i have recently Retrofitted electric seats and changed the HVAC controller to have the OEM switches to power them on, i'm unsure about how to go about it,this scan is of before the new hvac was fitted and after, any help would be greatly appreciated
Friday,02,October,2020,15:56:13:42685
VCDS Version: 20.4.2.0
VIN: WV2ZZZ7HZDH009386 License Plate: WT51MON
Mileage: 155530km-96641mi Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 10 15 17 18 19 25 56 0B
VIN: WV2ZZZ7HZDH009386 Mileage: 155530km-96641miles
Address 01: Engine (J623-CCHA) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 GJ HW: 03L 907 309 M
Component: R4 2,0L EDC X43 3302
Revision: 26X43--- Serial number: 00000000000000
Coding: 0119401A232400080000
Shop #: WSC 26214 051 00000
ASAM Dataset: EV_ECM20TDI01103L906019GJ 003002
ROD: EV_ECM20TDI01103L906019FG_003.rod
VCID: 79F3C9D0F87FEF4E54-802C
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 J HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0109
Revision: 00H43001
Coding: 208764AD09A4049E26A59079AA6410
Shop #: WSC 02756 790 49152
VCID: 397309D0B0FF2F4E14-806C
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E5 907 047 BL HW: 7E5 907 047 BL
Component: Climatic-T5 H20 0505
Revision: 00001010
Coding: 0000000002
Shop #: WSC 02756 790 50316
ROD: EV_ClimaT5Basis.rod
VCID: 7AF1D6DCFD79E4565D-802E
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 087 H HW: 7H0 937 087
Component: BCM T5GP H+4 H47 0254
Revision: BO047001 Serial number: 0429 147120514
Coding: B8B079BA2EF3241392284ED06EAB8DDDF08841FF608460C0320000000000
Shop #: WSC 02756 790 12345
Subsystem 1 - Part No SW: 7E0 959 801 B HW: 7E0 959 801 B Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 002 3313
Subsystem 2 - Part No SW: 7E0 959 802 B HW: 7E0 959 802 B Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 002 3313
Subsystem 3 - Part No: 7E1 951 171
Subsystem 5 - Part No: 7E1 951 171
Subsystem 6 - Part No SW: 5K0 959 542 B HW: 5K0 959 542 B
Component: E221__MFL-TAS H30 0036
Serial number: 0006934 FLE 20130307
Coding: 830000
03428 - Activation of Left Adaptive Light
Reset counter: 189
Mileage: 155539 km
Date: 2015.02.23
Time: 03:47:40
03429 - Activation of Right Adaptive Light
Reset counter: 189
Mileage: 155539 km
Date: 2015.02.23
Time: 03:47:40
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 L HW: 7N0 919 475
Component: PARKHILFE 8K H06 0106
Revision: -------- Serial number: 28261212800889
Coding: 108001
Shop #: WSC 87004 210 102191
ASAM Dataset: EV_VW75XParkAssis8K 001003
ROD: EV_VW75XParkAssis8K_001_VN75.rod
VCID: 3B7F13D8B2C31D5E06-806E
Part No SW: 7E0 959 655 C HW: 7E0 959 655 C
Component: VW10Airbag00P H07 0013
Revision: -------- Serial number: 003HM002CPD8
Coding: 000000000000000000000000000000003050
Shop #: WSC 02754 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 366902EC89E1C036F9-8062
Serial number: 3495ZRB405V0OPMMHOT$
Serial number: 3505ZRB405T0OPMMBHG3
Part No SW: 7E0 920 970 G HW: 7E0 920 970 G
Component: KOMBI H06 0605
Coding: 060F01
Shop #: WSC 02757 790 50316
VCID: 2E592A8C71B1F8F6B1-807A
Address 18: Aux. Heat Labels: None
Part No: 7E0 815 071 B
Component: J737__Standheizung 0605
Revision: 00085000 Serial number: 09019275F00000
Coding: 0000031
Shop #: WSC 02757 790 00000
VCID: 244DC8A4E77D42A657-8070
Part No SW: 6N0 909 901 HW: 7H0 937 087
Component: GW-K-CAN TP20 H47 0254
Revision: BO047001
Coding: 042300
VCID: 70E5F4F4A305AE06E3-8024
Component: IMMO H06 0605
VCID: 6AD1E69C8DD954D6AD-803E
Address 56: Radio
End-------------------------(Elapsed Time: 03:02)--------------------------
4708 - No Communications with HVAC Control Module (J301)
U0164 00 [038] - -
Mileage: 155539 km
Date: 2020.10.02
Time: 03:57:32
Engine speed: 0.00 /min
Coolant temperature: 35 °C
Intake air temperature: 24 °C
Voltage terminal 30: 12.060 V
Limitation: accelerator pedal: 92.4 Nm
Cruise Control System (CCS): status-Bits 0-7: 8
selected gear-Bits 0-7: 0
Revision: 00H43001
Part No SW: 7E5 907 047 AN HW: 7E5 907 047 AN
Component: Climatic-T5 H19 0404
Revision: 00001009
Coding: 0000000002
VCID: 7BFFD3D8F243DD5E46-802E
9471253 - Temperature Sensor for Footwell Vent
B1085 15 [008] - Open or Short to Plus
Reset counter: 229
Mileage: 155539 km
Date: 2020.10.02
Time: 03:58:19
13701968 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Fault Frequency: 44
Reset counter: 69
Mileage: 140007 km
Date: 2019.05.09
Time: 18:20:35
9472533 - Temperature Sensor for Evaporator Vent
B108A 15 [008] - Open or Short to Plus
Reset counter: 229
Mileage: 155539 km
Date: 2020.10.02
Time: 03:58:19
9479443 - Control Circuit for Front Right Seat Heater
B10A5 13 [009] - Open Circuit
Reset counter: 189
Mileage: 155539 km
Date: 2020.10.02
Time: 03:20:41
9479699 - Control Circuit for Front Left Seat Heater
B10A6 13 [009] - Open Circuit
Reset counter: 189
Mileage: 155539 km
Date: 2020.10.02
Time: 03:20:40
9477872 - AC Compressor First Run-In
B109E F0 [009] - Not Performed
Reset counter: 7
Mileage: 139289 km
Date: 2019.04.25
Time: 10:28:29
Coding: 830000
Reset counter: 189
Mileage: 155539 km
Date: 2015.02.23
Time: 03:47:40
Reset counter: 189
Mileage: 155539 km
Date: 2015.02.23
Time: 03:47:40
Coding: 108001
Coding: 060F01
Coding: 0000031
Mileage: 155539 km
Date: 2015.02.23
Time: 03:57:33
Temperature: 22.0°C
Voltage: 11.97 V
Temperature: 17.5°C
Revision: BO047001
Coding: 042300
Reset counter: 229
Mileage: 155539 km
Date: 2015.02.23
Time: 03:57:34
Address 56: Radio
End-------------------------(Elapsed Time: 03:04)--------------------------
