83.92 99.6 12 399.08 0 0 0 Enabled 398.83 0 0 0 Enabled
399.33 2680 83 99.6 9.8 399.46 0 0 0 Enabled 399.21 0 0 0 Enabled
399.71 2680 82.78 99.6 9.8 399.83 0 0 0 Enabled 399.58 0 0 0 Enabled
400.08 2680 83.06 99.6 10.5 400.21 0 0 0 Enabled 399.96 0 0 0 Enabled
400.46 2640 81.58 99.6 10.5 400.59 0 0 0 Enabled 400.34 0 0 0 Enabled
400.83 2640 81.08 99.6 12 400.95 0 0 0 Enabled 400.71 0 0 0 Enabled
401.21 2640 80.86 99.6 11.3 401.35 0 0 0 Enabled 401.08 0 0 0 Enabled
401.6 2640 83.61 99.6 11.3 401.72 0 0 0 Enabled 401.48 0 0 0 Enabled
401.98 2640 81.78 99.6 10.5 402.1 0 0 0 Enabled 401.85 0 0 0 Enabled
402.35 2680 81.81 99.6 11.3 402.47 0 0 0 Enabled 402.22 0 0 0 Enabled
402.72 2640 84.33 99.6 10.5 402.85 0 0 0 Enabled 402.6 0 0 0 Enabled
403.1 2640 81.36 99.6 11.3 403.22 0 0 0 Enabled 402.97 0 0 0 Enabled
403.47 2640 83.17 99.6 9.8 403.6 0 0 0 Enabled 403.35 0 0 0 Enabled
403.85 2640 88.56 99.6 4.5 403.97 0 0 0 Enabled 403.72 0 0 0 Enabled
404.23 2640 90.58 99.6 3.8 404.35 0 0 0 Enabled 404.1 0 0 0 Enabled
404.6 2680 92.69 99.6 3.8 404.73 0 0 0 Enabled 404.48 0 0 0 Enabled
404.98 3000 93 99.6 14.3 405.1 0 0 0 Enabled 404.85 0 0 0 Enabled
405.36 3800 116.33 99.2 18 405.49 0 0 0 Enabled 405.22 0 0 0 Enabled
405.74 4040 135.44 87.1 16.5 405.86 0 0 0 Enabled 405.61 0 0 0 Enabled
406.11 4040 136.47 75.3 13.5 406.24 0 0 0 Enabled 405.99 0 0 0 Enabled
406.49 4080 136.89 91 14.3 406.62 0 0 0 Enabled 406.37 0 0 0 Enabled
406.86 4080 137.83 97.6 16.5 406.99 0 0 0 Enabled 406.74 0 0 0 Enabled
407.24 4120 138.25 99.2 16.5 407.37 0 0 0 Enabled 407.11 0 0 0 Enabled
407.61 4160 139.83 99.6 16.5 407.74 0 0 0 Enabled 407.49 0 0 0 Enabled
407.99 4160 140.67 99.6 16.5 408.11 0 0 0 Enabled 407.86 0 0 0 Enabled
408.38 4200 142.33 99.6 16.5 408.5 0 0 0 Enabled 408.24 0 0 0 Enabled
408.76 4240 143.72 99.6 13.5 408.88 0 0 0 Enabled 408.63 0 0 0 Enabled
409.13 4240 144.72 99.6 13.5 409.26 0 0 0 Enabled 409 0 0 0 Enabled
409.51 4280 146.17 99.6 14.3 409.63 0 0 0 Enabled 409.38 0 0 0 Enabled
409.88 4280 145.67 99.6 17.3 410 0 0 0 Enabled 409.75 0 0 0 Enabled
410.26 4280 147.42 99.6 15 410.38 0 0 0 Enabled 410.13 0 0 0 Enabled
410.63 4320 147.94 99.6 17.3 410.75 0 0 0 Enabled 410.51 0 0 0 Enabled
411.01 4360 148.69 99.6 14.3 411.13 0 0 0 Enabled 410.88 0 0 0 Enabled
411.38 4360 149.42 99.6 12 411.5 0 0 0 Enabled 411.26 0 0 0 Enabled
411.75 4360 150.81 99.6 11.3 411.88 0 0 0 Enabled 411.63 0 0 0 Enabled
412.13 4360 150.81 99.6 12 412.26 0 0 0 Enabled 412 0 0 0 Enabled
412.52 4360 151.14 99.6 12 412.64 0 0 0 Enabled 412.39 0 0 0 Enabled
412.9 4400 151.42 99.6 12 413.02 0 0 0 Enabled 412.77 0 0 0 Enabled
413.27 4400 151.06 99.2 18 413.39 0 0 0 Enabled 413.15 0 0 0 Enabled
413.65 4400 151.86 86.7 18 413.77 0 0 0 Enabled 413.52 0 0 0 Enabled
414.02 4400 133.19 41.2 15 414.14 0 0 0 Enabled 413.89 0 0 0 Enabled
414.4 4360 89.39 24.3 20.3 414.52 0 0 0 Enabled 414.27 0 0 0 Enabled
414.77 4360 104.5 29.4 18.8 414.89 0 0 0 Enabled 414.65 0 0 0 Enabled
415.15 4360 118.72 33.3 17.3 415.27 0 0 0 Enabled 415.02 0 0 0 Enabled
415.54 4320 121.31 35.3 21.8 415.66 0 0 0 Enabled 415.41 0 0 0 Enabled
415.91 4280 100.28 26.7 17.3 416.04 0 0 0 Enabled 415.78 0 0 0 Enabled
416.29 4240 69.47 20 27.8 416.41 0 0 0 Enabled 416.16 0 0 0 Enabled
416.66 4240 87.53 24.3 27 416.79 0 0 0 Enabled 416.53 0 0 0 Enabled
417.04 4200 87.94 25.1 21.8 417.16 0 0 0 Enabled 416.91 0 0 0 Enabled
417.41 4160 98.53 29.8 20.3 417.54 0 0 0 Enabled 417.29 0 0 0 Enabled
417.79 4120 110.28 34.1 17.3 417.91 0 0 0 Enabled 417.66 0 0 0 Enabled
418.16 4120 110.75 34.1 18 418.29 0 0 0 Enabled 418.04 0 0 0 Enabled
418.55 4160 108.53 32.9 18.8 418.68 0 0 0 Enabled 418.42 0 0 0 Enabled
418.92 4120 110.56 33.3 17.3 419.05 0 0 0 Enabled 418.8 0 0 0 Enabled
419.3 4080 107.72 32.5 18.8 419.43 0 0 0 Enabled 419.18 0 0 0 Enabled
419.68 4080 93.67 27.1 18 419.8 0 0 0 Enabled 419.55 0 0 0 Enabled
420.05 4040 80.28 23.9 21 420.18 0 0 0 Enabled 419.92 0 0 0 Enabled
420.42 4040 95.64 29 25.5 420.56 0 0 0 Enabled 420.3 0 0 0 Enabled
420.81 4000 97.17 30.6 24.8 420.93 0 0 0 Enabled 420.68 0 0 0 Enabled
421.17 3960 98.33 31 18.8 421.3 0 0 0 Enabled 421.05 0 0 0 Enabled
421.57 3120 79.58 31.8 21.8 421.69 0 0 0 Enabled 421.44 0 0 0 Enabled
421.94 2600 65.5 34.1 24.8 422.07 0 0 0 Enabled 421.82 0 0 0 Enabled
422.32 2600 73.81 43.1 15.8 422.44 0 0 0 Enabled 422.19 0 0 0 Enabled
422.69 2600 70.83 37.3 16.5 422.82 0 0 0 Enabled 422.57 0 0 0 Enabled
423.07 2640 68.97 33.7 16.5 423.19 0 0 0 Enabled 422.94 0 0 0 Enabled
423.44 2600 61.69 25.1 25.5 423.57 0 0 0 Enabled 423.32 0 0 0 Enabled
423.82 2560 64.56 27.1 24 423.94 0 0 0 Enabled 423.69 0 0 0 Enabled
424.19 2600 67.14 29.8 15.8 424.32 0 0 0 Enabled 424.07 0 0 0 Enabled
424.58 2600 63.75 26.7 16.5 424.71 0 0 0 Enabled 424.46 0 0 0 Enabled
424.96 2600 67.33 29.4 16.5 425.09 0 0 0 Enabled 424.84 0 0 0 Enabled
425.34 2560 73.33 42.7 20.3 425.46 0 0 0 Enabled 425.21 0 0 0 Enabled
425.71 2560 73 41.2 19.5 425.83 0 0 0 Enabled 425.58 0 0 0 Enabled
426.08 2560 72.75 38.8 19.5 426.21 0 0 0 Enabled 425.96 0 0 0 Enabled
426.46 2600 61.33 25.9 18 426.58 0 0 0 Enabled 426.33 0 0 0 Enabled
426.83 2600 66.78 29.4 14.3 426.96 0 0 0 Enabled 426.71 0 0 0 Enabled
