Audi A8 4H Xenon retrofit from Before Lift to After Lift.
rexercio
Poland
C?ID=187377
Hi folks, Ive got Audi A8 from 2011 year. Car had front accident and during repair owner bought after lift front car (xenons, hood, bumper etc everything from 2016 year)
Xenons he bought are: 4H0941005 & 4H0941006 with this modules s 8K0941597E x2 | 4G0907697D x2
Im strugling with coding. Cant get High Beam lights to work. I dont know what type of lights where here before.
Also ive got fault : " LED Module for DRL and Parking Light - 012 - Electrical Fault in Circuit " (parking lights are working fine- but have got fault)
I made wirnings as they are in Elsa (of course i choose after lift 2013-> model).
Does anyone know if I need to change J519 to after lift model as well? Now it is 4H0 907 063 D.
Another question is about J431- now it is 4H4 907 357 . Need to be changed as well??
Wednesday,16,September,2020,09:51:33:23529
VIN: WAUZZZ4H1AN004397   License Plate:
Mileage: 115512km-71775mi   Repair Order:
Chassis Type: 4H-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 11 31 13 15 16 17 18 19 22 28 34
          36 3B 3C 42 46 47 52 53 55 56 57 5F 62 6C 6D 6F 72 81 85 88
          89 8B 8E 8F 90
VIN: WAUZZZ4H1AN004397   Mileage: 115512km-71775miles
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Cannot be reached 0100
18-Aux. Heat -- Status: Cannot be reached 0100
55-Headlight Range -- Status: Not registered 0011
6F-Centr. Conv. II -- Status: Malfunction 0010
85-On Board Cam. -- Status: Malfunction 0010
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine (J623-CDSB)       Labels:* Redir Fail!
   Part No SW: 4H0 907 409     HW: 4H0 907 409
   Component: 4.2TDI EDC17  H04 0010
   Revision: 34H04---
   Coding: 0106002C291F0268
   Shop #: WSC 39845 142 82063
   ASAM Dataset: EV_ECM42TDI1114H0907409 001016
   ROD: EV_ECM42TDI1114H0907409.rod
   VCID: 698FBC7619FC5CD3E5D-803C
4814 - System Voltage
          P0562 00 [032] - Too Low
4862 - No Communications with Aux. Heater Control Module
          U0166 00 [047] - -
                    Mileage: 106710 km
                    Date: 2019.12.19
                    Time: 16:26:06
                    Engine speed: 0.00 /min
                    Coolant temperature: 16 °C
                    Intake air temperature: 17 °C
                    Voltage terminal 30: 11.480 V
                    Crankshaft speed (RPM): 0.0 /min
                    Vehicle speed: 0.00 km/h
                    Battery voltage: 11480 mV
                    selected gear-Bits 0-7: 00000000
                    Cr C st Key 0-Bits 0-7: 00000000
4709 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [047] - -
          [Lost Communication WithCruise Control Front Distance Range Sensor]
                    Mileage: 106710 km
                    Date: 2019.12.19
                    Time: 16:26:04
                    Intake air temperature: 16 °C
                    Voltage terminal 30: 11.400 V
                    Battery voltage: 11400 mV
   Part No SW: 4H1 927 158 Q    HW: 0BL 927 156 E
   Component: 0BL 42 TDIRdW H08 0006
   Revision: --H08---
   Coding: 001111
   ASAM Dataset: EV_TCMALX51011 001013
   ROD: EV_TCMALX51011_001.rod
   VCID: 3E253F2A30F20B6B60F-806A
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 A    HW: 4H0 907 379 A
   Component: ESP PREMIUM   H08 0151
   Coding: E4EAA20027574500E300
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ESPPremi 004012
   ROD: EV_ESPPremi_004_AU64.rod
   VCID: 30391112FAA6ED1BE23-8064
0386 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ComScl_PDU_ACC_05_Timeout]
                    Reset counter: 217
                    Mileage: 115470 km
                    Date: 2020.09.13
                    Time: 18:14:29
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 07
                    Bit Info 3: 82
                    Bit Info 4: 00
                    F-Path: 1F
                    F-Type: 5B
                    Uz: 88
0650 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ComScl_PDU_ACC_10_Timeout]
                    Reset counter: 217
                    Mileage: 115470 km
                    Date: 2020.09.13
                    Time: 18:14:29
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 07
                    Bit Info 3: 82
                    Bit Info 4: 00
                    F-Path: 21
                    F-Type: 30
                    Uz: 88
   Part No SW: 4H0 907 064 DB    HW: 4H0 907 064 L
   Component: BCM2 2.0      H13 0510
   Coding: 05070001000000000000
   Shop #: WSC 03749 002 1048576
   VCID: 6C81C562168E49FB9EB-8038
   Subsystem 1 - Part No SW: 4H0 905 852 A    HW: 4H0 905 852 A
   Serial number: 0210000043413010
   Part No SW: 4H0 959 760 D    HW: 4H0 959 760 D
