Module 46 – Error 01565 - Luggage Compartment Light (W3)
lee1234
C?ID=68622
007 - Short to Ground
It seems this error is very common. So common that I can’t find any information on it, because there are so many logs which include it when you search for it. But also there is no mention of it in RossTech Wiki Fault Codes.
This is early 2009 TTS Cabriolet
Here is a full scan.
Sunday,27,September,2020,09:23:34:40778
VCDS Version: 20.4.2.0 (x64)
VIN: TRUZZZ8J19101xxxx   License Plate:
Mileage: 113950km-70805mi   Repair Order:
Chassis Type: 8J (1K0)
Scan: 01 03 08 09 10 14 15 16 17 19 22 25 26 42 44 46 47 52 55 56
          77
VIN: TRUZZZ8J19101xxxx   Mileage: 113950km-70805miles
Address 01: Engine (CDL)       Labels:. 06F-907-115-CDL.clb
   Part No SW: 8J0 907 115 Q    HW: 8J0 907 115
   Revision: 5BH16---    Serial number: AUX7Z0H7FNS04W
   Coding: 0113000C180F0060
   Shop #: WSC 41059 344 603265
   VCID: 3A7B087275C0D3561D-806E
004248 - Intake Manifold Tuning Valve Position Sensor (G336)
               P1098 - 001 - Open or Short to Plus
                    Fault Status: 01100001
                    Mileage: 113948 km
                    Date: 2020.09.26
                    Time: 11:38:30
                    RPM: 2367 /min
                    Load: 44.3 %
                    Speed: 32.0 km/h
                    Temperature: 41.0∞C
                    Temperature: 14.0∞C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 14.478 V
012691 - Intake Manifold Runner Control
               P3193 - 002 - Open Stop outside of Valid Range
                    Fault Status: 01100010
                    Mileage: 113954 km
                    Temperature: 85.0∞C
                    Temperature: 17.0∞C
                    Voltage: 13.208 V
Readiness: 0010 0101
Address 03: ABS Brakes        Labels: 8J0-614-517.clb
   Part No SW: 8J0 614 517 A    HW: 8J0 614 517 A
   Component: ESP MK60E1          0020
   Revision: 00H60001
   Coding: 0091958
   Shop #: WSC 01236 785 00200
   VCID: 2B553D368A9A7ADE96-807E
   Part No SW: 8J0 820 043 AG    HW: 8J0 820 043 AG
   Component: J255  Klima 1 Zone  0080
   Revision: 00H08006    Serial number: 00000001109807
   Coding: 1574148
   VCID: 6BD5FD364A1ABADED6-803E
Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
   Part No SW: 8P0 907 279 N    HW: 8P0 907 279 N
   Component: Bordnetz-SG     H54 2801
   Revision: 00H54000    Serial number: 00000008938139
   Coding: 15060E8280141C80CF18000A1800000000084E075B260802800000000000
   VCID: 489F62BA3B2CB1C69B-801C
   Subsystem 1 - Part No: 8J2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer AU354   H08 0070
   Coding: 00064784
   Shop #: WSC 01236
Address 10: Park/Steer Assist (J446)       Labels:. 8P0-919-475-7X1.clb
   Part No SW: 8P0 919 475 M    HW: 8P0 919 475 M
   Component: PARKHILFE 4K  H01 0140
   Revision: 11001001    Serial number: 36861125700145
   Coding: 000003
   Shop #: WSC 06314 000 00000
   VCID: 489F62BAFB2CB1C69B-801C
Address 14: Susp. Elect.        Labels: 8P0-907-376.lbl
   Part No SW: 8J0 910 376 B    HW: 8J0 907 376 B
   Component: J250 Raddaempfung   0050
   Revision: --H18---    Serial number: 190DPH 8218095
   Coding: 0000034
   VCID: 2E533422B9880FF6B1-807A
Address 15: Airbags        Labels: 8J0-959-655.lbl
   Part No SW: 8J0 959 655     HW: 8J0 959 655
   Component: -t Airbag 9.43  H02 0020
   Revision: 93H02002    Serial number: 0036K0036E4D
   Coding: 0011636
   VCID: 79F9D77E3046184E54-802C
   Subsystem 1 - Serial number: 6332DRB407AA4B2D/
   Subsystem 2 - Serial number: 6342DRB407CC04A1U
   Subsystem 3 - Serial number: 63747RB4041BD857W
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H36 0070
   Coding: 0003011
   VCID: 41897F9E1816808E5C-8014
   Component: E0221           H06 0030
Address 17: Instruments        Labels: 8J0-920-xxx-17-MY8.clb
   Part No SW: 8J0 920 980 A    HW: 8J0 920 980 A
   Component: KOMBIINSTR. VDO H14 0330
   Revision: D0H14006    Serial number: 2247H006002211
   Coding: 0069428
   Shop #: WSC 14557 067 57207
   VCID: 2F6D2926BE8206FEBA-807A
00003 - Control Module
            014 - Defective
                    Fault Status: 01101110
                    Mileage: 110750 km
                    Date: 2017.10.27
                    Time: 00:00:26
   Component: J533__Gateway   H16 0202
   Revision:   H16       Serial number: 2700K087228361
   Coding: E9AB1F261006025101
   VCID: 35611B4E5CDE3C2EF0-8060
   Part No SW: 0BR 907 554 A    HW: 0BR 907 554 A
   Component: Haldex 4Motion      3016
   Coding: 0000005
   VCID: 43857596020A929E4E-8016
   Revision: D0H14006    Serial number: AUX7Z0H7FNS04W
