MK7 Golf Sportwagen Front Fog Retrofit
StorableComa
C?ID=219649
Hello All,
I recently finished wiring up my front fog lights on my GSW. I've installed a new light switch with auto, front, and rear fog. I've recently retrofit Euro 7.5 LED tail lights, high line door controllers, power folding mirrors and reverse mirror dip; these are all working but rear fog. Note on rear fog, I did not run a wire to the BCM. I repurposed the drivers reverse wire and ran a T tap from the passenger reverse wire. I wired in the front fogs today, grounding at the black plastic circle behind the wiper fluid reservoir on the drivers side. I did wire to BCM B/45 and B/5 - though as to which fog to which pin i'm not quite sure. I figured when I retrofit my Bi-xenon lights I could always swap links and rechts if the cornering lights were reversed.
I did run the trigger wire from Headlight switch pin 5 to A/29.
I went to code for my front fogs today, making the following changes:
Step 1: Enable new rotary switch with fog function:
09 Central Electrics --> Adaptations --> Aussenlicht_uebergreifend-LDS_mit_Nebellicht --> change from No to Yes
(1)-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer (6 - LED Modul for LEDs)
(2)-Leuchte12NL LB45-Lampendefektbitposition 12,38
(3)-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,22
(4)-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links
(6)-Leuchte12NL LB45-Dimmwert AB 12,100 (127 for LED)
(1)-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer (6 - LED Modul for LEDs)
(2)-Leuchte13NL RB5-Lampendefektbitposition 13,42
(3)-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,23
(4)-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts
(6)-Leuchte13NL RB5-Dimmwert AB 13,100 (127 for LED)
I did install LED bulbs and have coded 6 and 127 accordingly.
I believe the issue is either with the trigger wire, or the LDS coding as when I had the following also coded, the fogs would come on with the headlights. So I believe power and ground are correct.
(5)-Leuchte12NL LB45-Lichtfunktion B 12,Abbiegelicht links
(5)-Leuchte13NL RB5-Lichtfunktion B 13,Abbiegelicht rechts
I've since returned them to not active.
When pulling out the switch once or twice I get neither rear fog nor front fogs. I do get the green light on the switch showing I pulled them out, but nothing on my dash.
Autoscan - Please ignore the errors, these are new and from disconnecting the A and B harness from the BCM:
Friday,02,October,2020,23:11:54:38692
VCDS Version: 20.4.2.0 (x64)  HEX-NET2 CB: 0.4527.4
VIN: 3VWC17AU4HM532202   License Plate:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75
VIN: 3VWC17AU4HM532202   Mileage: 66774km-41491miles
Address 01: Engine (J623-CXBB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 K    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 091A00122424002F0000
   Shop #: WSC 00066 790 00202
   ASAM Dataset: EV_ECM18TFS0208V0906264K 001004
   ROD: EV_ECM18TFS0208V0906264K.rod
   VCID: 44DA27434E12AD6B36B-8010
Readiness: 1110 1101
   Part No SW: 09G 927 158 AR    HW: 09G 927 158
   Component: AISIN AG6 G3  202 3198
   Coding: 010100000C000000000000000000000000000000
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_002_VW23.rod
   VCID: 0358E45F0B9C6A534F1-8056
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 AQ    HW: 5Q0 614 517 AF
   Component: ESC           H62 0400
   Revision: 00000000    Serial number: 50367000001346
   Coding: 04FA6AA12423096E4079020080C52920562490024001943400405050C002430000000012121212B835351919323200
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
   ROD: EV_Brake1UDSContiMK100ESP_036.rod
   VCID: 0052EB531A8A714B523-8054
0297 - Steering Angle Sensor
          B1168 F2 [137] - Not Initialized
                    Reset counter: 28
                    Mileage: 66774 km
                    Date: 2020.10.02
                    Time: 23:10:15
   Part No SW: 5GM 907 426 D    HW: 5GM 907 426 D
   Component: AC Manuell    H03 1801
   Revision: 00001K04
   Coding: 02020004200100000000000000000002
   VCID: 49C4367769307003C5D-801C
   Part No SW: 5Q0 937 087 AN    HW: 5Q0 937 087 AN
   Component: BCM PQ37BOSCH 032 0223
   Revision: --------    Serial number: C86413021700OT
   ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
   ROD: EV_BCMBOSCH_017.rod
   VCID: 0740F04F3FA44673139-8052
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    161129  043 0551
   Serial number: 97022066161212024516
   Serial number: 003GCR076DTR
   VCID: 47C0304F7F248673D39-8012
   Occupant Detection:
   Serial number: IBH000000000006OE3GN
   Coding: 303133
   Subsystem 2 - Part No SW: -----------    HW: 480 001 801 17
   Serial number: 35700000000D8841E02M
   Subsystem 3 - Part No SW: -----------    HW: 480 001 901 17
   Serial number: 35800000000C0D8CF02Z
