Retrofit cruise control Golf 7 have fault 17149 - Check Coding of ECUs
Tomasitas69
Lithuania
C?ID=198354
Hello
I have problem, I came up with the handle on the CCS, took the wire to the engine computer and this error occurred, and the CCS symbol with the exclamation mark burns on the panel. and EPC and does not work start-stop.
Monday,28,September,2020,19:40:26:13054
VCDS Version: 20.4.2.0 (x64)
VIN: WVWZZZAUZGW246433   License Plate: JEV188
Mileage: 110044km-68378mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZGW246433   Mileage: 110044km-68378miles
Address 01: Engine (J623-CYVB)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 GR    HW: 04E 907 309 BL
   Component: R4 1.2l TFS   H23 2394
   Revision: R4H23---
   Coding: 01190012232411082000
   ASAM Dataset: EV_ECM12TFS01104E906027GR 001005
   ROD: EV_ECM12TFS01104E906027GR.rod
   VCID: 7AFB0626FDEDA7565D-802E
   CAN Converter 01:
17149 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [167] - -
                    Mileage: 110044 km
                    Date: 2020.09.28
                    Time: 19:32:31
                    Engine speed: 0.00 /min
                    Coolant temperature: 86 °C
                    Intake air temperature: 30 °C
                    Voltage terminal 30: 12.486 V
                    Acceleration: 0.000 m/s²
                    Cruise Control System (CCS): status-Bits 0-7: 7
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 128
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 3
                    Drivetrain coordinator: brake fault status-Bits 0-7: 0
Readiness: 1110 0001
   Part No SW: 3Q0 907 379 AF    HW: 3Q0 907 379 F
   Component: ESC           H42 0625
   Revision: 00000000    Serial number: 60246000003064
   Coding: 01FA6AA114242972077B060341C62580562894E06082A4F300200078C002
   VCID: 7EF30A36E1C58B7661-802A
   Part No SW: 5G0 907 426 T    HW: 5G0 907 426 T
   Component: AC Manuell    H02 1001
   Revision: 00001K06
   Coding: 00020004200100001000000000000002
   VCID: 3C77C03EB75959660F-8068
   Part No SW: 5Q0 937 084 CJ    HW: 5Q0 937 084 AL
   Component: BCM MQBAB M   H24 0175
   Serial number: 01061603300919
   Coding: 00000842C20100530BA44080B10403081000000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 020B7EC6953DEF9605-8056
   Component: WWS    160118  043 0551
   Serial number:         160202001959
   Subsystem 2 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY160131MLT
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000034494503
   Part No SW: 5Q0 959 655 D    HW: 5Q0 959 655 D
   Component: AirbagVW20    015 0388
   Serial number: 003F6R1CL368
   VCID: 4189B1CAD0BB348E5C-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 001 102 16
   Serial number: 3576700000059BF0591/
   Subsystem 2 - Part No SW: -----------    HW: 480 000 902 16
   Serial number: 35867000000B6739291Y
   Subsystem 3 - Part No SW: -----------    HW: 480 400 502 16
   Serial number: 3516502A11EDD3E4D0AW
   Subsystem 4 - Part No SW: -----------    HW: 480 400 202 16
   Serial number: 3526502A31EDD3E4F27-
   Subsystem 5 - Part No SW: -----------    HW: 480 400 502 16
   Serial number: 35565029F18166C30168
   Part No SW: 5Q0 953 507 GP    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 26101504221523
   Coding: 1600
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_SMLSKLOMQB 020001
   VCID: 0A1B56E6AD0DB7D64D-805E
   Part No SW: 5G1 920 740 A    HW: 5G1 920 740 A
   Component: KOMBI         207 7652
   Coding: 07A41A002380000801090E001400000000000000
   ASAM Dataset: EV_DashBoardJCIMQBAB 009005
   ROD: EV_DashBoardJCIMQBAB_009.rod
   VCID: 2447185E2FE901A657-8070
   Part No SW: 5Q0 907 530 AG    HW: 5Q0 907 530 D
   Component: GW MQB Low    126 1244
   Revision: --------    Serial number: 0004419280
   Coding: 030000043F085700FB000048080F00010001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 76E31216C9F5C33639-8022
   Subsystem 2 - Part No SW: 5Q0 915 181 G    HW: 5Q0 915 181 G
   Serial number: 6921469203
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Serial number: 110116EA812728
   Coding: 003002208000040100001000
   Part No SW: 5Q0 909 144 S    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  126 1063
   Coding: 0103
   VCID: 4487B8DECFA921A677-8010
   Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
   Serial number: 160116EAG06316
   Coding: 003000208000040100801000
   VCID: 408FB4CEDBB13D8653-8014
   Part No SW: 5G0 035 867 C    HW: 5G0 035 867 C
   Component: MU-E--ER      851 6490
   Serial number: 11011600011751
   Coding: 02730000FF0000004011000100010000000000040000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001025
   ROD: EV_MUEnt4CGen2LGE_VW37.rod
   VCID: 2C57F07E4739C9E69F-8078
End-------------------------(Elapsed Time: 03:21)--------------------------
Sorry, but I have no idea what this means. Can you please explain in more detail?
downtime
Finland
C?ID=280813
And you know that you cannot just code CCS to MQB car? CCS is behind SWaP which means you need to buy official CCS kit from authorized dealer and after installation activate the CCS through the mothership connection with the activation key coming with the kit.
downtime
Finland
C?ID=280813
But did you understand what I wrote?
Did you buy the cruise control set from official VW dealer? In Golf 7 you CANNOT just install a handle and code it like in Golf 5/6. It simply does not work. You need an official ccs kit from authorized dealer.