   Component: MEM-BFS       H07 0115
   Revision: AA000000    Serial number: 00001010163321
   Coding: 0018320000043201000001010101112131313333283333
   Shop #: WSC 02313 785 00200
   VCID: 34311D020E3ED13B86B-8060
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 D    HW: 4H0 820 043 D
   Component: Klima 4 Zonen H12 0064
   Coding: 385101B80C
   Shop #: WSC 12658 003 1048576
   ASAM Dataset: EV_AirCondiFront 001048
   ROD: EV_AirCondiFront_001_AU64.rod
   VCID: 211FE456A14C54937DD-8074
0237 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 103
                    Mileage: 109854 km
                    Date: 2020.02.09
                    Time: 21:40:56
0383 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [Funktionseinschränkung wegen fehlender Botschaft]
                    Reset counter: 217
                    Mileage: 109854 km
                    Date: 2020.02.09
                    Time: 21:41:01
   Part No SW: 4H0 907 063 D    HW: 4H0 907 063 D
   Component: BCM1 2.0      H11 0083
   Revision: 15011001    Serial number: 00000000643542
   Coding: 0200201050B49FE1EB810007A0001908009CC3080A000101800008402100
           0200011050B49FE1EB818007A0001908009CC3080A000101800008402100
   VCID: 290FFC76D9FC9CD325D-807C
   Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 100505  H32 0040
   Serial number:         100507072258
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 10917460
   Coding: 025D5B
   Subsystem 3 - Part No SW: 4H0 941 531 B    HW: 4H0 941 531 B
   Component: E1 - LDS  H07 0044
   Serial number: 25 05 2010  00000090
   Subsystem 4 - Part No SW: 4H0 907 705 H    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0275
   Serial number: WA100558000000035406
   Coding: 020300
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: B0088625000000000001
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                    Fault Status: 01101100
                    Reset counter: 63
                    Mileage: 106710 km
                    Date: 2019.12.19
                    Time: 17:47:00
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                    Reset counter: 63
                    Mileage: 106710 km
                    Date: 2019.12.19
                    Time: 17:24:00
03280 - Switch Position of Light-Switch Knob
                    Reset counter: 247
                    Mileage: 115115 km
                    Date: 2020.09.05
                    Time: 19:37:00
Address 0E: Media Player 1 (R161)       Labels: None
   Part No SW: 4H0 035 108 F    HW: 4H0 035 108
   Component: DVDCAlpine    H42 0200
   Revision: AA001001
   VCID: 2313EE5EBBD046836F1-8076
   Part No SW: 4H0 919 475 C    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H05 0011
   Revision: 11001001    Serial number: 44831011100531
   Coding: 300902
   ASAM Dataset: EV_AU64XParkiAssis2 005003
   ROD: EV_AU64XParkiAssis2.rod
   VCID: 323D1B1AF4AADF0B947-8066
Address 11: Engine II (J624)       Labels:* None
   Revision: 34H04---
   ASAM Dataset: EV_ECM42TDI2114H0907409 001016
   ROD: EV_ECM42TDI2114H0907409.rod
          U0166 00 [047] - -
                    Mileage: 106710 km
                    Date: 2019.12.19
                    Time: 16:26:06
                    Voltage terminal 30: 11.500 V
                    Battery voltage: 11500 mV
          U0235 00 [047] - -
                    Mileage: 106710 km
                    Date: 2019.12.19
                    Time: 16:26:04
Address 13: Auto Dist. Reg
   Part No SW: 4H0 959 655 B    HW: 4H0 959 655 B
   Component: Airbag10.43   H22 0026
   Revision: --------    Serial number: 003G10012U3D
   Coding: 30314246304230303033554A304C34483053
   VCID: 3537200605C4C833B15-8060
   Serial number: 3575HRB405J6O2OU69SH
   Serial number: 3585HRB405J6O2OU7G97
   Serial number: 3515JRB404V6DUG6L8KF
   Serial number: 3525JRB40576094IF0GR
   Serial number: 3554VRB404V6NG4E802Q
   Serial number: 3564VRB404V0IAMCJ1F8
1050368 - Databus
          [CAN: 0x323 PCF_01 Timeout]
                    Reset counter: 63
                    Mileage: 106710 km
                    Date: 2019.12.19
                    Time: 16:26:03
   Part No SW: 4H0 953 568 A    HW: 4H0 953 568 A
   Component: Lenks.Modul   H07 0007
   Revision: --------    Serial number: 90815JDM0000E
   Coding: 00003C
   VCID: 313F1416F12CE413EDD-8064
   Subsystem 1 - Part No SW: 4H0 951 528 A    HW: 4H0 951 528 A
   Component: E221 - MFL  H06 0009
   Serial number: 25 03 2010  11006264
   Part No SW: 4H0 920 930 F    HW: 4H0 920 930 F
   Component: TDieRDWACC--- H30 0185
   Revision: 20030116    Serial number: 658270510593010
   Coding: 130608009F000008000000
   ASAM Dataset: EV_RBD4K 004033
   ROD: EV_RBD4K_AU64.rod
   VCID: 290FFC76D97C9CD325D-807C
