- Oct 2, 2020
- 3
- 2
- Norman, OK, USA
- C?ID=109545
I am looking for help in clearing a fault code 16365 in 3C:Lane Change. The history follows, I apologize in advance if I've provided TMI but I thought it best to provide a scan at each step.
While on a long trip the Side Assist stopped functioning, creating the fault 16365 in Address 3C. This fault also deactivated Adaptive Cruise Control. I could not clear the code, here is the scan:
I searched a good bit, including on this site, and decided to replace the driver side slave module CPU 2 (J770). The module is a new OEM part 4G0-907-568-D. After installation I rescanned. Both modules were evidently now recognized as they created two new codes (02849, 02850), which I assumed would be cleared by a dealer calibration of the system. My attempts to clear the original 16365 fault were not successful. (Please ignore the tail light bulb faults as these were triggered during the bumper removal process and I later cleared them.)
I took the car to the Audi dealership for calibration, explaining that the original code was still present. They performed the calibration which cleared the two new codes (02849, 02850), but they were unable to clear the original 16365 fault. Their diagnosis is to replace the master (J769) module also, stating Audi requires replacing the modules in pairs. This is the current status:
I'm prepared to replace the master module if necessary, but if there is another possibility I'd like to try it first, such as recoding, etc. I'm not a power user of VCDS but I'll give it a shot. The Audi tech mentioned there could be possible firmware incompatibilities between the older original module and the new module, any way to tell? Or maybe I just replaced the wrong module to begin with. Any help/suggestions would be greatly appreciated, thanks in advance.
Saturday,08,August,2020,22:11:11:24996
VCDS Version: 20.4.1.0 (x64)
VIN: WAUHMAFC5EN073984 License Plate:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 36 3B 3C 42 44 46 47
52 53 55 56 5F 62 6C 72 82 84 85 8B 8E 8F 90 AC
VIN: WAUHMAFC5EN073984 Mileage: 108508km-67423miles
Address 01: Engine (J623-CPNB) Labels:. 059-907-401-V2.clb
Part No SW: 4G0 907 401 N HW: 4G0 907 401 E
Component: 3.0TDI FSA H14 0016
Revision: 58H14---
Coding: 0A2A4012056601050000
Shop #: WSC 00359 004 1048576
ASAM Dataset: EV_ECM30TDI0114G0907401N 002016
ROD: EV_ECM30TDI0114G0907401N_002.rod
VCID: 2E58146D7176E1F6A9-807A
Part No SW: 4G0 927 158 Q HW: 0BK 927 156 AM
Component: 0BK 30 TDIUSA H16 1008
Revision: --H16---
VCID: 3C7C2E25B70A036617-8068
Part No SW: 4G0 907 379 M HW: 4G0 907 379 M
Component: ESP PREMIUM H09 0450
Coding: 27A79701E4E5E9804B00
Shop #: WSC 02391 785 00200
VCID: 3B7E2D39B204045E1E-806E
Part No SW: 4H0 907 064 DR HW: 4H0 907 064 DR
Component: BCM2 2.0 H35 0510
Coding: 0DA82046000000000000
VCID: 7CFCEE25FF8AC36657-8028
Serial number: 0213000333325016
Part No SW: 4G0 820 043 AF HW: 4G0 820 043 AF
Component: KLIMA 4 ZONEN H13 0088
Serial number: 10101300041338
Coding: 368120BA5D
ASAM Dataset: EV_AirCondiComfoUDS 002043
VCID: 63CEB5596A341C9E76-8036
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001641421
Coding: 09072091073C9FE281000884A0003800CF9CD308A60802258001085C7B00
VCID: 6FE6C969BEFCA8FEE2-803A
Component: WWS57X 131001 H36 0080
Serial number: 131005193329
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 21840032
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 H HW: 4G0 941 531 H
Component: E1 - LDS H07 0044
Serial number: 27 09 2013 00000778
Component: USHL4.2 H30 0030
Serial number: 0000002274555R81MT03
Subsystem 5 - Part No SW: 8K0 959 772 E HW: 8K0 959 772
Component: SLR-B8 H06 0007
Serial number: 0078079705
Coding: 853000
Subsystem 6 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A31 LED Mod1L H03 0006
Serial number: 00000010101300010187