   Subsystem 4 - Part No SW: -----------    HW: 480 402 701 17
   Serial number: 3510001BF248E89303FG
   Subsystem 5 - Part No SW: -----------    HW: 480 402 601 17
   Serial number: 3520001B7237EE245396
   Subsystem 6 - Part No SW: -----------    HW: 480 402 301 17
   Serial number: 3550002C723C4E33315+
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 301 17
   Serial number: 3560002C923C4E34A137
   Part No SW: 5Q0 953 507 GH    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 02031708491150
   Coding: 0410
   VCID: 0256E15B1486635B447-8056
   Part No SW: 5G1 920 840 B    HW: 5G1 920 840 B
   Component: KOMBI         244 8311
   Coding: 0BB5110AA180CF0502087A001000000000000000
   VCID: 261E9DCBD86E7F7B08F-8072
   Component: GW MQB High   518 5286
   Serial number: 14031910801185
   Coding: 0101000870085900FA0000081C0F00000001050000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 2F3078EFF7943E33FB9-807A
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0103
   Serial number: 27160003134840116474
   Coding: 31FFFF
   Serial number: 1012171YJ84946
   Coding: 001103205000020000000000
   VCID: 43D8245F4B1CAA530F1-8016
   Serial number: 00000000000005474626
   Coding: 011000
   Part No SW: 5QM 909 144 A    HW: 5QM 909 144 A
   Component: EPS_MQB_ZFLS  171 1072
   Coding: 0102
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 4FF0186F97545E339B9-801A
16275 - Steering Angle Sensor
          B1168 F2 [009] - Not Initialized
                    Reset counter: 28
                    Mileage: 66774 km
                    Date: 2020.10.02
                    Time: 23:10:14
                    Motor status: 00
                    Supply voltage: 12.00 V
                    Temperature: 37.0 °C
                    KFC: 3F
                    KFA: 00 93
                    Environmental conditions: 5F
                    uAdSensI_U1V2Filtered_gdu16: 1.19 V
                    uioUdNotFilt_xdu16: 11.98 V
                    uAdSensI_SwitchedKl30_xdu16: 11.99 V
                    NoInitCause_AsicSens: [0x12] ASC_CTRL_SAS_PERIOD_ERR - SASPERIOD content lost after last ignition off
                    NoInitCause_RackPos_Rohwert: 01 80
                    RP_VALCNTSAV: activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: activated
   Serial number: 2211181YJ83832
   Coding: 001103205C00020000000000
   VCID: 42D6215B5406A35B047-8016
   Serial number: 00000000000005464806
   Coding: 091000
   Part No SW: 3Q0 035 844 A    HW: 3Q0 035 844 A
   Component: MU-S-S-US     710 0751
   Coding: 02730200FF00000051220001001808009F0100D40120010002
   Shop #: WSC 00066 790 07025
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 2D0C62E7FD984C23C95-8078
   Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
   Component: ABT_Std-2  H53 1031
   Serial number: VWZ8Z9TJW024PY
          B11CF 53 [009] - Deactivated
                    Reset counter: 28
                    Mileage: 66774 km
                    Date: 2020.10.02
                    Time: 23:10:28
                    Voltage terminal 30: 12.0 V
                    SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
                    SDARS_tuner_status_2-Audio Signal: Not available
                    SDARS_tuner_status_2-Antenna current: 137 mA
                    SDARS_tuner_status_2-Reception quality: No_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
0008 - Connection between Antenna Amp 2 for Radio and Antenna
          B1273 13 [009] - Open Circuit
                    Reset counter: 28
                    Mileage: 66774 km
                    Date: 2020.10.02
                    Time: 23:10:16
                    Voltage terminal 30: 12.1 V
                    Status of antenna 2 for radio-Antenna current: 0 mA
                    Status of antenna 2 for radio-Connection between radio and antenna amplifier: Electrical OK
                    Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Open circuit
                    Status of antenna 2 for radio-Reception level antenna 2: 51 dBµV
   Coding: 02730202C2821A017F1E06000000
   ROD: EV_OCULowMQB.rod
End----------(Elapsed Time: 01:12, VBatt start/end: 12.2V/12.1V)-----------
Am I missing something here? Any help is appreciated.
Thanks,
Sean
StorableComa
C?ID=219649
Had it plugged into C29, checking pin on a29 and swapping now.
StorableComa
C?ID=219649
So double checked, A29 pin exists and it's plugged into the correct BCM slot (closest to the engine). Double checked and both B/5 and B/45 have pins and are in the correct middle connector.
Still no front or rear fog when pulling out the switch.
StorableComa
C?ID=219649
And never mind.. I had the trigger wire going to 7 on the LDS.:banghead:
Everything works fine now that I swapped it. Feel free to delete if needed.