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 F    HW: 4H0 919 204 F
   Component: Analoguhr D4  H04 0210
   Serial number: 1100417000043
10485824 - Internal Control Module Memory Check Sum Error
          B2000 41 [009] - General checksum failure
          [Steuergerät defekt (EEPROM-Bereich Tachokennlinie)]
16776960 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ACC_02_FR keine Kommunikation]
                    Reset counter: 63
                    Mileage: 106710 km
                    Date: 2019.12.19
                    Time: 16:26:02
16776961 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ACC_04_FR keine Kommunikation]
                    Reset counter: 63
                    Mileage: 106710 km
                    Date: 2019.12.19
                    Time: 16:26:02
Address 18: Aux. Heat
   Part No SW: 4H0 907 468 C    HW: 4H0 907 468 C
   Component: J533--Gateway H07 0175
   Revision: --------    Serial number: 00000000017168
   Coding: 00C1037D00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_GatewUDS 001021
   ROD: EV_GatewUDS_AU57.rod
   VCID: 313F1416F1ACE413EDD-8064
   Subsystem 1 - Part No SW: 4H0 915 181     HW: 4H0 915 181
   Component: J367-BDM  H07 0130
   Serial number: 00000000005640005197
5409 - No Communications with Aux. Heater Control Module
          U0166 00 [009] - -
                    Reset counter: 63
                    Mileage: 106710 km
                    Date: 2019.12.19
                    Time: 16:26:02
                    Voltage terminal 30: 11.5 V
                    Voltage terminal 15: 11.5 V
                    Control Module temperature: 28 °C
                    System status: Terminal 15 on
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
4365 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [009] - -
                    Reset counter: 63
                    Mileage: 106710 km
                    Date: 2019.12.19
                    Time: 16:26:02
                    Control Module temperature: 27 °C
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
0021 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [Steuergerät falsch codiert (CAN)]
                    Reset counter: 217
                    Mileage: 106710 km
                    Date: 2019.12.19
                    Time: 16:26:02
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
   Part No SW: 4H0 907 163     HW: 4H0 907 163
   Component: 4 Wheel Drive H11 0005
   Serial number: 002304100001002
   ASAM Dataset: EV_AllWheelDiffeQSPFR 003017
   VCID: 6695B74A08E273ABC8F-8032
Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
   Part No SW: 4H0 919 158 D    HW: 4H0 919 158 D
   Component: Klima Fond    H14 0045
   Coding: 0100000000
   ASAM Dataset: EV_AirCondiHeck 001038
   ROD: EV_AirCondiHeck.rod
0140 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 63
                    Mileage: 106710 km
                    Date: 2019.12.19
                    Time: 16:26:02
   Part No SW: 4H0 907 553 B    HW: 4H0 907 553
   Component: LUFE-DAEMPFER H16 0095
   Coding: 008002
   ASAM Dataset: EV_AirSuspe 003017
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2B03067ED3808EC3D71-807E
0002 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 217
                    Mileage: 106710 km
                    Date: 2019.12.19
                    Time: 16:26:02
   Component: MEM-FS        H07 0115
   Revision: AA000000    Serial number: 00001010163261
   Coding: 00183B0000053201000001010101112131313333203333
Address 3B: Sensor Elect. (J849)       Labels: None
   Part No SW: 4H0 907 637 A    HW: 4H0 907 637 A
   Component: SARA 6D red   H02 0015
   Revision: --------    Serial number: EJ1BPA370041JS0
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 2D070866ED9480F3C95-8078
1048835 - Supply voltage
          U1011 00 [032] - Voltage too Low
          [ECU temporarily disturbed: Undervoltage T30]
   Part No SW: 4H0 907 566     HW: 4H0 907 566
   Component: J769  SWA MasterH02 0060
   Revision: 00H02000    Serial number: 6PZ 010 287-00
   Coding: 0000101
   VCID: 6D87C866219440F3895-8038
   Subsystem 1 - Part No: 4H0 907 568
   Component: J770  SWA Slave H01 0060
   Subsystem 2 - Serial number: 6PZ 010 287-20
   Subsystem 3 - Serial number: 5F26.05.1000H010003CH11079˙
   Subsystem 4 - Serial number: H11079˙
   Part No SW: 4H0 959 793 E    HW: 4H0 959 793 E
   Component: TSG FA        H02 0158
   Revision: --------    Serial number: 0000104551783
   Coding: 011F12215E0062C202000007
   Shop #: WSC 02312 785 00200
   VCID: 3B23363E23601E43471-806E
   Revision: 00002001    Serial number: 0130275084
   Coding: 011A0E2000393585BB2007F28E0000000000000000000000000000000000