427.21 2560 64.58 27.1 13.5 427.33 0 0 0 Enabled 427.08 0 0 0 Enabled
427.6 2560 58.94 25.9 24 427.72 0 0 0 Enabled 427.47 0 0 0 Enabled
427.97 2560 63.97 25.5 24 428.1 0 0 0 Enabled 427.85 0 0 0 Enabled
428.35 2560 64.86 27.1 24.8 428.47 0 0 0 Enabled 428.22 0 0 0 Enabled
428.72 2600 69.58 29.4 15 428.85 0 0 0 Enabled 428.6 0 0 0 Enabled
429.1 2600 66.22 29.8 12.8 429.23 0 0 0 Enabled 428.98 0 0 0 Enabled
429.48 2560 69.56 32.2 14.3 429.6 0 0 0 Enabled 429.35 0 0 0 Enabled
429.85 2560 65.22 27.1 15.8 429.98 0 0 0 Enabled 429.73 0 0 0 Enabled
430.22 2600 63.69 24.7 17.3 430.35 0 0 0 Enabled 430.1 0 0 0 Enabled
430.6 2600 69.14 30.6 22.5 430.72 0 0 0 Enabled 430.47 0 0 0 Enabled
430.97 2560 65.78 27.5 21.8 431.1 0 0 0 Enabled 430.85 0 0 0 Enabled
431.35 2600 60.36 23.9 15.8 431.49 0 0 0 Enabled 431.23 0 0 0 Enabled
431.74 2640 58.03 22.4 18 431.86 0 0 0 Enabled 431.62 0 0 0 Enabled
432.11 2600 57.28 22 26.3 432.24 0 0 0 Enabled 431.99 0 0 0 Enabled
432.49 2600 78.28 49.8 21.8 432.61 0 0 0 Enabled 432.36 0 0 0 Enabled
432.87 2600 70.19 44.3 12.8 432.99 0 0 0 Enabled 432.74 0 0 0 Enabled
433.24 2600 66.06 34.9 13.5 433.37 0 0 0 Enabled 433.12 0 0 0 Enabled
433.63 2640 63.19 31 15.8 433.76 0 0 0 Enabled 433.51 0 0 0 Enabled
434.01 2640 56.72 22.7 15.8 434.13 0 0 0 Enabled 433.88 0 0 0 Enabled
434.38 2640 58.86 27.5 25.5 434.5 0 0 0 Enabled 434.25 0 0 0 Enabled
434.75 2640 68.78 40 21.8 434.88 0 0 0 Enabled 434.63 0 0 0 Enabled
435.13 2640 67.31 34.5 14.3 435.25 0 0 0 Enabled 435.01 0 0 0 Enabled
435.51 2640 67.17 32.2 15.8 435.63 0 0 0 Enabled 435.38 0 0 0 Enabled
435.88 2680 67.08 31.8 16.5 436 0 0 0 Enabled 435.76 0 0 0 Enabled
436.26 2720 67.17 31.8 17.3 436.38 0 0 0 Enabled 436.13 0 0 0 Enabled
436.63 2720 67.89 32.2 18 436.75 0 0 0 Enabled 436.5 0 0 0 Enabled
437.01 2720 69.06 32.5 18.8 437.13 0 0 0 Enabled 436.88 0 0 0 Enabled
437.38 2760 68.06 32.2 19.5 437.52 0 0 0 Enabled 437.25 0 0 0 Enabled
437.77 2760 65.89 31.4 20.3 437.9 0 0 0 Enabled 437.65 0 0 0 Enabled
438.15 2720 66.11 31.4 23.3 438.27 0 0 0 Enabled 438.02 0 0 0 Enabled
438.52 2760 66.83 31.8 20.3 438.64 0 0 0 Enabled 438.4 0 0 0 Enabled
438.89 2800 67.25 31.8 20.3 439.02 0 0 0 Enabled 438.77 0 0 0 Enabled
439.27 2760 66.72 31.8 23.3 439.4 0 0 0 Enabled 439.14 0 0 0 Enabled
439.66 2800 66.72 31.8 21 439.78 0 0 0 Enabled 439.53 0 0 0 Enabled
440.04 2800 64.03 31.4 24.8 440.16 0 0 0 Enabled 439.91 0 0 0 Enabled
440.41 2800 63.69 33.3 24.8 440.53 0 0 0 Enabled 440.29 0 0 0 Enabled
440.79 2840 62.5 31.8 22.5 440.91 0 0 0 Enabled 440.66 0 0 0 Enabled
441.17 2840 62.06 31 24 441.29 0 0 0 Enabled 441.03 0 0 0 Enabled
441.53 2800 62.64 30.6 24 441.66 0 0 0 Enabled 441.41 0 0 0 Enabled
441.91 2840 63.14 30.6 23.3 442.04 0 0 0 Enabled 441.79 0 0 0 Enabled
442.29 2840 62.69 30.6 23.3 442.41 0 0 0 Enabled 442.16 0 0 0 Enabled
442.66 2840 63.42 30.6 23.3 442.79 0 0 0 Enabled 442.54 0 0 0 Enabled
443.04 2840 63.58 31 24.8 443.16 0 0 0 Enabled 442.91 0 0 0 Enabled
443.41 2880 63.5 32.2 24 443.55 0 0 0 Enabled 443.29 0 0 0 Enabled
443.8 2840 63.25 32.2 23.3 443.92 0 0 0 Enabled 443.67 0 0 0 Enabled
444.18 2840 63 31.8 24.8 444.3 0 0 0 Enabled 444.05 0 0 0 Enabled
444.55 2840 62.64 32.2 24.8 444.68 0 0 0 Enabled 444.43 0 0 0 Enabled
444.92 2840 63.67 32.2 24.8 445.05 0 0 0 Enabled 444.8 0 0 0 Enabled
445.31 2840 63.44 32.5 24.8 445.43 0 0 0 Enabled 445.18 0 0 0 Enabled
445.7 2840 64.06 31.8 24.8 445.82 0 0 0 Enabled 445.57 0 0 0 Enabled
446.07 2840 64.11 32.2 25.5 446.19 0 0 0 Enabled 445.94 0 0 0 Enabled
446.44 2880 63.31 32.9 24.8 446.57 0 0 0 Enabled 446.32 0 0 0 Enabled
446.82 2840 63.5 32.2 24.8 446.94 0 0 0 Enabled 446.69 0 0 0 Enabled
447.19 2880 62.56 31.8 25.5 447.32 0 0 0 Enabled 447.07 0 0 0 Enabled
447.57 2840 63.89 31 25.5 447.69 0 0 0 Enabled 447.44 0 0 0 Enabled
447.94 2840 63.47 30.6 24.8 448.07 0 0 0 Enabled 447.82 0 0 0 Enabled
448.32 2880 63.03 30.6 24.8 448.44 0 0 0 Enabled 448.19 0 0 0 Enabled
448.71 2840 63.39 30.6 24.8 448.83 0 0 0 Enabled 448.58 0 0 0 Enabled
449.08 2840 63.47 30.6 25.5 449.21 0 0 0 Enabled 448.95 0 0 0 Enabled
449.46 2840 63.03 30.6 25.5 449.59 0 0 0 Enabled 449.34 0 0 0 Enabled
449.84 2840 63.36 30.6 24.8 449.96 0 0 0 Enabled 449.71 0 0 0 Enabled
450.21 2840 63.28 30.6 24.8 450.33 0 0 0 Enabled 450.09 0 0 0 Enabled
450.58 2840 63.03 30.6 25.5 450.71 0 0 0 Enabled 450.46 0 0 0 Enabled
450.96 2840 62.92 30.6 24.8 451.08 0 0 0 Enabled 450.83 0 0 0 Enabled
451.33 2880 62.97 30.6 25.5 451.46 0 0 0 Enabled 451.21 0 0 0 Enabled
451.72 2840 63.33 30.6 25.5 451.85 0 0 0 Enabled 451.6 0 0 0 Enabled
452.1 2840 63.25 30.6 25.5 452.22 0 0 0 Enabled 451.97 0 0 0 Enabled
452.47 2840 63.25 30.6 25.5 452.6 0 0 0 Enabled 452.35 0 0 0 Enabled
452.85 2840 63.42 30.6 24.8 452.97 0 0 0 Enabled 452.72 0 0 0 Enabled
453.23 2840 63.53 30.6 25.5 453.35 0 0 0 Enabled 453.1 0 0 0 Enabled
453.6 2880 63.5 30.6 25.5 453.73 0 0 0 Enabled 453.48 0 0 0 Enabled
453.98 2880 64 30.6 25.5 454.1 0 0 0 Enabled 453.85 0 0 0 Enabled
454.35 2880 63.78 31 25.5 454.48 0 0 0 Enabled 454.23 0 0 0 Enabled
454.72 2880 64.53 31 24.8 454.85 0 0 0 Enabled 454.6 0 0 0 Enabled
455.1 2880 64.31 30.6 26.3 455.22 0 0 0 Enabled 454.97 0 0 0 Enabled
455.47 2920 65.03 30.6 25.5 455.61 0 0 0 Enabled 455.35 0 0 0 Enabled
