ECM Issues
omegarhopsi72
I haven't driven my 2011 Audi A6 Quattro 3.0T in several weeks. (driving Truck) and so I took the battery out of the car and recharged. After reinstalling the battery, the car would not recognize the key (finally got it to work) and the engine light, TPMS light, red oil pressure light, etc., were ALL on. I did an auto-scan on my VCDS and got red status malfunctions at almost all address values. Is there a way to reboot or reprogram my ECM to get things back to normal? Thanks.
MartinsX
Riga, Latvia
C?ID=268515
1) Post an autoscan here
2) Check oil level
3) Charge battery
4) Clear all DTC, start engine, let it idle for some minutes, do a new autoscan and post here, if still needed
Mari
C?ID=150535
Most of the faultcodes will be warnings about low voltage... some of the warning-lights will disappear after driving a few miles (power-steering etc.).
  • Agree
omegarhopsi72
The battery is fully charged. The oil level is good when the engine is not running and there is no oil on the stick when the engine is running, indicating to me that the oil pump is working ok. Mari you are correct, most of the fault codes are warnings about low voltage. I did try to drive, but after backing up the car a few feet out of my driveway it stopped! The VCDS Address 02: Auto Trans is showing two fault codes: 005913 - Functionality limited due to Engine Control Module. P1719 - 002 and fault code 006231 - Load Signal P1857 -001 -Error Message from ECU - intermittent.
Thursday,01,October,2020,14:01:45:49422
VIN:               License Plate:
Mileage: 196060km-121826mi   Repair Order: 4
Chassis Type: FB-AU56 (4F0)
Scan: 01 02 03 05 08 09 0E 15 16 17 19 36 3C 42 46 47 4C 4F 52 53
          55 56 5F 62 6C 72 76
VIN:                Mileage: 196060km-121826miles
4C-Tire Pressure II -- Status: Malfunction 0010
Address 01: Engine (CCA)       Labels:. 06E-907-551-CAJ.clb
   Part No SW: 4F1 910 551 D    HW: 4F1 907 551
   Component: 3.0l V6 TFSI        0030
   Revision: --H07---    Serial number:
   Coding: 0105000A190F0120
   Shop #: WSC 02325 785 00200
   VCID: 2411EEE532D7EFCB16B-8070
005709 - Oil Pressure Switch for reduced Oil Pressure
               P164D - 000 - Malfunction - Intermittent
                    Fault Status: 00100001
                    Mileage: 196061 km
                    Date: 2020.08.24
                    Time: 16:25:14
                    RPM: 704 /min
                    Temperature: 78.0°C
                    Torque: 0.0 Nm
                    Voltage: 13.57 V
                    Bin. Bits: 00000011
               U1017 - 000 -
                    Fault Status: 01101000
                    Mileage: 196060 km
                    Date: 2010.04.16
                    Time: 00:00:33
                    RPM: 1216 /min
                    Mass Air / Rev.: 218.0 mg/str
                    Temperature: 37.5°C
                    Bin. Bits: 00000010
                    Load: 19.6 %
005480 - Throttle Actuator (J338)
               P1568 - 000 - Mechanical Failure - Intermittent
                    Mileage: 196060 km
                    Load: 94.5 %
                    Temperature: 52.5°C
                    Temperature: 28.5°C
                    Voltage: 12.34 V
000291 - Throttle Position Sensor (G69)
               P0123 - 000 - Signal too High - MIL ON
                    Fault Status: 11100001
                    Mileage: 196060 km
                    Mass Air / Rev.: 0.0 mg/str
                    Temperature: 51.0°C
                    Bin. Bits: 00000000
                    Load: 94.5 %
                    Bin. Bits: 00000000
000546 - Angle Sensor 2 for Throttle (G188)
               P0222 - 000 - Signal Too Low - MIL ON
                    Fault Status: 11100010
                    Mileage: 196060 km
                    Temperature: 51.0°C
                    Bin. Bits: 00000000
                    Load: 94.5 %
                    Bin. Bits: 00000000
Readiness: 1110 0101
   Part No SW: 4F9 910 156 A    HW: 09L 927 156 C
   Component: AG6 09L 3,0TFSI USA 0020
   Revision: --H05---    Serial number:        4599631
   Coding: 0000002
   VCID: 2A0D00DD50F339BB2C7-807E
               P1719 - 002 -
                    Fault Status: 01100010
                    Mileage: 196060 km
                    Date: 2010.04.17
                    Time: 02:46:00