   Subsystem 1 - Part No: 4H0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 3 - Part No SW: 4H0 959 591     HW: 4H0 959 591
   Component: J245 PS50.028  H06 0006
   Serial number:     WOO1015150U
   Coding: 001F00
   Subsystem 4 - Part No SW: 4H0 907 133 A    HW: 4H0 907 133 A
   Component: J505-FSH  H06 0045
   Serial number: 00000000000000000581
   Subsystem 5 - Part No SW: 4H0 947 135 G    HW: 4H0 947 135 G
   Component: Dachelektroni  H11 0070
   Serial number: A2010000000000089335
   Subsystem 6 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
   Component: V252 PS009  H05 0004
   Serial number:     WOO10003JMJ
01593 - Heated Windshield (Z2)
                    Reset counter: 217
                    Mileage: 106710 km
                    Date: 2019.12.19
                    Time: 16:26:04
                    Reset counter: 217
                    Mileage: 106710 km
                    Date: 2019.12.19
                    Time: 16:26:04
01319 - Control Module for Distance Control (J428)
                    Reset counter: 63
                    Mileage: 106710 km
                    Date: 2019.12.19
                    Time: 16:26:00
   Part No SW: 4H0 035 223     HW: 4H0 035 223
   Component: BOSE G3 D4    H07 0050
   Revision: CI007500    Serial number: 00000000002031
   VCID: 5BE396BEC3203E43671-800E
   Part No SW: 4H0 959 792 E    HW: 4H0 959 792 E
   Component: TSG BF        H02 0158
   Revision: --------    Serial number: 0000104613809
   VCID: 3A2D333A2C5A274B5C7-806E
   Part No SW: 4H0 907 801 C    HW: 4H0 907 801 A
   Component: EPB-4         H03 0009
   Revision: --------    Serial number: 00000000002270
   ASAM Dataset: EV_ParkiBrake 001015
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2809F972C276A5DB3A3-807C
10554390 - Supply voltage
          U1011 00 [000] - Voltage too Low
          [FC_LOW_V_BATT]
327936 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [FC_ACC_05_MESSAGE_TIMEOUT]
                    Reset counter: 63
                    Mileage: 106710 km
                    Date: 2019.12.19
                    Time: 16:26:02
                    Voltage terminal 30: 11.4 V
                    Internal Fault ID: 86
                    Function light in parking brake button: OFF
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: static
                    Status ParkingBrake left: Open
                    Status ParkingBrake right: Open
Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
   Part No SW: 4H4 907 357     HW: 4H4 907 357
   Component: ....AFS13.... H01 0070
   Serial number: 100430-0004-010
   Coding: 11116F33F91AEA00
   ASAM Dataset: EV_AdvanFrontSyste 005001
   ROD: EV_AdvanFrontSyste_AU21.rod
   VCID: 6FBBD26E2718B2E3BB9-803A
530180 - Local Data Bus
          U10BA 00 [137] - No Communication
                    Reset counter: 217
                    Mileage: 106710 km
                    Date: 2019.12.19
                    Time: 16:26:06
530190 - Local Data Bus
          U10B8 00 [137] - Defective
                    Reset counter: 63
                    Mileage: 106710 km
                    Date: 2019.12.19
                    Time: 16:44:22
   Part No SW: 4E0 035 061 L    HW: 4E0 035 061
   Component: Radio U DAB   H46 0085
   Revision: AB001007    Serial number: 014DR0A7507184
   Coding: 010103010000000001
   VCID: 2411ED42BEDE41BB16B-8070
02981 - Connection between Radio and Impedance Converter 1
                    Reset counter: 63
                    Mileage: 106710 km
                    Date: 2019.12.19
                    Time: 16:26:10
                    Voltage: 11.40 V
Address 57: TV Tuner (R78)       Labels: None
   Part No SW: 4F0 919 129 G    HW: 4F0 919 129
   Component: HybridTV-DVB  H07 0550
   Revision: R0070000    Serial number: 76301300254401
   Coding: 01010000
   VCID: 30391112FA26ED1BE23-8064
   Part No SW: 4H0 035 654 B    HW: 4H0 035 670
   Component: H-BNT-EU      H48 1034
   Revision: --------    Serial number: 410EW0A7555582
   Coding: 020100000001FBEF75108B1E00000003000001000000000000
   Shop #: WSC 00950 002 1048576
   VCID: 2517F046B5E4B8B3015-8070
   Subsystem 1 - Part No: 8R0 060 884 GH
   Component: EUR 2019/2020  2901
   Subsystem 2 - Part No SW: 4H0 919 604 C    HW: 4H0 919 604 C
   Component: DU8 D4 SV NB  H46 0021
   Serial number: AUZ8ZDA260012CZ
   Subsystem 3 - Part No SW: 4H1 919 600 H    HW: 4H1 919 600
   Component: E380 BDT D4  H09 0065
   Serial number: 00000000008376
   Component: CD-Database  1886
                    Reset counter: 217
                    Mileage: 115512 km
                    Date: 2020.09.16
                    Time: 09:41:47
                    Bin. Bits: 00000000 00100000
                    Bin. Bits: 00001000 00000000
                    Bin. Bits: 00000000 00000000