455.86 2920 64.33 30.6 26.3 455.99 0 0 0 Enabled 455.74 0 0 0 Enabled
456.24 2920 64.69 31 26.3 456.37 0 0 0 Enabled 456.12 0 0 0 Enabled
456.61 2920 64.75 31 26.3 456.74 0 0 0 Enabled 456.49 0 0 0 Enabled
456.98 2920 64.78 31 26.3 457.11 0 0 0 Enabled 456.87 0 0 0 Enabled
457.37 2920 64.78 31 26.3 457.49 0 0 0 Enabled 457.24 0 0 0 Enabled
457.75 2920 64.56 31 26.3 457.88 0 0 0 Enabled 457.63 0 0 0 Enabled
458.13 2960 64.72 31 26.3 458.26 0 0 0 Enabled 458.01 0 0 0 Enabled
458.51 2960 65.22 31 26.3 458.63 0 0 0 Enabled 458.38 0 0 0 Enabled
458.88 2960 64.83 31 26.3 459 0 0 0 Enabled 458.76 0 0 0 Enabled
459.25 2920 65.39 31 26.3 459.38 0 0 0 Enabled 459.12 0 0 0 Enabled
459.63 2960 64.92 31 26.3 459.75 0 0 0 Enabled 459.5 0 0 0 Enabled
460 2960 65.28 31 26.3 460.13 0 0 0 Enabled 459.88 0 0 0 Enabled
460.38 2920 65.25 31 26.3 460.5 0 0 0 Enabled 460.25 0 0 0 Enabled
460.77 2960 65.25 31 26.3 460.89 0 0 0 Enabled 460.64 0 0 0 Enabled
461.15 2960 65.31 31 25.5 461.27 0 0 0 Enabled 461.02 0 0 0 Enabled
461.52 2960 65.53 31 26.3 461.65 0 0 0 Enabled 461.4 0 0 0 Enabled
461.9 2920 65.5 31 25.5 462.02 0 0 0 Enabled 461.77 0 0 0 Enabled
462.27 2960 65.31 31 26.3 462.4 0 0 0 Enabled 462.15 0 0 0 Enabled
462.65 2960 64.86 31 26.3 462.77 0 0 0 Enabled 462.52 0 0 0 Enabled
463.02 2920 65.03 31 26.3 463.15 0 0 0 Enabled 462.9 0 0 0 Enabled
463.39 2920 65.06 31 25.5 463.52 0 0 0 Enabled 463.27 0 0 0 Enabled
463.77 2920 64.64 31 26.3 463.89 0 0 0 Enabled 463.65 0 0 0 Enabled
464.15 2920 64.58 31 26.3 464.27 0 0 0 Enabled 464.02 0 0 0 Enabled
464.52 2880 65.11 31 25.5 464.66 0 0 0 Enabled 464.39 0 0 0 Enabled
464.91 2840 64.33 31 24.8 465.04 0 0 0 Enabled 464.78 0 0 0 Enabled
465.29 2840 64.08 31 24.8 465.41 0 0 0 Enabled 465.16 0 0 0 Enabled
465.66 2880 64.03 31 24.8 465.78 0 0 0 Enabled 465.53 0 0 0 Enabled
466.04 2800 63.08 30.6 24.8 466.16 0 0 0 Enabled 465.92 0 0 0 Enabled
466.41 2840 78.03 52.5 24 466.54 0 0 0 Enabled 466.29 0 0 0 Enabled
466.8 2800 86.33 69.8 12.8 466.93 0 0 0 Enabled 466.68 0 0 0 Enabled
467.18 2800 86.36 74.1 12.8 467.3 0 0 0 Enabled 467.05 0 0 0 Enabled
467.55 2840 85.33 60.8 10.5 467.68 0 0 0 Enabled 467.43 0 0 0 Enabled
467.92 2760 82.17 47.5 12.8 468.05 0 0 0 Enabled 467.8 0 0 0 Enabled
468.3 2800 78.81 39.2 15.8 468.43 0 0 0 Enabled 468.18 0 0 0 Enabled
468.68 2760 75.83 35.3 20.3 468.8 0 0 0 Enabled 468.55 0 0 0 Enabled
469.05 2760 74.03 34.1 21 469.18 0 0 0 Enabled 468.92 0 0 0 Enabled
469.43 2720 73.39 33.7 18.8 469.56 0 0 0 Enabled 469.3 0 0 0 Enabled
469.8 2720 72.81 33.7 18.8 469.92 0 0 0 Enabled 469.68 0 0 0 Enabled
470.18 2720 73.03 33.7 21 470.3 0 0 0 Enabled 470.05 0 0 0 Enabled
470.55 2720 72.64 33.3 19.5 470.69 0 0 0 Enabled 470.43 0 0 0 Enabled
470.94 2720 72.53 33.3 19.5 471.07 0 0 0 Enabled 470.82 0 0 0 Enabled
471.32 2720 72.06 32.9 21 471.44 0 0 0 Enabled 471.19 0 0 0 Enabled
471.69 2720 72.03 32.9 19.5 471.82 0 0 0 Enabled 471.57 0 0 0 Enabled
472.07 2760 71.86 32.9 16.5 472.19 0 0 0 Enabled 471.94 0 0 0 Enabled
472.44 2760 71.69 32.9 17.3 472.57 0 0 0 Enabled 472.32 0 0 0 Enabled
472.83 2760 71.97 33.3 16.5 472.96 0 0 0 Enabled 472.71 0 0 0 Enabled
473.21 2760 72.11 33.3 16.5 473.33 0 0 0 Enabled 473.08 0 0 0 Enabled
473.59 2720 72.36 33.3 21 473.71 0 0 0 Enabled 473.46 0 0 0 Enabled
473.96 2720 72.5 33.3 17.3 474.09 0 0 0 Enabled 473.83 0 0 0 Enabled
474.34 2760 72.72 33.3 21 474.46 0 0 0 Enabled 474.21 0 0 0 Enabled
474.71 2760 72.61 33.3 17.3 474.83 0 0 0 Enabled 474.58 0 0 0 Enabled
475.08 2760 73.08 33.3 17.3 475.21 0 0 0 Enabled 474.96 0 0 0 Enabled
475.46 2760 73.31 33.3 21 475.58 0 0 0 Enabled 475.33 0 0 0 Enabled
475.83 2800 73.56 33.7 18.8 475.96 0 0 0 Enabled 475.71 0 0 0 Enabled
476.21 2760 73.42 33.3 18.8 476.33 0 0 0 Enabled 476.08 0 0 0 Enabled
476.58 2840 72.92 33.3 19.5 476.72 0 0 0 Enabled 476.46 0 0 0 Enabled
476.98 2800 69.17 32.5 21 477.1 0 0 0 Enabled 476.85 0 0 0 Enabled
477.35 2840 67.83 31.8 21 477.47 0 0 0 Enabled 477.22 0 0 0 Enabled
477.72 2840 67 31.8 21.8 477.85 0 0 0 Enabled 477.6 0 0 0 Enabled
478.1 2800 66 31.4 24.8 478.22 0 0 0 Enabled 477.97 0 0 0 Enabled
478.48 2800 65.89 31.8 24.8 478.6 0 0 0 Enabled 478.35 0 0 0 Enabled
478.85 2840 65.64 31.8 24.8 478.98 0 0 0 Enabled 478.73 0 0 0 Enabled
479.22 2880 65.89 31.4 24.8 479.35 0 0 0 Enabled 479.1 0 0 0 Enabled
479.6 2880 68.11 36.1 23.3 479.74 0 0 0 Enabled 479.46 0 0 0 Enabled
479.99 2840 71 34.9 23.3 480.12 0 0 0 Enabled 479.86 0 0 0 Enabled
480.36 2840 71.14 32.9 23.3 480.49 0 0 0 Enabled 480.24 0 0 0 Enabled
480.74 2880 70.31 32.5 23.3 480.87 0 0 0 Enabled 480.61 0 0 0 Enabled
481.11 2840 68.22 32.2 23.3 481.24 0 0 0 Enabled 480.99 0 0 0 Enabled
481.49 2880 67.86 32.2 23.3 481.61 0 0 0 Enabled 481.36 0 0 0 Enabled
481.87 2840 67.94 31.8 23.3 481.99 0 0 0 Enabled 481.74 0 0 0 Enabled
482.24 2840 68.08 31.8 23.3 482.37 0 0 0 Enabled 482.12 0 0 0 Enabled
482.62 2840 67.83 32.2 24 482.76 0 0 0 Enabled 482.49 0 0 0 Enabled
483.01 2840 67 31.8 24 483.13 0 0 0 Enabled 482.87 0 0 0 Enabled
483.38 2840 66.97 31.8 24 483.51 0 0 0 Enabled 483.26 0 0 0 Enabled
483.76 2840 66.5 31.8 24.8 483.88 0 0 0 Enabled 483.63 0 0 0 Enabled
484.13 2880 68 32.9 23.3 484.25 0 0 0 Enabled 484 0 0 0 Enabled