               P1857 - 001 - Error Message from ECU - Intermittent
                    Mileage: 196060 km
                    Date: 2010.04.17
                    Time: 02:46:01
Address 03: ABS Brakes        Labels: 4F0-910-517.clb
   Part No SW: 4F0 910 517 AL    HW: 4F0 614 517 BA
   Component: ESP8 quattro    H03 0060
   Coding: 0020921
   VCID: 6E85CCCDAC9B159BB0F-803A
                    Reset counter: 6
                    Mileage: 196060 km
                    Date: 2010.04.16
                    Time: 00:00:33
                    Hex Value: 0x00C0
                    Hex Value: 0x42A2
                    Hex Value: 0x0024
                    Hex Value: 0x018B
                    Hex Value: 0x00FF
                    Fault Status: 00101101
                    Reset counter: 46
                    Mileage: 196060 km
                    Date: 2010.04.17
                    Time: 02:46:02
                    Hex Value: 0x00C0
                    Hex Value: 0x62A2
                    Hex Value: 0x0025
                    Hex Value: 0x0197
                    Hex Value: 0x00FF
18265 - Load Signal
            P1857 - 000 - Error Message from ECU - Intermittent
                    Reset counter: 46
                    Mileage: 196060 km
                    Date: 2010.04.17
                    Time: 02:46:02
                    Hex Value: 0x00C0
                    Hex Value: 0x62A2
                    Hex Value: 0x0028
                    Hex Value: 0x019A
                    Hex Value: 0x00FF
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 E
   Component: FBSAUDIC6 ELV   H05 0130
   Revision: 00H05000    Serial number: 10603001709528
   Coding: 0000007
   Shop #: WSC 02324 785 00200
   VCID: 2517F3E139ED16C3015-8070
   Subsystem 1 - Part No: 4F0 910 132 L
   Component: FBSAUDIC6 EZS   H03 0020
   Component: FBSAUDIC6 KSG   H03 0020
   Component: FBSAUDIC6 IDG   H01 0053
00956 - Key 2
                    Fault Status: 00110010
                    Fault Frequency: 12
                    Reset counter: 46
                    Mileage: 195152 km
                    Date: 2020.04.05
                    Time: 13:05:38
                    Reset counter: 45
                    Mileage: 196060 km
                    Date: 2010.04.26
                    Time: 00:13:34
                    Reset counter: 45
                    Mileage: 196060 km
                    Date: 2010.04.26
                    Time: 00:12:37
01176 - Key
                    Reset counter: 46
                    Mileage: 196060 km
                    Date: 2010.04.18
                    Time: 01:05:53
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Part No SW: 4F0 910 043 B    HW: 4F1 820 043 AL
   Component: KLIMABETAETIGUNGH30 0080
   Revision: 00000076    Serial number: 00000030595788
   Coding: 0524326
   VCID: 1D67DB0111BDDE03595-8048
   Part No SW: 4F0 910 279 AE    HW: 4F0 907 279 A
   Component: ILM Fahrer      H30 0390
   Coding: 0133123
   Shop #: WSC 02335 785 00200
   VCID: 6C81C6C59A87E78B9EB-8038
   Subsystem 1 - Part No: 4F1 910 113 D  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H11 0040
   Coding: 00056595
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
                    Fault Status: 00111010
                    Reset counter: 45
                    Mileage: 196060 km
                    Date: 2020.08.23
                    Time: 18:54:00
                    Reset counter: 45
                    Mileage: 196060 km
                    Date: 2020.08.23
                    Time: 18:54:00
01494 - Bulb for Parking Lamps; Left (M1)
                    Fault Status: 00111011
                    Reset counter: 45
                    Mileage: 196060 km
                    Date: 2020.08.21
                    Time: 18:16:00
01498 - Bulb for Parking Lamps; Right (M3)
                    Reset counter: 45
                    Mileage: 196060 km
                    Date: 2020.08.21
                    Time: 18:16:00
                    Reset counter: 45
                    Mileage: 196060 km
                    Date: 2010.04.16
Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
   Part No SW: 4F0 035 110 A    HW: 4F0 035 110
   Component: CDC-MP3-Alp   H44 0140
   Revision: AA001001
   VCID: 1577C321E58D8643915-8040
                    Reset counter: 45