   Part No SW: 4H0 959 795 A    HW: 4H0 959 795 A
   Component: TSG HL        H04 0158
   Revision: --------    Serial number: 0000103135845
   Coding: 010F1221400062C202000007
   VCID: 392F2C36295C2C5355D-806C
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4H0 907 441     HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0030
   Revision: --H03---    Serial number: 525PA8-J04D0L6
   Coding: 1020002
   VCID: 6597B046F96478B3C15-8030
02203 - Audio / Video Input 1
                    Fault Status: 00101011
                    Fault Frequency: 20
                    Reset counter: 2
                    Mileage: 110883 km
                    Date: 2020.04.13
                    Time: 19:29:33
                        Reverse OFF
                    Count: 3
                    Fault Frequency: 24
                    Reset counter: 247
                    Mileage: 113814 km
                    Date: 2020.08.01
                    Time: 19:00:39
                        Reverse ON
                    Count: 4
Address 6D: Trunk Elect. (----)       Labels:* None
   Part No SW: 4H0 959 107 F    HW: 4H0 959 107 F
   Component: HDSG-Modul    H11 0632
   Revision: 09145325    Serial number: 124000352
   Coding: 0200044000
   ASAM Dataset: EV_DeckLidContrUnit 001023
   ROD: EV_DeckLidContrUnit.rod
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000005989
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 6393AE5EFBD006832F1-8036
0044 - Rear Right Door Lighting Color 1
          B1130 01 [009] - Electrical Failure
                    Reset counter: 69
                    Mileage: 106947 km
                    Date: 2019.12.25
                    Time: 19:26:39
                    Voltage terminal 30: 14.7 V
                    Control Module temperature: 22 °C
                    Processor load: 34.5 %
                    Color setting Ambient: Warm white
                    Status terminal 58s: On
0046 - Rear Right Door Lighting Color 2
          B1131 01 [009] - Electrical Failure
                    Reset counter: 63
                    Mileage: 106710 km
                    Date: 2019.12.19
                    Time: 16:26:07
                    Control Module temperature: 24 °C
                    Color setting Ambient: Cold white
0048 - Rear Right Door Lighting Color 3
          B1132 01 [009] - Electrical Failure
                    Reset counter: 69
                    Mileage: 106947 km
                    Date: 2019.12.25
                    Time: 19:26:12
                    Processor load: 35.0 %
                    Color setting Ambient: Red
   Component: TSG HR        H04 0158
   Revision: --------    Serial number: 0000102939281
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 4H1 927 731     HW: 4H1 927 731
   Component: GSM-LL        H07 0083
   Revision: 0L0D4011    Serial number: SN100310  0041
   ROD: EV_GSM2x3Mono_AU64.rod
   VCID: 6A8DC37A1CFA57CBEC7-803E
   Part No SW: 4H0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H22 0016
   Coding: EC060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 270BFA4ECF68AAA3339-8072
0724 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ACC_timeout]
                    Reset counter: 63
                    Mileage: 106710 km
                    Date: 2019.12.19
                    Time: 16:26:03
                    Outside air temperature: -43.0 °C
                    Voltage terminal 15: 11.2 V
                    Control Module temperature: 28.0 °C
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4H0 907 182 C    HW: 4H0 907 182 C
   Component: IVB           H03 0027
   Serial number: 00449500030201
   Coding: 660FF2
   ROD: EV_IVBDriveSideFrnt.rod
   VCID: 2A0D037ADC7A97CB2C7-807E
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 00449500066401
   Coding: 260FF2
   Part No SW: 4H0 907 541 A    HW: 4H0 907 541
   Component: ACC3          H15 0160
   Coding: 3604010201
   ASAM Dataset: EV_AdaptCruisContr2AU64X 001010
   ROD: EV_AdaptCruisContr2AU64X_001.rod
10 Faults Found:
16384 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [FAULT_VMON_VZ_LOW]
                    Reset counter: 2
                    Mileage: 106710 km
                    Date: 2019.12.19
                    Time: 17:29:33
                    Control Module temperature: 23 °C
                    Voltage terminal 15: 8.203 V
                    Velocity_vehicle_reference: -0.00 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s˛
16640 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [FAULT_VMON_VZ_LOW1]
                    Reset counter: 2
                    Mileage: 106710 km
                    Date: 2019.12.19
                    Time: 17:29:33
17152 - Supply voltage
          [FAULT_VMON_VZ_CONFIRMED_LOW]
