Skoda Fabia Mk3 Front PDC retrofit
kjrehsi
C?ID=287868
Hi Guys,
I recently retrofitted front PDC to my 2015 Skoda Fabia Mk3 that already had rear PDC (3 x sensors) installed from factory.
Everything has been wired and sensors installed to the front bumper. However my new pdc module with is a 8K module is failing to work with the rear PDC sensors.
The reason being module looking for the 4th sensor in the rear whereas it only came with 3 sensors installed with a 4K pdc module.
From my research I got the correct module 5Q0 919 294 E for the retrofit. The module was bought on ebay and came from a 2012 VW Golf which had EPB hence the error in Park/Assist as shown in the scan.
I have looked on various forums and can't seem to figure out how to adapt the module to accept 3 sensors in the rear?
Here is a scan of my vehicle
Wednesday,30,September,2020,23:49:17:14442
VIN: TMBFN6NJ8FZ039665   License Plate:
Chassis Type: NJ-SK26 (6C0)
Scan: 01 03 08 09 10 13 15 17 19 44 5F
Address 01: Engine (J623-CJZD)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 BC    HW: 04E 907 309 AF
   Component: 1.2l R4 TSI   H21 8229
   Revision: R4H21---
   Coding: 01190032230415080000
   Shop #: WSC 73430 031 00043
   ASAM Dataset: EV_ECM12TFS01104E906027BC 001006
   ROD: EV_ECM12TFS01104E906027BC.rod
   VCID: 6695B49628E44B9BC8F-8032
   CAN Converter 01:
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 G    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0003
   Serial number: 08507325150218
   Coding: 43F5487D492633C9091A106F0056C21292CC9008000DCAF98F00
   Shop #: WSC 13765 031 00043
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
   ROD: EV_Brake1ESP90iBOSCHPQ26.rod
   VCID: 33331DC22BB6EE339F1-8066
Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
   Part No SW: 6V0 820 045 A    HW: 6V0 820 045 A
   Component: AC Manuell    H01 0108
   Serial number:  1502081B-0183
   Coding: 100000001000100000
   ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
   ROD: EV_ACManueKMMValeoPQ26_SK26.rod
   VCID: 303912CEDAA0D52BE23-8064
Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 B    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H07 0065
   Serial number: 001098062538
   Coding: 0F0008404205097303A04080B10703080000D800D6013500000000000000
   Shop #: WSC 73430 790 00043
   ASAM Dataset: EV_BCMA0 004008
   ROD: EV_MQBA0.rod
   VCID: 2F3B11B2C79ECAD3FB9-807A
   Subsystem 1 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY150070WGZ
   Subsystem 2 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Serial number: 00000000000061684715
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39331510700336
   Coding: 0031051001
   ROD: EV_EPHVA18AU3700000_VW26.rod
   VCID: 3D273BFA1DF22843795-8068
1079316 - Center Rear Right Parking Aid Sensor
          B1078 14 [009] - Open or Short to Ground
                    Reset counter: 39
                    Mileage: 41792 km
                    Date: 2020.09.25
                    Time: 07:59:06
1113875 - Parking Aid Indicator Lamp
          B10FF 13 [009] - Open Circuit
                    Reset counter: 39
12658704 - Databus
          [Steuergerät für elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
                    Reset counter: 39
                    Mileage: 41792 km
                    Date: 2020.09.25
                    Time: 07:45:04
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Serial number: 20021503213418
   Coding: 00000000FE0739
   VCID: 38292AEE32D00D6BAA3-806C
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 F    HW: 6C0 959 655 F
   Component: VW20Airbag02D 001 0340
   Revision: --------    Serial number: 003RJ000ZD4F
   Coding: 88CCC000000000005C5400CF008800000000
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 363524D638C4FB1BB8F-8062
   Subsystem 1 - Part No SW: -----------    HW: 410 821 102 15
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00A718F7FA1D241
   Subsystem 2 - Part No SW: -----------    HW: 410 821 102 15
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H009B19CC243927X
   Subsystem 3 - Part No SW: -----------    HW: 442 151 202 15
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00AF1907C82524F
   Subsystem 4 - Part No SW: -----------    HW: 442 151 602 15
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00A118F2623D37C
Address 17: Instruments
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     H07 0065
   Revision: --------    Serial number: 001098062538
   Coding: 030100042F0A640000000000000000010001050000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 001001
   ROD: EV_GatewA0Lear_001_VW26.rod
   VCID: 6597B39AD5E24083C15-8030
   Subsystem 1 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000B2618170915
   Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: 62044B18022821494105
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C2 909 144 M    HW: 6C2 909 144 D
   Component: EPS_TRW_ALow  322 3211
   Serial number: CF2N0248
   Coding: 0007
   ASAM Dataset: EV_SteerAssisUDSTRW 011021
   ROD: EV_SteerAssisUDSTRW_011.rod
   Part No SW: 5Q0 035 820     HW: 5Q0 035 820
   Component: MU-S-D-ER     H11 0135
   Serial number: SKZAZ2R0053415
   Coding: 03620000BE0000001111120400880A002F0100C60120010000
   ASAM Dataset: EV_MUStd4CTSAT 001018
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 6889BAAE22F05DEBFA3-803C
   Subsystem 1 - Part No SW: 6V0 919 604     HW: 6V0 919 604
   Component: ABTm_Std2  H40 1022
   Serial number: SKZ8Z9RH3009EQ
1546 - Internal Control Module Memory Check Sum Error
          B2000 46 [009] - Calibration/parameter memory failure
          [Control module faulty: EEPROM error]
                    Mileage: 31955 km
                    Date: 2019.04.10
                    Time: 13:28:27
                    Voltage terminal 30: 12.1 V
End----(Elapsed Time: 00:42, VBatt start/end: 11.9V/11.5V. VIgn 11.6V)-----
downtime
Finland
C?ID=280813
New dataset required for the module. VCDS not able to do it.
kjrehsi
C?ID=287868
Oh dear :( Does it mean I will require ODIS or VCP? I assume if I get a 8K Module from the same vehicle it may work?
