Help with Audi Q5
wingman
C?ID=225881
Hello in VCDS world looking for some help with fault code below, nothing else stored management light comes on when you start it, code can be cleared, but returns as soon as you start it
   Part No SW: 03L 906 018 CM    HW: 03L 906 018 ES
   Component: R4 2.0l TDI   H28 9977
   Revision: 41H28---    Serial number:
   Coding: 00190012041701080000
   Shop #: WSC 38844 001 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018CM 003005
   ROD: EV_ECM20TDI01103L906018CM.rod
   VCID: 77FA6190CEC5123E22-8022
17262 - Terminal 30
          U140A 00 [175] - Open Circuit
                    Mileage: 94067 km
                    Engine speed: 0.00 /min
                    Vehicle speed: 255 km/h
                    Coolant temperature: -40 °C
                    Intake air temperature: -40 °C
                    Ambient air pressure: 0 mbar
                    Voltage terminal 30: 11.900 V
                    Limitation: torque: 0.0 Nm
                    Engine torque: -500.0 Nm
                    Generator: load signal: 0.00 %
Readiness: 1 1 0 0 1
+12V is missing on one of the uswitched power inputs to the ECU. Check fuses and relays.
MartinsX
Riga, Latvia
C?ID=268515
Wait a minute... Why U-code, not P-code?
17262 - Terminal 30
                    Mileage: 94067 km
Why some FF data are so strange? Speed, temperatures, air pressure?
Terminal 30 at ECU looks ok (except weak battery)
OP, please post full autoscan.
wingman
C?ID=225881
Hello thanks for your replys, I have checked battery all good, cleaned fuses, replaced relay 100 in under bonnet fuse-box, and capacitor drain across battery terminals. if I start car and then clear fault with engine running fault does not reappear. but when the car is started it pings up code and puts EML light on full scan below
Friday,02,October,2020,09:17:20:02134
VCDS Version: 20.4.2.0
[URL="http://www.Ross-Tech.com"]www.Ross-Tech.com[/URL]
VIN: WAUZZZ8U2DR031032   License Plate: M20TDH
Mileage: 94060km-58446mi   Repair Order:
Chassis Type: 8U-AU21 (8U0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 42 44 46 52 53 55 5F 62 69
          72
VIN: WAUZZZ8U2DR031032   Mileage: 94060km-58446miles
17262 - Terminal 30
                    Mileage: 94067 km
                    Voltage terminal 30: 11.880 V
   Part No SW: 5N0 614 109 AE    HW: 5N0 614 109 AE
   Component: J104   C6 450M V4C0 0120
   Revision: --H07---    Serial number: 00000006042296
   Coding: 0052359
   Shop #: WSC 00049 770 00192
   VCID: 6ED444F4799F53F6F1-803A
   Part No SW: 8U0 820 043 B    HW: 8U0 820 043 B
   Component: E87  Klimavoll      0050
   Revision: 00H03000    Serial number: 8U0820043B
   VCID: 30689A8CA32B0506A3-8064
   Part No SW: 8X0 907 063 K    HW: 8X0 907 063 K
   Component: BCM PQ35  M   111 0715
   Revision: AG111715
   Coding: 0E000A2CA805F1C0201841C00100094C43FF84AA206F912AE400878400C1
   Shop #: WSC 00049 770 00158
   VCID: 4480C65CC79389A677-8010
   Subsystem 1 - Part No SW: 8U2 955 119     HW: 8U2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS316 120717  H36 0085
   Serial number:         120718111439
   Coding: 0047F7
   Serial number: 20509596
   Coding: 02006E
   Subsystem 3 - Part No: 8X0 951 177
   Component: DWA-Sensor H0  H01 0020
00332 - Control Circuit for Tank Flap
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 192
                    Mileage: 94067 km
                    Date: 2020.10.01
                    Time: 11:43:19
                        Term 15 Off
                    Voltage: 12.25 V
                        Term 50 Off
Address 10: Park/Steer Assist (J446)       Labels:| 8X0-919-475.clb
   Part No SW: 8X0 919 475 M    HW: 8X0 919 475
   Component: PARKHILFE 4K  H03 0051
   Revision: 11001001    Serial number: 37001219401566
   Coding: 0D0005
   ASAM Dataset: EV_EPHVA14AU21X0000 002005
   ROD: EV_EPHVA14AU21X0000_002.rod
   VCID: 50A8FA0C0BEB6506C3-8004
   Part No SW: 8U0 959 655 B    HW: 8U0 959 655 B
   Component: AirbagVW-AU10 H07 0520
   Serial number: 003LRR02RH94
   Coding: 30393132313030303030554A305238553053
   Shop #: WSC 00049 770 00119
   ASAM Dataset: EV_AirbaAU10SMEAU316 001005
   ROD: EV_AirbaAU10SMEAU316_001.rod
   VCID: 4684DC54F9AFBBB669-8012
   Subsystem 1 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3496KSME5E183D1EZZZC
   Subsystem 2 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3506KSME26515E1EZZZ-
   Serial number: 3516KSME292B261EZZZ-
   Serial number: 3526KSME36322B1EZZZW
   Subsystem 5 - Part No SW: 8U0 959 651     HW: 8U0 959 651
   Serial number: 3555USME091C391DZZZ7
   Part No SW: 8X0 953 521 B    HW: 5K0 953 569 B
   Revision: FF010017    Serial number: 20120809100925
   Coding: 1084004000
   Shop #: WSC 00049 770 00156
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 3B72BDA0B26DF65E06-806E
   Subsystem 1 - Part No SW: 8U0 951 528 G    HW: 8U0 951 528 G
   Part No SW: 8U0 920 980 C    HW: 8U0 920 980 C
   Component: KOMBI_MEDIUM  H03 0251
   Coding: 42CF00
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04396
   VCID: 3C70BEBCB763F1660F-8068