                    Reset counter: 2
                    Mileage: 106710 km
                    Date: 2019.12.19
                    Time: 17:40:59
                    Control Module temperature: 25 °C
                    Voltage terminal 15: 8.437 V
94720 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FAULT_CIS_QDCACC_FAIL]
                    Reset counter: 217
                    Mileage: 107007 km
                    Date: 2019.12.27
                    Time: 18:15:15
                    Control Module temperature: 3 °C
                    Voltage terminal 15: 11.625 V
95232 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FAULT_CIS_QEPBACC_FAIL]
                    Reset counter: 217
                    Mileage: 106710 km
                    Date: 2019.12.19
                    Time: 16:26:02
                    Voltage terminal 15: 11.376 V
95488 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FAULT_CIS_QDISACC_FAIL]
                    Reset counter: 217
                    Mileage: 106724 km
                    Date: 2019.12.20
                    Time: 18:31:58
                    Control Module temperature: 9 °C
                    Voltage terminal 15: 12.543 V
77312 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [FAULT_CIM_TIMEOUT_LRRM_TRIG]
                    Reset counter: 217
                    Mileage: 115512 km
                    Date: 2020.09.16
                    Time: 09:41:42
                    Control Module temperature: 17 °C
                    Voltage terminal 15: 10.527 V
77568 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [FAULT_CIM_TIMEOUT_LRRM_DEJU]
                    Reset counter: 217
                    Mileage: 106710 km
                    Date: 2019.12.19
                    Time: 16:26:03
                    Voltage terminal 15: 11.379 V
154624 - Door Contact Switch
          C1076 29 [008] - Signal Implausible
                    Reset counter: 2
                    Mileage: 106711 km
                    Date: 2019.12.20
                    Time: 16:33:42
82688 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FAULT_CIS_TSK_FAIL]
                    Reset counter: 217
                    Mileage: 106724 km
                    Date: 2019.12.20
                    Time: 18:32:14
                    Control Module temperature: 10 °C
                    Voltage terminal 15: 12.525 V
Address 8E: Image Processing (J851)       Labels:* Redir Fail!
   Part No SW: 4H0 907 107     HW: 4H0 907 107
   Component: BV-SG         H25 0008
   Serial number: 000040052505107
   Coding: 01A08200
   ASAM Dataset: EV_BVS 001007
   ROD: EV_BVS.rod
   VCID: 6491AD42FEDE01BBD6B-8030
0046 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [ACC_timeout]
                    Reset counter: 2
                    Mileage: 106710 km
                    Date: 2019.12.19
                    Time: 16:26:02
0091 - Function Limitation due to Missing Video Data
          C1108 00 [008] - -
          [DPC_SystemError]
                    Reset counter: 2
                    Mileage: 106710 km
                    Date: 2019.12.19
                    Time: 17:46:57
   Part No SW: 4H0 980 945     HW: 4H0 980 945
   Component: RGS-VL        H04 0060
   Coding: 0066F609031F037E070308014240C2010000
   ASAM Dataset: EV_RGS_L 002006
   ROD: EV_RGS_L_VW51.rod
12583680 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 188
                    Mileage: 113613 km
                    Date: 2020.08.01
                    Time: 11:56:46
12583693 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 188
                    Mileage: 113613 km
                    Date: 2020.08.01
                    Time: 11:56:46
   Part No SW: 4H0 980 946     HW: 4H0 980 946
   Component: RGS-VR        H04 0060
   ASAM Dataset: EV_RGS_R 002006
   ROD: EV_RGS_R_VW51.rod
   VCID: 70B9D1123A26AD1BA23-8024
          U1111 00 [009] - -
                    Reset counter: 126
                    Mileage: 110864 km
                    Date: 2020.04.13
                    Time: 18:46:20
          U1111 00 [009] - -
                    Reset counter: 126
                    Mileage: 110864 km
                    Date: 2020.04.13
                    Time: 18:46:20
12589825 - Reversible Belt Tensioner Function
          B1202 16 [008] - Voltage Too Low
                    Reset counter: 228
                    Mileage: 113613 km
                    Date: 2020.08.01
                    Time: 11:52:03
End----(Elapsed Time: 03:10, VBatt start/end: 11.8V/11.8V. VIgn 11.9V)-----
rexercio
Poland
C?ID=187377
Hi, i have more news. I changed J519 for newer model an havnt got fault " LED Module for DRL and Parking Light - 012 - Electrical Fault in Circuit " any more.
