Urshalana
- Oct 3, 2020
- 6
- 0
- USA
- C?ID=419806 NAC + HU-2H
I now have a few things I need to figure out, thanks to Ross-Tech I have a WAY better idea where to start looking, but I did mess something up with my auto leveling lights. I was messing with them and noticed a light on for both the sensors on on the left side- I then followed a thread as guidance to reset the leveling range and managed to get both lights to go down, up then down again. I then got the code to go away and the lights to stay where they were (higher than they used to be which is good) but now I have a "Headlights were not adjusted" code and no clue how to fix it, I don't mind the code being there as the lights are where I want them to be but I want to get rid of the dashboard code its giving. I also would love to clear the "Brake Wear" indicator that's on the dash as well as I've just done pads and rotors with sensors all around and know that they are good. If anyone has any way of re-fixing the headlight range and/or turning off the dashboards codes I would love that.
Saturday,03,October,2020,13:09:43:61515
VCDS Version: 20.4.2.0 (x64)
VIN: WAUML54D61N008513 License Plate:
Chassis Type: 4D (4D - Audi A8 D2 (1994 > 2003))
Scan: 25 01 03 08 11 15 16 17 18 35 37 45 55 56 57 65 67 75 76 77
02
Address 01: Engine Labels: None
Part No: 4D0 907 560 AF
Component: 4.2l V8/5V G 0004
Coding: 07753
VCID: 6AD53E8F168FA2D6AD-515A
WAUML54D61N008513 AUZ7Z0Y1643109
17530 - Oxygen (Lambda) Sensor Heating; B2 S2
P1122 - 35-00 - Open Circuit
17526 - Oxygen (Lambda) Sensor Heating; B1 S2
P1118 - 35-00 - Open Circuit
17522 - Oxygen (Lambda) Sensor; B1 S2
P1114 - 35-00 - Internal Resistance too High
17548 - Oxygen (Lambda) Sensor; B2 S2
P1140 - 35-00 - Internal Resistance too High
17755 - Camshaft Position Sensor 2 (G163) / Engine Speed Sensor (G28)
P1347 - 35-00 - Incor. Correl.
16825 - EVAP Emission Control Sys
P0441 - 35-00 - Incorrect Flow
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 4D0 907 389 E
Component: ABS/ESP allrad D56
Coding: 08397
Shop #: WSC 02313
VCID: 3167E9E3FBD9110EAC-515A
Address 08: Auto HVAC Labels: 4D0-820-043-MYX.lbl
Part No: 4D0 820 043 Q
Component: A8-Klimavollautomat D13
Coding: 00180
Shop #: WSC 02313
VCID: 2A55FE8FD60F62D66D-258C
Address 15: Airbags Labels: 4D0-959-655-AI8.lbl
Part No: 4D0 959 655 T
Component: Airbag Front+Kopf 4000
Coding: 00417
Shop #: WSC 02335
VCID: 438BB32B5165939E4E-515A
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487 L
Component: Lenkradelektronik D03
Coding: 00112
Shop #: WSC 65535
VCID: 356FDDF30FB13D2EF0-5054
Address 17: Instruments Labels: 4D0-919-033-MYX.lbl
Part No: 4D0 919 035 AR
Component: KOMBI+WEGFAHRS.VDO D33
Coding: 02283
Shop #: WSC 00050
VCID: 76ED1AFF5237763639-515A
01176 - Key
Address 35: Centr. Locks Labels:. 8D0-862-257.clb
Part No: 8L0 862 257 N
Component: CV-Pump, Alarm, RC D16
Coding: 16141
Shop #: WSC 02313
VCID: 4081BC274073888653-4EE6
Address 37: Navigation Labels:
VCID: 55AF7D73ACF11D2E10-4AE6
Note: Excessive Comm Errors
Address 45: Inter. Monitor Labels: 4B0-951-178.lbl
Part No: 4D0 951 177 B
Component: Innenraumueberw. D06
Coding: 00001
VCID: 28510487C80350C67B-513C
Address 55: Headlight Range Labels: 4B0-907-357-DYN.lbl
Part No: 4B0 907 357 C
Component: dynamische LWR D05
Coding: 00001
VCID: 28510487C80350C67B-4B64
30-00 - Open or Short to Plus
00774 - Level Control System Sensor; Rear Left (G76)
28-00 - Short to Plus
00776 - Level Control System Sensor; Left Front (G78)
28-10 - Short to Plus - Intermittent
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 4D0 035 195 A
Component: Radio D00
Coding: 00116
Shop #: WSC 02313
VCID: 20411CA7A033A88633-4B00
Address 76: Park Assist Labels: 4D0-919-283.lbl
Part No: 4D0 919 283
Component: Parkingsystem A8 RDW D07
Coding: 01108
VCID: 68D14487088390C6BB-5196
01625 - Front Parking Aid Warning Chime (H22)
31-00 - Open or Short to Ground
01626 - Sensor for Parking-Aid; Front Right (G252)
01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
01629 - Sensor for Parking-Aid; Front Left (G255)
Address 02: Auto Trans Labels: 01L-927-156.lbl
Part No: 4D0 927 156 DF
Component: AG5 01L 4.2l5V USA 0708
Coding: 00002
VCID: 70E12CE730535806E3-5178
End-------------------------(Elapsed Time: 04:01)--------------------------
