2009 AUDI Q5 EPC and MISFIRE # 4 cylinder
joe1boss
Boston, MA, USA
Thursday,01,October,2020,20:50:58:61217
VCDS Version: 20.4.2.0 (x64)
VIN: WA1KK78R49A027055   License Plate: JOEBOS
Mileage: 212510km-132047mi   Repair Order: 10/01/2020
Chassis Type: 8R-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 52 53 55 56 5F 62
          65 6C 6D 72
VIN: WA1KK78R49A027055   Mileage: 212510km-132047miles
Address 01: Engine (J623-CALB)       Labels:| 06E-907-559-CAL.clb
   Part No SW: 8R0 907 559 A    HW: 8T0 907 559 B
   Component: 3.2 SIMOS8.2  H04 0006
   Revision: --------
   Coding: 0121000A190F0121
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_ECM32FSI8R0907559A A01012
   ROD: EV_ECM32FSI8R0907559A.rod
   VCID: 3E79D54EA198947621-806A
6353 - Cylinder 4
          P0304 00 [039] - Misfire Detected
                    Mileage: 212511 km
                    Date: 2020.10.01
                    Time: 16:37:09
                    Engine speed: 3153.00 /min
                    Normed load value: 100.0 %
                    Vehicle speed: 60 km/h
                    Coolant temperature: 99 °C
                    Intake air temperature: 45 °C
                    Voltage terminal 30: 14.015 V
                    Engine speed: actual: 3168 /min
                    MAF_ENVD: 637.30587 mg/stroke
                    Coolant temperature (unfiltered): 99.8 °C
                    Engine: operating status: PL
                    T_AST_ENVD: 257.00 s
                    Vehicle speed: actual: 60 km/h
6201 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
                    Mileage: 212510 km
                    Date: 2020.10.01
                    Time: 16:32:31
                    Engine speed: 1114.00 /min
                    Normed load value: 23.5 %
                    Coolant temperature: 101 °C
                    Intake air temperature: 66 °C
                    Voltage terminal 30: 11.070 V
                    Engine speed: actual: 1120 /min
                    MAF_ENVD: 174.30588 mg/stroke
                    Coolant temperature (unfiltered): 101.3 °C
                    Engine: operating status: IS
                    Engine load: 23.437500 %
                    Vehicle speed: actual: 0 km/h
7888 - Please Check DTC Memory of Steering Wheel Electronics
          P1698 00 [039] - -
                    Mileage: 212510 km
                    Date: 2020.10.01
                    Time: 16:21:54
                    Engine speed: 0.00 /min
                    Coolant temperature: 102 °C
                    Intake air temperature: 63 °C
                    Voltage terminal 30: 11.984 V
                    Engine speed: actual: 0 /min
                    MAF_ENVD: 397.63528 mg/stroke
                    Coolant temperature (unfiltered): 102.8 °C
                    Engine: operating status: ES
                    Battery voltage: 11.984375 V
6134 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
                    Mileage: 212510 km
                    Date: 2020.10.01
                    Time: 16:33:16
                    Engine speed: 690.00 /min
                    Normed load value: 38.0 %
                    Vehicle speed: 1 km/h
                    Coolant temperature: 98 °C
                    Intake air temperature: 68 °C
                    Voltage terminal 30: 13.609 V
                    Engine speed: actual: 672 /min
                    MAF_ENVD: 157.96470 mg/stroke
                    Coolant temperature (unfiltered): 98.3 °C
                    Engine load: 37.890625 %
                    Vehicle speed: actual: 1 km/h
7948 - Cylinder Disabling
          P130A 00 [167] - -
                    Mileage: 212511 km
                    Date: 2020.10.01
                    Time: 16:37:09
                    Engine speed: 3148.00 /min
                    Normed load value: 65.1 %
                    Vehicle speed: 61 km/h
                    Coolant temperature: 100 °C
                    Voltage terminal 30: 14.116 V
                    Engine speed: actual: 3008 /min
                    MAF_ENVD: 381.29411 mg/stroke
                    Coolant temperature (unfiltered): 100.5 °C
                    Engine: operating status: PU
                    Vehicle speed: actual: 61 km/h
Readiness: 1110 1101
Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
   Part No SW: 8R0 927 158     HW: 0B6 927 156
   Component: 0B6 32FSIUSA  H05 0013
   Revision: --H05---
   Coding: 001002
   ASAM Dataset: EV_TCMAL651 A01004
   ROD: EV_TCMAL651.rod