But still dont know how trigger High Beam.
Does any one know where from signal to triger High Beam comes from?
Which module trigger High beam?? Is it module J431??? Because there is a fault " 530180 - Local Data Bus U10BA 00 [137] - No Communication ". I think J431 dont see headlight modules and thats why i cant get high beam to work.
I checked wirning there is everything ok.
Could it be J431 module that need to be changed? If yes then to what number?
In etka there are only 3 option
<img src="https://ibb.co/r6nwYrK">
...357 B & ... 357 E are for LED & matrix headlight
...357 C is for cornering headlight.
My headlights are not cornering. Will it work?
Maybe everything I need is good coding?
Please help!
Tuesday,06,October,2020,21:04:03:23529
Dealer/Shop Name: sss
Scan: 01 02 03 05 06 08 09 0E 10 11 31 13 15 16 17 19 22 28 34 36
          3B 3C 42 46 47 52 53 55 56 57 5F 62 6C 6D 6F 72 81 85 88 89
          8B 8E 8F 90
VIN: WAUZZZ4H1AN004397   Mileage: 115513km-71776miles
0E-Media Player 1 -- Status: Malfunction 0010
81-Gear Shift -- Status: Malfunction 0010
   Revision: 34H04---
          U0166 00 [039] - -
                    Mileage: 115513 km
                    Date: 2020.10.06
                    Time: 20:00:43
                    Coolant temperature: 53 °C
                    Intake air temperature: 42 °C
                    Voltage terminal 30: 12.920 V
                    Battery voltage: 12920 mV
   Revision: --H08---
   Coding: 001111
                    Fault Status: 00100001
                    Reset counter: 1
                    Mileage: 115513 km
                    Date: 2020.10.06
                    Time: 20:39:12
                    Fault Status: 00101101
                    Reset counter: 1
                    Mileage: 115513 km
                    Date: 2020.10.06
                    Time: 20:39:12
   Coding: 385101B80C
          U1111 00 [009] - -
                    Reset counter: 217
                    Mileage: 115513 km
                    Date: 2020.10.06
                    Time: 20:00:28
0314 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 217
                    Mileage: 115513 km
                    Date: 2020.10.06
                    Time: 20:00:28
0316 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 217
                    Mileage: 115513 km
                    Date: 2020.10.06
                    Time: 20:11:04
          U1113 00 [008] - -
                    Reset counter: 2
                    Mileage: 115513 km
                    Date: 2020.10.06
                    Time: 20:00:28
   Part No SW: 4H0 907 063 DA    HW: 4H0 907 063 AA
   Component: BCM1 2.0      H20 0310
   Revision: 22020001    Serial number: 00000052961001
   Coding: 26000010D1B45D010029400300005D4C431C67082A00C241000000000040570000000000000000
   VCID: 6A8DC37A1C7A57CBEC7-803E
   Coding: 0045F7
   Coding: 025D5B
                    Reset counter: 217
                    Mileage: 115513 km
                    Date: 2020.10.06
                    Time: 20:00:26
01517 - Control Module for Trailer/Towing Sensor (J345)
                    Reset counter: 217
                    Mileage: 115513 km
                    Date: 2020.10.06
                    Time: 20:00:26
01229 - A/C Humidity Sensor (G260)
                    Reset counter: 217
                    Mileage: 115513 km
                    Date: 2020.10.06
                    Time: 20:00:26
   Revision: AA001001
02283 - Video Connection to Output [End Unit]
                    Reset counter: 217
                    Mileage: 115513 km
                    Date: 2020.10.06
                    Time: 20:00:30
   Coding: 300902
   Revision: 34H04---
          U0166 00 [039] - -
                    Mileage: 115513 km
                    Date: 2020.10.06
                    Time: 20:00:43
   Part No SW: 4H0 907 561 B    HW: 4H0 907 561
   Component: ACC3          H19 0410
   Coding: 7E04010201
   ASAM Dataset: EV_AdaptCruisContrAU64X 002021
   ROD: EV_AdaptCruisContrAU64X_002.rod
15360768 - Component Protection
          U1101 00 [009] - Active
          [FAULT_ATP_IKA_FAST_FAILED]
                    Reset counter: 217
                    Mileage: 115513 km
                    Date: 2020.10.06
                    Time: 20:00:29
                    Control Module temperature: 20 °C
                    Voltage terminal 15: 12.817 V
155136 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FAULT_CIS_CONFIG_AEBL]
                    Reset counter: 217
                    Mileage: 115513 km
                    Date: 2020.10.06
                    Time: 20:00:29
150016 - invalid data record
          B2005 00 [009] - -
          [FAULT_BPC_NVM_DATA]
                    Reset counter: 217
                    Mileage: 115513 km
                    Date: 2020.10.06
                    Time: 20:00:29