   Part No SW: 8U0 907 468 G    HW: 8U0 907 468 G
   Component: GAT 4CAN 1L M H13 0059
   Revision: 1P090032    Serial number: 3241P128030066
   Coding: FBCF1A5A000100610353
   Shop #: WSC 00121 210 96463
   VCID: 4684DC54F1AFBBB669-8012
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900906347
   Serial number: 12236002463011200181
   Part No SW: 0BS 907 554 D    HW: 0BS 907 554 D
   Component: Haldex 4Motion      4017
   Coding: 0000005
   VCID: 479AD15036A5A2BE92-8012
   Component: IMMO          H03 0251
   Coding: 000002
   ROD: EV_Immo_UDS_VDD_AU10.rod
   Part No SW: 8X0 959 793 E    HW: 8X0 959 793 E
   Component: TSG FA        H09 0410
   Coding: 011806200001000000
   VCID: 4FAAF9701ED57AFEDA-801A
   Part No: 5N0 909 144 P
   Component: EPS_ZFLS Kl. 293    3305
   Revision: 00H22000
   VCID: 3E74B4B4697FE37621-806A
   Part No SW: 8X0 959 792 E    HW: 8X0 959 792 E
   Component: TSG BF        H09 0410
   VCID: 4E94E47419DF73F6D1-801A
   Revision:   H19       Serial number: 00000000366180
   Coding: 0025166
   VCID: 3664AC94414F2B36F9-8062
   Part No SW: 8X0 907 357 B    HW: 8X0 907 357 A
   Component: ****LWR12**** H02 0021
   Serial number: 120727-0002-028
   Coding: 1157A61010002300
   ROD: EV_HeadlRegulBasic.rod
   VCID: 418ECF48D0819C8E5C-8014
   Part No SW: 8U0 035 193 B    HW: 8U0 035 193 A
   Component: RMC Cnct Nav  H53 0775
   Coding: 01010600020153070823020103010000000000
   VCID: 3460969C97333926C7-8060
   Subsystem 1 - Part No SW: 8U0 919 603     HW: 8U0 919 603
   Component: DUBasic AU316  H41 0018
   Serial number: AUZ8ZDC0601TP3Z
Address 62: Door, Rear Left (J388)       Labels:. 8X0-959-795.clb
   Part No SW: 8X0 959 795 A    HW: 8X0 959 795 A
   Component: TSG HL        H06 0409
   Coding: 010006200001000000
   VCID: 4D96E37814D948EEA8-8018
   Component: ConWysTrailer H07 0100
   Revision: 3A001001    Serial number: 00000132425721
   Coding: 0100000100000000
   Shop #: WSC 00007 223 174336
   VCID: 30689A8C632B0506A3-8064
Address 72: Door, Rear Right (J389)       Labels:. 8X0-959-795.clb
   Component: TSG HR        H06 0409
End-------------------------(Elapsed Time: 03:10)--------------------------
MartinsX
Riga, Latvia
C?ID=268515
Searched my head + internet a bit.
I have some questions to OP:
- Is the topic title correct? Car is Q5 or Q3, maybe?
- What is engine code?
- Any recent work on car before Check Engine light and this DTC appeared? Repairs, chiptuning, any other kind of programming, drained battery, jump-starting etc.?
- Do You have WD?
- Have You checked power and ground at ECU connector T94? Pins 3, 5, 6 and 92 are terminal 30 (constant battery voltage), pins 1, 2, 4 are GND.
And a question to RT:
Is it possible that VCDS incorrectly displays this exact fault code as U140A? I have unconfirmed information that other scan tools are showing P0562 instead. And this EDC 17 internal fault table does not contain U140A at all.
wingman
C?ID=225881
Hello Thanks for reply, sorry it i a Q3 i just realized i made a typo error, no chip tuning and no recent work done and i do not think any jump start..engine code is CFFB and not checked any voltage at ECU car starts and runs fine just have EML light on
Also scanned it with TEXA and get same fault code what is WD??
MartinsX
Riga, Latvia
C?ID=268515
If You want to get it repaired, You will need WD (point mouse at acronyms highlighted dark green and forum software will tell You what is it), DVOM, load light and some mechanics tools for the beginning. First check power supply at ECU connector pins according my previous post (pinout is correct, I decoded from autoscan data that it is CFFB in Q3, just asked to be completely sure). Do two measurements at each pin - voltage without load and voltage with load.
One more simple test - take good quality jump-start cable (only one lead) and make a temporary extra ground wire between battery negative and metal parts of engine. Clear code, start engine and see if code is back again.
wingman
C?ID=225881
Thanks for the info, I will try earth lead and let you know how that works out, yes i do have a DVOM and a WD, but the fault seems to happen in a nano second when cranking
MartinsX
Riga, Latvia
C?ID=268515
Also You can try to swap the J317 "Terminal 30 Supply Relay" with another one. There should be some more with the same partnumber in the engine compartment fuse/relay box. Oxidized and/or burnt contacts of this relay may cause that fault code stored at time of start, too.
For the Passat B6 exists a TPI for that fault code - damaged wiring in engine compartment. (Red/green wire supplying power to ECU pins mentioned in previous post.)
wingman
C?ID=225881
I have changed out the relay in the engine fuse box,which controls the engine management it was showing number 100 on the top of it, exchanged it with another one, but still no difference,
wingman
C?ID=225881
Just an update on things, customer took car away and has just returned, she said after a couple of days the EML light stopped coming on and has not done since, so unsure what to post here as job seems to be running ok. thanks for your help with replys
