Hi could someone please help me out please.
Couple of weeks ago the coil light on my van started to flash and went into limp mode, stopped for 10 mins and re-started all seemed fine until a week later and the same fault appeared again this time with the engine management as well as the coil light.
Seems to be in limp mode all the time now no boost at all, the large pipe coming from the inter cooler to the throttle body doesn't swell during revs i can depressed the pipe with little force and it remains depressed all the time.
I've change the G31 Sensor and N75 boost pressure valve no improvement.
Thank you kev
VIN: WV1ZZZ7HZBH091138
Thank you kev
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 09 15 17 19 25 56 0B
VIN: WV1ZZZ7HZBH091138 Mileage: 142200km-88358miles
Address 01: Engine (J623-CAAC) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 022 CH HW: 03L 907 309 K
Component: R4 2,0L EDC X41 9126
Revision: 26X41--- Serial number: 00000000000000
Coding: 01194010230400080000
Shop #: WSC 01286 386 08256
ASAM Dataset: EV_ECM20TDI01103L906022CH 002012
ROD: EV_ECM20TDI01103L906019AM_002.rod
VCID: 6D863B0CAD160C73895-8038
11901 - Manifold Pressure / Boost Sensor (G31)
P0236 00 [040] - Implausible Signal
Mileage: 142148 km
Engine speed: 0.00 /min
Coolant temperature: 65 °C
Intake air temperature: 34 °C
Voltage terminal 30: 12.580 V
Charge air pressure: actual value: 970.0 hPa
Intake air pressure sensor after air cleaner: raw value: 999 hPa
Engine status: COENG_FINISH
Outside air temperature: 19.0 °C
Particle filter: difference pressure: -1 hPa
Sensor for particle filter differential press: raw value: 1 hPa
4124 - Sensor Reference Voltage B
P0651 00 [040] - Open Circuit
Mileage: 142137 km
Date: 2020.09.22
Time: 14:39:55
Engine speed: 2049.50 /min
Normed load value: 5.1 %
Vehicle speed: 45 km/h
Coolant temperature: 75 °C
Intake air temperature: 36 °C
Voltage terminal 30: 14.180 V
Exh.gas temp.sen 1: 153.6 °C
Exh.gas temp.sen 2: -0.0 °C
Exh.gas temp.sen 3: 201.5 °C
Exh.gas temp.sen 4: 175.1 °C
Shut-off timer: last engine shut-off time: 16400 s
9120 - EGR Sensor 1
P046C 00 [096] - Implausible Signal
Readiness: 0 2 0 0 1
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 G HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0105
Revision: 00H43001
Coding: 708724AD89AD0E9624A39174A96610
Shop #: WSC 02736 790 49152
VCID: 3634D46098408FABB8F-8062
Fault Status: 00101101
Reset counter: 181
Mileage: 141985 km
Date: 2015.02.12
Time: 18:54:27
Count: 2304
Count: 4113
Count: 8241
Count: 248
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 087 F HW: 7H0 937 087
Component: BCM T5GP H+4 H47 0230
Revision: BO047001 Serial number: 0396 017110499
Coding: A9A030B22E612431802048103C2B8C500000430F60060000300000000000
Shop #: WSC 02734 790 12345
VCID: 372AD9649F4A76A3A39-8062
Subsystem 1 - Part No SW: 7E0 959 801 B HW: 7E0 959 801 B Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 002 3311
Subsystem 2 - Part No SW: 7E0 959 802 B HW: 7E0 959 802 B Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 002 3311
03302 - Response Closing Status of Passenger's Door
Reset counter: 156
Mileage: 140847 km
Date: 2015.01.18
Time: 10:59:14
03442 - Return Message Closing Status of Rear Lid
Fault Frequency: 155
Reset counter: 178
Mileage: 138786 km
Date: 2014.09.28
Time: 17:41:18
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag009 H06 0013
Revision: -------- Serial number: 003HL003HRLN
Shop #: WSC 02734 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3536D36C85C684B3B15-8060
Part No SW: 7E0 920 960 C HW: 7E0 920 960 C
Component: KOMBI H04 0204
Coding: 460200
Shop #: WSC 02736 790 50316
VCID: 290E0F1C597ED05325D-807C
Part No SW: 6N0 909 901 HW: 7H0 937 087
Component: GW-K-CAN TP20 0230
Coding: 042300
VCID: 70B82278BAA4E19BA23-8024
Reset counter: 142
Mileage: 123158 km
Date: 2013.02.22
Time: 11:09:14
Component: IMMO H04 0204
VCID: 6A8C30109CF81B4BEC7-803E