                    Mileage: 196060 km
                    Date: 2010.04.16
                    Time: 00:03:30
                    Voltage: 8.00 V
Address 15: Airbags (J234)       Labels:* 4F0-910-655-10.clb
   Part No SW: 4F0 910 655 R    HW: 4F0 959 655 H
   Component: Airbag AU1042 H07 0200
   Revision: --------    Serial number: 003FA001FX1Z
   Coding: 303142373035303030314A55304C34463053
   ROD: EV_Airba10AURB4.rod
   VCID: 363524AD98CB6D5BB8F-8062
   Subsystem 1 - Part No SW: 4F0 910 339 B    HW: 4F0 959 339 B
   Component: BF-Gewichtss.  H03 0060
   Serial number: 5810000R000000532U
   Serial number: 3574SRB40000CFB132CG
   Serial number: 3584SRB40000D08890DC
   Serial number: 3516HRB401M076KATKJ-
   Serial number: 3526HRB401K076KAV356
   Serial number: 3554NRB400005EE7A67G
   Serial number: 3564NRB400005F29C7BF
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 C
   Component: J0527               0530
   Revision: 00H06000    Serial number: 90026103190010
   Coding: 0012341
   VCID: 270BF9E943E104D3339-8072
   Component: E0221           H02 0100
                    Reset counter: 45
                    Mileage: 196060 km
                    Date: 2010.04.26
                    Time: 00:13:29
                    Reset counter: 45
                    Mileage: 196060 km
                    Date: 2010.04.26
                    Time: 00:14:25
Address 17: Instruments (J285)       Labels:. 4F0-920-xxx-17.clb
   Part No SW: 4F0 920 983 H    HW: 4F0 920 983 H
   Component: KOMBIINSTR.   H09 0209
   Revision: 00000000    Serial number: FKX071CCA
   Coding: 8BD60A050B00CF05020201
   Shop #: WSC 02391 823 56573
   VCID: 313F17B171254A63EDD-8064
   Part No SW: 4F0 907 468 N    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0035
   Revision: MB200030    Serial number: 3000M10B088451
   Coding: 000303
   VCID: 3A2D309DAC53893B5C7-806E
   Subsystem 1 - Part No SW: 8K0 915 181 C    HW: 8K0 915 181 C
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790249708
                    Fault Frequency: 27
                    Reset counter: 46
                    Mileage: 195364 km
                    Date: 2020.05.22
                    Time: 18:06:29
                    Bin. Bits:    10111
                    Voltage: 11.40 V
                    Count: 7
                    Reset counter: 45
                    Mileage: 196060 km
                    Date: 2010.04.26
                    Time: 00:13:43
                    Bin. Bits:    00000
                    Voltage: 7.70 V
                    Count: 11
   Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
   Component: MEM-FS        H08 0064
   Revision: AA000000    Serial number: 00001002215635
   Coding: 00581B00004011110000
   VCID: 323D18BD7423717B947-8066
                    Reset counter: 45
                    Mileage: 196060 km
                    Date: 2010.04.26
                    Time: 00:12:35
                    Reset counter: 45
                    Mileage: 196060 km
                    Date: 2010.04.26
                    Time: 00:13:35
   Part No SW: 4L0 910 566 D    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH01 0020
   Revision: 00H01000    Serial number: 6PZ 009 014-15
   Coding: 0000002
   VCID: 2F3B11C96B115C93FB9-807A
   Subsystem 1 - Part No: 4L0 910 568 D
   Component: J0770_SWA_Slave_H01 0020
   Subsystem 2 - Serial number: 6PZ 009 014-35
   Subsystem 3 - Serial number: 5F13.10.1000H010003CN11181ÿ
   Subsystem 4 - Serial number: N11181ÿ
   Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
   Component: TSG FA        H12 0361
   Revision:             Serial number: 0008000133189
   Coding: 011F57204E40410001
   VCID: 48C95A55E2BFEBABDA3-801C
                    Reset counter: 45
                    Mileage: 196060 km
                    Date: 2010.04.26
                    Time: 00:12:50
                    Reset counter: 45
                    Mileage: 196060 km
                    Date: 2010.04.26
                    Time: 00:13:44
Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
   Part No SW: 4F0 910 289 N    HW: 4F0 907 289 N
   Component: Komfortgeraet   H29 0250
   Revision: 02500029    Serial number: 01841505440000
   Coding: 4618269
   Shop #: WSC 06136 444 95552
   VCID: 353723A1894D6643B15-8060
Address 47: Sound System (J525)       Labels: Redir Fail!