Coding: 110000
Subsystem 7 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A27 LED Mod1R H03 0006
Serial number: 00000014101300010173
Coding: 110000
Subsystem 8 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA106971000004940576
Coding: 020300
Subsystem 9 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 0D0942D6000000000001
Revision: 11001001 Serial number: 61061328502579
Coding: A8EB06
VCID: 71E2CF11A0C8BE0EF4-8024
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H19 0410
Coding: 7E01010202
VCID: 2854E2755392BFC663-807C
145152 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Reset counter: 102
Mileage: 108135 km
Date: 2020.08.08
Time: 17:33:05
Control Module temperature: 42 °C
Voltage terminal 15: 13.735 V
Velocity_vehicle_reference: 32.58 m/s
Longitudinal_acceleration_vehicle_reference: 0.01 m/s²
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H33 0033
Revision: -------- Serial number: 003D8003K7BM
Coding: 303234373131303030324A55304C34473053
VCID: 336E05199A54CC1EC6-8066
Serial number: 6940000Y130000YBKC05
Serial number: 3575HRB401050N209GU-
Serial number: 3585HRB406722SF8C862
Serial number: 3515JRB401650MU8R158
Serial number: 3525JRB401050NQIOGS2
Serial number: 3554VRB401850NQKA9T6
Serial number: 3564VRB400A50NQID11G
Revision: -------- Serial number: 90372MJF0006S
Coding: 0004DC
VCID: 387432358B322F46F3-806C
Subsystem 1 - Part No SW: 4G0 951 528 F HW: 4G0 951 528 F
Component: E221 - MFL H09 0010
Serial number: 07 08 2013 A1232373
Part No SW: 4G8 920 984 A HW: 4G8 920 984 A
Component: TDieUsaAccNv H58 0621
Revision: 29460233 Serial number: 658111013596011
Coding: 0BCF0A040F51D705020000
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K_AU57.rod
VCID: 346C06059F5ACB26DF-8060
Part No SW: 4G0 907 468 AD HW: 4G0 907 468 AC
Revision: -------- Serial number: 00000001134166
Coding: 00CD077D00
VCID: 72E0C01DA5CE85160D-8026
Serial number: 3921811403
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 13072500000000000511
Part No SW: 4G0 919 158 K HW: 4G0 919 158 K
Component: KLIMA FOND H07 0088
Serial number: 09101300040232
Coding: 20
ASAM Dataset: EV_ClimaContrUnitRearUDS 002021
VCID: 377631098E2C203EFA-8062
Part No SW: 4G8 959 760 A HW: 4G8 959 760 A
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000077528414
Coding: C0581B008F006001000001010101102030303232203232
Component: SARA 6D H03 0056
Revision: -------- Serial number: EJ1BPA8205543L
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 36683C0D8926D936E1-8062
Part No SW: 4G0 907 566 D HW: 4G0 907 566
Component: J769 SWA MasterH03 0060
Revision: 00H03000 Serial number: 6PZ 010 287-03
Coding: 0000001
VCID: 30640A15A342F706BB-8064
Subsystem 1 - Part No: 4G0 907 568 D
Component: J770 SWA Slave H03 0060
Subsystem 2 - Serial number: 6PZ 010 287-23
Subsystem 3 - Serial number: 5F15.10.1300H03000AMS15899ÿ
Subsystem 4 - Serial number: S15899ÿ
16365 - Control Module - Electrical Error; CPU 2
014 - Defective
Fault Status: 01101110
Reset counter: 102
Mileage: 108135 km
Date: 2020.08.08
Time: 17:33:04
Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
Component: TSG FA H04 0507
Coding: 011F17005E00628002000013
VCID: 458A4BC1CCC042AE78-8010
Component: RCEPS H39 0010
Revision: 00001000 Serial number: 0015954495
Coding: 101001010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 3260001D654EC516CD-8066
Revision: 00002001 Serial number: 0315419880
Coding: 0106023A00FA408580A0088402070E470000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0081
Serial number: 00000000000000184367
Subsystem 3 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
Component: J245 PS40.039 H01 0008
Serial number: WOO24751362
Coding: 101F00
Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Component: Dachelektroni H10 0100
Serial number: 0000000AP00004485222
Subsystem 5 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Component: GEB.F.Heckoef H16 0811