   VCID: 7AF1195EFD3078565D-802E
Address 03: ABS Brakes        Labels: None
   VCID: 55AB6AE2BCEE772E10-FFFE
No Faults Found
   Part No SW: 8K0 907 064 AS    HW: 8K0 907 064 AS
   Component: BCM2 1.1      H80 0145
   Coding: 090500
   VCID: 01036EB298E62B8E1C-8054
   Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
   Serial number: 0509000000825008
   Component: ELVAUDIB8  H36 0041
   Serial number: 0208000112150007
   Part No SW: 8T1 820 043 AC    HW: 8T1 820 043 AC
   Component: KLIMA 3 ZONEN H06 0150
   Revision: C1000000    Serial number: 01220120090510
   Coding: 46112000
   VCID: 72E1317EAD40001615-8026
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 203
                    Mileage: 212510 km
                    Date: 2020.10.01
                    Time: 16:22:57
   Component: BCM1 1.0      H22 0253
   Revision: 05022001    Serial number: 00000000196070
   Coding: 26001091063CAF000000080300001D0D0F1C460800010161000000
   VCID: 3065FB7663CC7206A3-8064
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 090113  H10 0041
   Serial number: 90243014081206032154
   Coding: 01DD13
   Component: RLS  H04 0003
   Serial number: 10365024
   Coding: 024D25
   Subsystem 3 - Part No SW: 8K0 941 531 AA    HW: 8K0 941 531 AA
   Component: E1 - LDS  H07 0080
   Serial number: 00000000002101091161
   Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
   Component: HOMELINK  H01 0010
                    Reset counter: 203
                    Mileage: 212510 km
                    Date: 2020.10.01
                    Time: 16:20:00
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 203
                    Mileage: 212510 km
                    Date: 2020.10.01
                    Time: 16:20:00
   Part No SW: 8K0 919 475 G    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0040
   Revision: 11001001    Serial number: 40040902603561
   Coding: 300105
   Shop #: WSC 06325 000 00000
   VCID: 3D7BD242A49E8F6E38-8068
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 A    HW: 8R0 959 655 A
   Component: AirbagVW-AU10 H12 0320
   Serial number: 003BRD0438WF
   Coding: 303633313432303030304A55304C38523053
   ASAM Dataset: EV_AirbaAU10SMEAU416 001001
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 4281A1BED560F09645-8016
   Subsystem 1 - Part No SW: 8R0 959 339     HW: 8R0 959 339
   Serial number: 5810000R08000039MH
   Serial number: 6334MSME46114E61A
   Serial number: 6344MSME426120784
   Serial number: 6352QSME6F160302A
   Serial number: 6362QSME151726202
   Serial number: 63732SME4E1D1E1EI
   Serial number: 63832SME4E1D53085
   Component: Lenks.Modul   H13 0013
   Revision: --------    Serial number: 90315IAI0007C
   Coding: 000017
            014 - Defective
                    Reset counter: 203
                    Mileage: 212510 km
                    Date: 2020.10.01
                    Time: 16:30:01
                    (no units): 44.0
                    Text: 2CA0FFFFFFFF00C0FF
                        -25.067
                    Raw, Index/Key Err.: 255 255 000
                    Text: 229E00005B2FD30B00
                    Speed: 0.00 km/h
                    Steering Angle: 390.1°
                    Lambda Factor: 1.000
                    Fault Status: 01101000
                    Reset counter: 203
                    Mileage: 212510 km
                    Date: 2020.10.01
                    Time: 16:33:20
                    (no units): 44.0
                        -25.067
                    Speed: 0.00 km/h
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 980 A    HW: 8R0 920 980 A
   Component: KOMBIINSTR.   H08 0224
   Revision: 00000000    Serial number: 9EP65AK19
   Coding: 8B1622000300D705020000
   VCID: 3777C06A86A2A53EE2-8062
   Part No SW: 8T0 907 468 P    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0095
   Revision: EB500046    Serial number: 4600E0911600A6
   Coding: 000303
   VCID: 4E99858E193804F6D1-801A
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0107
   Serial number: 00000000004140411528
   Part No SW: 8R0 959 760     HW: 8R0 959 760
   Component: MEM-FS        H05 0043
   Revision: AA000000    Serial number: 00001001214778
   Coding: 00581300000044440000
   VCID: 7EF9154EE918547661-802A
   Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
   Revision:             Serial number: 0000008346158
   Coding: 011D03205E00440004
   VCID: 4183AEB2D866EB8E5C-8014
   Revision: 00002001    Serial number: 0116702887
   Coding: 0126023A207A749404B005
   Component: GTO BF  H06 0040