   Part No SW: 4F0 035 223 P    HW: 4F0 035 223 P
   Component: BOSE G3 C6    H01 0100
   Revision: AG001300    Serial number: 00000000107292
   Coding: 05000000
   VCID: 290FFFD159F532A325D-807C
                    Reset counter: 45
                    Mileage: 196060 km
                    Date: 2010.04.26
                    Time: 00:13:43
                    Voltage: 8.20 V
                    Reset counter: 45
                    Mileage: 196060 km
                    Date: 2010.04.26
                    Time: 00:12:53
                    Voltage: 8.20 V
Address 4C: Tire Pressure II        Labels: 4F0-910-274.clb
   Part No SW: 4F0 910 274 B    HW: 4F0 907 274
   Component: J793  RKA+      H03 0110
   Revision: 00000276    Serial number: 00002760008209
   Coding: 0623301
   VCID: 2313EDF937D9E8F36F1-8076
                    Fault Status: 11101101
                    Reset counter: 5
                    Mileage: 196060 km
                    Date: 2010.04.16
                    Time: 00:00:34
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0005
                    Voltage: 12.20 V
                    Temperature: 33.0°C
                    (no units): 0.0
                    Reset counter: 5
                    Mileage: 196060 km
                    Date: 2010.04.16
                    Time: 00:00:32
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0005
                    Voltage: 10.40 V
                    Temperature: 33.0°C
                    (no units): 0.0
   Part No SW: 4F0 910 280     HW: 4F0 907 280 C
   Component: ILM Beifahrer   H14 0100
   Revision:             Serial number: 00000000810535
   Coding: 0002014
   VCID: 5EE59C0D5C3B851B00F-800A
                    Reset counter: 45
                    Mileage: 196060 km
                    Date: 2010.04.26
                    Time: 00:15:00
                    Voltage: 6.900 V
                    Temperature: 77.0°C
                    Reset counter: 45
                    Mileage: 196060 km
                    Date: 2010.04.26
                    Time: 00:12:00
                    Voltage: 8.300 V
                    Temperature: 77.0°C
   Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
   Component: TSG BF        H12 0361
   Revision:             Serial number: 0008000133808
   VCID: 47CB5969EFA1E4D3D39-8012
                    Reset counter: 45
                    Mileage: 196060 km
                    Date: 2010.04.26
                    Time: 00:12:51
                    Reset counter: 45
                    Mileage: 196060 km
                    Date: 2010.04.26
                    Time: 00:13:44
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801 D    HW: 4F0 907 801 B
   Component: EPB  CEFC0090   H05 0090
   Revision: --H05---
   Coding: 0000222
   Shop #: WSC 02145 785 00200
   VCID: 211FE7F12DC5FAE37DD-8074
   Part No SW: 4L0 910 357 B    HW: 4L0 907 357 B
   Coding: 0000026
   VCID: 2B0305D95F0920B3D71-807E
   Subsystem 1 - Part No: 4F0 941 329 D
   Component: AFS-Modul links H01 0010
   Subsystem 2 - Part No: 4F0 941 329 D
   Component: AFS-Modul rechtsH01 0010
   Part No SW: 4G0 035 082     HW: 4G0 035 082
   Component: Radio U SIRIU H51 0052
   Revision: AB001007    Serial number: 471K10A7543458
   Coding: 020007010000000000
   VCID: 5DE79B015D3D9E03195-8008
                    Reset counter: 45
                    Mileage: 196060 km
                    Date: 2010.04.26
                    Time: 00:13:35
                    Voltage: 7.60 V
                    Reset counter: 45
                    Mileage: 196060 km
                    Date: 2010.04.26
                    Time: 00:13:05
                    Voltage: 8.00 V
03455 - Function Restriction due to Faults in Other Modules
                    Reset counter: 45
                    Mileage: 196060 km
                    Date: 2010.04.17
                    Time: 02:46:25
                    Bin. Bits: 00000000 00000001
   Part No SW: 4E0 035 664 B    HW: 4E0 035 664 A
   Component: H-BN-NA       H49 0116
   Revision: --------    Serial number: 488JJ0A7539698
   Coding: 010200000102E1FF51000F05EF6300030000
   VCID: 2313EDF93BD9E8F36F1-8076
   Subsystem 1 - Part No: 8R0 060 884 P
   Component: NAR 2010  0407
   Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
   Component: DU7 High  H43 0084
   Serial number: 9466K10A0264695