Serial number: 93079848
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000042251
Coding: 030000
VCID: 1D3AC3A104D06A6E00-8048
Component: TSG BF H03 0507
Coding: 011F17005E00628002000002
VCID: 46884CCDF1C649B671-8012
Part No SW: 4H0 907 801 G HW: 4H0 907 801 A
Component: EPB-4 H03 0014
Revision: -------- Serial number: 00000000852960
ROD: EV_ParkiBrake_VW51.rod
VCID: 2C5C1E65476A93E687-8078
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Serial number: 131020-0002-065
Coding: 1221A6601002A500
ROD: EV_HeadlRegulBasic.rod
VCID: 2D5A13617C709AEE90-8078
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Revision: AB001007 Serial number: 156J30D7920566
Coding: 020007010000000001
VCID: 244CF64527BA5BA64F-8070
Part No SW: 4G0 035 746 E HW: 4G0 035 746 E
Component: H-BNT-NA H40 0735
Revision: -------- Serial number: 194JD0D7559764
Coding: 050200000003EDEF7D16CB1E00000003100001000000000000
VCID: 2952E771409886CE7C-807C
Subsystem 1 - Part No: 8R0 060 884 BD
Component: NAR 2013/2014 0802
Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Serial number: AUZ8ZDDD002SC0R
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C
Serial number: 90349MJC0003L
Component: CD-Database 5298
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Component: TSG HL H03 0507
VCID: 499247F1E0D8A6CE9C-801C
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4H0 907 428 B HW: 7P6 907 441 D
Component: TopView H05 0220
Revision: 11001001 Serial number: 82330JF0113037
Coding: 0200000001010000000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
ROD: EV_CamerSysteTopViewAUDI_007.rod
Component: TSG HR H03 0507
Address 82: Heads Up Display (J898) Labels:| 4G0-919-604.clb
Part No SW: 4G0 919 604 K HW: 4G0 919 604 K
Component: HeadUpDisplay 004 0201
Coding: D60000
ASAM Dataset: EV_HUDContiC7 001023
ROD: EV_HUDContiC7.rod
Address 84: Night Vision (J853) Labels:| 4H0-907-547.clb
Part No SW: 4H0 907 547 F HW: 4H0 907 547
Component: NV-ECU-Gen1 H10 0042
Serial number: 0K84AE40102080
Coding: 1311
ASAM Dataset: EV_NightVisioGen1 001002
ROD: EV_NightVisioGen1.rod
Night vision system camera:
Subsystem 1 - Part No SW: 4H0 980 552 A HW: 4H0 980 552
Component: NV-CAM-Gen1 H09 0008
Serial number: 00000000001317000022
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H26 0038
Coding: 6A060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 2648EC4D5986A9B651-8072
Part No SW: 4G0 907 541 A HW: 4G0 907 541
Component: ACC3 H19 0400
Coding: 7E01010202
U1113 00 [009] - -
Reset counter: 102
Mileage: 108135 km
Date: 2020.08.08
Time: 17:33:05
Control Module temperature: 41 °C
Voltage terminal 15: 13.902 V
Velocity_vehicle_reference: 32.68 m/s
Part No SW: 4G0 907 107 E HW: 4H0 907 107
Component: BV-SG H32 0041
Serial number: 005000120210137
Coding: 04C198180111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
0063 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Reset counter: 102
Mileage: 108135 km
Date: 2020.08.08
Time: 17:33:06
Outside air temperature: 35.0 °C
Voltage terminal 15: 13.9 V
Control Module temperature: 50.0 °C
Component: RGS-VL H13 0080
Coding: 0066E608031F0376070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L_VW51.rod
VCID: 31620F116048FE0EB4-8064
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R_VW51.rod
Part No SW: 4G0 907 355 C HW: 4G0 907 355 B
Component: SCR-Stg-G2 H09 0010
Revision: 00000000 Serial number: 132000222
ROD: EV_RDCMA00100.rod
VCID: 2B5E1D79426494DE8E-807E
End-------------------------(Elapsed Time: 06:52)--------------------------
Monday,28,September,2020,20:33:14:24996
VCDS Version: 20.4.2.0 (x64)
VIN: WAUHMAFC5EN073984 Mileage: 113051km-70246miles
Revision: 58H14---
VCID: 2E58146D7176E1F6B1-807A
Revision: --H16---
VCID: 3C7C2E25B70A03660F-8068
VCID: 3B7E2D39B204045E06-806E
VCID: 7CFCEE25FF8AC3664F-8028
Coding: 368120BA5D