Address 26: Auto Roof        Labels: 8J7-959-255.lbl
   Part No: 8J7 959 255 B
   Component: 256 VSG TT      H14 0110
   VCID: 3E73046269E8FF7621-806A
   Part No SW: 8J7 959 801 E    HW: 8J7 959 801 E
   Component: Tuer-SG         H02 0070
   Coding: 0000637
   Part No: 8J0 909 144 C
   Component: EPS_ZFLS Kl. 237    2302
   Revision: 00H15000
   VCID: 306F2A5AA3BC1906A3-8064
Address 46: Central Conv.        Labels:. 8J0-959-433.lbl
   Part No: 8J0 959 433 B
   Component:    KSG          H11 0080
   Coding: 1890300241182D098505489AD633
   Subsystem 1 - Part No: 1K0 951 605 F
   Component: LIN BACKUP HORN H01 0008
   Subsystem 2 - Part No: 8J0 951 177
   Component: DWA-Sensor      H03 0020
Address 47: Sound System        Labels: 8J0-035-223.lbl
   Part No SW: 8J0 035 223 D    HW: 8J0 035 223 D
   Component: J525 Amp High   H04 0150
   Revision: PROD_01     Serial number: 00000000006525
   Coding: 0136115
   Shop #: WSC 19378 444 84935
   VCID: 2541CB0EEC7E4CAE40-8070
16349 - Control Module - Error in Output Stage
                    Fault Status: 00101110
                    Fault Frequency: 29
                    Reset counter: 228
                    Mileage: 37160 km
                    Date: 2011.09.09
                    Time: 01:48:58
00871 - Bass Speaker Front Right (R23)
                    Fault Status: 00111011
                    Reset counter: 64
   Part No SW: 8J7 959 802 E    HW: 8J7 959 802 E
   Coding: 0000636
   VCID: 3F8D79666EE2F67E2A-806A
   Part No: 8P0 907 357 H
   Coding: 0000011
   Part No SW: 8J0 035 195 G    HW: 8J0 035 195 G
   Component: R Symphony2+    H07 0270
   Revision: 00H07000    Serial number: AUZ1Z4H7170255
   Coding: 0730101
   Part No SW: 8P0 862 335 S    HW: 8P0 862 335 S
   Component: FSE_256x BT     H34 0550
   Revision: 00000000    Serial number: 00000005036919
   Coding: 0001202
   VCID: 46836C823138A7B669-8012
End-------------------------(Elapsed Time: 02:16)--------------------------
There are not many wires involved. Only a single wire from Terminal 11 of plug T18g of Module J393 to the lamp, then from the lamp to Ground.
I traced the wire from J393 via the lamp to ground and all seems good, so then I disconnected the lamp and taped the connector away from bodywork. Cleared the error but it returned.
So then I removed pin 11 and taped it up.
Therefore, there is NOTHING connected externally to pin 11. Cleared the error but it still returns even though there is now no wire to W3.
So, all I can see is that there must be a short to ground within the module??
Is it safe to reconnect the lamp and ignore the error? Shorting to ground isn’t the best in terms of battery life/ fire risk.
MartinsX
Riga, Latvia
C?ID=268515
Several bugs, undocumented things and incorrect fault code descriptions are present in real life ;)
I have no personal experience with this exact fault code in MY 2009. TT, but You can try:
- check all (!) fuses supplying power to J393,
- connect a test lamp of similar power as original bulb in W3 directly between T18g/11 and ground,
- try to actuate this output via "Output tests" (if applicable, if not, try by opening trunk)
lee1234
C?ID=68622
Just to confirm, I think the suggestions here are looking for missing power supply, replacing the existing (currently non existant) circuit with an equivalent, and checking what happens when the control circuit is activated (open the trunk). None of those are really anything to do with the error message given - 'Short to Ground'.
Since I have completely removed the W3 circuit, there is no possibility of a 'Short to Ground' within the W3 circuit. Therefore if we take the error at face value, then the only possible outcome is that the module is faulty.
But, is there something lost in translation? Are we saying that 'Short to Ground' should not be taken at face value? Does '007 - Short to Ground' really mean - permanent or intermittent lack of power supply or permanent or intermittent Open Circuit or permanent or intermittent wrong resistance? Should '007 - Short to Ground' really be ignored, and instead should be written or read as 'there is an electrical problem'?
South Molton, UK
'Short to Ground' means the diagnostics are not detecting any voltage - which can be due to several reasons including a blown fuse, a broken wire, or a genuine short to ground.
VAG diagnostics descriptions give a clue to the problem, and should not be taken verbatim.
  • Agree
lee1234
C?ID=68622
Thanks Dave. I have not yet had chance to do any more testing since I disconnected the W3 wire. Hoepfully I'll get chance later this week. Cheers.