484.51 2800 67.53 32.2 23.3 484.63 0 0 0 Enabled 484.38 0 0 0 Enabled
484.88 2840 67.78 32.2 23.3 485 0 0 0 Enabled 484.75 0 0 0 Enabled
485.26 2800 67.83 32.2 23.3 485.38 0 0 0 Enabled 485.13 0 0 0 Enabled
485.63 2800 67.58 31.8 23.3 485.77 0 0 0 Enabled 485.5 0 0 0 Enabled
486.02 2800 67.25 31.8 23.3 486.14 0 0 0 Enabled 485.89 0 0 0 Enabled
486.4 2800 67.44 31.8 23.3 486.52 0 0 0 Enabled 486.27 0 0 0 Enabled
486.77 2800 67.44 31.8 20.3 486.9 0 0 0 Enabled 486.64 0 0 0 Enabled
487.15 2760 67.28 31.8 20.3 487.27 0 0 0 Enabled 487.02 0 0 0 Enabled
487.52 2800 67.28 31.8 21 487.64 0 0 0 Enabled 487.4 0 0 0 Enabled
487.89 2760 67.08 31.8 23.3 488.02 0 0 0 Enabled 487.77 0 0 0 Enabled
488.27 2800 63.83 28.6 21 488.4 0 0 0 Enabled 488.14 0 0 0 Enabled
488.65 2760 39.94 15.7 27 488.78 0 0 0 Enabled 488.52 0 0 0 Enabled
489.03 2720 55.64 20 27 489.16 0 0 0 Enabled 488.91 0 0 0 Enabled
489.41 2720 55.42 22 26.3 489.54 0 0 0 Enabled 489.29 0 0 0 Enabled
489.79 2680 55.03 22 26.3 489.91 0 0 0 Enabled 489.66 0 0 0 Enabled
490.16 2640 9.64 4.7 34.5 490.28 0 0 0 Enabled 490.04 0 0 0 Enabled
490.54 2640 13.06 6.7 40.5 490.66 0 0 0 Disabled 490.41 0 0 0 Disabled
490.91 2600 13.17 6.3 6 491.04 0 0 0 Disabled 490.79 0 0 0 Disabled
491.29 2520 12.67 6.7 41.3 491.41 0 0 0 Disabled 491.16 0 0 0 Disabled
491.66 2480 28.86 11 34.5 491.8 0 0 0 Enabled 491.54 0 0 0 Disabled
492.05 2440 22.5 9.4 34.5 492.18 0 0 0 Enabled 491.93 0 0 0 Enabled
492.43 2400 18.19 8.6 36.8 492.55 0 0 0 Enabled 492.3 0 0 0 Enabled
492.8 2400 18.97 8.6 36.8 492.93 0 0 0 Enabled 492.67 0 0 0 Enabled
493.17 2360 19.17 8.6 36.8 493.3 0 0 0 Enabled 493.05 0 0 0 Enabled
493.55 2320 19.14 8.6 38.3 493.68 0 0 0 Enabled 493.42 0 0 0 Enabled
493.93 2280 19.33 8.6 36 494.05 0 0 0 Enabled 493.8 0 0 0 Enabled
494.31 2240 22.86 9.8 36.8 494.42 0 0 0 Enabled 494.18 0 0 0 Enabled
494.67 2240 23.69 9.8 35.3 494.8 0 0 0 Enabled 494.55 0 0 0 Enabled
495.05 2200 17.94 8.2 35.3 495.18 0 0 0 Enabled 494.93 0 0 0 Enabled
495.43 2160 12.78 6.3 36.8 495.55 0 0 0 Enabled 495.3 0 0 0 Enabled
495.82 2160 12.83 6.3 39 495.94 0 0 0 Enabled 495.68 0 0 0 Enabled
496.19 2120 15.11 7.1 36.8 496.32 0 0 0 Enabled 496.07 0 0 0 Enabled
496.57 2120 10.61 5.1 39 496.69 0 0 0 Disabled 496.44 0 0 0 Enabled
496.94 2040 10.28 5.1 3.8 497.07 0 0 0 Disabled 496.82 0 0 0 Disabled
497.32 2040 10.14 5.1 3.8 497.44 0 0 0 Disabled 497.19 0 0 0 Disabled
497.69 1920 9.94 5.1 3 497.82 0 0 0 Disabled 497.56 0 0 0 Disabled
498.07 1840 9.64 4.7 2.3 498.2 0 0 0 Disabled 497.94 0 0 0 Disabled
498.44 1800 9.25 4.7 1.5 498.57 0 0 0 Disabled 498.32 0 0 0 Disabled
498.83 1760 8.92 4.3 0.8 498.96 0 0 0 Disabled 498.69 0 0 0 Disabled
499.21 1680 8.78 4.3 0.8 499.33 0 0 0 Disabled 499.09 0 0 0 Disabled
499.58 1640 15.72 7.8 39 499.71 0 0 0 Disabled 499.46 0 0 0 Disabled
499.96 1640 18.06 8.2 33 500.08 0 0 0 Enabled 499.83 0 0 0 Disabled
500.33 1680 24.53 11 29.3 500.46 0 0 0 Enabled 500.21 0 0 0 Enabled
500.71 1640 24.36 11 28.5 500.83 0 0 0 Enabled 500.58 0 0 0 Enabled
501.08 1720 28.83 13.3 27 501.21 0 0 0 Enabled 500.96 0 0 0 Enabled
501.45 1640 28.67 13.7 26.3 501.58 0 0 0 Enabled 501.33 0 0 0 Enabled
501.85 1680 28.72 14.1 26.3 501.97 0 0 0 Enabled 501.71 0 0 0 Enabled
502.23 1680 25.53 12.5 26.3 502.35 0 0 0 Enabled 502.1 0 0 0 Enabled
502.6 1720 25.83 11.8 27 502.73 0 0 0 Enabled 502.48 0 0 0 Enabled
502.98 1720 25.86 12.2 27.8 503.1 0 0 0 Enabled 502.85 0 0 0 Enabled
503.35 1720 25.17 11.4 28.5 503.48 0 0 0 Enabled 503.23 0 0 0 Enabled
503.72 1720 24.81 11 28.5 503.85 0 0 0 Enabled 503.6 0 0 0 Enabled
504.1 1720 24.61 11 29.3 504.22 0 0 0 Enabled 503.97 0 0 0 Enabled
504.47 1720 24.31 10.6 28.5 504.6 0 0 0 Enabled 504.35 0 0 0 Enabled
504.86 1720 21.56 9.4 30 504.99 0 0 0 Enabled 504.72 0 0 0 Enabled
505.24 1760 20.94 9.4 30.8 505.36 0 0 0 Enabled 505.12 0 0 0 Enabled
505.62 1720 18.5 8.6 32.3 505.74 0 0 0 Disabled 505.49 0 0 0 Enabled
505.99 1760 21.14 9.4 32.3 506.12 0 0 0 Disabled 505.87 0 0 0 Disabled
506.36 1880 20.94 9.4 32.3 506.49 0 0 0 Disabled 506.24 0 0 0 Disabled
506.74 2400 27.03 11.4 32.3 506.86 0 0 0 Disabled 506.61 0 0 0 Disabled
507.12 2640 24.17 10.2 34.5 507.24 0 0 0 Disabled 506.99 0 0 0 Disabled
507.49 2680 24.53 10.2 36 507.62 0 0 0 Disabled 507.37 0 0 0 Disabled
507.87 2680 31.44 12.5 33.8 507.99 0 0 0 Disabled 507.74 0 0 0 Disabled
508.24 2680 36.89 14.1 30.8 508.37 0 0 0 Enabled 508.11 0 0 0 Disabled
508.61 2720 36.78 14.1 30.8 508.74 0 0 0 Enabled 508.49 0 0 0 Enabled
509 2720 36.61 14.1 30.8 509.13 0 0 0 Enabled 508.88 0 0 0 Enabled
509.38 2680 36.36 14.1 30.8 509.5 0 0 0 Enabled 509.25 0 0 0 Enabled
509.76 2720 36.36 14.1 30.8 509.88 0 0 0 Enabled 509.63 0 0 0 Enabled
510.13 2720 36.44 14.1 30.8 510.25 0 0 0 Enabled 510 0 0 0 Enabled
510.5 2720 36.42 14.1 30.8 510.63 0 0 0 Enabled 510.38 0 0 0 Enabled
510.88 2720 37.83 14.9 30.8 511 0 0 0 Enabled 510.75 0 0 0 Enabled
511.26 2720 39.19 15.3 30.8 511.38 0 0 0 Enabled 511.13 0 0 0 Enabled
511.63 2720 40.47 15.7 30 511.76 0 0 0 Enabled 511.51 0 0 0 Enabled
512.02 2720 40.33 15.3 30 512.15 0 0 0 Enabled 511.89 0 0 0 Enabled
512.39 2720 40.19 15.3 30 512.52 0 0 0 Enabled 512.27 0 0 0 Enabled
512.77 2720 39.81 15.3 30 512.9 0 0 0 Enabled 512.64 0 0 0 Enabled