VCID: 63CEB5596A341C9E6E-8036
VCID: 6FE6C969BEFCA8FEFA-803A
Coding: 0045F7
Coding: 02006D
Coding: 853000
Coding: 110000
Coding: 110000
Coding: 020300
Coding: A8EB06
VCID: 71E2CF11A0C8BE0EEC-8024
Coding: 7E01010202
VCID: 2854E2755392BFC67B-807C
U1113 00 [009] - -
Reset counter: 153
Mileage: 112509 km
Date: 2020.09.19
Time: 12:04:03
Control Module temperature: 28 °C
Voltage terminal 15: 11.994 V
Velocity_vehicle_reference: -0.00 m/s
VCID: 336E05199A54CC1EDE-8066
Coding: 0004DC
VCID: 387432358B322F46EB-806C
VCID: 346C06059F5ACB26C7-8060
Coding: 00CD077D00
VCID: 72E0C01DA5CE851615-8026
Voltage stabilizer:
Coding: 20
VCID: 377631098E2C203EE2-8062
ROD: EV_SARA2.rod
VCID: 36683C0D8926D936F9-8062
Coding: 0000001
VCID: 30640A15A342F706A3-8064
Component: J770 SWA Slave H05 0060
Subsystem 3 - Serial number: 5F14.06.1900H05000AMS10395ÿ
Subsystem 4 - Serial number: S10395ÿ
014 - Defective
Reset counter: 102
Mileage: 108135 km
Date: 2020.08.08
Time: 17:33:04
02850 - Control Module 2 for Lane Change Assistance (J770)
Fault Status: 01100101
Reset counter: 164
Mileage: 113051 km
Date: 2020.09.28
Time: 20:23:32
02849 - Control Module for Lane Change Assistance (J769)
Reset counter: 164
Mileage: 113051 km
Date: 2020.09.28
Time: 20:23:32
VCID: 458A4BC1CCC042AE60-8010
VCID: 3260001D654EC516D5-8066
Coding: 101F00
02771 - Bulb for Left Brake / Turn Signal / Tail Lamp (M69)
Fault Status: 00101100
Reset counter: 193
Mileage: 112509 km
Date: 2020.09.19
Time: 12:01:13
02772 - Bulb for Right Brake / Turn Signal / Tail Lamp (M70)
Reset counter: 193
Mileage: 112509 km
Date: 2020.09.19
Time: 12:01:13
02742 - Bulb for Brake/Turn Signal Light; Left
Reset counter: 193
Mileage: 112509 km
Date: 2020.09.19
Time: 12:13:00
02743 - Bulb for Brake/Turn Signal Light; Right
Reset counter: 193
Mileage: 112509 km
Date: 2020.09.19
Time: 12:13:00
Coding: 030000
VCID: 1D3AC3A104D06A6E18-8048
VCID: 46884CCDF1C649B669-8012
VCID: 2C5C1E65476A93E69F-8078
VCID: 2D5A13617C709AEE88-8078
VCID: 244CF64527BA5BA657-8070
VCID: 2952E771409886CE64-807C
VCID: 499247F1E0D8A6CE84-801C
Coding: D60000
Coding: 1311
Coding: 6A060000
VCID: 2648EC4D5986A9B649-8072
Coding: 7E01010202
U1113 00 [009] - -
Reset counter: 153
Mileage: 112509 km
Date: 2020.09.19
Time: 10:55:22
Control Module temperature: 31 °C
Voltage terminal 15: 12.030 V
ROD: EV_BC7.rod
U1113 00 [009] - -
Reset counter: 153
Mileage: 112509 km
Date: 2020.09.19
Time: 10:55:23
Outside air temperature: 24.0 °C
Voltage terminal 15: 12.0 V
Control Module temperature: 32.0 °C
VCID: 31620F116048FE0EAC-8064
VCID: 2B5E1D79426494DE96-807E
End-------------------------(Elapsed Time: 06:42)--------------------------
Friday,02,October,2020,19:26:42:24996
VIN: WAUHMAFC5EN073984 Mileage: 113396km-70461miles
Revision: 58H14---
Revision: --H16---
Coding: 368120BA5D
Coding: 0045F7
Coding: 02006D
Coding: 853000
Coding: 110000
Coding: 110000
Coding: 020300
Coding: A8EB06
Coding: 7E01010202
U1113 00 [009] - -
Reset counter: 170
Mileage: 113333 km
Date: 2020.10.01
Time: 14:47:59
Control Module temperature: 34 °C
Voltage terminal 15: 12.175 V
Coding: 0004DC
Coding: 0BC60A040F51D705020000
Shop #: WSC 19601 004 1048576
Coding: 00CD077D00
Voltage stabilizer:
Coding: 20
ROD: EV_SARA2.rod
Coding: 0000001
014 - Defective
Reset counter: 102
Mileage: 108135 km
Date: 2020.08.08
Time: 17:33:04
Coding: 101F00
Coding: 030000
Coding: D60000
Coding: 1311
Coding: 6A060000
Coding: 7E01010202
U1113 00 [009] - -
Reset counter: 170
Mileage: 113333 km
Date: 2020.10.01
Time: 14:47:59
Control Module temperature: 32 °C
Voltage terminal 15: 12.176 V
ROD: EV_BC7.rod
U1113 00 [009] - -
Reset counter: 170
Mileage: 113333 km
Date: 2020.10.01
Time: 14:47:59
Outside air temperature: 26.5 °C
Voltage terminal 15: 12.2 V
Control Module temperature: 30.0 °C
End-------------------------(Elapsed Time: 06:51)--------------------------