   Serial number: 00000000000000114827
   Subsystem 3 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J245EE16SKB10  H01 0180
   Subsystem 4 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J394EE16SKB10  H01 0180
   Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
   Revision:             Serial number: 0000008415707
   VCID: 4085ABB6D36CE28653-8014
   Part No SW: 8K0 907 801 F    HW: 8K0 907 801 F
   Component: EPB Audi B8   H06 0070
   Revision: 00000003    Serial number: 10000000161868
   VCID: 3261F17E6DC04016D5-8066
   Part No: 8K0 907 357 B
   Component: Dynamische LWR  H01 0030
   Coding: 0000006
   Shop #: WSC 06334 000 00000
   VCID: 346DF76657D44E26C7-8060
   Part No SW: 4F0 035 082     HW: 4F0 035 082
   Component: Radio U SIRIU H44 0006
   Revision: AB001007    Serial number: 335AX097507945
   Coding: 020000020100000001
   VCID: 5CBD7FC65FC4A6662F-8008
                    Reset counter: 203
                    Mileage: 212510 km
                    Date: 2020.10.01
                    Time: 16:32:37
   Part No SW: 8T1 035 664     HW: 8T1 035 664
   Component: H-BN-NA       H63 0023
   Revision: --------    Serial number: 328A 097509667
   Coding: 010200060005A1EF41000B0E00000003
   VCID: 75EB0A62DC2E172E30-8020
   Subsystem 1 - Part No SW: 4F0 919 604     HW: 4F0 919 604
   Component: DU7 High  H43 0306
   Serial number: 9356AL091052626
   Subsystem 2 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
   Serial number: 00000000219603
   Part No SW: 4F0 959 795 M    HW: 8K0 959 795 B
   Revision:             Serial number: 0000008357853
   Coding: 010C03204000240004
   VCID: 438FA4BAC27AF99E4E-8016
Address 65: Tire Pressure (J502)       Labels: 8K0-907-273.clb
   Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
   Component: J502-RDK      H03 0250
   Revision: 00001001    Serial number: 13140790002792
   Coding: 0CD153
   Part No SW: 8R0 907 441     HW: 4L0 907 441 A
   Component: J772__Rearview      0070
   Revision: --H12---    Serial number: 525PA8-J8ZA0CT
   Coding: 1020010
   VCID: 73EF347A125A091E1E-8026
                    Reset counter: 203
                    Mileage: 212510 km
                    Date: 2020.10.01
                    Time: 16:29:09
                        Reverse OFF
                    Count: 3
Address 6D: Trunk Elect. (J605)       Labels: 4L0-910-945.clb
   Part No SW: 8R0 827 851 A    HW: 8R0 827 851
   Component: J605  Master  H24 0280
   Revision: --------    Serial number: 8R0827851
   VCID: 3A71D95EB5B0B8561D-806E
   Subsystem 1 - Part No SW: 8R0 827 852 A    HW: 8R0 827 852
   Component: J756  Slave  H24 0280
   Serial number: 8R0827852
16347 - Control Module - EEPROM Error
            014 - Defective
                    Reset counter: 203
                    Mileage: 212510 km
                    Date: 2020.10.01
                    Time: 16:28:51
02242 - Rear Lid Lock Button in Luggage Compartment (E406)
                    Reset counter: 203
                    Mileage: 212510 km
                    Date: 2020.10.01
                    Time: 16:28:51
   Revision:             Serial number: 0000008357702
                    Reset counter: 203
                    Mileage: 212510 km
                    Date: 2020.10.01
                    Time: 16:34:00
End-------------------------(Elapsed Time: 04:02)--------------------------
How old are the plugs and coils? The very first thing I'd do is swap the #4 coil with one from another cylinder to see if the problem moves with it.
Your ABS seems to be out to lunch in this scan. What happens if you go directly to [Select] -> [03-ABS Brakes]?
joe1boss
Boston, MA, USA
Plugs was replaced last year. I swap coils 4 to 5, but misfire stayed at #4. I clean the carbon build up on the valves that did not fix the problem.
Then I think the next steps would be checking fuel injectors and a compression test.
MartinsX
Riga, Latvia
C?ID=268515
Then only thing left is fuel injector. Replace it, or swap with another cylinder to be completely sure ;)
joe1boss
Boston, MA, USA
The injector was the problem thanks, Replaced # 4 injector and the car runs great. Now I have a little vibration at idle and when is in drive or reverse it vibrates more with no codes.
Tonytx
Texas
C?ID=423392
now it might be a motor mount, get them tested
cschmitz20
Verified VCDS-Lite User
C?ID=385099
How did you clean the carbon build up? I have one stubborn cylinder amd thinking its carbon. I already put sea foam a few werks ago and iy is still randomly misfiring in cylinder 5 esp at cold start.