513.15 2680 39.39 15.3 30 513.27 0 0 0 Enabled 513.02 0 0 0 Enabled
513.52 2720 46.89 17.3 29.3 513.64 0 0 0 Enabled 513.4 0 0 0 Enabled
513.91 2680 46.92 17.6 28.5 514.03 0 0 0 Enabled 513.77 0 0 0 Enabled
514.29 2640 48 18.4 28.5 514.41 0 0 0 Enabled 514.16 0 0 0 Enabled
514.66 2640 47.97 18.4 28.5 514.79 0 0 0 Enabled 514.53 0 0 0 Enabled
515.04 2600 47.78 18 28.5 515.16 0 0 0 Enabled 514.91 0 0 0 Enabled
515.41 2640 47.33 18 29.3 515.54 0 0 0 Enabled 515.29 0 0 0 Enabled
515.79 2600 48.17 18.8 28.5 515.91 0 0 0 Enabled 515.66 0 0 0 Enabled
516.16 2640 59.39 29 25.5 516.29 0 0 0 Enabled 516.04 0 0 0 Enabled
516.54 2600 65.19 40 21.8 516.66 0 0 0 Enabled 516.41 0 0 0 Enabled
516.91 2640 57.17 28.6 25.5 517.04 0 0 0 Enabled 516.79 0 0 0 Enabled
517.28 2640 57.11 28.2 25.5 517.41 0 0 0 Enabled 517.16 0 0 0 Enabled
517.66 2640 57.14 27.1 25.5 517.79 0 0 0 Enabled 517.53 0 0 0 Enabled
518.05 2680 56.64 25.9 25.5 518.18 0 0 0 Enabled 517.92 0 0 0 Enabled
518.42 2680 56.19 25.1 26.3 518.55 0 0 0 Enabled 518.3 0 0 0 Enabled
518.8 2680 56.72 25.1 26.3 518.93 0 0 0 Enabled 518.68 0 0 0 Enabled
519.17 2720 56.72 25.1 26.3 519.3 0 0 0 Enabled 519.05 0 0 0 Enabled
519.56 2680 57.28 25.1 25.5 519.68 0 0 0 Enabled 519.43 0 0 0 Enabled
519.92 2720 57.39 25.1 25.5 520.05 0 0 0 Enabled 519.8 0 0 0 Enabled
520.3 2720 57.36 25.1 25.5 520.43 0 0 0 Enabled 520.18 0 0 0 Enabled
520.68 2760 57.75 25.1 25.5 520.8 0 0 0 Enabled 520.55 0 0 0 Enabled
521.07 2760 56.03 23.5 27 521.19 0 0 0 Enabled 520.94 0 0 0 Enabled
521.44 2760 52.14 20.8 27 521.57 0 0 0 Enabled 521.32 0 0 0 Enabled
521.82 2760 50.47 19.2 27.8 521.94 0 0 0 Enabled 521.69 0 0 0 Enabled
522.19 2720 49.64 18.8 28.5 522.32 0 0 0 Enabled 522.07 0 0 0 Enabled
522.57 2720 49.5 18.4 28.5 522.69 0 0 0 Enabled 522.44 0 0 0 Enabled
522.95 2680 49.33 18.8 28.5 523.07 0 0 0 Enabled 522.82 0 0 0 Enabled
523.32 2720 49.25 18.4 28.5 523.45 0 0 0 Enabled 523.2 0 0 0 Enabled
523.7 2680 49.11 18.4 28.5 523.82 0 0 0 Enabled 523.57 0 0 0 Enabled
524.08 2720 49.19 18.8 28.5 524.21 0 0 0 Enabled 523.96 0 0 0 Enabled
524.46 2680 53.11 20.8 28.5 524.58 0 0 0 Enabled 524.33 0 0 0 Enabled
524.83 2720 56.89 24.3 27 524.96 0 0 0 Enabled 524.71 0 0 0 Enabled
525.21 2720 57.42 25.5 27 525.33 0 0 0 Enabled 525.08 0 0 0 Enabled
525.58 2720 58.03 26.3 27 525.71 0 0 0 Enabled 525.46 0 0 0 Enabled
525.97 2760 56.17 23.5 27 526.1 0 0 0 Enabled 525.83 0 0 0 Enabled
526.35 2760 53.56 20.8 28.5 526.47 0 0 0 Enabled 526.23 0 0 0 Enabled
526.73 2760 52.56 20 28.5 526.85 0 0 0 Enabled 526.6 0 0 0 Enabled
527.1 2720 47.36 18.4 28.5 527.23 0 0 0 Enabled 526.97 0 0 0 Enabled
527.48 2720 47.47 17.6 28.5 527.6 0 0 0 Enabled 527.35 0 0 0 Enabled
527.85 2720 47.67 17.6 29.3 527.97 0 0 0 Enabled 527.72 0 0 0 Enabled
528.22 2720 47.86 18 28.5 528.35 0 0 0 Enabled 528.1 0 0 0 Enabled
528.6 2720 47.78 18 28.5 528.72 0 0 0 Enabled 528.47 0 0 0 Enabled
528.97 2720 47.67 18 28.5 529.1 0 0 0 Enabled 528.85 0 0 0 Enabled
529.35 2680 47.17 17.6 28.5 529.47 0 0 0 Enabled 529.23 0 0 0 Enabled
529.72 2680 46.94 17.6 28.5 529.85 0 0 0 Enabled 529.6 0 0 0 Enabled
530.11 2640 46.61 17.6 28.5 530.24 0 0 0 Enabled 529.99 0 0 0 Enabled
530.49 2640 46.33 17.6 28.5 530.61 0 0 0 Enabled 530.36 0 0 0 Enabled
530.87 2600 46.61 18 28.5 530.99 0 0 0 Enabled 530.74 0 0 0 Enabled
531.24 2640 46.75 18 28.5 531.36 0 0 0 Enabled 531.12 0 0 0 Enabled
531.61 2600 48.58 18.8 29.3 531.74 0 0 0 Enabled 531.49 0 0 0 Enabled
531.99 2560 49.56 19.6 28.5 532.12 0 0 0 Enabled 531.87 0 0 0 Enabled
532.37 2600 49.78 20 27.8 532.49 0 0 0 Enabled 532.24 0 0 0 Enabled
532.74 2560 52.28 22 27 532.87 0 0 0 Enabled 532.61 0 0 0 Enabled
533.13 2520 52.69 23.5 26.3 533.26 0 0 0 Enabled 533 0 0 0 Enabled
533.5 2520 52.86 23.1 27 533.63 0 0 0 Enabled 533.38 0 0 0 Enabled
533.88 2520 51.14 22.4 27 534 0 0 0 Enabled 533.75 0 0 0 Enabled
534.26 2520 50.42 21.2 26.3 534.38 0 0 0 Enabled 534.13 0 0 0 Enabled
534.63 2520 50.56 20.8 26.3 534.75 0 0 0 Enabled 534.51 0 0 0 Enabled
535.01 2520 50.25 20.8 26.3 535.13 0 0 0 Enabled 534.88 0 0 0 Enabled
535.39 2520 48.94 20 27 535.51 0 0 0 Enabled 535.25 0 0 0 Enabled
535.76 2520 49.36 20 27.8 535.88 0 0 0 Enabled 535.63 0 0 0 Enabled
536.15 2560 49.47 20.4 27.8 536.27 0 0 0 Enabled 536.02 0 0 0 Enabled
536.52 2480 49.44 20 26.3 536.64 0 0 0 Enabled 536.4 0 0 0 Enabled
536.9 2520 47.86 18.8 27.8 537.02 0 0 0 Enabled 536.77 0 0 0 Enabled
537.27 2520 46.31 18 28.5 537.39 0 0 0 Enabled 537.15 0 0 0 Enabled
537.65 2560 45.47 17.6 29.3 537.77 0 0 0 Enabled 537.52 0 0 0 Enabled
538.01 2520 44.97 17.6 29.3 538.14 0 0 0 Enabled 537.89 0 0 0 Enabled
538.39 2560 44.81 17.6 29.3 538.52 0 0 0 Enabled 538.27 0 0 0 Enabled
538.77 2520 44.39 17.6 29.3 538.89 0 0 0 Enabled 538.64 0 0 0 Enabled
539.16 2520 44.11 17.3 29.3 539.29 0 0 0 Enabled 539.04 0 0 0 Enabled
539.54 2520 43.89 17.3 28.5 539.66 0 0 0 Enabled 539.41 0 0 0 Enabled
539.91 2520 43.92 17.3 29.3 540.04 0 0 0 Enabled 539.79 0 0 0 Enabled
540.29 2520 43.97 17.3 29.3 540.41 0 0 0 Enabled 540.16 0 0 0 Enabled
540.66 2480 44.08 17.3 29.3 540.79 0 0 0 Enabled 540.54 0 0 0 Enabled
541.03 2520 43.72 17.3 29.3 541.16 0 0 0 Enabled 540.91 0 0 0 Enabled
