Amarok (V6 2019) + Westfalia trailer
jharrop
Australia
C?ID=222902
I'd appreciate confirmation regarding proposed coding please.
I bought the Westfalia towbar module part no 321 704 300 107 with a view to being able to use a trailer with LED lights, without warning lights appearing on the dashboard.
See it at https://www.ebay.com.au/itm/VW-Amar...-321704300107-Westfalia-Genuine/274330890747? which states:
  • Blinker monitoring:CAN
  • Parking aid shut-off:yes
  • Dauerplus (terminal 30):no
  • Power connection:rear
I'd like to use VCDS to code this for my 2019 V6 Amarok, but the Westfalia instructions are vague, and that's putting it politely!
Hooking up VCDS, in 69 trailer function, there are 4 bytes.
  • byte 1 was set to "rest of world", but there is an Australia option (that's my location). should i accept it? Not sure what makes Australia special...
  • byte 2: 00 for NOT coded, or 0D for "type/swivelling function: fixed /detachable / preparation". I guess I should choose 0D?
The other 2 options concern terminal 30
  • byte 3 has options for "terminal 30 output switched (pin 9)" options being
    • NOT active
    • active
    • active while towing
  • byte 4 has options for "terminal 30 output switched (pin 10/charging relay)" options being
    • NOT active
    • active [OLD]
    • active while trailer
    • active [NEW]
The ad linked above says "Dauerplus (terminal 30):no" so I think I should choose "NOT active" for bytes 3 and 4? The web suggests terminal 30 is a permanent power supply (permanent positive, permanent plus, or B+)
Is there anything else I need to code, for example engine control module / ABS?
I'm attaching below the fault codes present prior to coding.
thanks .. Jason
Thursday,24,September,2020,15:42:32:44581
Chassis Type: 2H-VN81 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 22 25 32 5F 61 69 0B
VIN: *****   Mileage: 9880km-6139miles
69-Trailer -- Status: Not registered 0011
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 2H6 907 379 A    HW: 2H6 907 379
   Component: ESC           H06 0310
   Revision: 00000000    Serial number: 61879000000340
   Coding: 207344B64994B69E04A322AC92556D85390000
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1ESCCONTIVN817GP 008001
   ROD: EV_Brake1ESCCONTIVN817GP_008.rod
   VCID: 343118BDBEB18DFB86B-8060
4175 - Regulation Function Shut Off; Locking Electronics Active
          C1049 00 [008] - -
                    Fault Frequency: 11
                    Reset counter: 119
                    Mileage: 1284 km
                    Date: 2020.06.08
                    Time: 16:58:12
   Part No SW: 7E0 909 901     HW: 7E0 937 089 C
   Component: GW-K-CAN TP20 H82 0762
   Revision: BB082001
   Coding: 742301
   Shop #: WSC 00059 790 00052
   VCID: 6889BCCDB279391BFA3-803C
                    Date: 2020.06.16
   Component: Anhaenger     H12 0100
   Revision: 3A001001    Serial number: 00000512021464
   Coding: 0100000100000000
   VCID: 303914AD4A29B1DBE23-8064
02564 - Trailer; Left Tail Lamps (M60)
                    Fault Status: 11101010
                    Reset counter: 50
End----(Elapsed Time: 01:33, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