   Coding: 00003C
   Coding: 1306080097000008000000
   Analog_clock:
          U1014 00 [009] - -
                    Reset counter: 217
                    Mileage: 115513 km
                    Date: 2020.10.06
                    Time: 20:00:28
   Coding: 00C1037D00
          U1101 00 [008] - Active
                    Reset counter: 2
                    Mileage: 115513 km
                    Date: 2020.10.06
                    Time: 20:13:11
                    Voltage terminal 30: 13.0 V
                    Voltage terminal 15: 13.0 V
                    Control Module temperature: 36 °C
                    Engine running: OFF
                    IN ZAS_Te_X: On
                    Datenfeld: 0
0016 - Supply voltage
          U1012 00 [008] - Voltage too High
          [Versorgungsspannung oberer Grenzwert überschritten]
                    Reset counter: 2
                    Mileage: 115513 km
                    Date: 2020.10.06
                    Time: 20:40:26
                    Voltage terminal 30: 15.6 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 38 °C
                    System status: Gateway_local_awake
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
   Coding: 0100000000
          U1111 00 [009] - -
                    Reset counter: 217
                    Mileage: 115513 km
                    Date: 2020.10.06
                    Time: 20:00:28
   Coding: 008002
   Coding: 0000101
   Coding: 011A0E2000393585B32007F28E0000000000000000000000000000000000
   Coding: 001F00
   Subsystem 4 - Part No SW: 4H0 947 135 G    HW: 4H0 947 135 G
   Subsystem 5 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
                    Reset counter: 1
                    Mileage: 115513 km
                    Date: 2020.10.06
                    Time: 20:39:12
                    Reset counter: 217
                    Mileage: 115513 km
                    Date: 2020.10.06
                    Time: 20:00:32
                    Reset counter: 217
                    Mileage: 115513 km
                    Date: 2020.10.06
                    Time: 20:00:36
                    Voltage: 13.00 V
   Coding: 01010000
                    Reset counter: 217
                    Mileage: 115513 km
                    Date: 2020.10.06
                    Time: 20:00:31
                    Bin. Bits: 00000000 10000000
   Coding: 1020002
   Coding: 0200044000
   ROD: EV_Ambie.rod
0006 - Front Left Footwell Lighting  Color 2
          B111D 01 [009] - Electrical Failure
                    Reset counter: 217
                    Mileage: 115513 km
                    Date: 2020.10.06
                    Time: 20:00:33
                    Voltage terminal 30: 12.9 V
                    Control Module temperature: 32 °C
                    Status terminal 58s: OFF
                    Reset counter: 217
                    Mileage: 115513 km
                    Date: 2020.10.06
                    Time: 20:00:33
10020 - Display for Gear-Selector Position
          P17C4 00 [008] - Malfunction
                    Reset counter: 2
                    Mileage: 115513 km
                    Date: 2020.10.06
                    Time: 20:44:01
                    Voltage terminal 15: 12.3 V
                    Voltage terminal 30: 12.4 V
                    Driving position: P
                    Selector lever position: drive lane (X)
                    Lighting for selector lever position display-Signal LED lighting: 7 %
                    Lighting for selector lever position display-Current for the P LED: 1.3 mA
                    Lighting for selector lever position display-Current for the R LED: 0.0 mA
                    Lighting for selector lever position display-Current for the N LED: 0.0 mA
                    Lighting for selector lever position display-Current for the D/S LED: 0.0 mA
   Coding: EC060000
   Coding: 660FF2
   Coding: 260FF2
   Part No SW: 4H0 907 541 B    HW: 4H0 907 541
   Component: ACC3          H19 0400
   Coding: 7E04010201
   ASAM Dataset: EV_AdaptCruisContr2AU64X 002018
   ROD: EV_AdaptCruisContr2AU64X_002.rod
                    Reset counter: 217
                    Mileage: 115513 km
                    Date: 2020.10.06
                    Time: 20:00:29
                    Voltage terminal 15: 12.822 V
          U1014 00 [009] - -
                    Reset counter: 217
                    Mileage: 115513 km
                    Date: 2020.10.06
                    Time: 20:00:29
   Coding: 01A08200
   ROD: EV_BVS.rod
End----------(Elapsed Time: 02:49, VBatt start/end: 12.6V/12.8V)-----------
rexercio
Poland
C?ID=187377
Sorted out. 4H0941005 & 4H0941006 are not AFS. They dont have and dont need can communication. From very begging it was really easy - problem was witk ETKA. Does not show those headlamps at all.
Can be closed