541.41 2520 37.06 14.9 29.3 541.54 0 0 0 Enabled 541.29 0 0 0 Enabled
541.79 2520 35.17 14.1 30 541.91 0 0 0 Enabled 541.66 0 0 0 Enabled
542.16 2520 34.58 13.7 30.8 542.29 0 0 0 Enabled 542.04 0 0 0 Enabled
542.53 2480 35.17 14.1 30.8 542.66 0 0 0 Enabled 542.41 0 0 0 Enabled
542.91 2440 35.5 14.1 30 543.05 0 0 0 Enabled 542.79 0 0 0 Enabled
543.3 2480 36.06 14.5 30.8 543.43 0 0 0 Enabled 543.17 0 0 0 Enabled
543.68 2480 36.47 14.9 30 543.81 0 0 0 Enabled 543.56 0 0 0 Enabled
544.06 2400 35.17 14.1 30 544.18 0 0 0 Enabled 543.92 0 0 0 Enabled
544.43 2400 34.64 14.1 30 544.55 0 0 0 Enabled 544.3 0 0 0 Enabled
544.8 2400 29.03 12.2 30 544.93 0 0 0 Enabled 544.68 0 0 0 Enabled
545.19 2360 10.33 5.1 35.3 545.32 0 0 0 Enabled 545.07 0 0 0 Enabled
545.57 2320 11.28 5.9 39 545.69 0 0 0 Disabled 545.44 0 0 0 Disabled
545.94 2280 11.28 5.9 4.5 546.07 0 0 0 Disabled 545.82 0 0 0 Disabled
546.32 2160 10.78 5.5 4.5 546.44 0 0 0 Disabled 546.19 0 0 0 Disabled
546.69 2080 10.42 5.1 3.8 546.82 0 0 0 Disabled 546.57 0 0 0 Disabled
547.07 2000 10.14 5.1 3.8 547.19 0 0 0 Disabled 546.94 0 0 0 Disabled
547.44 1880 9.75 4.7 18.8 547.57 0 0 0 Disabled 547.32 0 0 0 Disabled
547.82 1720 9.08 4.3 12.8 547.94 0 0 0 Disabled 547.69 0 0 0 Disabled
548.21 1520 7.97 3.9 27 548.33 0 0 0 Disabled 548.09 0 0 0 Disabled
548.59 1320 7.5 3.5 34.5 548.71 0 0 0 Disabled 548.46 0 0 0 Disabled
548.96 1040 9.19 5.1 30.8 549.08 0 0 0 Disabled 548.83 0 0 0 Disabled
549.33 840 20.47 9 20.3 549.46 0 0 0 Disabled 549.21 0 0 0 Disabled
549.71 960 11.39 5.9 20.3 549.83 0 0 0 Enabled 549.58 0 0 0 Enabled
550.08 1080 7.75 4.7 24 550.21 0 0 0 Enabled 549.96 0 0 0 Enabled
550.46 1040 8.25 4.3 24.8 550.58 0 0 0 Enabled 550.33 0 0 0 Enabled
550.83 920 8.72 4.7 24 550.96 0 0 0 Enabled 550.71 0 0 0 Enabled
551.22 840 9.14 4.3 20.3 551.35 0 0 0 Enabled 551.1 0 0 0 Enabled
551.59 800 8.33 3.9 20.3 551.72 0 0 0 Enabled 551.47 0 0 0 Enabled
551.97 720 11.44 4.3 20.3 552.1 0 0 0 Enabled 551.85 0 0 0 Enabled
552.34 720 8.31 4.3 18 552.48 0 0 0 Enabled 552.23 0 0 0 Enabled
552.72 720 8.22 5.9 18.8 552.84 0 0 0 Enabled 552.6 0 0 0 Enabled
553.1 640 9.44 7.1 15.8 553.23 0 0 0 Enabled 552.97 0 0 0 Enabled
553.47 480 10.06 6.3 13.5 553.6 0 0 0 Enabled 553.35 0 0 0 Enabled
553.85 560 7.89 6.3 10.5 553.97 0 0 0 Enabled 553.72 0 0 0 Enabled
554.24 480 7.42 5.1 12.8 554.36 0 0 0 Enabled 554.11 0 0 0 Enabled
554.62 440 25.69 7.5 11.3 554.74 0 0 0 Enabled 554.49 0 0 0 Enabled
554.99 480 8.42 7.5 12.8 555.11 0 0 0 Enabled 554.86 0 0 0 Enabled
555.36 400 7.31 6.7 12 555.48 0 0 0 Enabled 555.23 0 0 0 Enabled
555.73 400 6.53 5.1 12 555.86 0 0 0 Enabled 555.61 0 0 0 Enabled
556.11 440 7.08 8.2 12 556.24 0 0 0 Disabled 555.98 0 0 0 Enabled
556.48 440 8.89 8.2 12.8 556.61 0 0 0 Disabled 556.36 0 0 0 Disabled
556.87 440 7.36 6.3 12 556.99 0 0 0 Enabled 556.73 0 0 0 Disabled
557.26 520 5.75 6.7 12.8 557.38 0 0 0 Enabled 557.13 0 0 0 Enabled
557.63 560 8.19 7.8 12.8 557.75 0 0 0 Enabled 557.5 0 0 0 Enabled
558 440 8.33 7.8 12.8 558.13 0 0 0 Enabled 557.88 0 0 0 Enabled
558.38 480 8.33 9 12 558.51 0 0 0 Enabled 558.25 0 0 0 Enabled
558.75 480 9.14 8.2 12 558.88 0 0 0 Enabled 558.63 0 0 0 Enabled
559.13 480 9.67 8.6 12.8 559.26 0 0 0 Enabled 559 0 0 0 Enabled
559.51 440 9.31 10.6 12 559.64 0 0 0 Enabled 559.38 0 0 0 Enabled
559.88 480 7.78 9.8 12.8 560 0 0 0 Enabled 559.75 0 0 0 Enabled
560.26 440 8.19 9.4 12 560.38 0 0 0 Enabled 560.14 0 0 0 Enabled
560.63 480 10.44 14.1 12.8 560.76 0 0 0 Enabled 560.51 0 0 0 Enabled
561 440 8.39 11 11.3 561.14 0 0 0 Enabled 560.88 0 0 0 Enabled
561.4 400 7.56 8.6 11.3 561.52 0 0 0 Enabled 561.27 0 0 0 Enabled
561.77 440 6.89 9 12 561.9 0 0 0 Enabled 561.65 0 0 0 Enabled
562.15 440 9.39 7.8 12 562.27 0 0 0 Enabled 562.02 0 0 0 Enabled
562.52 480 7.44 9.8 12 562.64 0 0 0 Disabled 562.4 0 0 0 Disabled
562.9 360 6.36 6.7 12 563.03 0 0 0 Disabled 562.77 0 0 0 Disabled
563.29 400 8.36 8.2 12 563.41 0 0 0 Disabled 563.16 0 0 0 Disabled
563.67 480 7.47 9 12 563.79 0 0 0 Disabled 563.54 0 0 0 Disabled
564.03 360 7.14 8.6 12 564.16 0 0 0 Disabled 563.92 0 0 0 Disabled
564.41 400 10.5 9.8 12 564.54 0 0 0 Disabled 564.29 0 0 0 Disabled
564.79 400 8.25 30.2 12 564.91 0 0 0 Disabled 564.66 0 0 0 Disabled
565.16 0 0 85.5 11.3 565.28 0 0 0 Disabled 565.04 0 0 0 Disabled
565.54 0 0 0.8 11.3 565.65 0 0 0 Disabled 565.42 0 0 0 Disabled
565.91 0 1.31 1.2 11.3 566.04 0 0 0 Disabled 565.79 0 0 0 Disabled
566.3 0 1.31 1.2 11.3 566.43 0 0 0 Disabled 566.17 0 0 0 Disabled
566.67 0 1.31 1.2 11.3 566.8 0 0 0 Disabled 566.55 0 0 0 Disabled
567.05 0 1.31 1.2 11.3 567.17 0 0 0 Disabled 566.92 0 0 0 Disabled
567.42 0 1.39 1.2 11.3 567.55 0 0 0 Disabled 567.3 0 0 0 Disabled
567.8 0 1.31 6.3 11.3 567.92 0 0 0 Disabled 567.67 0 0 0 Disabled
568.17 0 1.47 6.3 11.3 568.3 0 0 0 Disabled 568.05 0 0 0 Disabled
568.55 0 1.31 6.3 11.3 568.68 0 0 0 Disabled 568.43 0 0 0 Disabled
568.92 0 1.31 6.3 11.3 569.05 0 0 0 Disabled 568.8 0 0 0 Disabled
569.32 0 1.31 6.3 11.3 569.44 0 0 0 Disabled 569.19 0 0 0 Disabled
569.7 0 0 6.3 11.3 569.82 0 0 0 Disabled 569.57 0 0 0 Disabled
pauljs33
C?ID=385174
I am attaching a scan of the vehicle that I ran today. This should include codes that were thrown while I did the test drive.