   Subsystem 3 - Part No SW: 4F0 910 609 E    HW: 4F1 919 611 Q
   Component: Bedienteil MM  H01 0060
   Serial number: 00000001337903
   Component: CD-Database  1886
                    Reset counter: 45
                    Mileage: 196060 km
                    Date: 2010.04.26
                    Time: 00:13:55
                    Voltage: 7.70 V
02244 - Button in Control Head is Stuck
                    Fault Frequency: 19
                    Reset counter: 21
                    Mileage: 195304 km
                    Date: 2020.04.21
                    Time: 18:00:29
                    Voltage: 12.30 V
                    Bin. Bits: 10000100 10000000
                    Bin. Bits: 00000000 00000000
02257 - Remote Control Receiver
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 6
                    Mileage: 183624 km
                    Date: 2018.10.18
                    Time: 09:13:44
                    Voltage: 11.50 V
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0361
   Revision:             Serial number: 0008000134942
   Coding: 010E57204040220001
   VCID: 46D5546DE8ABFDDB28F-8012
                    Reset counter: 45
                    Mileage: 196060 km
                    Date: 2010.04.26
                    Time: 00:12:51
                    Reset counter: 45
                    Mileage: 196060 km
                    Date: 2010.04.26
                    Time: 00:13:44
   Part No SW: 4F0 910 441 D    HW: 4L0 907 441 B
   Revision: --H04---    Serial number: 525PA8-J0X23RD
   Coding: 1000304
02203 - Audio / Video Input 1
                    Fault Status: 00101011
                    Reset counter: 45
                    Mileage: 194685 km
                    Date: 2020.03.05
                    Time: 10:31:34
                        Reverse OFF
                    Count: 3
                    Fault Status: 01101101
                    Reset counter: 6
                    Mileage: 196060 km
                    Date: 2010.04.18
                    Time: 01:06:16
                        Reverse OFF
                    Count: 3
                    Reset counter: 45
                    Mileage: 196060 km
                    Date: 2010.04.26
                    Time: 00:12:35
                        Term 15 Off
                        Reverse OFF
                    Count: 3
                    Reset counter: 45
                    Mileage: 196060 km
                    Date: 2010.04.26
                    Time: 00:12:52
                        Term 15 Off
                        Reverse OFF
                    Count: 3
   Component: TSG HR        H11 0361
   Revision:             Serial number: 0008000134939
                    Reset counter: 45
                    Mileage: 196060 km
                    Date: 2010.04.26
                    Time: 00:12:51
                    Reset counter: 45
                    Mileage: 196060 km
                    Date: 2010.04.26
                    Time: 00:13:44
   Part No SW: 4L0 910 283 B    HW: 4L0 919 283 B
   Component: Parkhilfe 4-Kan H03 0500
   Revision: 00H03000    Serial number: 37231032903542
   Coding: 0021206
   VCID: 290FFFD155F532A325D-807C
End----------(Elapsed Time: 02:11, VBatt start/end: 12.0V/12.0V)-----------
I would clear all these fault codes. Do it in 01-Engine, as well as [Clear All] on the Auto-Scan screen. Then let's see what comes back.
Oh, and please set the date/time in the car first so that the freeze-frame data in any fault codes that come back is accurate.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
With flat battery it can be that some modules got data corrupted , Flat battery is really bad thing to do in new car , Modules are very sensitive and most of the time they get corrupted.
As UWE mention clear all codes to see what will come back. But before that drive car short distance to start recognize steering angle sensor.
And yes when you do Clear All codes, go back to 01-Engine and clear codes manual direct in controller.
omegarhopsi72
Thanks for your help Uwe and Jetta 97. I tried driving my car, but it will not move after going in reverse. I can drive forward, but I'm in my driveway, and need to back out first! Now, I'm really in panic mode. I have a previous VCDS self-diagnosis log. Can I use/change something in this (i.e. coding) to reinput the data in the modules to get them to reset, reprogram, etc.?