There's a bunch of Engine related codes. Also a Battery Regulator Intermittent code that I haven't seen in past scans
BR
P
Thursday,08,October,2020,11:22:32:04546
Dealer/Shop Name: Paul
VIN: WA1AY74L28D042453   License Plate: XXXXXXXX
Mileage: 250050km-155373mi   Repair Order: 18
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 42 46 47 4F 52 56
          61 62 65 6D 6F 72
VIN: WA1AY74L28D042453   Mileage: 250050km-155373miles
6F-Centr. Conv. II -- Status: Malfunction 0010
Address 01: Engine (BHK)       Labels: 03H-906-032-BLV.clb
   Part No SW: 03H 906 032 CA    HW: 03H 906 032 G
   Component: Q7 3.6-FSI-LEV2 G   1379
   Revision: 5CH05---    Serial number:
   Coding: 0001175
   Shop #: WSC 31414 790 00001
   VCID: 6393A8C17754A4332F1-8036
008518 - Supply Voltage for Fuel Injector Group A
               P2146 - 002 - Open Circuit - Intermittent
                    Mileage: 249832 km
                    Date: 2020.10.03
                    Time: 13:18:10
                    RPM: 4110 /min
                    Load: 98.8 %
                    Speed: 75.0 km/h
                    Temperature: 89.0°C
                    Temperature: 23.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.589 V
                    Mileage: 249995 km
                    Date: 2020.10.05
                    Time: 11:45:47
                    RPM: 2307 /min
                    Load: 62.3 %
                    Speed: 26.0 km/h
                    Temperature: 54.0°C
                    Temperature: 24.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 13.970 V
000628 - Fuel Injector #5 (N83)
               P0274 - 001 - Short to Plus - Intermittent
                    Fault Status: 00100001
                    Mileage: 250030 km
                    Date: 2020.10.05
                    Time: 17:26:39
                    RPM: 4110 /min
                    Load: 98.8 %
                    Speed: 75.0 km/h
                    Temperature: 89.0°C
                    Temperature: 23.0°C
                    Voltage: 13.589 V
               P0300 - 001 -  - Intermittent - MIL ON
                    Fault Status: 10100001
                    Mileage: 250030 km
                    Date: 2020.10.05
                    Time: 17:26:39
                    RPM: 4110 /min
                    Load: 98.0 %
                    Speed: 75.0 km/h
                    Temperature: 89.0°C
                    Temperature: 23.0°C
                    Voltage: 13.462 V
000773 - Cylinder 5
               P0305 - 001 - Misfire Detected - Intermittent - MIL ON
                    Mileage: 250030 km
                    Date: 2020.10.05
                    Time: 17:26:39
                    RPM: 4110 /min
                    Load: 98.0 %
                    Speed: 75.0 km/h
                    Temperature: 89.0°C
                    Temperature: 23.0°C
                    Voltage: 13.462 V
000320 - Oxygen (Lambda) Sensor B1 S2
               P0140 - 004 - No Activity - Intermittent
                    Mileage: 250040 km
                    Date: 2020.10.05
                    Time: 17:58:04
                    RPM: 2448 /min
                    Load: 22.0 %
                    Speed: 84.0 km/h
                    Temperature: 97.0°C
                    Temperature: 18.0°C
                    Voltage: 13.716 V
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 4L0 910 156 B    HW: 0AT 927 156
   Component: AG6 0AT 3,6 FSI USA 0010
   Revision: --H04---    Serial number:        4035629
   Coding: 0000002
   VCID: 2809FFED4EF2076B3A3-807C
   Part No SW: 4L0 910 517 B    HW: 4L0 614 517 D
   Component: ESP ALLRAD MK25E1   0010
   Revision: 00H30001
   Coding: 0099345
   VCID: 290FFAE955F83E6325D-807C
                    Fault Status: 00101101
                    Reset counter: 180
                    Mileage: 249620 km
                    Date: 2020.09.26
                    Time: 15:28:02
                    Count: 8257
                    Count: 8193
                    Count: 48640
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0230
   Revision: 09010701    Serial number: 10601500957792
   Coding: 0000131
   Subsystem 1 - Part No: 4F0 910 131 J
   Component: FBSAUDIC6 EZS   H45 0080
   Subsystem 2 - Part No: 4F0 910 220 A
   Component: FBSAUDIC6 IDG   H01 0040
Address 07: Control Head        Labels: Redir Fail!
   Part No SW: 4L0 910 730 Q    HW: 4L0 035 730 C
   Component: MMI Cockpit     H80 0410
   Revision: C61120EU    Serial number: AUZ6Z2GBMD36I3
   Coding: 0444222
   VCID: 3537269989406A83B15-8060
   Component: Bedienteil MMIC6H01 0060
   Subsystem 2 - Serial number: 00000001337903
   Subsystem 3 - Serial number: 0123.06.090000000100010489ÿ
   Subsystem 4 - Serial number: 010489ÿ
   Part No SW: 4L0 910 043 B    HW: 4L0 820 043 L
   Component: KLIMABETAETIGUNGH07 0030
   Revision: 00---013    Serial number: 00000030075150
   Coding: 0524326
   VCID: 2313E8C137D4E4336F1-8076
   Part No SW: 4F0 910 279 K    HW: 4F0 907 279
   Component: ILM Fahrer      H18 0250
   Coding: 0010103
   VCID: 313F12897D2846A3EDD-8064
   Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H14 0100
   Coding: 00064792
   Shop #: WSC 31414
   Subsystem 2 - Part No: 4E0 910 557 B  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0100
   Coding: 00150059
   Shop #: WSC 31414
Address 0E: Media Player 1        Labels: None
   Coding: 0444222
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 K    HW: 4E0 035 593 F
   Component: SDAR SIRIUS     H07 0140
   Revision: 00000000    Serial number: AUZ4Z7G0215383
   Coding: 0000100
   VCID: 2F3B14F16B1C5053FB9-807A
                    Time Indication: 15
   Part No SW: 4L0 910 655 A    HW: 4L0 959 655 B
   Component: 73 AIRBAG AUDI8RH42 0230
   Revision: 06H42000    Serial number: 0038QD07AHFD
   Coding: 0014131
   VCID: 2B0300E15F042C73D71-807E
   Subsystem 1 - Part No: 4L0 910 339 A
   Component: BF-Gewichtsens. H03 0030
   Subsystem 2 - Serial number: 6332QSME474D250BL
   Subsystem 3 - Serial number: 6342QSME4B21413BD
   Subsystem 4 - Serial number: 6352QSME45182D47L
   Subsystem 5 - Serial number: 6362QSME506E3709M
   Subsystem 6 - Serial number: 63734SME49611F3B8
   Subsystem 7 - Serial number: 63834SME4B212911X
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
   Component: J0527               0410
   Revision: 00H03000    Serial number: 90055073260076
   Coding: 0002022
   VCID: 270BFCD143EC0813339-8072
   Component: E0221           H02 0030
Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
   Part No SW: 4F0 910 900 C    HW: 4L0 920 950 E
   Component: KOMBIINSTR. M73 H16 0240
   Revision: 00200000    Serial number: 65U11K4D7
   Coding: 1555283
   Shop #: WSC 01126 067 57207
   VCID: 2019E7CD26C2FF2B723-8074
Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
   Part No SW: 4L0 910 468 A    HW: 4L0 907 468 B
   Component: J533__Gateway   H06 0060
   Revision: 00H06000    Serial number: 1100B07B278015
   Coding: E557BE57700A0200
   VCID: 2D070EF961102243C95-8078
Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
   Part No SW: 4L0 910 110 A    HW: 4L0 035 110
   Component: MP3-Changer     H45 0350
   Revision: 00045007    Serial number: AUZ5ZBG1242540
   VCID: 1D67DE3911B0D2C3595-8048
Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
   Component: TSG FA          H12 0150
   Revision: 00-00000
   Coding: 0035403
   Part No SW: 4L0 910 289 F    HW: 4L0 907 289 C
   Component: Komfortgeraet   H07 0050
   Revision: 0050 ---    Serial number: 01084767680000
   Coding: 7370781
   VCID: 33331881873474B39F1-8066
01403 - Glass-Break Sensors; Rear
                    Reset counter: 160
Address 47: Sound System (J525)       Labels: Redir Fail!
   Part No SW: 4L0 910 223 H    HW: 4L0 035 223 C
   Component: DSP-AU716-RD  H07 0250
   Revision: S0900000
   Coding: 060000
   VCID: 290FFAE959F83E6325D-807C
   Part No SW: 4F0 910 280     HW: 4F0 907 280 D
   Component: ILM Beifahrer   H12 0100
   Revision:             Serial number: 00000000022253
   Coding: 0012001
   VCID: 5EE599355C3689DB00F-800A
Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
   Component: TSG BF          H12 0150
   Revision: 00-00000
   Coding: 0035403
Address 56: Radio        Labels: None
   Coding: 0444222
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4L0 910 181 A    HW: 4L0 915 181
   Component: J0644 BEM       H12 0690
   Revision: --------    Serial number: 00000000043063
   Shop #: WSC 07109 444 57830
   VCID: 2517F6D939E01A03015-8070
   Subsystem 1 - Part No: 4F0 915 105 C
   Component: von VA0  2711240739
   Coding: 344630393135313035432056413032373131323430373339
02256 - Quiescent Current
                    Reset counter: 171
                    Mileage: 249179 km
                    Date: 2020.09.05
                    Time: 22:08:11
Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
   Component: TSG HL          H21 0150
   Coding: 0035338
Address 65: Tire Pressure        Labels: 4F0-910-273-BA.lbl
   Part No SW: 4F0 910 273 B    HW: 4F0 907 273 A
   Component: Reifendruck 3   H05 0100
   Revision: 00050100    Serial number: 00000900061728
   Coding: 0062424
   VCID: 221DEDC528CEED3B647-8076
   Part No SW: 4L0 910 945     HW: 4L0 827 851 C
   Component: ValeoHeckdeckel H25 0290
   Revision: --H25001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6C81C3FD9A8AEB4B9EB-8038
   Subsystem 3 - Serial number: RD07.12.07--H25001001B0054ÿ
   Subsystem 4 - Serial number: 1B0054ÿ
   Component: ILM HINTEN 2    H05 0060
   Revision: AAH05061    Serial number: 003314871-----
   Coding: 0000009
   VCID: 2615F1D544E6111B08F-8072
02961 - Lamp in Bumper; Rear Right
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 97
                    Mileage: 248545 km
                    Date: 2020.07.12
                    Time: 12:50:32
                    Bin. Bits:  000 100
Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
   Component: TSG HR          H21 0150
   Coding: 0035338
End----------(Elapsed Time: 01:43, VBatt start/end: 12.1V/12.1V)-----------
If it were mine, I would start by trouble-shooting the electrical problems that the ECU reports. I understand this won't be easy because they are Intermittent, but I think there's a good chance they are the cause of the misfires.
TFSI
Maryland, USA
C?ID=66650
P
BR
P
          61 62 65 6D 6F 72
   Coding: 0001175
                    Mileage: 249832 km
                    Date: 2020.10.03
                    Time: 13:18:10
                    RPM: 4110 /min
                    Load: 98.8 %
                    Speed: 75.0 km/h
                    Temperature: 89.0°C
                    Temperature: 23.0°C
                    Voltage: 13.589 V
                    Mileage: 249995 km
                    Date: 2020.10.05
                    Time: 11:45:47
                    RPM: 2307 /min
                    Load: 62.3 %
                    Speed: 26.0 km/h
                    Temperature: 54.0°C
                    Temperature: 24.0°C
                    Voltage: 13.970 V
                    Mileage: 250030 km
                    Date: 2020.10.05
                    Time: 17:26:39
                    RPM: 4110 /min
                    Load: 98.8 %
                    Speed: 75.0 km/h
                    Temperature: 89.0°C
                    Temperature: 23.0°C
                    Voltage: 13.589 V
                    Mileage: 250030 km
                    Date: 2020.10.05
                    Time: 17:26:39
                    RPM: 4110 /min
                    Load: 98.0 %
                    Speed: 75.0 km/h
                    Temperature: 89.0°C
                    Temperature: 23.0°C
                    Voltage: 13.462 V
000773 - Cylinder 5
                    Mileage: 250030 km
                    Date: 2020.10.05
                    Time: 17:26:39
                    RPM: 4110 /min
                    Load: 98.0 %
                    Speed: 75.0 km/h
                    Temperature: 89.0°C
                    Temperature: 23.0°C
                    Voltage: 13.462 V
                    Mileage: 250040 km
                    Date: 2020.10.05
                    Time: 17:58:04
                    RPM: 2448 /min
                    Load: 22.0 %
                    Speed: 84.0 km/h
                    Temperature: 97.0°C
                    Temperature: 18.0°C
                    Voltage: 13.716 V
   Coding: 0000002
   Revision: 00H30001
   Coding: 0099345
                    Reset counter: 180
                    Mileage: 249620 km
                    Date: 2020.09.26
                    Time: 15:28:02
                    Count: 8257
                    Count: 8193
                    Count: 48640
   Coding: 0000131
   Coding: 0444222
   Coding: 0524326
   Coding: 0010103
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Coding: 0444222
   Coding: 0000100
                    Time Indication: 15
   Coding: 0014131
   Coding: 0002022
   Coding: 1555283
   Revision: 00-00000
   Coding: 0035403
   Coding: 7370781
                    Reset counter: 160
   Revision: S0900000
   Coding: 060000
   Coding: 0012001
   Revision: 00-00000
   Coding: 0035403
   Coding: 0444222
                    Reset counter: 171
                    Mileage: 249179 km
                    Date: 2020.09.05
                    Time: 22:08:11
   Coding: 0035338
   Coding: 0062424
   Coding: 0000009
                    Reset counter: 97
                    Mileage: 248545 km
                    Date: 2020.07.12
                    Time: 12:50:32
                    Bin. Bits:  000 100
   Coding: 0035338
Paul,
If this was my car, I will not worry about the battery regulation fault under the circumstance because the expected engine RPM relative to load and firing power intensity is lost when you floor gas pedal due to faulty injection system. This will obviously affect the expected performance of the alternator/battery control. You will need the VAG test box, WD and multimeter to do wiring check, especially on the injector circuits..if possible unplug the N83 circuit to the ECU and check for corrosion as well. Having said that, however If car runs ok during idling and moderate cruising speeds but not when gas pedal is fully depressed, I will not rule out bad circuit but injector nozzle blockage or defective N83- its one of them. Does this makes sense?
pauljs33
C?ID=385174
Thanks Uwe.
This appears to be most likely an electrical issue, So, I think I'd like to do a complete inspection of the wiring harness and connectors. Since I'll need to remove the intake manifold to accomplish this I may as well bite the bullet and replace the injectors. They have >150K miles on them and are probably a little tired at this point. I'll take resistance and inductance measurements of the old injectors to see if there is any differences between them. Since the injectors are inductively actuated electro-mechanical devices, if there is an issue in the inductive coil i'll take that out of the picture by replacing them. I can also try to figure out some sort of bench test on the old injector to see if they are failing to squirt under various pulse widths that might simulate this high loading. This test may not be possible, but I'll investigate and give it a shot if it seems feasible.
Next I'll inspect the integrity of the cable harnesses for any cracking of insulation. I'll also do a good cleaning of the connectors prior to reinstalling on the new injectors.
If it's not the injectors or cable harnesses, the next thing back in the system is probably the ECU. I don't really want to think about that possibility right now....
Let me know if you think I'm off base here.
BR,
P
P
Paul,
Hi T,
Thanks for the comments. I already took a look at N83 a few days ago. Looks pretty clean, but I plan to clean it up with some electronic cleaner to be sure. I've already hit it with some alcohol for good measure. Could you help me with a PN on the VAG test box? When I do a google search, I come up with all sorts of variations on a VAG test box. There are various versions of the VAG 1598/xx available. Any recommendations which one? I Assume I need one that is a breakout box and then use a multimeter or a short/open finder.
Your comments have been very helpful for me. Many thanks for your inputs.
P
TFSI
Maryland, USA
C?ID=66650
Thanks Uwe.
BR,
P
Hi T,
P
I think for the Q7 you will need VAG1598/42 if I remember correctly plus WD. I do not have the long ASE part number but the dealer can help.
pauljs33
C?ID=385174
Thanks T,
I have a full manual with wiring diagrams. I'll be armed and dangerous if I get the 1598.
P
pauljs33
C?ID=385174
Checking back in to give an update. I'm not finished with this yet, but I wanted to share a few things.
1) The VAG 1598/42 was kind of expensive, so I settled for a ghetto version of it. I've attached a link to pic so you can take a look if interested. If I was a pro, I would have bought the VAG 1598, but I figured - How often am I going to be doing this? My ghetto tester has all the pins numbered and served it's purpose. It has breakout pins for the connector which a clip-lead can easily be attached for electrical test.
2) I located 2 bare wires under the Intake manifold. I'm guessing these are at least part of the problem. Interestingly they are on injectors 3 & 5. Injector 5 is where I kept getting intermittent issues.
Still work to do, but making progress.
Thanks to everyone who has given me direction and support on this issue. I will post again when I make more progress.
P
NostraJackAss
The aforementioned in picture, is not your issue, only shows a prior recent butcher since wire is not oxidized yet, however, this FOD must be fixed and connector too!
It doesn't take an expensive 1598 tester to load light the harness end to end isolated.
Further, this truck is known for ECU failure from water ingress right through the vent port if TSB shield failed to be installed by service action.
Is the black shield installed, give us a pic of ECU?
JPPSG and look up decade box tests plus this video.
If you need an ECU please let me know.
If you would like yours observed for donation + freight let me know.
pauljs33
C?ID=385174
Hi Jack,
Thanks for the heads up. I checked ECU and it has a plastic cover over it. Pics attached covered and cover lifted.
Thanks for the info.
Paul
pauljs33
C?ID=385174
Work is completed.
Replaced all FI's on the engine since the old ones likely have ~150K Miles on them. Note: FI's 1, 3, & 5 were much more difficult to get out than FI's 2, 4, & 6.
Also replaced the fuel pressure sender since I already had everything disassembled. Ended up replacing the connector on the harness for this sensor since it looked ratty.
I replaced wiring from the firewall to FI #'s 1, 3, & 5 using butt connectors and heat shrink.
Also cleaned the valves while I had things open. They were pretty crusty. Was able to clean them pretty well using a product called Bench Buddy Brushes and carb cleaner.
Final Assembly complete.
Test drove this afternoon for 30 minutes with no issues. I also made sure I drove it hard because this is the condition where the misfires were happening. Pushed my foot through the floor a few times to dare it to go flakey on me again. No issues. I'll report back in a few weeks/ months once winter sets in around here to let you all know how it's doing.
Many thanks for all the help and advice. I had never tackled a job like this before. My wife was certain it would never see the road again.
Paul
pauljs33
C?ID=385174
Oh no it does not sir!
Cover - Volkswagen (4L0-907-577)
Hi Jack,
Many thanks for clearing that up for me. Is there a TSB number associated with this issue that you can share? Seems like a straight forward fix. Glad I sent the pics!
P
NostraJackAss
RTFB or search NHTSA yet?
Meh. ... Women, their usually right but it's great when the nag bag is wrong!
